 Old 02-26-2011, 08:44 AM   #1
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
Default Jracers build starts now !
Starting my build today.
Started taking apart my spare motor . Got to get it torn down and then get the block checked to see what pistons I need to order. ( stock bore or .020 over ) .
Going with wiseco pistons K1 or Eagle rods. Arp head studs .
New gaskets, timing chain and tentioner. New VVT and oil pump .
BSD delete and baffle , CPE injector seals.. Also doing the clutch while it's out.
I'll post pics later when I get home.
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
The Following 7 Users Say Thank You to jracer For This Useful Post:
danesti (02-27-2011), Docnox (02-26-2011), forever_skyline (03-16-2011), kmac (02-26-2011), PunjabiPlaya (02-28-2011), spiker98 (02-26-2011), super_pablo_ (02-26-2011)
 Old 02-26-2011, 12:08 PM   #2
kmac's Avatar
Posts: 1,792   (View Stats)
Way to go brother ,Gl with everything can't wait to see the pics and progress.
The Following User Says Thank You to kmac For This Useful Post:
jracer (02-27-2011)
 Old 02-26-2011, 12:17 PM   #3
Mazdanspeed3's Avatar
Posts: 157   (View Stats)
Mazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond repute
while your at it, take a gander at the corksport crank pulley... you'd be the first to use it!
Mazdanspeed3 is offline   Reply With Quote
 Old 02-26-2011, 12:42 PM   #4
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
Nice, mang. Makes me want to start a build thread, but it would be pointless because I won't be goin BT for at least another 6 months.
2007 CTS-V - Trying to sell
jracer (02-27-2011)
 Old 02-26-2011, 04:00 PM   #5
jracer's Avatar
Groans: 89
Hopefully I can also swing a new turbo also while it's all apart
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 02-26-2011, 11:58 PM   #6
spiker98's Avatar
Posts: 427   (View Stats)
spiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the worldspiker98 is the leader of the world
Wait...what? Your doing all of this for the K04?? Dude..maybe I did it backwards by going BT first...but there is no reason to build this motor on a turbo that spins out at 5500 rpm..
2006 LP MS6 sport-
Garret GT30, Carillo rods, ARP mainstuds, CP custom forged pistons, Custom Downpipe, Creative Performance exhaust manifold, MAP intake manifold, Tial 38mm external wastegate, Cp-e Nviscid BT inlet pipe, Cp-e XL Xcel intake, Cp-e standback, Cp-e fuel cut fix/ Maf/ full throttle flash, Custom screamer pipe, Cp-e FMIC Blacked out, HKS SSQV blackout edition, KMD v2 fuel pump internals, BSD kit, Oil baffle, SU stiff diff brace, TWM stage 2 short shifter, BC coilovers, AWR endlinks font/ rear, SPC balljoints, SURE Juggernaut, Car-led tail lights, Cp-e center gauge pod, Prosport premium boost/ Air fuel/ Oil pressure gauges. All the little shit that goes with that. In coordination with Ginger performance and DDMworks.
spiker98 is offline   Reply With Quote
The Following 2 Users Say Thank You to spiker98 For This Useful Post:
jracer (02-27-2011), super_pablo_ (02-27-2011)
 Old 02-26-2011, 08:56 PM   #7
Block8head's Avatar
Posts: 4,345   (View Stats)
Groans: 206
Exciting to see your progress!
O4 350z "Money pit"
06 MS6 "Gone"
BOSTON STRONG
The Following User Says Thank You to Block8head For This Useful Post:
jracer (02-27-2011)
 Old 02-27-2011, 05:36 AM   #8
jracer's Avatar
Groans: 89
Well my car has 85k miles on it , so I figure build it now not when it breaks.
Who knows with these engines .. Some last 100k some 40k then boom. ..
I am fully bolted so the only thing I need is a turbo after it's built . I may just have to rock the k04 for a few more months ..
If my car had less miles I would do like everyone els , BT first .
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
Last edited by jracer; 02-27-2011 at 05:42 AM. Reason: MSF Database - Automerged Doublepost
 Old 02-27-2011, 07:18 AM   #9
bmylez's Avatar
Groans: 31
Yeah, I'm running essentially what you'll be running. Bought the car this way. It definitely leaves you wanting more when the K04 runs out of breath and the motor says, "That's all you got? Come on, throw 400 ft-lbs at me, dammit!"
jracer (02-27-2011)
 Old 02-27-2011, 11:05 PM   #10
jracer's Avatar
Groans: 89
I am at work and will update when I get home ..
FAIL .... From the get go !!
Well all my EX. Valves are bent ... Fuck !!
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 02-27-2011, 11:25 PM   #11
xdm88's Avatar
Posts: 279   (View Stats)
xdm88 is the leader of the worldxdm88 is the leader of the worldxdm88 is the leader of the worldxdm88 is the leader of the worldxdm88 is the leader of the worldxdm88 is the leader of the worldxdm88 is the leader of the worldxdm88 is the leader of the worldxdm88 is the leader of the worldxdm88 is the leader of the worldxdm88 is the leader of the world
man, jealous im sorry to say, wish you the best with the build, i bet your gonna love your car even more after your done with all those shiny new internals!
xdm88 is offline   Reply With Quote
 Old 02-28-2011, 06:43 AM   #12
jracer's Avatar
Groans: 89
upadate **********
Well the story behind this engine is it came out of a mazda for warranty .. it had timing chain issues... the engine has been sitting in my garage for 8-9 months..
anyways.. when i would turn it over bye hand at TDC it had resistance...so i knew something wasnt right !!
so i got it all torn apart yesterday..
found all the exhaust valves stuck open !! they are all bent i think thats why they are staying open.. you can see little marks on the valves where they touched the pistons..
i guess the engine was out of time or something...
the #4 cylinder looks like it ingested something at one time.. you can see it in the pic of he valves i posted.. see all the dents ??
hope it can be fixed..ill have to take it to a cylinder head shop and see..
the bores look ok, i can see wear marks but i cant feel them. maybe they will hone out or maybe i will have to get it bored.
looks like this build just cost a lot more than i thought it was going to be....
i am bummed............
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
The Following 2 Users Say Thank You to jracer For This Useful Post:
PunjabiPlaya (02-28-2011), spiker98 (02-28-2011)
 Old 02-28-2011, 01:37 PM   #13
jracer's Avatar
Groans: 89
i called a cylinder head shop and they will do my head for $250 and ill supply the ex. valves and valve guide seals.. they have to see the damage on the head to see if they can fix it..
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 02-28-2011, 01:57 PM   #14
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
VVT broke.. Make sure you have the head and block dipped/cleaned very well, you may have some metal from the vvt acutator in the oil passages...
The Following User Says Thank You to SSinstaller For This Useful Post:
jracer (02-28-2011)
 Old 02-28-2011, 02:04 PM   #15
jracer's Avatar
Groans: 89
if the VVT broke it would move time just enough to fuck the Exhaust valves ??..
.. you see the marks on the head ??
do they look bad ?
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
Last edited by jracer; 02-28-2011 at 02:04 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-28-2011, 02:16 PM   #16
Alpha's Avatar
Posts: 3,711   (View Stats)
Damn, this makes me want to get the DCR VVT just in case... That's crazy.
 Old 02-28-2011, 02:27 PM   #17
jracer's Avatar
Groans: 89
yeah from what the history on the motor was it was the VVT/timing the guy said..
but i guess it moved just enough to bend EVERY ex.valve !!..
so i guess to all guys watch your VVT !!..
some pics of the valves stuck open.. and where they hit the piston............
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 02-28-2011, 02:31 PM   #18
PunjabiPlaya's Avatar
Posts: 5,131   (View Stats)
Groans: 131
interference engine...
Cobb SRI
CPE 75 duro RMM
AP - tune in progress
broke ass college student
The Following User Says Thank You to PunjabiPlaya For This Useful Post:
 Old 02-28-2011, 02:45 PM   #19
spiker98's Avatar
Damn dude, sorry to hear this. Builds do NOT go as planned.. welcome to the club.
2006 LP MS6 sport-
The Following User Says Thank You to spiker98 For This Useful Post:
jracer (02-28-2011)
 Old 02-28-2011, 03:15 PM   #20
essejkcamraw's Avatar
Posts: 922   (View Stats)
looks like you have your work cut out for you, the whole build process thing sucks. welcome to the club man!
From built & Big turbo to Miata Gheys
The Following User Says Thank You to essejkcamraw For This Useful Post:
jracer (02-28-2011)
 Old 02-28-2011, 03:37 PM   #21
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
Aww man that fucking blows. This is supposed to be a happy time, glad it is not your only engine though.
Hopefully the machine shop can fix it without completely killing your wallet. Good luck man!
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
jracer (02-28-2011)
 Old 02-28-2011, 04:27 PM   #22
bmylez's Avatar
Groans: 31
There's a guy with an SVT Focus with very similar head damage. It can be welded up and shaved. The cylinder walls will need a very nice hone at the very least. Boring out .020" isn't the worst idea...hell, you'd gain a little displacement (prolly 2.35L, maybe more).
Sorry to hear the probs, but that damage isn't all that catastrophic.
jracer (02-28-2011)
 Old 03-01-2011, 09:02 AM   #23
jracer's Avatar
Groans: 89
well ordered my CPE safeseals today !!..
i am taking the head to the cylinder head shop in the morning for them to look at it to determine if i should fix it or not..
i posted a want add in the for sale section looking for a head.. so if you know of anyone send them my way !
there is one on ebay but its waaay to much $500+ bucks..
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 03-01-2011, 10:13 AM   #24
Alpha's Avatar
How difficult is it to swap the VVT guys? Just curious. Not too bad?
 Old 03-03-2011, 09:57 AM   #25
jracer's Avatar
Groans: 89
wow.. this is going to cost more to build than i thought !!.. with my head being fucked ..
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 03-03-2011, 10:10 AM   #26
Two nuns and a pack mule
AtTheDriveIn's Avatar
Posts: 1,527   (View Stats)
Sucks, man. I think your build calls for a DCR VVT upgrade. Mine crapped out on me at 30K bone stock, but luckily replaced under warranty. Good luck! Subbed for progress...
AtTheDriveIn is offline   Reply With Quote
 Old 03-14-2011, 10:24 AM   #27
jracer's Avatar
Groans: 89
well a little update..
got my head fixed ! all new ex. valves and two intake valves.
head cleaned everything checked , valve job.. ect..
picking it up tomorrow morning.. so ill post pictures.
cost me $350 plus tax it came to $375.
clearwater cylinder head did the work...
ill get the part numbers and all the good stuff
Cylinder Heads of Clearwater
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
The Following User Says Thank You to jracer For This Useful Post:
essejkcamraw (03-14-2011)
 Old 03-14-2011, 03:31 PM   #28
good shit man, good to see they could help you out.
 Old 03-14-2011, 04:27 PM   #29
bmylez's Avatar
Groans: 31
Yeah, I would say you are getting some really cheap labor out of them. If it's quality, you got yourself a deal. Good stuff.
 Old 03-15-2011, 07:20 AM   #30
jracer's Avatar
Groans: 89
picked up my head this morning..
3 angle valve job
pressure tested
soda blasted
new guides
8- new EX valves
2- new intake valves
gasket surface skimmed ( not decked )
$350 + tax.. $375 out the door.
the company has been around forever..good reputation.
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
The Following 4 Users Say Thank You to jracer For This Useful Post:
amoosenamedhank (03-15-2011), BLURSPORTS (03-15-2011), holeinmypocket (03-15-2011), madvillain (03-17-2011)
 Old 03-31-2011, 12:04 PM   #31
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
3 angle valve job
pressure tested
soda blasted
new guides
8- new EX valves
Ok so this is a stock ported head correct? So what direction are you going with the rods and pistons?
track weight 3220
street weight 3370
 Old 03-16-2011, 01:24 AM   #32
forever_skyline's Avatar
Posts: 28   (View Stats)
forever_skyline is a splendid one to beholdforever_skyline is a splendid one to beholdforever_skyline is a splendid one to beholdforever_skyline is a splendid one to beholdforever_skyline is a splendid one to beholdforever_skyline is a splendid one to beholdforever_skyline is a splendid one to behold
this is a thread I will follow
Good luck with the build!
Black MPS6 -2007
EcuTek - 306hp and 332lb/ft
forever_skyline is offline   Reply With Quote
The Following User Says Thank You to forever_skyline For This Useful Post:
jracer (03-16-2011)
 Old 03-22-2011, 10:58 AM   #33
obijack's Avatar
Posts: 1,830   (View Stats)
head looks great..and so does the price. Who are you going to let do the bottom end work, I am looking for a good place myself in Florida.
2014 Honda Grom-Red
2014 Yamaha Grizzly 350- Blue
 Old 03-23-2011, 07:33 AM   #34
jracer's Avatar
Groans: 89
dont know yet about the bottom end work.... still have to save some more money for stuff..
those CPE stage 2 pistons look cool !!
but if anyone needs head work check out the place i went..
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 03-31-2011, 12:16 PM   #35
Tech/Sales@EM's Avatar
Posts: 1,173   (View Stats)
Tech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the world
Groaned at 28 Times in 11 Posts
Wiseco and Eagle Rods!!
Tech/Sales@EM is offline   Reply With Quote
 Old 03-31-2011, 02:37 PM   #36
mighty mouse's Avatar
Posts: 62   (View Stats)
mighty mouse is a jewel in the roughmighty mouse is a jewel in the roughmighty mouse is a jewel in the rough
that head came out great. What valves did you end up going with? OEM?
09 Mazdaspeed3 GT
90 Miata
mighty mouse is offline   Reply With Quote
 Old 04-01-2011, 07:02 AM   #37
jracer's Avatar
Groans: 89
stock head.. no port job. the exhaust valves are aftermarket.. dont know the brand.
i think i am going eagle/wiseco combo..not looking for huge HP .
350-385 -400 max hp.. would be nice..
Like all builds they dont ever go as planned ! didnt know my head was all fucked up then i messed up two tires running over something in the road so i went ahead and got 4 new tires. So the motor build fund got dipped into. so time to save some more money............
but i did get a few other parts like the SURE intake manifold gasket, CPE safe seals,Street unit EGR block off plate, a extra intake manifold to lightly port and remove the VTCS.. and a Matt damond new check valve for my OCC.
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 04-01-2011, 09:56 AM   #38
So are you going to port the intake yourself?
track weight 3220
street weight 3370
SEAT starts construction of new Spanish plant to build Audi Q3 Haltech Automotive News 0 06-19-2009 05:00 PM
Theory: Build before Build demonspeed MazdaSpeed 6 - Engine, Transmission & Driveline 5 02-10-2009 06:52 PM
Page generated in 0.54590 seconds with 38 queries
