Like Tree6Likes
 Old 08-19-2011, 07:52 PM   #601
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
anyone documented difference in spark with BAS or HKS. bigger gap more boost without misfires, did anyone use it to stop misfires at high boost and work
My hks completely fixed the random misfire MIL I would get at idle... I cant speak for the WOT issues as i've never had them. I don't know why, but I assume it may have something to do with my low compression pistons, or maybe I'm just not making enough power...
The Following 2 Users Say Thank You to SSinstaller For This Useful Post:
djuosnteisn (08-21-2011), Nitr0EngiE (08-19-2011)
 Old 08-19-2011, 08:37 PM   #602
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
what are your plugs gapped to
 Old 08-19-2011, 09:25 PM   #603
Groans: 60
I'm running hks 2 step colder plugs, IIRC they're pre-gapped at .28.
 Old 08-20-2011, 07:33 AM   #604
Daily Driver
Nitr0EngiE's Avatar
well my theory is this BAS will prevent me from getting mis fires under higher boost and light up all the fuel, even if you cant see hp increase on the dyno im sure car will run and pull smoother under higher boost.
With that said I cant wait to get mine installed.
One question I have is intercepting the one green wire provides the voltage increase to all 4 coils because its the Power source for all coils im guessing? I figured the voltage woulda come from ECU so splicing it over there does not make sense to me unless like i said if its the Source of all Voltage power for all 4 coils. can anyone confirm thats why it works. not having to splice all 4 coils.
is the speed 3 And 6 the same wiring so its the green wire for both cars ?
 Old 08-20-2011, 07:38 AM   #605
spnkr21's Avatar
Posts: 2,827   (View Stats)
This thread did get cluttered with the weaponX bullshit so I can't blame you there nitro. If you REread the thread there are a few of us running the bas with great results. It's what allowed me to keep tuning otherwise the blowout was too severe.
Yes you splice the one green wire that splits to 5 wires in the harness. 4 go to the plugs, one goes to the capacitor(or resistor or whatever it is).
2012 WRX HB w/mudflaps yo!
The Following User Says Thank You to spnkr21 For This Useful Post:
Nitr0EngiE (08-20-2011)
 Old 08-20-2011, 07:45 AM   #606
Daily Driver
Nitr0EngiE's Avatar
god that makes it a stupid easy installation I dont know why everyone is ditching the BAS for HKS for 400 more i Bet no bs the BAS can put out more amp output then the HKS and is more tunable.
to top it off the part of the harness you need to cut is a 2 foot replaceable section so who gives a fuck you can replace it later if you dont like it being cut !.
I am really happy with this solution. when I splice mine I am going to install removable plug connectors on the green wire instead of direct solder. I will solder the connectors on then i can plug and play BAS.
loool 1 wire improvement I LOVE IT
 Old 08-20-2011, 08:05 AM   #607
spnkr21's Avatar
That's a good idea with the connectors.
 Old 09-01-2011, 02:13 PM   #608
Daily Driver
Nitr0EngiE's Avatar
How To: Kenne Bell Boost a Spark with removable connectors
how to with connector
 Old 08-08-2013, 03:25 PM   #609
btstarcher's Avatar
Posts: 4,852   (View Stats)
Holy threadbump Batman!
Subbed for info....
SnailTune in progress
 Old 03-13-2014, 09:36 PM   #610
btstarcher's Avatar
What would the advantages/disadvantages to bypassing the boost switch and running it all the time?
 Old 03-13-2014, 10:14 PM   #611
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
my bas works flawlessly been on their for 40000 miles not one misfire sense installation and mine was a used unit
at 104000 2 bent rods
tuned by nishan
The Following User Says Thank You to rigor For This Useful Post:
btstarcher (03-13-2014)
 Old 03-13-2014, 11:28 PM   #612
btstarcher's Avatar
I got mine from @SilverDemon; Thanks again! But I don't have the boost switch. Also when I get misfire codes, they always pop up at idle or under normal highway driving. I know it's not blowout, but still I wonder if this unit will be effective if it's enabled under all conditions and not just under boost.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/kenne-bell-boost-spark-63536/
side gapping plugs - Page 2 This thread Refback 07-24-2014 06:06 PM
Boost-A-Spark - Kenne Bell - Page 3 This thread Refback 04-30-2014 02:33 PM
'Saved by the Bell' Fan Takes It to the Max Haltech Celeberty Smut 0 07-05-2009 07:50 AM
'Saved by the Bell' Fan Takes It to the Max Haltech Celeberty Smut 0 07-04-2009 03:10 AM
Billy Mays Had Just Inked a Deal with Taco Bell Haltech Celeberty Smut 2 06-28-2009 05:36 PM
Page generated in 0.32335 seconds with 25 queries
