Like Tree64Likes
 Old 08-03-2011, 08:26 PM   #1
kmac's Avatar
Posts: 1,792   (View Stats)
Default kmac's 6262 build
I figured I would make a new tread, considering I tested the prototypes and finished the layout, as well as painted them.
basically it's a factory block 20k on it, comp is 180 across the board, oil has been changed every 2500 with penz platinum and all new fluids etc. The parts I'm running are mostly one offs made by me, some are modified other parts by me as well.
my mods made or modified by me are:
intake manifold
liquid to air intercooler welded tanks
water storage tank for intercooler w/ ice baffle
one intercooler pipe with bov flange
intake and velocity stack
throttle body modification with external tps
4 bar map sensor wired and scaled kept the factor iat
throttle body tpfe thermal spacer
cat with 60mm ewg on it to dump to release back pressure to allow me to keep the cat with out restrictions.
methanol splitter log and nozzle adapters(running 5 ports , 4 direct one pre throttle body)
255 in tank pump with external regulator and return line
fuel pump voltage amplifiers (one on the fuel pump and one on the meth pump)
medieval manifold with flange , merge collector and ewg modification
valve cover drilled and tapped for storage tank mounting, aslo vent plate drilled inside and packed with steel wool with external oil separator
new fuel line under hood with external fuel filter added
fuel pump module , water intercooler pump, and meth controller fuses and relays add into factor battery dist box to remove clutter and for a clean look.
down pipe
ford inj seals mod to fit
Things I didn't make:
cdfp stage 2 pump (ptp)
windage tray (ptp)
bal shaft delete (ptp)
intake manifold thermal gasket ptfe (ptp)
inj stud and washer kit (ptp)
fuel high pressure rel valve (ptp)
tial mv-s
synapse bov in recirc
cobb ap
twm full replacement shifter with trans linkage
n2mb wot box with 2 step
gauges w/cpe gauge pod afr, egt, boost
meth controller cooling mist with vent gauge pod (it's 2 1/16 like a normal gauge)
dash hawk
coilovers
eng and trans mounts
traction bars
gt-spec braces
I'm sure there are more but that's all I can think of for now. I will take some more pics tomorrow . I got home late and I just snapped some fast pics just to get some up, because I'm excited it's almost done.
that's chewbacca saying hello
believe it or not the intercooler storage tank clears the hood. I also have a thermal blanket on the bottom of the tank and teflon washers between the mounting points to eliminate heat soak and radiant heat from the engine. all in all I like the setup.
Erich, MindCrimes, AJ713 and 3 others like this.
The Following 55 Users Say Thank You to kmac For This Useful Post:
06Speed6 (08-03-2011), 8.5MS3 (10-11-2011), 802MS3 (08-03-2011), AJ713 (10-15-2011), AZSPEED3 (08-19-2011), bcmurphy87 (09-08-2011), BigJimMs3 (10-31-2011), BlueStreak (08-03-2011), Boonestafa (09-16-2011), Broxer (09-20-2011), Chimmike (08-05-2011), Ckmazdaspeed3 (08-18-2011), Coaststarlight (05-11-2012), Dano (08-05-2011), Decepticon (10-16-2011), djuosnteisn (09-07-2011), Docnox (10-17-2011), doubleflusher (08-04-2011), Erich (08-04-2011), Ferg (09-08-2011), Fobio (08-03-2011), frodaddyweez (08-04-2011), GLORIFIEDBOZO (05-19-2012), Hamilton69 (10-16-2011), I Love Brownies (08-03-2011), jack_hammer (08-03-2011), josurr (10-15-2011), kunfu (10-31-2011), magicka (08-04-2011), mason (08-04-2011), mazdafreak (01-01-2012), Meder (10-11-2011), MindCrimes (08-04-2011), Monotonous ONE (08-03-2011), MPSdriver (08-07-2011), MS3-a(sore)ASS-rex (08-04-2011), mtnrunner (08-03-2011), Puddle Dynamics (08-20-2011), PunjabiPlaya (08-03-2011), pzr2874 (10-15-2011), RayRay (01-08-2012), rfinkle2 (08-04-2011), rigor (10-21-2011), Scribbles (08-03-2011), SLOWHATCH (10-15-2011), speed23 (08-18-2011), SpeedSixxx (08-04-2011), superskaterxes (08-04-2011), TexasSpeed3 (10-14-2011), Tomas (09-23-2011), uncorked11 (11-29-2011), wankular (08-04-2011), zpele (09-23-2011), zx2man (08-06-2011)
 Old 08-03-2011, 08:29 PM   #2
LiEast's Avatar
Posts: 582   (View Stats)
LiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the world
oooo shit.. im speachless
I cant believe you couldnt make your own BS delete kit haha lol
2008 RED MS3 GT>>>T3 GT35R .82 A/R>>>Tial 44 EWG dumping>>>SteedSpeed T3 Mani>>>Built Motor
PERM!
LiEast is offline   Reply With Quote
The Following 2 Users Say Thank You to LiEast For This Useful Post:
kmac (08-03-2011), SpeedSixxx (08-04-2011)
 Old 08-03-2011, 08:32 PM   #3
Scribbles's Avatar
Posts: 861   (View Stats)
Scribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the world
Im so hard right now
07 MS3
Built motor with K1 rods/wesico pistons, ATP 3076r, SS Mani, ATP DP, Cobb FMIC V2, CPE FP, TurboSmart MBC, TurboSmart Dual Port BOV, Hotchkis RSB FSB, BC Coilovers, AP, Dashhawk, Trilogy JBR 88 duro's, JBR catch can, Guardian Angel
Perm
Scribbles is offline   Reply With Quote
The Following 2 Users Say Thank You to Scribbles For This Useful Post:
 Old 08-03-2011, 08:33 PM   #4
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
Nice !
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
The Following 2 Users Say Thank You to jracer For This Useful Post:
 Old 08-03-2011, 08:34 PM   #5
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
wow. I have always been impressed with all of the hands on work that you have done with this car. I'm really hope everything comes out the way that it is supposed to.
Congrats on almost being done!!!!
Can't wait to see this thing rolling around on the streets.
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
The Following 2 Users Say Thank You to taf0422 For This Useful Post:
 Old 08-03-2011, 08:35 PM   #6
manelscout4life's Avatar
Posts: 1,781   (View Stats)
Groans: 661
dyno?
The Following User Says Thank You to manelscout4life For This Useful Post:
kmac (08-03-2011)
 Old 08-03-2011, 08:39 PM   #7
kmac's Avatar
Originally Posted by manelscout4life View Post
dyno?
not yet, as soon as it's done I'm going to realspeed automotive out in bohemia to dyno. My buddy dan carlson is a big time mustang tuner and he want's to see my tune it on the dyno , he's intersted in tuning the speed models.
The Following 4 Users Say Thank You to kmac For This Useful Post:
manelscout4life (08-03-2011), rfinkle2 (08-04-2011), SpeedSixxx (08-04-2011), uncorked11 (11-29-2011)
 Old 08-03-2011, 08:37 PM   #8
LiEast's Avatar
Im coming for a ride when its complete.. you have no choice lol
i owe you a beer with helping me with my rearmain seal leak anyways.
PERM!
 Old 08-03-2011, 08:38 PM   #9
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
Holy shit, insane build.
2007 CTS-V - Trying to sell
The Following 3 Users Say Thank You to bmylez For This Useful Post:
kmac (08-03-2011), rfinkle2 (08-04-2011), SpeedSixxx (08-04-2011)
 Old 08-03-2011, 08:46 PM   #10
PunjabiPlaya's Avatar
Posts: 5,131   (View Stats)
Groans: 131
I came
Cobb SRI
CPE 75 duro RMM
AP - tune in progress
broke ass college student
The Following 4 Users Say Thank You to PunjabiPlaya For This Useful Post:
kmac (08-03-2011), SpeedSixxx (08-04-2011), TexasSpeed3 (10-14-2011), zpele (09-23-2011)
 Old 08-03-2011, 08:54 PM   #11
Two nuns and a pack mule
AtTheDriveIn's Avatar
Posts: 1,527   (View Stats)
Fuck yeah... Good luck!!
AtTheDriveIn is offline   Reply With Quote
The Following 2 Users Say Thank You to AtTheDriveIn For This Useful Post:
 Old 08-03-2011, 10:00 PM   #12
Miembro
nighthawk358's Avatar
Posts: 725   (View Stats)
nighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the world
Groans: 27
amazing..keep us posted dude..i hope you break 600whp
2008.5 MS3 Metro Gray...slow
nighthawk358 is offline   Reply With Quote
The Following 2 Users Say Thank You to nighthawk358 For This Useful Post:
kmac (08-04-2011), SpeedSixxx (08-04-2011)
 Old 08-03-2011, 10:38 PM   #13
mtnrunner's Avatar
Posts: 864   (View Stats)
mtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the world
Bad ass build man! What kind of power numbers are you shooting for?
Murdered out 2007 speed3 GT with navi.
mtnrunner is offline   Reply With Quote
The Following User Says Thank You to mtnrunner For This Useful Post:
kmac (08-04-2011)
 Old 08-04-2011, 03:33 AM   #14
kmac's Avatar
Hopefully I'll break 500 on the factory block before I break a piston or ring. Would like to hit an 11.6 on the factory stuff. I think the numbers are possible, but only the dyno and 1/4 will prove that.
Check it out @SpeedSixxx, u f-in homo.
Last edited by kmac; 08-04-2011 at 03:33 AM. Reason: MSF Database - Automerged Doublepost
The Following 7 Users Say Thank You to kmac For This Useful Post:
djuosnteisn (09-07-2011), mtnrunner (08-04-2011), rfinkle2 (08-04-2011), SpeedSixxx (08-04-2011), TexasSpeed3 (10-14-2011), uncorked11 (11-29-2011), zpele (09-23-2011)
 Old 08-03-2011, 10:50 PM   #15
I Love Brownies's Avatar
Posts: 3,791   (View Stats)
I Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the world
Groans: 371
good luck man!!! best of luck to you and this shit looks damn sexy!!
I Love Brownies is offline   Reply With Quote
The Following 3 Users Say Thank You to I Love Brownies For This Useful Post:
kmac (08-04-2011), rfinkle2 (08-04-2011), SpeedSixxx (08-04-2011)
 Old 08-03-2011, 10:57 PM   #16
essejkcamraw's Avatar
Posts: 922   (View Stats)
this is going to be intense.
From built & Big turbo to Miata Gheys
The Following 2 Users Say Thank You to essejkcamraw For This Useful Post:
 Old 08-03-2011, 11:21 PM   #17
rtabagaboy's Avatar
Posts: 363   (View Stats)
rtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the world
Groaned at 7 Times in 3 Posts
Build it and we will come... uuhhh.
2008.5 BlackMica Mods:
- Cobb SRI, Turbosmart BPV, CPE RMM 60d, TRZ TMM, TopSpeed PMM, HTP Turbo Inlet... I'm workin' on it.
AZ Status!
rtabagaboy is offline   Reply With Quote
The Following User Says Thank You to rtabagaboy For This Useful Post:
kmac (08-04-2011)
 Old 08-04-2011, 05:02 AM   #18
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
smallest picts ever lol good luck!!!
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
The Following 3 Users Say Thank You to superskaterxes For This Useful Post:
4G63 (08-04-2011), kmac (08-04-2011), SpeedSixxx (08-04-2011)
 Old 08-04-2011, 05:43 AM   #19
kmac's Avatar
Haha, I know . I did it last night before I went to bed I looked at it on my phone and was like crap that's small.
The Following 3 Users Say Thank You to kmac For This Useful Post:
4G63 (08-04-2011), jracer (08-04-2011), SpeedSixxx (08-04-2011)
 Old 08-04-2011, 05:13 AM   #20
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
Cant wait to see the end result
The Following 2 Users Say Thank You to forcedinduktion For This Useful Post:
 Old 08-04-2011, 07:39 AM   #21
BlueStreak's Avatar
Posts: 1,467   (View Stats)
You know you mean business when you throw on a 4 BAR MAP sensor.
Looking forward to the results.
'07 CWP MS3
Forged.
The Following 5 Users Say Thank You to BlueStreak For This Useful Post:
kmac (08-04-2011), manelscout4life (08-04-2011), rfinkle2 (08-04-2011), SpeedSixxx (08-04-2011), TexasSpeed3 (10-14-2011)
 Old 08-04-2011, 07:53 AM   #22
Best of luck Kmac.
Crazy original build ideas and fab work.
-Thanks for all of your help BTW
kmac likes this.
 Old 08-04-2011, 01:13 PM   #23
kmac's Avatar
Best of luck Kmac.
Thanks brother I appreciate it.
The Following 2 Users Say Thank You to kmac For This Useful Post:
 Old 08-04-2011, 03:15 PM   #24
Mazdanspeed3's Avatar
Posts: 157   (View Stats)
Mazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond repute
=) sweet. In NY too? i wanna take a ride when its done. sick shit man. Hope ur rewarded for the effort put in!
Mazdanspeed3 is offline   Reply With Quote
 Old 08-04-2011, 03:16 PM   #25
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
Groans: 778
I just have to let all you guys know...
this entire build was all my idea and most of the fab work was done by me after kmac begged...
just sayin...
LOL, nice shit Kev..... can't wait for you to be done! then we take care of me and then we could look forward to some blown motors!
The Following User Says Thank You to SpeedSixxx For This Useful Post:
kmac (08-04-2011)
 Old 08-04-2011, 03:33 PM   #26
nothing to see here....
drknyte's Avatar
Posts: 501   (View Stats)
drknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the world
Groans: 39
Groaned at 43 Times in 18 Posts
Nice work!
2008 Mazdaspeed 3 GT in Black Mica:
60ft: 2.167
1/8: 9.052
1/4: 13.922 @ 100.37
(26psi tire pressure & stock tires)
CP-E CAI; CP-E Turbo Inlet Pipe; CP-E RMM; Engals ETD; TRZ TM; PG ExhMani; JBarone Shifter Weight, E4 Performance Shift Knob; Solid Shifter bushings; JBarone SSP
drknyte is offline   Reply With Quote
The Following 2 Users Say Thank You to drknyte For This Useful Post:
kmac (08-04-2011), SpeedSixxx (08-05-2011)
 Old 08-05-2011, 02:05 PM   #27
kmac's Avatar
I'm going to mount the meth pump and finish the wiring today for extending the harness in certain area's. I'll hopefully have the gauges and meth controller wired in also.
The Following User Says Thank You to kmac For This Useful Post:
 Old 08-05-2011, 02:11 PM   #28
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Kmac, thank you for being the guy to step up and test out stock motor strength. So many guys built their motors (essetially for no reason yet) without knowing the limits of the stock motor.
I'm thinking 500whp will be perfectly possible. If 550whp is reached, I'll probably nut all over the keyboard.
kmac likes this.
07 MS3
The original Genpoo Hater
kmac (08-05-2011), SpeedSixxx (08-05-2011)
 Old 08-05-2011, 02:33 PM   #29
mason's Avatar
Posts: 946   (View Stats)
im rite behind you on testing stock block. sooner or later ill be running
The Following User Says Thank You to mason For This Useful Post:
kmac (08-05-2011)
 Old 08-05-2011, 02:38 PM   #30
kmac's Avatar
I'm hoping 500 wheel or more before a serious problem. So let's see what happens. I agree it should be possible.
 Old 08-05-2011, 04:04 PM   #31
SpeedSixxx's Avatar
Groans: 778
you are the guy to go to... you would know or have the most educated opinion on it so ...
yeah, test that shit out!
The Following 2 Users Say Thank You to SpeedSixxx For This Useful Post:
kmac (08-05-2011), uncorked11 (11-29-2011)
 Old 08-05-2011, 04:56 PM   #32
Must Have Teh 10's!
make sure u dont just turn it up to 35psi and hope for the best lol.
i would say drive it for a week at power levels of like 450, 500, 550 each to see if its can take some abuse at each power level.
MS3-a(sore)ASS-rex likes this.
The Following 10 Users Say Thank You to superskaterxes For This Useful Post:
AJ713 (10-15-2011), Alpha (10-11-2011), Chimmike (08-06-2011), Dano (08-05-2011), Fobio (08-05-2011), kmac (08-05-2011), MS3-a(sore)ASS-rex (08-05-2011), mtnrunner (08-05-2011), Scribbles (08-05-2011), TexasSpeed3 (10-14-2011)
 Old 08-05-2011, 05:16 PM   #33
mtnrunner's Avatar
^^ I agree, sorting out tuning at each boost level then driving it for a bit will give us a better idea of actual safe power for the stock longblock.
The Following 2 Users Say Thank You to mtnrunner For This Useful Post:
kmac (08-05-2011), superskaterxes (08-05-2011)
 Old 08-05-2011, 05:17 PM   #34
bmylez's Avatar
Groans: 31
How confident are you that the fuel system will support 550?
kmac (08-05-2011)
 Old 08-05-2011, 05:38 PM   #35
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
very nice Kmac!!
GL with everything. I like the CM boost gauge/controller. My buddy has an 04 STI that we are working on and he is about to order that kit with the flow sensor and new intank pump setup.
He actually wants do to a pre-turbo nozzle as well as cold pipe, but I am trying to talk him out of it...shortens the turbo life for sho.
I don't fully trust PI WMI but with that 5th port at the TB you have at least a lil insurance.
kmac (08-05-2011)
 Old 08-05-2011, 05:33 PM   #36
708
Erich's Avatar
Posts: 4,274   (View Stats)
Looks like everything is finally coming together. Meet somewhere in the middle to race?
The Following 2 Users Say Thank You to Erich For This Useful Post:
kmac (08-05-2011), manelscout4life (08-05-2011)
 Old 08-05-2011, 05:41 PM   #37
bmylez's Avatar
Groans: 31
Why don't you trust port WMI?
 Old 08-05-2011, 05:59 PM   #38
kmac's Avatar
Thanks guys, I'm pretty confident the fuel system will do 500+ , but there's only one way to find out. I would love to meet up half way for a run. It should be done within the next 2 weeks and ready to start tuning.
 Old 08-18-2011, 07:04 PM   #39
kmac's Avatar
I never posted pics of the wastegate I added to the exhaust pre-cat to relieve back pressure ,so I could still have the cat and not go 4 inch and eliminate back pressure. I originally had a 4 inch cat but I couldn't fit this in there with it so I went metallic core random technology hi-flow 3 inch. @superskaterxes we discussed this in another tread and i never posted the pics, so here they are.
It works pretty awesome. Turned out how I expected it to work. It opens at 11 psi.
The Following 20 Users Say Thank You to kmac For This Useful Post:
AJ713 (10-15-2011), btstarcher (12-25-2013), Ckmazdaspeed3 (08-18-2011), Dano (08-18-2011), djuosnteisn (09-07-2011), Docnox (10-17-2011), Easter Bunny (09-09-2011), josurr (10-15-2011), Meder (10-11-2011), PunjabiPlaya (09-06-2011), Realgib3 (08-19-2011), redboat (12-25-2013), rfinkle2 (09-27-2011), SilverDemon (08-18-2011), Speed_j23 (10-31-2012), spnkr21 (08-19-2011), TexasSpeed3 (10-14-2011), Tomas (01-11-2012), uncorked11 (11-29-2011), zpele (09-23-2011)
 Old 08-18-2011, 07:10 PM   #40
2k4_8's Avatar
Posts: 684   (View Stats)
2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world
Groans: 64
Groaned at 18 Times in 6 Posts
Nice, thanks for keeping it updated... 2 words-Fucking Sick!
COBB AP, CPE STAGE 2 RMM, CS SRI/TIP, AT HPFP INTERNALS, CNT CATTED DP, CP-E TRITON, JBR RSB, SWIFT SPRINGS, CS CAMBER ARMS
2k4_8 is offline   Reply With Quote
The Following User Says Thank You to 2k4_8 For This Useful Post:
CDSPEED3 (09-16-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/kmac-s-6262-build-87868/
Utah Mazdas Dyno Day this SAT 15th This thread Refback 11-21-2011 02:47 AM
• View topic - Awesome MPS This thread Refback 10-19-2011 07:56 AM
Mazda Owners Club SA • View topic - Awesome MPS This thread Refback 10-16-2011 09:59 AM
Theory: Build before Build demonspeed MazdaSpeed 6 - Engine, Transmission & Driveline 5 02-10-2009 06:52 PM
Page generated in 0.89907 seconds with 46 queries
