Like Tree64Likes
 Old 09-06-2011, 11:18 AM   #81
bcmurphy87's Avatar
Posts: 1,435   (View Stats)
this look so good, huge fan of the wg location
06 Speed6 GT- Sold
The Following User Says Thank You to bcmurphy87 For This Useful Post:
kmac (09-06-2011)
 Old 09-06-2011, 06:49 PM   #82
kmac's Avatar
Posts: 1,792   (View Stats)
I'll post some logs after work tomorrow.
The Following 2 Users Say Thank You to kmac For This Useful Post:
BigjohnB20 (09-07-2011), djuosnteisn (09-07-2011)
 Old 09-07-2011, 04:14 PM   #83
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Why am i so late to the party?
Lots of custom goodies in there. Hope all goes well with the tuning man. Sounds like it already is.
Supplemental fuel is gonna be key lol. When do you see 15psi? Spool decent?
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
kmac (09-07-2011)
 Old 09-07-2011, 04:20 PM   #84
BigjohnB20's Avatar
Posts: 779   (View Stats)
BigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the world
Originally Posted by kmac View Post
I'm hitting like 11.6
I know you already know this but going to 12ish should give you a little bit of headroom. Combine that with whatever you are able to pull out with the increased FP and hopefully you can eek some more out of this monster.
2006 BCM MS6 GT
CS SRI/TIP
Jbarone SSP/bushings
cp-e RMM, TMIC, Stiff Diff
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
BigjohnB20 is offline   Reply With Quote
The Following User Says Thank You to BigjohnB20 For This Useful Post:
kmac (09-07-2011)
 Old 09-07-2011, 06:55 PM   #85
kmac's Avatar
Better later then never , yeah I thin I was hitting 15 at like 4500. I'm going to go in to the throttle table and close it a little and open fully under later load to increase air speed to spool faster. There r so many good thing about this platform for tuning that other platforms wish they had. I'll get some logs up tomorrow.
The Following 8 Users Say Thank You to kmac For This Useful Post:
Dano (09-11-2011), djuosnteisn (09-08-2011), Erich (09-08-2011), manelscout4life (09-08-2011), Realgib3 (09-07-2011), rfinkle2 (09-15-2011), SpeedSixxx (09-09-2011), wolly6973 (09-20-2011)
 Old 09-07-2011, 07:00 PM   #86
kmac's Avatar
I agree, I'll be leaning out as I go this week and as I up the pressure that should help some more. I also have 5 nozzles for meth so secondary fuel should be helping out quite a bit. Especially with the pump I have. I'm going tp shoot for 28 psi on the final tune. After that I'm going to build my block for next season.
The Following 7 Users Say Thank You to kmac For This Useful Post:
BigjohnB20 (09-07-2011), Chimmike (09-07-2011), Erich (09-08-2011), LiEast (09-09-2011), Realgib3 (09-07-2011), SpeedSixxx (09-09-2011), wolly6973 (09-20-2011)
 Old 09-08-2011, 01:34 PM   #87
bcmurphy87's Avatar
i like you attitude....already planning for next season
06 Speed6 GT- Sold
The Following 2 Users Say Thank You to bcmurphy87 For This Useful Post:
kmac (09-08-2011), SpeedSixxx (09-09-2011)
 Old 09-08-2011, 02:02 PM   #88
kmac's Avatar
i got the inj d/c down to 85 % at 17.4 psi by hitting 12.2 afr and upping the pressure a little. I'm going to log in a little and I'll post what i have.
The Following 5 Users Say Thank You to kmac For This Useful Post:
BigjohnB20 (09-08-2011), Erich (09-08-2011), rfinkle2 (09-15-2011), SpeedSixxx (09-09-2011), wolly6973 (09-20-2011)
 Old 09-08-2011, 02:08 PM   #89
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Sick! Still gonna try to max out the stock block?
07 MS3
The original Genpoo Hater
 Old 09-08-2011, 02:49 PM   #90
kmac's Avatar
absolutely, I'm not going to stop till I'm happy. I'm going to run it like this then tune with meth. Once I run the meth I'll be good. I may also run another fuel system I've been working on , on this stock block , but idk yet. If I run that I'm shooting for 30psi.
The Following 10 Users Say Thank You to kmac For This Useful Post:
AJ713 (10-15-2011), Chimmike (09-08-2011), Dano (09-11-2011), djuosnteisn (09-09-2011), Docnox (10-17-2011), LiEast (09-09-2011), Monotonous ONE (09-09-2011), Realgib3 (09-08-2011), SpeedSixxx (09-09-2011), wolly6973 (09-20-2011)
 Old 09-08-2011, 05:16 PM   #91
kmac's Avatar
here's the log I got today I got slight knock because my bat jumped up high and I couldn't figure out why. I found out the pump took a shit , so I just ordered another one , but this is to what I have for now. Once I get the pump I will increase the redline to 7200 or 7400. it doesn't want to stop pulling. I just have to do some more fuel pressure adjustments and timing.
kmac4.13 revised boost_110908180015.xlsx
AJ713 (10-15-2011), Boonestafa (09-16-2011), Dano (09-11-2011), djuosnteisn (09-09-2011), Erich (09-08-2011), rfinkle2 (09-15-2011), SpeedSixxx (09-16-2011), wolly6973 (09-20-2011)
 Old 09-08-2011, 05:26 PM   #92
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
What pump are you running? That's one thing that scares me about water I/C. If your pump fails and you're NOT datalogging/paying attention, bad things can happen. Sure, that goes for other things like AFR and knock, but a regular FMIC can't just randomly fail, haha.
2007 CTS-V - Trying to sell
The Following 3 Users Say Thank You to bmylez For This Useful Post:
kmac (09-08-2011), SpeedSixxx (09-16-2011), wolly6973 (09-20-2011)
 Old 09-08-2011, 05:33 PM   #93
708
Erich's Avatar
Posts: 4,274   (View Stats)
I have been able to pick up between 20% and 30% inj duty cycle using the port meth injection and targeting 12.5 AFR. No knock.
I have the failsafe with mine that kills the EBCS effectively dropping to WG spring pressure. Had it happen once (don't know why, maybe air in the lines) and very noticeable dropping from 22 to 16 PSI, very easy to get off it quickly.
Boonestafa likes this.
The Following 4 Users Say Thank You to Erich For This Useful Post:
djuosnteisn (09-09-2011), kmac (09-08-2011), rfinkle2 (09-15-2011), wolly6973 (09-20-2011)
 Old 09-08-2011, 05:57 PM   #94
kmac's Avatar
it's a cobra pump, but it wasn't new. It was out of my other system , but i got rid of the car and i kept the pump. It's old so I'll just get a new one no big deal.
The Following User Says Thank You to kmac For This Useful Post:
 Old 09-09-2011, 11:07 AM   #95
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
Groans: 778
glad i'll be around to watch it go down.
hows the 6262? mike do you right or what?
 Old 09-09-2011, 07:53 PM   #96
kmac's Avatar
Yeah, he did the right thing it runs great he did a fantastic job.
rfinkle2 (09-16-2011), SpeedSixxx (09-16-2011)
 Old 09-09-2011, 08:37 PM   #97
LiEast's Avatar
Posts: 582   (View Stats)
LiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the worldLiEast is the leader of the world
man looks like you got awesome progress going on over there sounds great
2008 RED MS3 GT>>>T3 GT35R .82 A/R>>>Tial 44 EWG dumping>>>SteedSpeed T3 Mani>>>Built Motor
PERM!
LiEast is offline   Reply With Quote
The Following 2 Users Say Thank You to LiEast For This Useful Post:
kmac (09-09-2011), SpeedSixxx (09-10-2011)
 Old 09-15-2011, 07:52 PM   #98
kmac's Avatar
Got my new i/c yesterday. It's kind of big , but I got it so I can move my intake. It's a vertical flow not horizontal flow which allows me to get the room I need . I just cut off the ends of the tanks to weld on the new outlets. They need to be extremely tight radius, so I made all my cuts and I'll weld it tomorrow. The density on the core is awesome. I'll post pics tomorrow.
The Following 9 Users Say Thank You to kmac For This Useful Post:
AJ713 (10-15-2011), amoosenamedhank (09-16-2011), Chimmike (09-16-2011), Dano (09-16-2011), djuosnteisn (09-16-2011), Erich (09-16-2011), rfinkle2 (09-15-2011), SpeedSixxx (09-16-2011), wolly6973 (09-20-2011)
 Old 09-16-2011, 10:55 AM   #99
Captain
It's tomorrow.
www.permtuning.com
The Following 9 Users Say Thank You to djuosnteisn For This Useful Post:
amoosenamedhank (09-16-2011), Chimmike (09-16-2011), Dano (09-16-2011), jracer (09-16-2011), kmac (09-16-2011), rfinkle2 (09-16-2011), SpeedSixxx (09-16-2011), wolly6973 (09-20-2011), Ziggo (09-16-2011)
 Old 09-16-2011, 11:28 AM   #100
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
now dustin, you more than anyone know it takes time and sometimes, "tomorrow" is actually next week LOL
djuosnteisn (09-16-2011), kmac (09-16-2011), wolly6973 (09-20-2011)
 Old 09-16-2011, 12:31 PM   #101
Captain
Hahahahahaha. Tell me about it. And "tonight" is 3 days from now.
FML.
www.permtuning.com
Dano (09-16-2011), kmac (09-16-2011), wolly6973 (09-20-2011)
 Old 09-16-2011, 03:06 PM   #102
Boonestafa's Avatar
Posts: 204   (View Stats)
Boonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the worldBoonestafa is the leader of the world
pure sex!! i feel like a douche but this is in a 6 right?
2008 True Red MS3 GT HKS ssqv black, JBR SRI, JBR TIP, CPE ToW PlatE.
JBR RMM, HPFP Internals, cobb AP in near future!
Boonestafa is offline   Reply With Quote
The Following User Says Thank You to Boonestafa For This Useful Post:
kmac (09-16-2011)
 Old 09-16-2011, 03:10 PM   #103
bmylez's Avatar
Groans: 31
Big giveaway that it's not a 6 is there is no driveshaft down the tunnel, among other things.
kmac (09-16-2011)
 Old 09-16-2011, 03:16 PM   #104
Boonestafa's Avatar
i'm at work and only a few of the pictures are making it past the filters. which is weird as you'd think it would be all or nothing.
anyway super sick build!
kmac (09-16-2011)
 Old 09-16-2011, 06:59 PM   #105
kmac's Avatar
I finished welding the outlets on the end tanks and tested them no leaks.The test fit is good the intake will be made tomorrow, it will fit right under the new intercooler tubing. I'll also be installing the bov tomorrow, I'm going to put my tial on. Here's the pics.
inside fin view
same
inside the water inlet/outlet
so I got them posted today in real world time not unreal build time . the core is much bigger it should work well for my application. I'll move the intake and do the bov tomorrow. already getting ready for paint tomorrow as well.I should be done by sunday with everything. I hope everyone has a boner like I do. I'll post pics after intake and bov tomorrow and paint hopefully on sunday. then I'll post finished pics, Enjoy.
The Following 6 Users Say Thank You to kmac For This Useful Post:
Dano (09-19-2011), djuosnteisn (09-19-2011), Erich (09-18-2011), MPSdriver (09-19-2011), silvapain (09-17-2011), wolly6973 (09-20-2011)
 Old 09-16-2011, 07:32 PM   #106
bmylez's Avatar
Groans: 31
How do you have your ECU mounted?
kmac (09-16-2011)
 Old 09-16-2011, 08:00 PM   #107
kmac's Avatar
I took it out , I hook the car up to my brain. I did it mainly to save weight.
Broxer (10-12-2011), Erich (09-18-2011), harryclay (09-27-2011), manelscout4life (09-17-2011), MPSdriver (09-19-2011), wolly6973 (09-20-2011)
 Old 09-16-2011, 08:09 PM   #108
bmylez's Avatar
Groans: 31
Douche . I see an ECU plug, but that's all I see...you have so much stuff in the way, haha.
kmac (09-16-2011)
 Old 09-16-2011, 08:11 PM   #109
Boonestafa's Avatar
dude my dicks so hard it hurts. one day.. one day i too will have skills like yours. i have the will.. i just lack the space to operate. growing up my dad had a kick ass 3 car garage that he insisted he 'saw wood' and 'keep his tools in' cause 'that was his job'. fucker got sawdust all over all my car stuff! then like 3 years ago the bastard lost his job.. and his wife.. and his house... all before i could buy it from him! now i have to work on the street at my town house.
true story. but seriously.. i sooo want to be able to do what your doing.
kmac (09-16-2011)
 Old 09-16-2011, 08:13 PM   #110
kmac's Avatar
I made a bracket that bolts to the ic from underneath . You won't be able to see it.
 Old 09-16-2011, 08:19 PM   #111
kmac's Avatar
thanks, I appreciate your support. Hopefully soon u start a build tread we can all get a
boner over.
 Old 09-17-2011, 12:00 AM   #112
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
I'm going to have to put this guy down before the prophecy is fulfilled......
Carry on citizens....
10.7 @ 133 auto 1G DSM
The Following 6 Users Say Thank You to Darksun280 For This Useful Post:
4G63 (10-11-2011), Dano (09-19-2011), Erich (09-18-2011), kmac (09-17-2011), silvapain (09-19-2011), wolly6973 (09-20-2011)
 Old 09-17-2011, 02:41 AM   #113
kmac's Avatar
Lmao , I love it.
 Old 09-18-2011, 07:16 PM   #114
kmac's Avatar
well I never got a chance to paint it , but I got a chance to test it and it works great . Bat down to 84 at 17 psi iat at 72 deg. I also had to eliminate the recirc bpv abd put my tial on and go vta no room . I was able to fit my 4in intake from the turbo up to mate with my 4in maf, iat is in the tip of the air filter . Here's some pics I'll post the painted pics later this week after I paint it.
djuosnteisn (09-19-2011), Erich (09-20-2011), Realgib3 (09-19-2011), silvapain (09-19-2011), wolly6973 (09-20-2011)
 Old 09-20-2011, 06:59 AM   #115
kmac's Avatar
Made the appointment yesterday for the dyno on next Friday. Hopefully all goes well ,I have it for 4 hours. I'll do some tuning and see how far I get , then if I don't complete it I'll setup another time when I have more of it.
The Following 4 Users Say Thank You to kmac For This Useful Post:
djuosnteisn (09-20-2011), Erich (09-20-2011), rfinkle2 (09-20-2011), wolly6973 (09-20-2011)
 Old 09-20-2011, 10:15 AM   #116
Captain
I'll pm you my number in case you need a second opinion on anything. GL man! Maybe we'll be on the dyno at the same time haha.
www.permtuning.com
Erich (09-20-2011), kmac (09-20-2011)
 Old 09-20-2011, 10:24 AM   #117
Good luck on the dyno Kmac.
I can't wait to see your results.
As always, thanks for all of your help.
kmac (09-20-2011)
 Old 09-20-2011, 10:41 AM   #118
kmac's Avatar
Thanks , I appreciate it. Let's have a dyno showdown.
djuosnteisn (09-20-2011), Don06speed6 (09-20-2011), Erich (09-20-2011), rfinkle2 (09-20-2011)
 Old 09-20-2011, 02:06 PM   #119
Captain
Hahaha, we can definitely try. I'm shooting for like 450 uncorrected right now. Then when i have more fuel, i'll shoot for 500 - 550.
www.permtuning.com
BlueStreak (09-20-2011), Don06speed6 (09-20-2011), Erich (09-20-2011), kmac (09-20-2011), Realgib3 (09-20-2011)
 Old 09-20-2011, 02:12 PM   #120
kmac's Avatar
I would like 470 to 510 whp but I'm sea level , on a stock block I'd be mare then happy. When I'm done we need to meet at a track and run. I'll go half way.
djuosnteisn (09-20-2011), manelscout4life (09-20-2011), rfinkle2 (09-20-2011), SpeedSixxx (09-23-2011), wolly6973 (09-20-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/kmac-s-6262-build-87868/
Utah Mazdas Dyno Day this SAT 15th This thread Refback 11-21-2011 02:47 AM
• View topic - Awesome MPS This thread Refback 10-19-2011 07:56 AM
Mazda Owners Club SA • View topic - Awesome MPS This thread Refback 10-16-2011 09:59 AM
Theory: Build before Build demonspeed MazdaSpeed 6 - Engine, Transmission & Driveline 5 02-10-2009 06:52 PM
Page generated in 0.58457 seconds with 33 queries
