![]() Join Date: Feb 2009 Location: Atlanta Ga
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,123
(Thread Starter) | Not Ranked : 0 score Also what oil and weight are you guys running. Im currently using 15w-40 no synthetic. I have almost put 500 miles on the motor then ill be changing over to synthetic. I keep getting a cel for p0012. We have checked the timing and believe this light because of the low oil pressure and the vvt can not properly engage. |
Groans: 31
| Not Ranked : 0 score I run Rotella T6 5w40, but I'm not sure if that would help you...ask Dustin what his clearances are since I know he has good oil pressure.
| The Following User Says Thank You to bmylez For This Useful Post: | bcmurphy87 (10-25-2011) |
| jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13536 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,744
Groans: 793
| Not Ranked : 0 score Yeah that's mad low. Usually a blocked passage would result in high oil pressure, but I wouldn't rule it out. I'd pull that oil filter and see if there's anything obvious in there. Also, you may end up needing to pull the pan to inspect the pickup.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
| Fux Wit It ![]() ![]() Join Date: Mar 2008 Location: Li
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,795
Groans: 175
| Not Ranked : 0 score I think a local guy had this issue after his built motor and it was his rear main seal. end of the day that motor is going to have to come out to investigate. Sorry man. But give us the run down on the situation? is it your stock block built? did your stock motor die? who did the work? did you reuse any parts. did one shop do the entire build?
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous |
i would move your OP sender around to different parts of the oil system and see if you can trace any abnormalities
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
| The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | bcmurphy87 (10-25-2011), Tokay444 (10-25-2011) |
(Thread Starter) | Not Ranked : 0 score Thanks for the info guys. I been working with DJ on the matter because were also trying to dial in a tune. The same shop did the entire build. I started with a used block and head but had it all sent off to the machine shop and checked out. I have no oil leaks to my knowledge. Dj was thinking it was my rod bearing even though there brand new might be to thin for the build. Since no one makes over sized rod bearing my only option would be to get them coated. I just trying to see if anyone else had this issues What are you guys oil pressure? What should i be aiming for?
__________________ 06 Speed 6- EBtec built, FreekTuned and 5862 powered! 540/493 06 Speed6 GT- Sold Last edited by bcmurphy87; 10-25-2011 at 09:13 AM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to bcmurphy87 For This Useful Post: | djuosnteisn (11-09-2011) |
(Thread Starter) | Not Ranked : 0 score I am summoning @djuosnteisn |
(Thread Starter) | Not Ranked : 0 score do you have an oil pressure gauge? what is your pressure running this oil. Dj suggested the same oil to me. |
![]() Join Date: Jun 2010 Location: li, merrick, new york
Rep Power: 2273 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,757
| Not Ranked : 0 score It sounds like a clearance issue . Did they plasi-gauge everything ? Also take a reading of oil pressure at the head . There should be a spot u can check it at , you should have some real low pressure there. |
| Not Ranked : 0 score Im not sure how loose that tolerance is, but if the motor is buil loose you will need to run heavier oil to account for the larger gaps |
(Thread Starter) | Not Ranked : 0 score Im gonna switch over to the 5w-50 tonight and see how that does, but i think that is only masking an issue. |
![]() Join Date: Jan 2009 Location: ME, Kittery
Rep Power: 1818 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,848
| Not Ranked : 0 score BSD? Did you plug the oil feed to the bs?
__________________ 2012 WRX HB w/mudflaps yo! |
(Thread Starter) | Not Ranked : 0 score Oh wow i wonder if that did get plugged. I know the BSD is out. man i really dont want to have to drop the pan lol. |
| Not Ranked : 0 score Did you buy a plug for them to install? If not it's a pretty easy fix. I wouldn't run the car without one.
![]() Join Date: Mar 2008 Location: Long BEach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score We had that issues, I installed a motor. he had another shop build. Once car got warm oil preassure ligh flicked at idle. (light comes on around 10psi) dropped pan (its usually not that bad). and sure enough the BSD kit was not there. Bolt or plate to block hole. Installed it, Cheacked preassure after instal. Ran to specs. Car has been running fine (and tracked and bolt ons added) since then. he has a few thousand miles. already. |
| The Following 5 Users Say Thank You to ALIEN3T For This Useful Post: | bcmurphy87 (11-07-2011), bertrand_CX_7 (11-07-2011), Darksun280 (10-26-2011), Easter Bunny (10-26-2011), wolly6973 (11-07-2011) |
(Thread Starter) | Not Ranked : 0 score Still getting the flickering of the oil light at idle. The prosport gauge shows 20+ psi and im still getting the flickering dash light. Any idea what this maybe. I am on thicker oil now though. |
| Not Ranked : 0 score Did u drop the pan and make sure your bs delete is in ? Also did you make sure the pick up is tight and has the o-ring installed?
__________________ First 500whp stock block mazdaspeed3 (503whp 423wtq) <3 Tokay. |
| The Following 2 Users Say Thank You to kmac For This Useful Post: | bcmurphy87 (11-07-2011), wolly6973 (11-07-2011) |
(Thread Starter) | Not Ranked : 0 score i did drop the oil pan the bsd is there and ill check the oil pick up. i need to change my oil this weekend. |
![]() | | #19 | ![]() |
| rabble rabble ![]() Join Date: Aug 2008 Location: Delawhere
Rep Power: 3167 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score 19psi of oil pressure is pretty normal at idle i believe. i have the sandwich plate above the filter and when the motor is warm, oil pressure reads about 12-15psi. increases linearly with rpm.
__________________ '08 CWP MS3 w/ T3 3071r |
| The Following User Says Thank You to 802MS3 For This Useful Post: | kmac (11-07-2011) |
![]() | | #20 | ![]() |
Groans: 793
| Not Ranked : 0 score Possibly just a bad sensor then.
| The Following User Says Thank You to Tokay444 For This Useful Post: | kmac (11-07-2011) |
![]() | | #21 | ![]() |
| 708 ![]() Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 45885 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,982
| Not Ranked : 0 score Same for me. Routinely have seen between 15-20 PSI at idle for 3 years now. Both on the stock block (from about 3000 miles on) and now on the built block. I would have to guess your dummy light sensor is bad. |
![]() | | #22 | ![]() |
| Not Ranked : 0 score Pssshhhh..... OP's oil issue has nothing on his fueling issue. Hahaha. Should have lit a match Chris, hahaha.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
| The Following User Says Thank You to djuosnteisn For This Useful Post: | rigor (11-10-2011) |
![]() | | #23 | ![]() |
![]() Join Date: Apr 2010 Location: Elizabeth /NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,623
| Not Ranked : 0 score Do you have the oil pressure sensor on the sandwich plate or on the filter housing ? Try this 1. Remove the oil pressure switch. 2. Screw in a oil pressure gauge into oil pressure switch installation hole. 3. Warm up the engine to normal operating temperature. 4. Run the engine at the specified speed, and note the gauge readings. If not within the specification, inspect for the cause and repair or replace if necessary. NOTE: The oil pressure can vary with oil viscosity and temperature. Oil pressure (reference value) [oil temperature: 100 °C {212 °F}] 297—551 kPa {3.03—5.61 kgf/cm2, 43.1—79.9 psi} [3,000 rpm] |
| The Following 2 Users Say Thank You to SPEED6 KILLAH For This Useful Post: | 802MS3 (07-18-2012), qtrmile beast (11-13-2011) |
![]() | | #24 | ![]() |
![]() Join Date: Apr 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score If you are pushing low oil pressure and everything is accounted for such as the BSD you might consider running a 20w50 oil. On a built turbo engine you really should run the thickest oil possible. AMSoil has some great articles on built engines tolerances and oil weight. If you want some reference material. Also fuck plasti gauge use a proper tool sense that only measures one area and is a biased measurement. Did you check the BSD by removing it and inspecting the O-ring? I have seen these fail on a few kits if the O-ring is made of rubber just a heads up. Best is to ether have a plug pressed into the hole with a back plate for support or welding it shut. |
| The Following User Says Thank You to pinkcheese For This Useful Post: | bcmurphy87 (07-16-2012) |
![]() | | #25 | ![]() |
![]() Join Date: Nov 2011 Location: edgewood md
Rep Power: 2429 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,644
Groans: 391
Groaned at 75 Times in 49 Posts
__________________ moore automitive 4/13/13 515whp 511 tq Mason Dixon Raceway 11.289 @125 1.845 60' Killah Built Powered By Purple Drank |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yea i solved it after i spun 3 of 4 bearings lol. The PTP bsd plug that was in my used block failed and wasnt holding pressure and finally gave out and dropped all pressure. It was a freeze plug design. Im now using a sure bsd plug and no issues. |
| The Following 7 Users Say Thank You to bcmurphy87 For This Useful Post: | 802MS3 (07-18-2012), atvfreek (07-16-2012), Captain KR (07-16-2012), doubleflusher (07-16-2012), Easter Bunny (07-16-2012), phate (07-19-2012), superskaterxes (07-16-2012) |
![]() | | #27 | ![]() |
Rep Power: 151849 ![]() Thanks: 55,993
Groans: 1,443
| Not Ranked : 0 score Add that to the list of failed PTP products.
__________________ Evo VIII - 9.93 @ 150.05 - CAI and LEDs Beanfab / Tuned by Nishan |
| The Following 3 Users Say Thank You to doubleflusher For This Useful Post: |
![]() | | #28 | ![]() |
Groans: 391
__________________ moore automitive 4/13/13 515whp 511 tq Mason Dixon Raceway 11.289 @125 1.845 60' Killah Built Powered By Purple Drank Last edited by Captain KR; 07-16-2012 at 10:43 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score | |
| The Following User Says Thank You to bcmurphy87 For This Useful Post: | Tokay444 (07-16-2012) |
![]() | | #30 | ![]() |
Groans: 391
| Not Ranked : 0 score lol damn whiteys holding niggas down making me down and now you jew's start holding me down wtf is up with that bro?
![]() | | #31 | ![]() |
![]() Join Date: Jan 2010 Location: charles co, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,295
| Not Ranked : 0 score As i told you this morning that my car is doing this wild LOW OIL LIGHT thing in my car as well. It just started on my car though and i have 20,000 miles on my built motor. But my DEFI oil pressure gauge shows i am getting the same oil pressure as i have always gotten as its warming up it is about 60 psi. At idle i get about 19-21 psi i believe. I will take a video tomorrow as to what mine is doing. I also checked my oil and the level is fine. I let my car Idle for about 20 minutes or so this morning and the flickering light was there. This is the first i have ever seen of this..
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport Last edited by qtrmile beast; 07-16-2012 at 11:15 AM. | |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score Stop driving it!!!! you should have like 45-50+ at idle. i had the same oil pressure 19-20 before i spun all 3 something is wrong!!!! trust me. i bet the oil light goes away instantly when you drive or rev too. its sounds just like mine and its bad. I switched up to a heavy oil and it only masked the problem. i as using 20-50 and it helped but really all it did was buy me time before i was dead in the water |
![]() | | #33 | ![]() |
I think that your problem might be different than ours. i think your problem might have been oil pump related or tolerance related.. None of the motors that we have built has ever spun a bearing at least not to my knowledge. About the 50-60 psi at idle.. yes my car does do that when it is cold starting, but when it is normal operating temperature it will go down to about 19-21 psi.
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport | ||
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score oh ok well let me know what you find |
![]() | | #35 | ![]() |
Groans: 391
| Not Ranked : 0 score ughhhhh need oil filter conversion and oil pressure gauge
![]() | | #36 | ![]() |
| Not Ranked : 0 score Holding up to the stress I put it through just fine.
__________________ 2 years after hitting 700hp and still running strong. Happy to see others joining the club. |
| The Following User Says Thank You to Erich For This Useful Post: | rfinkle2 (05-26-2015) |
![]() | | #37 | ![]() |
| Not Ranked : 0 score 19-21psi at idle is just fine a good rule of thumb is you want to keep 10psi for every 1000rpm you go. |
| FML and possibly my built motor | turd burglar | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 14 | 04-19-2011 10:02 PM |
| Built Motor is Done..... | yoichi | MazdaSpeed 6 - Engine, Transmission & Driveline | 107 | 12-14-2009 10:52 AM |
| has anyone with built motor broke a rod | cbspeed3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 41 | 08-05-2009 12:24 PM |
| built motor | ms3boost | MazdaSpeed 3 - Engine, Transmission & Driveline | 17 | 05-20-2009 10:22 AM |
| Who Has A Built Motor? Need Impressions | Haltech | MazdaSpeed 3 - Engine, Transmission & Driveline | 99 | 12-22-2008 08:51 AM |
