 Old 07-19-2010, 06:35 AM   #1
h0rsies's Avatar
Posts: 133   (View Stats)
h0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond repute
Default LSD haha
Protege Garage - Quaife Limited Slip Differential - Mazdaspeed3
Is this worth the money
h0rsies is offline   Reply With Quote
 Old 07-19-2010, 06:49 AM   #2
flyrevs2's Avatar
Posts: 1,235   (View Stats)
only if your stock lsd is shot, or you have unlimited cash
2013 Mazdaspeed3 Gen2
flyrevs2 is offline   Reply With Quote
 Old 07-19-2010, 06:50 AM   #3
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
why do you say that? my friend has one and it apparently changes the car completely. i want one really badly but it will cost a grip to install.
 Old 07-19-2010, 06:51 AM   #4
ms3brendan's Avatar
Posts: 1,017   (View Stats)
ms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the world
I'm sure it wouldn't be too bad to have.. Haha. Quaiffe LSDs are amongst the best out there but, we already have an LSD.. Yeah I would say it's worth to get if yours is broke.. But other than that it's pretty much a waste of money.. Not a total waste but the gains would never justify the cost.
2012 BMW 135i //M-Sport
ms3brendan is offline   Reply With Quote
The Following 2 Users Say Thank You to ms3brendan For This Useful Post:
Blackspeed (07-19-2010), flyrevs2 (07-19-2010)
 Old 07-19-2010, 06:58 AM   #5
ILL3ST
xcoldricex's Avatar
maybe you guys are all just interested in going in a straight line. in that case you, bought the wrong car.
the stock lsd and this one are totally different. stock is a cone type, the quaife is helical gear type.
it will reduce torque steer and is more effective at multiplying torque to the wheel that has grip.
 Old 07-19-2010, 07:01 AM   #6
ms3brendan's Avatar
They also help in exiting corners...
 Old 07-19-2010, 07:01 AM   #7
flyrevs2's Avatar
sounds good, now give us some specific details why it's so great. I'm not being smart I just want to know the specifics. Thanks
 Old 07-19-2010, 07:02 AM   #8
KR....i haz it
Blackspeed's Avatar
Posts: 2,845   (View Stats)
Blackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the world
Groans: 166
No one has problems with the stock lsd. like others have said....not worth it unless yours is broke.
Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts |
CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp
While the other forum is GREAT for technical/mechanical information and how to, that place is filled with single-minded (if you aren't driving fast, you're doing it wrong), arrogant, and professional douchebags.
Blackspeed is offline   Reply With Quote
 Old 07-19-2010, 07:02 AM   #9
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
I would say that unless you are super hardcore into autocrossing, there is no need. Even then, it would probably be one of the last pieces that I bought. The only time I have wished my LSD worked better is in tight turns where I can overpower the tires (which is everywhere in autocross). This generally means 1st/2nd and sometimes 3rd gear. Straight line: our LSD works very well. Larger radius turns in higher gears: it works pretty darn good.
 Old 07-19-2010, 07:06 AM   #10
ILL3ST
xcoldricex's Avatar
ask saitech he actually has one. better than just saying, no it's not worth it. the quaife is one of the reasons all the reviewers like the focus rs so much...
 Old 07-19-2010, 07:08 AM   #11
h0rsies's Avatar
thanks for the help scratchin this off my wishlist
 Old 07-19-2010, 07:09 AM   #12
flyrevs2's Avatar
how hard is this to install ?
 Old 07-19-2010, 07:11 AM   #13
ILL3ST
xcoldricex's Avatar
you need to crack your trans case open. the local trans guy at the dealer was very reluctant to install the one on saitech's car. i don't know anyone who has done it themselves unfortunately. if it were easy, i'd definitely buy one.
 Old 07-19-2010, 04:35 PM   #14
SJP0tato's Avatar
Posts: 322   (View Stats)
SJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the world
If it's anything like other transmissions/differentials you need to measure/adjust preload using various sized shims and proper technique. It's a PITA and definitely not plug & play.
SJP0tato is offline   Reply With Quote
The Following User Says Thank You to SJP0tato For This Useful Post:
Amp goes BOOM.. Haha Shiraz MazdaSpeed 3/6 - Car Audio & Electronics 1 04-01-2009 10:22 PM
Page generated in 0.33221 seconds with 26 queries
