 Old 05-24-2016, 04:45 PM   #1
Xxblinddzxx's Avatar
Posts: 126   (View Stats)
Xxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud of
Groaned at 26 Times in 11 Posts
Default Maxing out CS Turbo with WMI ?
Hi guys,
So here's the question. I have a CS turbo with WMI kit and was wondering if a 375ml/min meth nozzle should be able to max out the CS turbo?
Thanks
Xxblinddzxx is offline   Reply With Quote
 Old 05-24-2016, 04:53 PM   #2
gdawg25's Avatar
Posts: 248   (View Stats)
What mix are you going to use with the WMI system? 50:50? 100% meth?
 Old 05-24-2016, 04:53 PM   #3
Going 100%
 Old 05-24-2016, 06:34 PM   #4
Boost_creep's Avatar
Posts: 829   (View Stats)
I would run the 625 ml/min nozzle. You will run out of fuel around 22-23 psi on the 375 ml/min nozzle. I run the 625 at 26 psi (gtx3071), and see ~85% inj duty cycle.
The Following 2 Users Say Thank You to Boost_creep For This Useful Post:
mize13 (05-24-2016), Xxblinddzxx (05-25-2016)
 Old 05-24-2016, 06:44 PM   #5
Uh oh. Doesn't sound good for me! I'll have to order meth nozzle ASAP then. Thx for info
Maxing out flow someguy 2010 MS3 - ECU Computer Tuning 35 08-17-2013 07:18 PM
Maxing out flow someguy 2010 MS3 - Turbo Induction 0 07-30-2013 09:07 PM
Maxing out my wastegate? Grim MazdaSpeed 3/6 - Turbo Induction 45 02-22-2009 05:06 PM
Maxing my Fuelpump with these mods? arkenzo MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 14 09-23-2008 05:50 PM
Page generated in 0.25646 seconds with 22 queries
