 Old 07-07-2016, 05:16 PM   #1
andrecorreia's Avatar
Posts: 8   (View Stats)
andrecorreia has a spectacular aura aboutandrecorreia has a spectacular aura about
Default Mazda 6 2.3 atmosferic converted to turbo AWD
Hello,
I would like to present my build, this build is a car that i'm building to offer to a friend that is handicapped but really like this car.
the car will have
forged pistons,
forged conecting rods
cometic head gasket
all round arp bolts
acl race bearings
gt2876r with ceramic ballbearings
intercooler
aluminium intercooler pipe
tial wastegate actuator
tial blow off
ID 850 cc injectors
stainless steel exhaust manifold
76mm downpipe and exhaust
What do you think?
the car is a station wagon and AWD and auto gearbox.
Hope you like
andrecorreia is offline   Reply With Quote
The Following User Says Thank You to andrecorreia For This Useful Post:
SpeedRebirth (07-07-2016)
 Old 07-07-2016, 05:47 PM   #2
JoelNR's Avatar
Posts: 29   (View Stats)
JoelNR is a splendid one to beholdJoelNR is a splendid one to beholdJoelNR is a splendid one to beholdJoelNR is a splendid one to beholdJoelNR is a splendid one to beholdJoelNR is a splendid one to beholdJoelNR is a splendid one to beholdJoelNR is a splendid one to behold
Originally Posted by andrecorreia View Post
What do you think?
Well...
2010 Celestial Blue MS3
The Have:
- Cobb V3 AP w/ Stratified OTS+E85 - CS Stage II SRI - CS HPFP - CS Race Pipe - CS OCC - Cobb BPV - JBR EGR Delete
- CP-E Stage II RMM - CS Shifter Plate & Bushings -
- 18x8 Konig Runlites - CS Hood Scoop - Webasto Sunroof - Pioneer AVIC 5100 NEX -
The Want:
- CP-E TMIC - Catless DP - Damond PMM - Bigger Leaf Blower -
JoelNR is offline   Reply With Quote
The Following 2 Users Say Thank You to JoelNR For This Useful Post:
Vansquish (07-11-2016), WetzMS3 (07-12-2016)
 Old 07-07-2016, 05:49 PM   #3
how can i put photos?
 Old 07-07-2016, 05:54 PM   #4
JoelNR's Avatar
When you hit "Reply", click on the paperclip (Attachments) to the right of the smiley face and browse from the files on your computer.
The Have:
The Want:
 Old 07-11-2016, 04:41 PM   #5
here are some photos
Here are the parts i bought for it
CWP_MS3 (07-12-2016)
 Old 07-11-2016, 04:47 PM   #6
the turbo
Tial blow off
Tial wastegate set to 1.2 bar
and a photo off the car
 Old 07-11-2016, 04:50 PM   #7
Police - Grammarhead
Vansquish's Avatar
What AWD system are you using?
 Old 07-11-2016, 04:51 PM   #8
Next i will start to build the engine.
Do you know anybody or any thread off somebody how had done this conversion to turbo?
I tried to find but i was not successful.
what you think about stock ecu will it be ok only mapped?
It's the stock auto gearbox 5 speed. It's already awd
Last edited by andrecorreia; 07-11-2016 at 04:51 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-11-2016, 05:17 PM   #9
Vansquish's Avatar
A few people have converted the 2.3 (naturally aspirated) MZR engine to be turbocharged. However, there aren't very many. You will also definitely need a way to tune the car to handle the boost. Additionally, that torque-converter automatic may be weak for the kind of power that the turbo you've chosen can make. The axles may be too weak too.
 Old 07-11-2016, 05:27 PM   #10
In relation to the axles we can build better ones in house if needed( already have done that to other projects)
At my country this is the only mazda 6 2.3 awd so i think the worst part will be tune it.
I can read this ecu but i will have to learn or find someone good enough to change the map axis because of load.
Since it's atmospheric it has a load based from 0 to 1 in relation to a stock turbo car that is 0 to 3 ±
let's see!
Also another problem i think will the idle due to the maf values change so the i will need to rescale it.
 Old 07-11-2016, 05:35 PM   #11
dale_gribble's Avatar
Posts: 4,720   (View Stats)
I can't speak to the N/A. You can always run a piggyback or full EMS depending on what you want to do.
I'm not sure how much different the ECU is than the MZR from a programatic perspective, but reach out to Steve at Versatune and see if he has done anything on Mazdas outside of the Mazdaspeeds.
MINI H1 6.0 - CAR LED TAILS
Micha (07-17-2016)
Speed3 converted to RWD mazdas4me Mazdaspeed3/6 General Discussion 148 06-25-2014 03:04 PM
converted a SMC Enterprise Sti/WRX WMI kit on my MS6 redboat MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 09-04-2013 09:10 AM
Page generated in 0.30696 seconds with 24 queries
