| Banned ![]() Join Date: Mar 2013 Location: Portland, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 35
(Thread Starter) | Not Ranked : 0 score I just installed my DO Meth kit and while installing the boost actuated controller, I realized that I will be needing at least 3 boost sources for my install as I also ordered a Gaurdian Angel. Where do all of you tap into boost? I am assuming you don't just add 3 "T's" to the boost line into the BPV. I currently need boost sources for my Boost gauge, WMI controller, and GA. I don't know if I will need one for the boost dial as well or not. |
| The Following 3 Users Say Thank You to Stew For This Useful Post: |
![]() Join Date: Oct 2011 Location: Secaucus/New Brunswick NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 769
| Not Ranked : 0 score Subbed for results! looking forward to seeing what numbers you put down
__________________ BMW 335xi 6MT AR Catless Downpipes///HPF Fmic///BMS DCI///CP-e Chargepipe///Cobb AP V2///Volk TE37sl 18x9.5+22F 18x10.5+20R 2007 BM Mazdaspeed 6 GT #10477 SOLD 8/29/14 ![]() |
(Thread Starter) | Not Ranked : 0 score Lex said to go straight to a D010 nozzle for the meth. I would like to get close to 330 hp and 350 tq. I think those are reasonable numbers. 350 hp would be my ideal goal. Stewart |
| Not Ranked : 0 score I might copy your build later on as those are roughly the same numbers im looking hit.
| Not Ranked : 0 score For the boost sources here's what I use: 1. The GA will simply interrupt the line to your BPV 2. Connect the WMI controller and boost gauge to the line going to the BPV 3. The boost source for boost control will come off the BNR S3 compressor housing.
![]() Join Date: May 2011 Location: Portland OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,451
| Not Ranked : 0 score Wish my hks worked with GA
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. |
| The Following User Says Thank You to breakfstincluded For This Useful Post: | Jh8909 (10-04-2013) |
![]() Join Date: Jan 2012 Location: Edmonton, Alberta, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,581
Groans: 53
)Interested to see what happens. GL with this set up
__________________ 06 Speed 6 rock chipped n' shit Performance: Stratified Tune in progress Old Set-up: CS Ram air intake with 3" HTP inlet + "sig" Vdyno 323 awhp 349 awtq uncorrected Current Set up: JBR 3.5" WP, Perm PCV w/dual catch cans, trunk battery Vdyno 343 awhp 374 awtq uncorrected Corksport CBE ~ Ebay DP ~ Autotech Internals ~ COBB AP ~ BC Racing Coilovers ~ SURE shortcut ~ SURE countershift ~ SURE anchors ~ heavy sphere shift knob by maisonvi (MSF member) ~ CP-E seals ~ BSD ~ baffle pan ~ Dual Corksport OCC ~ CP-E Rear Diff Mount ~ SURE Juggernaught ~ Dashhawk ~ AWR 88 duro trilogy ~ EGR delete ~ 3 bar ~ JBR TIG's ~ Grimmspeed 3 port ~ GT2871R w/ported hotside ~ JBR 3.5 inch intake ~ Perm Tuning PCV Plate ~ Forge V1 BPV ~ ITV22's @ .026" ~ CP-E Helihose | |
(Thread Starter) | Not Ranked : 0 score Yes. I have been following your build. I was hoping since you got those number without that I could get 350 with. We'll see. |
| The Following User Says Thank You to Stew For This Useful Post: | Swinger13 (10-04-2013) |
Groans: 53
| Not Ranked : 0 score My latest numbers uncorrected 350whp and 370 wtq was in 10~ degree celcius so like 46 ish fahrenheit? your power goals seem within reach. I'm also at 2200 ft so a marginal loss there.
(Thread Starter) | Not Ranked : 0 score Turbo is now in after a fairly painful install. Probly just because I am a rather inexprienced mechanic. And that oil return line is the biggest pain to get out and even more to get back in on the MS6. Started the car with an appropriate base map, and AFRs started going lean after a few minutes of idling. Did a boost test tonight and @Lex; told me I had the boost dial hooked up wrong. Fixed that and a T-bolt clamp I forgot to clamp down. That fixed AFR's until I drove it. Did a few WOT pulls and an MAF cal log. Realized I had my GA set to activate and too little boost. and something must have come off or loosened because idling AFR's are back to being lean as in AFRs are in the 18 range. |
Groans: 53
(Thread Starter) | Not Ranked : 0 score yep. but no need to this time. Saw it as soon as I opened the hood. The boost tube from the turbo to the intercooler partially came off. I need a smaller tube. |
![]() Join Date: Mar 2008 Location: W. Suffield, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 674
| Not Ranked : 0 score Installing mine now. Ive got everything undone except oil and coolant. Trying to determine how I get these off. Oil feed is easy but oil drain not sure. Assume coolant feed line is a PITA too with PTO in the way. Any help?
__________________ MS6 - BNRs3 - Cobb AP - JBR Tru-3.0 - Spearco FMIC - MAC EBCS - Synapse BOV - DNP - CPE DP->MF - SU RRM - TTFMM - TT + CPE Diff Mounts - Mrlilguy HPFP - Projector HID fogs - TSX projector retrofit - LI jammers - Advan RZs w/ 245 PSSs - Koni - WL RSB |
For the oil drain, small hands and lots of patience. For the coolant drain, it is easier if you have one person under the car, then from the top you unhook the coolant drain from the T-case while the person underneath puts some rags over so that coolant loss is minimal. With the coolant line freed, you will be able to tilt the turbo and unhook the line from the turbo, then put it back on the T-case and clamp. I would use new clamps for all the hoses, the clamp on my coolant line was worn out at the T-case and had a subtle coolant leak after the install. Fortunately, the shop was able to sneak a new clamp on the hose without taking anything apart, but imagine if that was the connection at the turbo.
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned | |
| The Following User Says Thank You to Code Monkey For This Useful Post: | redboat (11-27-2013) |
| Not Ranked : 0 score Working alone. Got bottom oil drain off block. Had to run to sears to get 6pt 8mm and did 2nd bolt from bottom. Had to turn clamp on diff cooler and got that off. Plugged with a bolt with electrical tape wrapped around it. Turbo out. Can BNR be installed before work tomorrow...that is the mystery What sucks is all I have is Zyrex which is blue and so when I add it to replace the antifreeze I lost my coolant will turn brownish..
| Not Ranked : 0 score If Im using stock EBCS do I hook comp port to WG like OEM?
| Not Ranked : 0 score i think theres a diagram on stratified for this, look at their 2 port mode
(Thread Starter) | Not Ranked : 0 score Yeah, the oil drain is a pain in the butt. So far everything is going ok for me. Still have not done a base line VD. I think I am driving Lex a little nuts because I am not used to having to consult someone else as far as mechanical fixes to different problems. Right now I am fighting some sort of throttle body issue. The car throws a P2100 code and will run very rough and the gas peddle will not work. However, usually, I can restart it and it will be fine. But sometimes it takes multiple restarts before it works. It will even happen while driving. I will lose power, the DSC light will come on, and I will have to restart. I think it could be a poor connection at the throttle body so I am trying to dissasemble the connector to tighten the pins. Have to see if that works. Stewart |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well I haven't really kept this thread updated, so here is where I'm at. Car is running solidly. Fourth iteration of the tune on the car and it pulls pretty hard. 2nd pulls like a mother, 3rd and 4th are a little meh. Averaging out the number on the Vdyno (runs are both ways on the road) I have about 320 horse and 325 torque. Pretty good numbers and well on the way to reaching my goal of ~350 WHP and TQ. STew |
| The Following User Says Thank You to Stew For This Useful Post: | breakfstincluded (12-01-2013) |
![]() | | #20 | ![]() |
![]() Join Date: Dec 2012 Location: Portland, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 800
| Not Ranked : 0 score how's the car running now? |
![]() | | #21 | ![]() |
(Thread Starter) | Not Ranked : 0 score Running like a champ. Pulls pretty hard. But had to promise my girlfriend no racing :/ LOL |
![]() | | #22 | ![]() |
![]() Join Date: Sep 2011 Location: Croatia (Europe)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 265
__________________ 06 MS6, Versatuner, Stratified Tuned BNR Stage 3 turbo, Eagle con. rods, HTP Full 3" intake + AEM DryFlow filter Autotech HPFP internals, Forge V1 BPV Custom 3" cat-back with stock mufflers, M2 3" catless Downpipe Grimmspeed EBCS + Stratified Boost Dial, 3BAR BOSCH MAP NGK Iridium IX one step colder plugs, CPE SafeSeals & studs Custom FMIC with 2.5" piping and Treadstone TR8 IC SnowPerfomance WMI, Stratified Guardian Angel Eibach pro kit lowering springs | |
![]() | | #23 | ![]() |
(Thread Starter) | Not Ranked : 0 score Road wasn't completely flat. Doing runs going both ways. Stew |
![]() | | #24 | ![]() |
![]() Join Date: Aug 2008 Location: Pittsburgh, PA
Rep Power: 637 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,048
| Not Ranked : 0 score Glad to see it's coming along. You need to find a nice flat spot for those VD runs though. |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score I got one. My ambient temps are fairly cool right now so power is looking pretty good. Did another vdyno on a flat spot and I'm looking at about 330 hp 335 tq. Will load up another vdyno after I get my next tune from lex. |
![]() | | #26 | ![]() |
| Not Ranked : 0 score @Stew; How does the 3.5" intake fit with the s3? Did you relocate your battery before you swapped the s3?
| MS6 BNRS3 | kish89 | Mazdaspeed3/6 General Discussion | 9 | 08-20-2013 03:22 AM |
| First Install Cobb SRI/TIP/Airbox looking for TIP install video? | Phog | Mazdaspeed3/6 General Discussion | 3 | 12-14-2012 04:26 PM |
| What to install/not install for autocross. | maisonvi | Auto-X / Road Racing / Time Attack | 17 | 06-22-2012 09:02 AM |
