Like Tree6Likes
 Old 08-12-2014, 09:32 PM   #1
Bulgsta's Avatar
Posts: 120   (View Stats)
Bulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond repute
I did not run the wastegate dump tube in the same hole as the downpipe. There is an opening to the left (passenger side) of the downpipe. What I did is crushed the tip of the dump tube so it would slide in there.
File Type: jpg 10402813_10152510648145962_3037498613005323568_n.jpg (206.4 KB, 22 views)
2007 Mazdaspeed 6
GTX3076 - CPE- EX-mani w/ 44mm EWG - CPE Safe Seals - COBB APv3 - COBB Shifter Weight - DO Stage 2 Meth - PnP Intake Mani - Catless TBE - Corksport FMIC - Corksport Rear Diff Mount - Corksport OCC - AWR RRM, TMM, PMM - TT Front Engine Mount - TT Front Diff Mount - HTP 3.5 " - GFB 50/50 - AT internals - GrimSpeed ECBS - 3 Bar Map - Perm PCV plate - JBR BSD w/ baffle - JBR TIGS - Sure Shortcut - Tower Strut Bar - EGR Delete - EGR Valve Deleted - Shifter Bushings - H&R Springs - Koni Yellow Shocks - Stoptech D&S rotors - EBC Pads - Stainless Steel Brake Lines - Denso ITV 22 - Whiteline RSB - Guardian Angel
Bulgsta is offline   Reply With Quote
Wes' 2010 GTX3076 build Wes10S3 2010 MS3 - Build Diaries 7 08-02-2014 11:04 AM
447HP GTX3076 Lakespeed6 MazdaSpeed 3/6 - Dyno Sheets/Discussions 31 02-23-2014 01:44 PM
MonkTuning GTX3076 mrmonk7663 2010 MS3 - Big Turbo Builds 17 12-08-2013 10:36 PM
Mazda 6 MPS GTX3076 1.06 tial Vadim aka ScooteR MazdaSpeed 3/6 - Dyno Sheets/Discussions 4 10-15-2013 12:51 AM
Page generated in 0.25943 seconds with 22 queries
