Like Tree6Likes
 Old 05-22-2014, 06:38 PM   #1
Bulgsta's Avatar
Posts: 120   (View Stats)
Bulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond repute
Default MS6 GTX3076 EWG
Figured I would do one of these too.
2007 Mazdaspeed 6 51K miles
Parts list:
GTX3076
Tial 44mm EWG
CPE Exhaust Mani
PNP Intake Mani
CPE Safe Seals
Stage 2 DO Meth
PERM PCV plate
HTP 3.5 " intake
3 Bar
Guardian Angel
Front Engine Mount
Had to take a before picture. Not the cleanest engine bay
Ended up getting the wrench that was wedged between my engine and transfer case for the past year YAYYY great success!
All torn out
Flat black valve cover? Why not
And here is when the fun begins. Have to start with turbo comparison
CPE mani and DP bolted on. I could not imagine would it would be doing this while either the turbo or the mani was on the car..
What I ended up doing is mounting all the lines on the turbo prior to dropping it all in.
Here is some sweet brazing work. I ended up not using the 90 degree elbow and brazing a whole new 45 degree so it would better align with the cut oil return line
When dropping the CPE mani in as mentioned before... take out the windshield crawl. Spend the 10 minutes but it will make your installation a breeze.
Here it is dropped in
Fabbed up a meth tank bracket and put the pump right under it with another bracket that is invisible from the carpet
Cleaned the valves and no the valve was not open when i cleaned it
Update 05/23/2014
Finished my oil catch can setup with dual port Perm PCV plate
Intake Mani going in
The gunk that was built up in the old IM.
Front and the back of the engine are back together. Except for the EWG and screamer pipe which will be done soon. Time to work on the side
Update 05/26/2014
Fabbed up my screamer pipe
fitment is perfect on it. cant wait to hear it.
Update 05/27/2014
Its up and running
2007 Mazdaspeed 6
GTX3076 - CPE- EX-mani w/ 44mm EWG - CPE Safe Seals - COBB APv3 - COBB Shifter Weight - DO Stage 2 Meth - PnP Intake Mani - Catless TBE - Corksport FMIC - Corksport Rear Diff Mount - Corksport OCC - AWR RRM, TMM, PMM - TT Front Engine Mount - TT Front Diff Mount - HTP 3.5 " - GFB 50/50 - AT internals - GrimSpeed ECBS - 3 Bar Map - Perm PCV plate - JBR BSD w/ baffle - JBR TIGS - Sure Shortcut - Tower Strut Bar - EGR Delete - EGR Valve Deleted - Shifter Bushings - H&R Springs - Koni Yellow Shocks - Stoptech D&S rotors - EBC Pads - Stainless Steel Brake Lines - Denso ITV 22 - Whiteline RSB - Guardian Angel
Bulgsta is offline   Reply With Quote
The Following 19 Users Say Thank You to Bulgsta For This Useful Post:
5LOWMS6 (05-26-2014), Code Monkey (05-22-2014), crazyp (05-22-2014), cshunter (06-09-2014), Downmented (06-04-2014), EricLee23 (06-10-2014), impossible (06-04-2014), jambisgone696 (06-09-2014), kbz0129 (08-02-2014), Lex (06-08-2014), Mazdazilla6 (06-04-2014), Micha (05-22-2014), ms6mil (05-28-2014), rymanmazda (05-27-2014), SamiChicago (05-28-2014), sidekick (07-24-2014), SpeedRebirth (05-22-2014), Status Update (05-28-2014), XxSmarTz (05-27-2014)
 Old 05-22-2014, 07:23 PM   #2
mr.speedy3's Avatar
Posts: 1,690   (View Stats)
first
please make me super pissed off for not going EWG with my GTX3076...
I want videos!
 Old 05-22-2014, 07:31 PM   #3
Bulgsta's Avatar
Ewg is the way to go.
Once it's up and running and tuned I'll get some videos going
2007 Mazdaspeed 6
The Following User Says Thank You to Bulgsta For This Useful Post:
mr.speedy3 (05-22-2014)
 Old 05-22-2014, 07:31 PM   #4
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
I need to paint my VC
have fun!
 Old 05-25-2014, 02:12 PM   #5
2011speed's Avatar
Posts: 1,497   (View Stats)
Subbed for ewg vids lol. We have similar builds I'm stoked
FreeKtuned
fitty fitty
 Old 05-27-2014, 09:38 PM   #6
Bulgsta's Avatar
Well its up and running. got it started. no visual leaks for now. Started it really late (8 pm) so I could not really look for leaks from every part I have touched. Too much air in the coolant so my engine temp went up to 235 at which point I decided to cut it for tonight. I will run it tomorrow again hopefully get the coolant circulating normally.
From what I could tell it is circulating. since it went from 190 to 235 in about 30+ minutes. If there was no coolant it would of overheated in a heart beat.
Ill give an update to what happens.
Before and after pic
2007 Mazdaspeed 6
The Following 6 Users Say Thank You to Bulgsta For This Useful Post:
alaskazero (06-10-2014), BLKSTIG (05-28-2014), cshunter (06-09-2014), impossible (06-04-2014), ItsNox (05-28-2014), rymanmazda (05-27-2014)
 Old 05-28-2014, 10:37 AM   #7
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
let us know about how it drives and react!
Good job!
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 05-28-2014, 07:38 PM   #8
JDMCRX's Avatar
Posts: 128   (View Stats)
JDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond reputeJDMCRX has a reputation beyond repute
Groaned at 18 Times in 6 Posts
Looks good man. Does the car shake a lot with that front engine mount? Also post vids up
JDMCRX is offline   Reply With Quote
 Old 05-28-2014, 08:24 PM   #9
ItsNox's Avatar
Posts: 3,076   (View Stats)
After shot looks really nice and clean man. I'm interested to hear about the TT front engine mount as well. And what brand is that tower strut bar?
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
 Old 05-28-2014, 08:29 PM   #10
Bulgsta's Avatar
I need to break the turbo in first before I let you guys know about the front engine mount vibrations. At low speeds it feels the same as when I had the AWR trilogy. But yet again I dont have a balance shaft... girls love this car. Free vibrator
As of now I have 10 miles on the turbo. Needs a proper tune since I am knocking like crazy at no boost and low rpm.
I will keep you guys posted.
Vids will be soon when I start tuning and pushing the car
2007 Mazdaspeed 6
ItsNox (05-28-2014)
 Old 05-28-2014, 08:36 PM   #11
Bulgsta's Avatar
and the tower strut bar is off of ebay. no name brand
M2 Performance Manzo USA Front Upper Strut Bar Fits Mazda 6 2003 2008 | eBay
Does not work with a TMIC
2007 Mazdaspeed 6
ItsNox (05-28-2014)
 Old 06-03-2014, 06:19 PM   #12
levon.mark's Avatar
Posts: 268   (View Stats)
Groaned at 9 Times in 4 Posts
great build.. saw it on instagram while back.. btw if you see cruise knock that is normal.
YEEMARKS
Old Time in S3:
12.4 @ 111
The Following 2 Users Say Thank You to levon.mark For This Useful Post:
Bulgsta (06-03-2014), Lsmspeed53 (07-16-2014)
 Old 06-03-2014, 06:26 PM   #13
Bulgsta's Avatar
Haha well it was about time I got the car running. Took my sweet time with every part of it.
Now that she is running. I rarely see any knock. And if any, it is very minimal.
The EWG is really loud. Tried getting some videos up but having 4 engine mounts all the highest duro I could get and no balance shaft made too much cabin noise to really hear the EWG. Not to mention the vibration
2007 Mazdaspeed 6
 Old 06-03-2014, 06:40 PM   #14
maddocx240's Avatar
Posts: 823   (View Stats)
Nice setup! Where in Long Island are you located? Like the all black valve cover and manifold too!
The Following User Says Thank You to maddocx240 For This Useful Post:
 Old 06-03-2014, 06:52 PM   #15
Bulgsta's Avatar
Thank you I am located in east Rockaway. Right next to Lynbrook.
2007 Mazdaspeed 6
 Old 06-03-2014, 07:09 PM   #16
mr.speedy3's Avatar
Where are the videos?
 Old 06-03-2014, 07:32 PM   #17
Bulgsta's Avatar
I tried taking videos. You can barely hear it from all the cabin noise. I gotta have a car next to me recording it. I'll get you guys videos no worries
2007 Mazdaspeed 6
 Old 06-03-2014, 08:31 PM   #18
mr.speedy3's Avatar
Tbh, same with me. Car is a different car when inside and out lol.
tapatalkin
The Following User Says Thank You to mr.speedy3 For This Useful Post:
 Old 06-03-2014, 09:41 PM   #19
Bulgsta's Avatar
" JBR Trilogy, BSD (the car is instant foreplay for any passenger) "
Now add a front engine mount to that too and then try recording anything inside the car. 3.5K rpm = wet panties
mr.speedy3 likes this.
2007 Mazdaspeed 6
 Old 06-04-2014, 08:09 AM   #20
mr.speedy3's Avatar
Speed3 has no front mount, so no wet panties
 Old 06-04-2014, 08:30 AM   #21
Bulgsta's Avatar
I'm sure when your gtx spools up there are
2007 Mazdaspeed 6
mr.speedy3 (06-04-2014)
 Old 06-04-2014, 10:23 AM   #22
mr.speedy3's Avatar
Well... At that point, they have no choice lol
tapatalkin
Bulgsta (06-04-2014)
 Old 06-04-2014, 12:10 PM   #23
What you talkin bout willis?
Turbine Tech Inc.
 Old 06-04-2014, 12:38 PM   #24
mr.speedy3's Avatar
Turbine Tech Inc.
What in the actual fuck.
 Old 06-04-2014, 01:00 PM   #25
Bulgsta's Avatar
Time to spend more money
2007 Mazdaspeed 6
 Old 06-04-2014, 03:29 PM   #26
mr.speedy3's Avatar
Hahaha I just bought some 10mm spacers lugs and ARP studs... Tired of these stock ones striping... On top of that, I need to find coin for some nt05s so I can hold down this power...
tapatalkin
 Old 06-08-2014, 08:29 PM   #27
maddocx240's Avatar
Oh ok. You ever been to a nator meet? A lot of them are from long island, you should check it out.
 Old 06-08-2014, 08:31 PM   #28
Bulgsta's Avatar
Been to a few but they are on a Thursday and im kind of busy.
I was at the last OCC meet though. The car did not look anything like this though
2007 Mazdaspeed 6
 Old 06-08-2014, 08:37 PM   #29
maddocx240's Avatar
Yea thursdays are no good for me either. How's the car running so far?
 Old 06-08-2014, 08:40 PM   #30
Bulgsta's Avatar
It was running awesome for the past 2 weeks.
Recently i got a boost leak somewhere in the line. Today pressure tested and I cant find it. i have to look into it more.
The car has trouble boosting. and it is running very rich when i shift so i am suspecting it is from the BOV. good thing I have my forge BPV still so when I get a change I will put it in and see
2007 Mazdaspeed 6
 Old 06-09-2014, 07:49 AM   #31
maddocx240's Avatar
You checked all your fmic piping/couplers? Are you self tuning the car?
 Old 06-09-2014, 10:04 AM   #32
Jeff23spl's Avatar
The bov leaking is probably the first place to check if you don't see any leak going outside and then maybe a pcv for the OCC.
As long as the A/F is too rich, it mean that some air passing thru the maf is escaping somewhere out of the engine without beoing burned.
Wife drive 2010 CX7
 Old 06-09-2014, 02:16 PM   #33
Bulgsta's Avatar
Doubt it's the pcv going to the catch can. It goes IM-->pcv-->occ-->check valve-->crank case.
I checked all the piping in the engine bay and they seem fine. I have 4 couplings behind the bumper so I will have to pop that out and see them.
I did find a leak coming from the bov gasket which I fixed by putting some silicone on it. But still no boost... Idk I will try few more things and let you guys know what I find
Let me correct that. I do see boost. It climbs up veeeery slowly. At 7k rpm I am getting 17 psi. Compared few logs and I was hitting full boost at 4k now I get 5 psi
2007 Mazdaspeed 6
Last edited by Bulgsta; 06-09-2014 at 02:16 PM. Reason: MSF Database - Automerged Doublepost
 Old 06-10-2014, 04:50 PM   #34
mr.speedy3's Avatar
Exact thing just happened to me. Ended up blowing my bpv gasket in half because one of the nuts on my flange for the bpv backed out. So I'd boost, bpv would lift a little because no nut, then destroyed the gasket. I bought one from turbosmart (even though you have forge, the flange should be the same) and scanned it into my computer and made a printable template If you want to make another one. Autozone sells gasket material. I outlined it and had my lady cut it out because she has much steadier hands.this was of course before I bought the replacement.
I plan to CAD the gasket but for now it works. Lete know If you want it lol.
tapatalkin
 Old 06-10-2014, 05:41 PM   #35
Bulgsta's Avatar
I have a go fast bits bov on the car right now. The gasket was leaking so I fixed it. Now it still does not hold the pressure when I fill up the system with the compressor. Found a leak on my intake mani gasket. Bolts guess came loose from all the vibration. Have to start putting locktite on them.
Now my question is: say I pump the system to 13 psi, should it hold 13 until I let it out or is it normal for some to escape.
I will go more into it this weekend and try to find anything else loose
2007 Mazdaspeed 6
 Old 06-14-2014, 09:13 AM   #36
Bulgsta's Avatar
I can not figure out what the problem is. I pressure tested the car found few minor leaks which I fixed but I am still running too rich and do not boost properly.
When I pressurize the system it very slowly drops down to 0 psi on my gauge. So I figured even if there was some kind of a leak I would still be able to boost with just a minor leak. But that not the case.
Here are 2 log : log 28 is idle on a cold start. fuel trims are at -12
log 29 is a drive around the block. you can see that every time i release the gas my fuel trims spike to -26 because my afrs are all over the place
2007 Mazdaspeed 6
 Old 06-14-2014, 10:05 AM   #37
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
Do your ltft ever go positive? Just curious for my own troubleshooting.
 Old 06-14-2014, 10:10 AM   #38
Bulgsta's Avatar
Haven't really payed attention to them that much. Usually from what I've seen is they stay around 0
2007 Mazdaspeed 6
 Old 07-15-2014, 11:34 PM   #39
Bulgsta's Avatar
Quick update:
After all this pressure testing and smoke testing I found out why the turbo was not spooling. My IWG bracket came off and the IWG was fully open at all times -__-
Pressure testing at its finest
2007 Mazdaspeed 6
The Following 3 Users Say Thank You to Bulgsta For This Useful Post:
Code Monkey (07-16-2014), impossible (07-16-2014), ItsNox (07-16-2014)
 Old 07-16-2014, 06:37 AM   #40
ItsNox's Avatar
Quick update:
Hahah when I first looked at the picture I was like "WTF why is he using beer bottles as part of his intake/ic tubing?!"
Keep the updates coming!
Sent from my SPH-L710 using Tapatalk
'06 Mazdaspeed 6 GT
- Miltuned
Wes' 2010 GTX3076 build Wes10S3 2010 MS3 - Build Diaries 7 08-02-2014 11:04 AM
447HP GTX3076 Lakespeed6 MazdaSpeed 3/6 - Dyno Sheets/Discussions 31 02-23-2014 01:44 PM
MonkTuning GTX3076 mrmonk7663 2010 MS3 - Big Turbo Builds 17 12-08-2013 10:36 PM
Mazda 6 MPS GTX3076 1.06 tial Vadim aka ScooteR MazdaSpeed 3/6 - Dyno Sheets/Discussions 4 10-15-2013 12:51 AM
Page generated in 0.58515 seconds with 31 queries
