 Old 08-22-2011, 11:54 AM   #1
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Default Me three goes ATP 3071
Bought the tc from a dude going by the name of Roadblock.
Ported exh. gas housing and coated with Tech Line Turbo X.
MAC 3 way solenoid in interrupt with flow control valve on exit port going to wastegate actuator.
DIY support bracket holding terboh on one of the DP bolts going into exh gas housing
Still running ETS top mount.
Originally I wanted to run the flow control valve on the compressor housing but then after deeply reflecting on the practicality of this I had an epiphany and relocated it to the port on the solenoid.
Fobio (08-22-2011), PunjabiPlaya (08-22-2011)
 Old 08-22-2011, 11:57 AM   #2
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
Hey Tomas...you got your WGA running alright? I got mine fixed now, but I doubt my values are suitable for you to run. I'm running a ~8psi spring pressure and my WGDC is in the 90's and 100. Lemme know.
-- Mario Andretti --
The Following User Says Thank You to Fobio For This Useful Post:
Tomas (08-22-2011)
 Old 08-22-2011, 07:47 PM   #3
Bob Ross Fanclub
Tomas's Avatar
Hey Fobio,
Yeah, wg actuator is running fine. I am gradually adjusting duty cycle and boost up. I am also experimenting with the flow control valve. If your WGDC is in the nineties and higher you probably need a smaller orifice in your restrictor if you have one at all. the flow control valve is neat because you can decrease the flow till you start seeing boost spikes and then you are set.
Fobio (08-23-2011)
 Old 08-22-2011, 10:52 PM   #4
How do you like it?
 Old 08-23-2011, 06:35 AM   #5
Bob Ross Fanclub
Tomas's Avatar
Too early to tell Lex. Need about a week or two to get my tune up to spec. At the low boost pressures I am running now the thing is obviously incredibly smooth. The itchiness of the throttle is all but gone. You stab the gas from 3K and there is 8-9 psi right there which feels like a soft breeze on a baby's arse. Its just super ghey.
At the moment I am at around 30-35% WGDC and aiming for 170 load from 4K to red line. WGDC is only enough to get me 10-12 psi and about 150 load. I will continue increasing WGDC till I get load up to 170 and then adjust load and consequently DC and see where that leaves me. This all with no meth. Then the meth comes on. And then it gets gheyer than ever.
jracer (08-23-2011), Lex (08-23-2011)
3071 HOW TO: MSP6COP MazdaSpeed 6 - How-To's 59 08-22-2011 02:37 AM
T3 3071 EWG = 400hp ? jracer MazdaSpeed 3/6 - Turbo Induction 11 08-19-2011 11:47 PM
ATP 3071 IWG Size vbt101 MazdaSpeed 3/6 - Turbo Induction 6 05-30-2011 12:36 AM
Page generated in 0.26499 seconds with 22 queries
