 Old 11-25-2010, 04:47 PM   #1
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
Default Motor build parts list ?
Well it seems alot of BT builds are going on and some full engine builds. Maybe someone with the know how could maybe make a sticky post on a parts list needed..
items like what bearings, gaskets ect...
main bearings
rod bearings
thrust washer
timing chain
timing chain tentioner
main seals
i know thats the basics, but i was wondering what gaskets are needed ?? do you really need to buy a whole mazda gasket kit ?? what bolts are needed ?? ( crank bolt, flywheel bolts ?)
just a idea so when someone starts a build we could have a shopping list so to speak of whats needed. and if someone wants to get real crazy list part numbers too i guess..
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 11-25-2010, 05:14 PM   #2
jracer's Avatar
Groans: 89
maybe add pics from marks motor build ..
link...
http://www.mazdaspeedforum.org/forum/foru...s-build-22217/
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 11-25-2010, 05:18 PM   #3
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
u can reuse chain and chain tentioner
u need a flywheel bolt and crank bolt
its cheaper to get the gasket kit
also you need arp studs head/main
If you wana a parts list just go on streetunit.com they give you a detailed list of what you need. You can also contact Mark he can help you with any questions in reguards to parts needed to build. I almost positive he has supplied the parts for all the builds on here.
hope this helps
The Following 2 Users Say Thank You to NJSPEED3 For This Useful Post:
jracer (11-25-2010), madvillain (12-21-2010)
 Old 11-25-2010, 05:26 PM   #4
jracer's Avatar
Groans: 89
yeah the streetunit guys are great.. most the stuff on my car is from them.!! good peeps.!
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 12-21-2010, 01:19 PM   #5
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
i think a sticky on this would be a good idea
The Following User Says Thank You to xcoldricex For This Useful Post:
NJSPEED3 (12-26-2010)
 Old 12-22-2010, 12:38 PM   #6
essejkcamraw's Avatar
Posts: 922   (View Stats)
your main parts list will consist of this.
Flywheel Bolts
Mazda OEM Crank Pulley Bolt
Complete OEM Engine Gasket Kit
ARP Head Studs
ARP Main Studs
Mazda OEM Rod Bearings
Mazda OEM Main Bearings
Mazda OEM Thrust Washer
Rear Main Oil Seal
OEM Water pump
OEM Oil pump
really only need water/oil pumps if you have 50k+ on your motor.
(not to mention rods pistons and machine work of course)
it's a pretty expensive and PITA process. but you should go for it so theres a built BT ms6 running around these parts.
The Following 2 Users Say Thank You to essejkcamraw For This Useful Post:
NJSPEED3 (12-26-2010), tbot (12-22-2010)
 Old 12-25-2010, 06:20 PM   #7
MS3KO's Avatar
Posts: 579   (View Stats)
MS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the world
Bump for an awesome information!
2009 MazdaSpeed 3 Metro Grey-T3 Gt3071, Re-flanged RR mani, 44mm Tial WG, Cusom DP, Custom 4in to 3.5in intake, Custom 3.5in maf, Custom FMIC kit, Tial BOV, EVO Prosport Boost gauge, EVO oil temp gauge, AEM wideband, TRZ RMM, JBR PMM, JBR TM, JBR Shifter Plate, TWM SS, Hks CBE, COBB AP, Road Magnet Springs.
PERM Tuned!///389hp 360tq///Best time:12.2 @117 (with new tires 11's here i come!)
Hit up BC Autoworks for all your powder coating needs!
MS3KO is offline   Reply With Quote
list of guys that has built motor and upgraded turbos johnac08 MazdaSpeed 3/6 - Turbo Induction 13 02-16-2010 06:35 PM
Parts suppliers dominate list of top creditors Haltech Automotive News 0 04-30-2009 03:10 PM
Motor Trend releases annual industry Power List Haltech Automotive News 0 12-30-2008 01:10 PM
New Parts List w/potential release dates whoosh@Realtune Mazdaspeed3/6 General Discussion 3 04-03-2008 09:02 AM
Page generated in 0.27433 seconds with 24 queries
