![]() | | #41 | ![]() |
![]() Join Date: Feb 2011 Location: Lusby, MD
Rep Power: 496 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 119
| Not Ranked : 0 score
__________________ 06 MS6 |SP Built motor - Weisco Pistons .020" over, Manley H-Beam Rods, Ported Head, Ported Intake, VTCS Delete, BS Delete, VVT Actuator, Keyed Crank, 6th Port Fuel Injection | ACT 6 Puck w/ Streetlite Flywheel | Bullseye S259 .70 A/R Single Scroll | 3.5" Intake/MAF Housing | Steedspeed Twin Scroll T3 Top Mount Manifold | Tubosmart 40mm EWG | Custom DP | Custom TBE | Custom LTA Intercooler | HKS Type IV TT | Dashhawk | COBB AP | AWR RMM | PTP HPFP Guts | KILLAH BUILT |
![]() | | #42 | ![]() |
![]() Join Date: Dec 2009 Location: layton, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 122
(Thread Starter) | Not Ranked : 0 score so i got a mediocre amount done to the car this weekend.... My ambitions were to clean my intake valves and install my Perrin EBCS... Got all of it done except for cylinder 3's intake valves (i believe thts the right cylinder or cylinder 4....second cylinder from the right if looking at the front of the car correct?) here's some pics of what i got done ... PRE intake valve cleaning and post intake valve cleaning( this also took about 1 full can of b12 chemtool to clean each cylinders set of intake valves if anyone wanted to know) P.S. i also changed my oil in e34 bmw 520i also replaced all vacuum lines and bought some new tools and a whole new tool box... pics included!!!
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna |
| The Following User Says Thank You to MSP611 For This Useful Post: | dougefresh_ (03-06-2012) |
![]() | | #43 | ![]() |
| Not Ranked : 0 score Yup, it's Cyl 3. Cyl 1 is the farthest left when looking at front of car, and they just count to the right in order. Great improvement on the valves man. Good job.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
| The Following User Says Thank You to djuosnteisn For This Useful Post: | MSP611 (03-06-2012) |
![]() | | #44 | ![]() |
(Thread Starter) | Not Ranked : 0 score @djuosnteisn ya i should get cylinder 3 done this week or weekend and hopefully get my fuel pump internals done as well... i really need a vice though, does anyone have a confirmation tht you really need a vice to change your fuel pump internals? Also i need a different site than fastenal to get new injector studs... does anyone have a different website to get the studs? @dougefresh
![]() | | #45 | ![]() |
(Thread Starter) | Not Ranked : 0 score @dougefresh_ ^^^
![]() | | #46 | ![]() |
| Not Ranked : 0 score I've heard of people doing hpfp internals with an impact gun and no vice. Probably do able. Check with @burn813, and maybe he could offer a few tips. On the studs, i just bought some at the local ACE hardware store.
![]() | | #47 | ![]() |
(Thread Starter) | Not Ranked : 0 score @djuosnteisn its gunna be hard to go to a local ace hardware here in germany... i dont speak the best german and that kinda of stuff is hardly translatable, but well see if they have the same pitch and dimension studs at my local place called "Hela"
| The Following User Says Thank You to MSP611 For This Useful Post: | djuosnteisn (03-06-2012) |
![]() | | #48 | ![]() |
![]() Join Date: Mar 2008 Location: W. Suffield, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 674
| Not Ranked : 0 score I bought my studs at sears. They had only two 50mm so I got 2 of those, two 46mm and four like 40mm I think. 50mm would not work as they were not threaded far enough down. 46mm worked but they only had two so I used those and two of the shorter ones that just worked. wores comes to wors you could cut an M8x1.25 bolt, clean up the threads and use it as a stud...for that matter you could also use bolts. I would say 40mm bolts would be pefect. |
| The Following 2 Users Say Thank You to aviator79 For This Useful Post: | djuosnteisn (03-06-2012), dougefresh_ (03-06-2012) |
![]() | | #49 | ![]() |
(Thread Starter) | Not Ranked : 0 score @aviator79 by using bolts u mean get the right size bolts then dremel the heads off?
![]() | | #50 | ![]() |
![]() Join Date: May 2010 Location: West Palm Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,842
Groans: 819
| Not Ranked : 0 score impact gun is good for the internals |
| The Following User Says Thank You to Monotonous ONE For This Useful Post: | djuosnteisn (03-06-2012) |
![]() | | #51 | ![]() |
(Thread Starter) | Not Ranked : 0 score dont have a compressor just yet... will be my next big purchase next check... i do have a 3/8ths drive brand new snap on impact gun though tht i got for free
![]() | | #52 | ![]() |
| Not Ranked : 0 score Get an electric impact gun.... WAY better than air gun.
![]() | | #53 | ![]() |
![]() Join Date: Jul 2009 Location: South Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,578
| Not Ranked : 0 score Looks like they already got places for the studs/nuts covered. Only other place I've heard of is PTP. I got mine from fastenal.
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] |
![]() | | #54 | ![]() |
(Thread Starter) | Not Ranked : 0 score rog^^^ will look local i guess first, its gunna take some research though and some broken ass German lol... then ill try maybe ptp or ordering them from like auto-zone or something... fastenal wouldn't ship to me for some reason even though the package would be tiny
![]() | | #55 | ![]() |
![]() | | #56 | ![]() |
(Thread Starter) | Not Ranked : 0 score ya i know the purpose of the new studs im just trying to find the best fix for the studs if i cant find them here locally
![]() | | #57 | ![]() |
| Not Ranked : 0 score In for 'tries to order a set of nuts/studs, ends up ordering a German transvestite by mistake'
![]() | | #58 | ![]() |
(Thread Starter) | Not Ranked : 0 score ya i know its fucking ridiculous tryin to speak to the old germans here cuz they dont speak shit for english and my german isn't the best
![]() | | #59 | ![]() |
| Not Ranked : 0 score you think germany is bad...try okinawa. japanese is the biggest pain in the ass to understand/speak/read
![]() | | #60 | ![]() |
| Not Ranked : 0 score I thought it was women
![]() | | #61 | ![]() |
| Not Ranked : 0 score yea good point lol
![]() | | #62 | ![]() |
(Thread Starter) | Not Ranked : 0 score hoping to get a shitload done this weekend... we will see though
| The Following User Says Thank You to MSP611 For This Useful Post: | dougefresh_ (05-27-2012) |
![]() | | #63 | ![]() |
(Thread Starter) | Not Ranked : 0 score Alright so i got a shitload done today. I also decided to wait to do my venturi setup on my OCC till i get back to the states (about a month till i go back) since i have a welder and the tools there, i can do it myself. So got the PG reworked turbo fully installed, my wrapped stock exh. mani fully installed and my M2 DP fully installed. Tomorrow i will try to tackle the Perrin EBCS and my FMIC... Also mayb do the EGR delete and the TB coolant bypass... Here's some pics of the progress (still need to finish the port and polish and VCTS delete on my intake mani. Tht shit takes forever to get looking right and not fuck it up.)
![]() | | #64 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 492
Groaned at 20 Times in 11 Posts
| Not Ranked : 0 score is that pipe touchin the pto, cant tell |
![]() | | #65 | ![]() |
(Thread Starter) | Not Ranked : 0 score no not touching just a shitty angle... there's ample room
![]() | | #66 | ![]() |
(Thread Starter) | Not Ranked : 0 score alright guys so im finishin up the build this week. i am going to be runnin an ap (obviously).... what base tune should i run? i will have the fuel pump internals as u can see, should i run a safety tune or ne thing of tht sort? After the break in period of the internals, what tune should i start with? and should i do MAF cal right away? This is my first adventure really tuning so any info greatly appreciated. (all mods r in sig)
![]() | | #67 | ![]() |
(Thread Starter) | Not Ranked : 0 score alright guys here's and update... i dunno if you saw, but i made a thread of a possible Zoom Zoom Boom.... Well its almost certain now tht i have bent a rod. Without having the time or stuff to do it here i will be waiting on my cars return to California (where im moving back to next week). I will be enlisting the help of my grandfather hopefully to help me pull the motor. He also has some hookups on some machine shop work tht i will be using to look over my block and my head and fix ne problems they seem fit and prob assemble my short block... From there i will obviously be going forged since its a waste of time to tear motor out otherwise and might as well go for the whole kit and kaboodle with a big turbo. Alright here's what i have in mind or what is up for debate: GT3582 T3 divided .86 A/R with Anti surge housing (still want a quicker spool) Steedspeed t3 divided manifold with 44mm EXT WGA DJ's custom top mount kit for the DP and intake/oil and coolant lines Maybe run my same intercooler, thts up for debate as well K1 rods and Wiseco pistons, Definitely up for debate just wat ive seen used most with success, plus the price explains itself Everything else except for odds and ends i think i have already... will be selling all my KO4 stuff. i think im going to try to shoot for 500AWHP if i can, does tht sound unreasonable on this setup? Will most likely try running meth injection or e85 either one. Give me your suggestions on the setup, car will be weekend car still with some track time. (mostly road course and drags)
![]() | | #68 | ![]() |
(Thread Starter) | Not Ranked : 0 score update... back in cali and gettin the money together for my BT build. will need about 5k for everything or so I'll keep u updated Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
| The Following 2 Users Say Thank You to MSP611 For This Useful Post: | djuosnteisn (09-11-2012), Monotonous ONE (09-11-2012) |
![]() | | #69 | ![]() |
| Not Ranked : 0 score Props for not giving up man. DJ hit 500 with a s300 so you should be able to hit 500 with the 35r. May wanna look into the DSS axle if youre takin it to the strip and dont plan on creeping off the line.
| The Following User Says Thank You to Navy_Mech2 For This Useful Post: | djuosnteisn (09-25-2012) |
![]() | | #70 | ![]() |
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna | |
![]() | | #71 | ![]() |
| Not Ranked : 0 score Haha good shit man. What branch were you in? I just hit 6 years in the Navy this month. I think the borg warner turbos are really under utilized by this platform...even though they may take a little more effort to make work than the GT series turbos. This winter im swappin to a top mount S259 with a twin scroll manni as well. DJ's car is a monster though... Have you looked into cams at all to try and extend the powerband on the back end a little bit?
![]() | | #72 | ![]() |
![]() | | #73 | ![]() |
(Thread Starter) | Not Ranked : 0 score so I know ive been procrastinating... I know I know its stupid and sux. Now tht I have a legit ass job with G&E... so my build plans have changed slightly and am open for suggestion since I am no expert in this field but am a good tech. have been looking at the borg warner EFR series turbos.. more specifically the 7163 t4 twinscroll .94 A/R.... im goal is to make 500awhp/500awftlbs.... I want this to be a quick spooling vehicle though is the kick since it will be mostly used for canyon and mountain type/ open mountain roads. any suggestions on turbos. I am looking to have all the parts by January time from because tht is when I come home from Saudi. money is not a super factor anymore with this new job. still looking for a machine shop in northern California that can do me good. any suggestions? obviously all supporting mods will be done I.E jmf mani with 1000cc injectors, full mounts etc etc so lets see your suggestions
![]() | | #74 | ![]() |
![]() Join Date: Jun 2013 Location: Everywhere
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Did this build ever become anything? |
![]() | | #75 | ![]() |
(Thread Starter) | Not Ranked : 0 score I have changed my build plans again. I will be running the kozmic kit with a precision 5858 to save some money... will be changing jobs to Abu Dhabi and I only get to come back to states once a year for 30days as of right now. it fuckin sucks couldn't get much done on car this last trip home. I have my own garage now as well so I don't have to be doin this in someone elses anymore. its been a long time comin, but im not givin it up.
![]() | | #76 | ![]() |
(Thread Starter) | Not Ranked : 0 score ok the BIG UPDATE... you guys have seen me floating around still.. well my car hasnt been running for quite some time, becuz i tried to open a business in texas when i first got out of the military and it failed becuz my fuckin meth head partner (didnt know he was into hard shit when we started).... Also ran into problems getting a spare block and head but finally got them all sorted out.. First block i got was shipped not so well and it got damaged in the shipping process, so i had to find another full short block to build tht was good and would get messed up in shipping again.. P.S paypals buyer protection blows wieners, they make u pay to ship w.e u got tht was fucked up back so essentially u lose out on money becuz of the original sellers shipping habits. anyways, now tht i have a steady job, money saved up and a way better income i am finally doing the build. List of new parts: Built block by Jordan Keefover .020 wiseco pistons H-beam rods Clevite bearings freshly rebuilt head with pinned cams, VVT, and sprockets Crower 65lb valve springs pinned sprockets and crank N2MB wot box custom intake fuel pump with dual deutschwerks pumps and a return style system Fuel lab FPR Kozmic 6th port kit with upgraded bosch 2200cc injectors AFI stock position exh. mani t3 flanged Relentless customs, custom 3.5" intake (will be shipped this weekend) stock ported intake mani with vcts delete (still needs to be sent out) Schrothe 4 pointe rallye harnesses Ortiz customs, first custom dual steering column gauge pod (will be shipped this week) SP63 PNP map harness Redline goods custom ebrake boot, shift boot and steering wheel cover AEM wideband/UEGO failsafe gauge and single gauge pod Grimmspeed or SP63 ECBS (forgot which one i bought lol) Front bumper blue Quick latches Tial 44mm exh. waste gate with dump tube JBR vented occ along with my already installed saikou michi OCC WRX STI front lip Still need to purchase: PTE 5858 t3 .82 A/R Enkei 17x9 PF01SS +43 Hankook RS-3's 245/40/17 5mm spacers Bilstein b6 sport struts H&R springs (will be temporary till i can get corner balanced and send struts off for revalving) Corksport BBK (suggestions here, not many options) Send in Intake mani for porting and powdercoat Fluids 3" intake piping for front brake ducts 2" intake piping for rear brake ducts AUX fan controller (this needed?) Oil temp gauge (suggestions?) Boost gauge (suggestions?) Battery relocation (suggestions?) Optima yellow top battery (suggestions?) Hubcentric 67.1 rings Muteki SR48 blue lug nuts Now wat i need to remove from the car/extras i wanna do: Custom front crash bar or crash bar delete Delete rear crash bar Power steering delete Have car corner weighted/balanced Interior dash lights all changed to Blue/white LED's Duct the FMIC and radiator in like @Code Monkey; Car will be tuned by Purple drank tuning!!! Also will be getting a shitload of new tools so i might post some pics up of those... I have attached pics of all the shit i have... motor will not be shipped to me until right before i come home so it doesnt sit around with no oil in it for a long period. This will all be gettin accomplished in beginning of february 16'... Shout out to all the dudes helpin me out with parts and all @LumberJack; @keefover; @purpledranktuning; @Rambo; (dont remember his MSF name either) for the custom intake, @SwizzleSpd; @Z32_MS3; @mxlplx71;
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna Last edited by MSP611; 09-25-2015 at 09:45 AM. |
| The Following 3 Users Say Thank You to MSP611 For This Useful Post: |
![]() | | #77 | ![]() |
![]() Join Date: Feb 2012 Location: davenport, iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 128
| Not Ranked : 0 score i'd wait on the fan controller. i never had one on my three or six and didnt overheat.
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. |
![]() | | #78 | ![]() |
(Thread Starter) | Not Ranked : 0 score thts wat im thinkin too i was jw cuz i heard some people were havin more trouble than it was worth.
![]() | | #79 | ![]() |
(Thread Starter) | Not Ranked : 0 score so i finally pulled the trigger on turbo choice!! I got a Comp turbo CT4x 53-56. It is a lil smaller than i wanted to go, but i will spool faster by a few hundred RPMs comapared to a PTE 5858... Should still make the power i want which is nice as well. Turbo is factory fresh rebuild with 0 miles on it got it for a great price as well
| The Following 5 Users Say Thank You to MSP611 For This Useful Post: | BLKSTIG (10-04-2015), Code Monkey (10-03-2015), Hammology (10-04-2015), mxlplx71 (10-03-2015), TRBLSM (10-03-2015) |
![]() | | #80 | ![]() |
![]() Join Date: Apr 2011
Also, I'm a bit of a tool whore, great choice on the CDI torque wrenches. Best bang for the buck that is still top-tier for accuracy. They are an arm of Snap-on tools, now, and partner with precision instruments on their split-beam wrenches. You can see the similarities. Precision Instruments: The Finest Torque Wrenches cditorque.com | |
| HOW TO build an mzr motor!! | qtrmile beast | MazdaSpeed 6 - Engine, Transmission & Driveline | 4 | 09-12-2012 05:07 AM |
| Coaststarlight's Forged Motor Build Thread! | Coaststarlight | MazdaSpeed 6 - Engine, Transmission & Driveline | 37 | 02-09-2011 02:30 PM |
| Motor build parts list ? | jracer | MazdaSpeed 3/6 - Big Turbo Builds | 6 | 12-25-2010 06:20 PM |
| everything neded to build motor? | ms3boost | MazdaSpeed 3 - Engine, Transmission & Driveline | 15 | 05-04-2009 11:14 PM |
