Like Tree7Likes
 Old 06-15-2016, 01:13 PM   #41
muffhugger's Avatar
Posts: 326   (View Stats)
muffhugger is the leader of the worldmuffhugger is the leader of the worldmuffhugger is the leader of the worldmuffhugger is the leader of the worldmuffhugger is the leader of the worldmuffhugger is the leader of the worldmuffhugger is the leader of the worldmuffhugger is the leader of the worldmuffhugger is the leader of the worldmuffhugger is the leader of the worldmuffhugger is the leader of the world
Originally Posted by Boost_creep View Post
You're going to need that 625 for added fuel, once you start turning the boost up
It's on my list of things to do haha. Just because the damn nozzle is under the throttle body. Also going to be bypassing the coolant to the throttle body for even lower BATs.
muffhugger is offline   Reply With Quote
 Old 06-15-2016, 02:17 PM   #42
Moar Meth.
 Old 06-15-2016, 03:14 PM   #43
muffhugger's Avatar
The Following User Says Thank You to muffhugger For This Useful Post:
WetzMS3 (06-15-2016)
 Old 06-18-2016, 08:28 AM   #44
omgzilla85's Avatar
Posts: 84   (View Stats)
omgzilla85 is a splendid one to beholdomgzilla85 is a splendid one to beholdomgzilla85 is a splendid one to beholdomgzilla85 is a splendid one to beholdomgzilla85 is a splendid one to beholdomgzilla85 is a splendid one to beholdomgzilla85 is a splendid one to beholdomgzilla85 is a splendid one to behold
Nice setup. Considering the SP kit myself. Couple questions:
What are all the parts you used to make that filler tube setup?
Are you using a TB spacer for injection? If so, which one?
The brackets holding the pump and the tank look custom, willing to make some extras?
2007 True Red MS3 GT - AP V3 - BNR S4 - eBay DP - JBR Tru 3.0 - TR8 FMIC - TS BPV - Autotechs - JBR EBCS - 3 BAR - JBR PMM - CS RMM - CS Shift Plate - DM OCC - Koni Yellows - Eibach Pro-Kit - Enkei Evo Xs - Freektuned
omgzilla85 is offline   Reply With Quote
 Old 06-18-2016, 01:50 PM   #45
AnimalMother's Avatar
Posts: 366   (View Stats)
AnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the worldAnimalMother is the leader of the world
He made gen pu brackets too lol
Juan on meth
AnimalMother is offline   Reply With Quote
 Old 06-19-2016, 07:56 PM   #46
muffhugger's Avatar
2-1/4" Vented Black Nylon Cap | U.S. Plastic Corp.
2-1/4" HDPE Remote Filler Spout Black with 5/8" Outlet | U.S. Plastic Corp.
5/8" ID high temp hose (2 feet should be more than enough, just cut to fit)
Sioux Chief 5/8 in. x 3/4 in. Plastic 90-Degree Barb x MPT Elbow-904-28253001 - The Home Depot
I used zip ties to attach the reservoir but someday will make a solid mount.
https://damondmotorsports.com/collec...-ports-pre-buy
Everbilt 3/4 in. x 48 in. Aluminum Flat Bar with 1/8 in. Thick-801917 - The Home Depot
That's what I used to mount the tank and pump. Pretty much measure twice, cut once. Used self tapping screws and existing M6x1.0 holes on the body to attach it. Once you figure out how you're going to mount everything, it's as easy as putting a puzzle together.
Hope this answers your questions.
omgzilla85 likes this.
Build me a BIG Turbo Build for MS3 NCspecV81 2010 MS3 - Big Turbo Builds 14 04-15-2013 02:16 PM
Report: Fiat to build Alfa Romeo SUV alongside Jeeps in America, build small car in Italy Haltech Automotive News 0 09-02-2011 07:20 AM
Theory: Build before Build demonspeed MazdaSpeed 6 - Engine, Transmission & Driveline 5 02-10-2009 06:52 PM
Page generated in 0.26918 seconds with 23 queries
