 Old 06-12-2011, 10:52 AM   #1
WeaponX_Perf's Avatar
Posts: 41   (View Stats)
WeaponX_Perf has a reputation beyond reputeWeaponX_Perf has a reputation beyond reputeWeaponX_Perf has a reputation beyond reputeWeaponX_Perf has a reputation beyond reputeWeaponX_Perf has a reputation beyond reputeWeaponX_Perf has a reputation beyond reputeWeaponX_Perf has a reputation beyond reputeWeaponX_Perf has a reputation beyond reputeWeaponX_Perf has a reputation beyond reputeWeaponX_Perf has a reputation beyond reputeWeaponX_Perf has a reputation beyond repute
Hmm if I were you I would start removing non essential fuses and relays one by one until things sort itself out. Hopefully that will isolate the bad circuit and it's something electrical connected in your vehicle causing a problem.
If that doesn't work, an air leak, loose hose after the MAF will also cause erratic running like you are suggesting. If a meth kit was installed I would suspect that (causing an air leak) as another culprit. Good luck.
WeaponX_Perf is offline   Reply With Quote
Page generated in 0.23016 seconds with 20 queries
