Like Tree6Likes
 Old 12-30-2011, 09:22 PM   #1
nofear72784's Avatar
Posts: 72   (View Stats)
nofear72784 has a reputation beyond reputenofear72784 has a reputation beyond reputenofear72784 has a reputation beyond reputenofear72784 has a reputation beyond reputenofear72784 has a reputation beyond reputenofear72784 has a reputation beyond reputenofear72784 has a reputation beyond reputenofear72784 has a reputation beyond reputenofear72784 has a reputation beyond reputenofear72784 has a reputation beyond reputenofear72784 has a reputation beyond repute
Default My experience installing and tuning BNR stage 3
Ok so I finally got my BNR stage 3 dialed in and figured I would give a little feedback. I expected this to go super easy and ran into quite a few snags. First off the turbo looks top notch! Hats off to Bryan for the quality build. He includes crush washers, oil return gasket and a banjo fitting that has a nipple on it to reroute your coolant return. First off here are some parts you will need to complete this without having to run to the store.
1 foot of 5/16th's line to reroute the coolant return
1 foot quarter inch vacuum line
1 vacuum line T
2 5/16th's hose clamps
Zip ties
.8mm and 1mm Mig welding tips
1 gallon of coolant
Installation issues:
I had a HELL of a time removing the oil return line!
The turbo is larger but I found that removing the EGR allowed me to slip it in there.
How to use the stock WGA solenoid with the BNR stage 3:
Use 3" of the vacuum line you got slide 1 of the mig welding tips into the middle (its safer to start with the larger 1mm tip to prevent spiking)
Attach one end of that to the reference nipple on the turbo
Connect a vacuum T to the other side
Use another 3" of the tubing and run it to the WGA
You now have 1 open port on the T, take the last 6" and attach that to the solenoid
you need a longer tube because there are no holes to bolt the solenoid onto the turbo
Attach the bleed line back to your turbo inlet tube
I Zip tied my solenoid onto the egr harness
Tuning:
For the first drive I loaded up a map I made with the WGA set to 20 and 15psi boost targets. This was made off of an older v1 map I was using before. This gave me VERY slow spool and I couldn't hit my targets. Upped the WGA, no change. I updated the AP and modified a new V2 map and tried again. Very odd... WGA was always showing 0. Here was what fixed it. The actuator on this is adjustable albeit a total PIA to get to when on the car. I TIGHTENED to rod 2 turns to apply more preload to the WG. Drove again, much better. Drove it this way for a day, 150 miles to break everything in. Tried to up the targets and it just couldn't get past 19 and was still slow to spool. I removed the 1mm restrictor and put in the .8mm. Night and day difference! Had full control again over the WGA and spooling was greatly improved. After all was said and done I did find that this WGA takes quite a bit to hit targets with the stock solenoid but this combination worked very well. It build boost quickly, only goes over the target by 1 psi then settles back down and holds perfectly.
Driving impressions.... wow it's nice to not die in the top end! Slightly slower spool than stock but it still makes more lower end power and just keeps pulling. The improved powerband makes the car so much more fun to drive. I find it to be more than enough power for a DD. Overall I would deff recommend it to anyone looking to ditch the smoking K04 that doesn't want to go balls out looking for maximum power.
Just so you don't have to search... here's this mornings virtual dyno runs. Screenshot is the untitled.doc attached. Made 4 runs this was the middle run and all were within 6hp and 12tq. This is my crappy tune that I threw together.. will post another after my PERM! Discuss
dizzydtrain and rfinkle2 like this.
06 Pearl White MS6 Grand Touring- Cobb SRI- Cobb TIP- BNR S3- P&P Tb- Devils Own Meth kit- CP-E TMIC- Cp-e catless DP- Magnaflow Cb- CP-e RMM-Autotech Internals- Cobb AP with ATR- JBR short shift kit- Brembo GT big brake kit- Custom fiberglass A pillar gauge pod- Intercooler temp gauge
Last edited by nofear72784; 01-08-2012 at 10:57 AM. Reason: Added Virtual Dyno run
nofear72784 is offline   Reply With Quote
The Following 32 Users Say Thank You to nofear72784 For This Useful Post:
AJ713 (01-09-2012), atvfreek (12-31-2011), BigjohnB20 (01-04-2012), BrianB6 (12-31-2011), charlesfist (01-04-2012), ckMS3 (02-04-2012), crazyp (12-30-2011), dizzydtrain (12-31-2011), drknyte (01-04-2012), eljefe62 (02-17-2013), h.h.sk1nny (01-05-2012), IMASA (12-30-2011), Jh8909 (02-01-2012), jracer (12-31-2011), Jsn_Rob (12-31-2011), kritz (12-31-2011), kunfu (01-04-2012), manselainen (12-31-2011), mason (01-09-2012), meelo88 (05-08-2013), Micha (02-05-2013), Mistersix (03-13-2013), mrmonk7663 (01-01-2012), MS3inDC (01-01-2012), Pointless (02-05-2013), psychophyr (02-01-2012), rfinkle2 (01-04-2012), rghispanic88 (01-04-2012), S-hendrix (12-31-2011), TiGraySpeed6 (12-31-2011), uncorked11 (12-31-2011), zpele (12-31-2011)
 Old 12-30-2011, 11:03 PM   #2
zenger's Avatar
Posts: 602   (View Stats)
zenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the world
Groaned at 8 Times in 7 Posts
where you located your car sounds identical to mine
2007-Mazdaspeed 6
BNRSIII~all supportings
Zoom Zoom Boom part out.
zenger is offline   Reply With Quote
 Old 12-30-2011, 11:15 PM   #3
I'm in Connecticut. Hows your BNR holding up? What was your experience with the tuning?
 Old 12-31-2011, 06:17 AM   #4
manselainen's Avatar
Posts: 38   (View Stats)
manselainen is a splendid one to beholdmanselainen is a splendid one to beholdmanselainen is a splendid one to beholdmanselainen is a splendid one to beholdmanselainen is a splendid one to beholdmanselainen is a splendid one to beholdmanselainen is a splendid one to behold
I'm seriously considering this, thanks for sharing.
3 MPS '07, BNR S3, HTP 3", ETS TMIC, Cobb catted DP, PTP HPFP internals, Bosch 3 bar MAP w/ PNP Harness, RMM, KW Variant 3, DO water/meth, Michelin Pilot Sport Cup 2 235/40-18, OZ Alleggerita, self tuned with VersaTuner E30, awaiting inspiration to build bottom end due to major blow-by @ 100 kmiles / 165 kkm
manselainen is offline   Reply With Quote
The Following User Says Thank You to manselainen For This Useful Post:
nofear72784 (12-31-2011)
 Old 01-04-2012, 12:16 PM   #5
zenger's Avatar
running strong.
@phate tuned
2007-Mazdaspeed 6
The Following 3 Users Say Thank You to zenger For This Useful Post:
dizzydtrain (01-04-2012), Jh8909 (02-01-2012), nofear72784 (01-04-2012)
 Old 09-30-2013, 01:18 PM   #6
aviator79's Avatar
Posts: 3,934   (View Stats)
Still in CT? Or did you get rid of the MS6?
 Old 02-05-2015, 09:07 AM   #7
PhorB13's Avatar
Posts: 47   (View Stats)
PhorB13 is a jewel in the roughPhorB13 is a jewel in the roughPhorB13 is a jewel in the rough
Where in CT are you? I'd love to get a BNR upgraded turbo at some point. Even just a stage 1.
2007 Speed3 - cp-e Nano, Cobb TIH, cp-e HPFP, Stage 1 AP tune (for now), Bilstein Sports with Corksport springs
PhorB13 is offline   Reply With Quote
 Old 02-18-2012, 09:39 PM   #8
G Sp33dy's Avatar
Posts: 337   (View Stats)
G Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the worldG Sp33dy is the leader of the world
Groaned at 7 Times in 3 Posts
and YOURS sounds identical to MINE! :O
G Sp33dy is offline   Reply With Quote
 Old 12-31-2011, 12:58 PM   #9
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Nice write-up- Thanks!
edit to add question- curious about fueling demands, if there's any benefit to tinkering with the injectors for a bnrs3
340hp / 371tq
 Old 12-31-2011, 11:51 PM   #10
not quite sure by what you mean tinkering with the injectors..... all I have as far as fuel is Autotech internals and I slightly bumped the FP to 1710.
 Old 01-03-2012, 07:25 PM   #11
Ziggo's Avatar
Posts: 3,843   (View Stats)
On pure pump, not really. Once you start mixing E85 (you really need a octane boost E85 or Meth to run more than 19-20psi) you can take them right to the limit. In 70deg ambients I was hitting 95% IDC, I have not done a WOT log recently, but in the cooler air I imagine this has gone over 100%
This turbo is well suited to the stock injector fueling capabilities. It leave just a small amount of headroom on the fueling capacity.
Ask Me About My:
The Following 5 Users Say Thank You to Ziggo For This Useful Post:
atvfreek (01-03-2012), dizzydtrain (01-03-2012), Mistersix (03-13-2013), rfinkle2 (01-04-2012), TiGraySpeed6 (01-03-2012)
 Old 01-03-2012, 09:19 PM   #12
Your having knock issues over 19-20 psi on pump? Whats your timing table look like? Running the cobb v2 stage 2 tmic table on Mobil/Shell 93 with a degree or 2 added. It's not very aggressive but at 22-23 psi I have 0 issues... I have the meth kit installed but not running it since I installed the BNR... just don't have the time to tune it properly right now. Was very surprised to get away with close to the same timing as the k04 with meth.
 Old 12-31-2011, 01:26 PM   #13
S-hendrix's Avatar
Posts: 1,410   (View Stats)
S-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the world
Amazing what a .2 mm difference for the restrictor can make. I'll keep this turbo in mind for potential upgrades. Thanks for the write-up.
BNR S3 . FREEKTUNED . COBB FMIC . COBB CBE . SURE full 3" . CPe Safe Seals . KMD Internals . Grimmspeed EBCS . Guardian Angel . TWM Short Shifter Replacement . MSD DashHawk V2 . Turbo XS DP+RP . Turbosmart Hybrid BOV (full recirc) . JBR SSP+Bushings+Knob/ Rear Sway Bar/ Rear Camber Arms . Sure PMM/TMM . JBR EGR Delete . AWR Adjustable Front/Rear Endlinks . TRZ Dogbone RMM . Denso ITV-22 . Eibach Sport Line . Koni Yellows
S-hendrix is offline   Reply With Quote
The Following User Says Thank You to S-hendrix For This Useful Post:
 Old 12-31-2011, 01:33 PM   #14
dizzydtrain's Avatar
Posts: 2,476   (View Stats)
Groans: 64
This is turbo is on top of my list as an upgrade. I was thinking about a GTX but I don't track my car and don't care for stupid high power. More reliability and useful powerband is what I am after and this seems to fit the bill.
Although it does seem like the install is not as straight forward as I thought. I have been following @Ziggo install and tuning thread with his BNR.
The Following 3 Users Say Thank You to dizzydtrain For This Useful Post:
atvfreek (12-31-2011), nofear72784 (12-31-2011), rfinkle2 (01-04-2012)
 Old 01-04-2012, 07:24 AM   #15
All of the above, plus no creeping issues.
AtTheDriveIn (01-04-2012), dizzydtrain (01-04-2012)
 Old 01-04-2012, 07:15 AM   #16
Ziggo's Avatar
I don't know what the OTS Cobb timing is, but I was limited to 9* peak timing at 11.2AFR on pump during the heat of the summer. I picked up something like 70whp by leaning it out to 12.0 and moving to 17* peak timing on a 3/9 mix of E85. I am making just under 400whp with this turbo now.
FYI my install thread:
http://www.mazdaspeedforum.org/forum/forum/showthread.php?t=88946
My tuning thread
http://www.mazdaspeedforum.org/forum/forum/showthread.php?t=89309
Zigatapatalka
Ask Me About My:
The Following 4 Users Say Thank You to Ziggo For This Useful Post:
Bucker (01-08-2012), nofear72784 (01-04-2012), rfinkle2 (01-04-2012), rghispanic88 (01-04-2012)
 Old 01-04-2012, 08:32 AM   #17
BNR S3 Swap How To - Mazdaspeed Forums
My tuning thread
ATR tuning A BNR Stage 3 - Mazdaspeed Forums
Zigatapatalka
Some places have better gas than others. Locally I am limited to 10* at 20psi on the K04 and AFRs are in the 10s to make it work. Otherwise I am limited to 8* and the 2* gain in timing is worth the richer AFRs.
At the same psi, the BNR should run cooler which will help with knock.
dizzydtrain (01-06-2012), Micha (02-05-2013), rfinkle2 (01-04-2012), TiGraySpeed6 (01-04-2012)
 Old 01-04-2012, 07:40 AM   #18
Two nuns and a pack mule
AtTheDriveIn's Avatar
Posts: 1,527   (View Stats)
And no smoke! Seriously considering between this and a GT28. Im not looking for a unicorn, just a way to get rid of my smoking turbo.
AtTheDriveIn is offline   Reply With Quote
The Following User Says Thank You to AtTheDriveIn For This Useful Post:
 Old 01-04-2012, 09:13 AM   #19
BigjohnB20's Avatar
Posts: 779   (View Stats)
BigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the world
Sounds good OP. Got any logs you can share?
Oh yea, I haven't really looked, but does anyone know how the Stg3 lines up price wise vs. the Gt(x) series? I know you need a core for the BNR and some of the vendors here are around 1600 for the Garrets. Just curious how they compare
2006 BCM MS6 GT
CS SRI/TIP
Jbarone SSP/bushings
cp-e RMM, TMIC, Stiff Diff
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
BigjohnB20 is offline   Reply With Quote
 Old 01-04-2012, 11:11 AM   #20
Groans: 64
Exactly, I forgot that one.
This solution is pretty great. I think Ziggo (BNR stg3) and Ck( who has a GT28) were comparing logs in one of Ziggo's threads and the power is very comprable.
It's 1200 like Finkle said plus core. The one nice thing is that you can get a cheap used core on the site and keep your original k04, especially if it's stil good. I plan on getting a used core on this site and sending it in (if i go this route). If at any point I sell or part out, I still have my good k04 to put it back to stock.
The used core doesn't have to be rebuildable but should have a good turbine housing in order for Brian at BRN to work his magic.
The Following 2 Users Say Thank You to dizzydtrain For This Useful Post:
BigjohnB20 (01-04-2012), rfinkle2 (01-04-2012)
 Old 01-04-2012, 09:30 AM   #21
BNR S3 = $1200.00
info here:
bnrsupercars.com
Its finally here! The BNR 2871 is in production! Here is the finished product! Bolt on, minimal fabriaction required! This upgrade is for the customer wanting to reach the limitations of the stock engine without killing response! This is what the upgrade includes:
GT2871 compressor wheel
New GT28 non ball bearing CHRA
360 degree thrust assembly
upgraded wastegate actuator assembly
balanced to or under .5 gram/in2
upgraded compressor housing with custom outlet for the factory intercooler piping/couplers
1 year warranty!
@nofear72784, what did you need the welding tips for?
BigjohnB20 (01-04-2012), dizzydtrain (01-04-2012), SLOWHATCH (01-04-2012)
 Old 01-04-2012, 12:11 PM   #22
They are for the boost signal line going to the WG solenoid -they are restrictor pills. The flow needs to be limited or the solenoid won't be able to increase boost.
dizzydtrain (01-06-2012), nofear72784 (01-04-2012), rfinkle2 (01-04-2012)
 Old 01-04-2012, 12:14 PM   #23
Oh geez. Thanks Lex. Reading fail on my part.
I totally missed that in the first post.
Thanks again to the OP and Lex.
dizzydtrain (01-04-2012), nofear72784 (01-04-2012)
 Old 01-04-2012, 12:36 PM   #24
Ziggo's Avatar
Or you could just switch to a 3 port at the same time. It's only $100 and you will have to find a place to put the stock solenoid anyway since the 2871 compressor housing on the BNR does not have the stock solenoid mounting feature.
Zigatapatalka
Ask Me About My:
 Old 01-04-2012, 01:04 PM   #25
Zigatapatalka
You have a pic of how you mounted your solenoid?
 Old 01-04-2012, 02:20 PM   #26
Ziggo's Avatar
I mounted it on the front of the battery box per grimspeed's instructions. I am not a big fan of how long that makes the tubes from the boost source/to the WG but I have not seen any ill effects like slow response or boost oscillation.
Zigatapatalka
Bucker likes this.
Ask Me About My:
Bucker (01-08-2012), Lex (01-08-2012), rfinkle2 (01-04-2012)
 Old 01-04-2012, 02:21 PM   #27
Zigatapatalka
I'll snap a pic of where I have mine mounted when I get home from work.
Ziggo, all the links are busted (to the pics) in your install thread (@ least on my work computer).
 Old 01-04-2012, 03:22 PM   #28
Ziggo's Avatar
They seemed to load ok for me, if a bit slow. Here is a picture of the installed grimmspeed ECBS in 3 port mode.
Zigatapatalka
Ask Me About My:
 Old 01-04-2012, 04:07 PM   #29
dereeek's Avatar
Posts: 2,053   (View Stats)
dereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the world
Groans: 386
Good write up. I've been thinking about getting one of these lately.
BNR3-FREEK-PU-398HP
I lost track of the mods in my car.
dereeek is offline   Reply With Quote
 Old 01-04-2012, 04:28 PM   #30
I had a threaded hole that I able to take advantage of.
Sorry about the link thing Ziggo, must've been my work computer blocking your pics in your thread.
 Old 01-08-2012, 04:01 PM   #31
Posted virtual dyno run for all those that have asked. It's in the original post.
The Following User Says Thank You to nofear72784 For This Useful Post:
dizzydtrain (01-08-2012)
 Old 01-08-2012, 07:32 PM   #32
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
for easier pic posting Picasa is free along with free hosting and if you right click the graph in Vdyno you can save as a jpg
Nice build man
The Following User Says Thank You to crazyp For This Useful Post:
nofear72784 (01-09-2012)
 Old 01-19-2012, 04:04 PM   #33
KostasCX-7's Avatar
Posts: 125   (View Stats)
KostasCX-7 has a reputation beyond reputeKostasCX-7 has a reputation beyond reputeKostasCX-7 has a reputation beyond reputeKostasCX-7 has a reputation beyond reputeKostasCX-7 has a reputation beyond reputeKostasCX-7 has a reputation beyond reputeKostasCX-7 has a reputation beyond reputeKostasCX-7 has a reputation beyond reputeKostasCX-7 has a reputation beyond reputeKostasCX-7 has a reputation beyond reputeKostasCX-7 has a reputation beyond repute
I used a single MBC. The boost "T" (purple on photo) has inside a ball with a spring and works like a restrictor pill. This setup builds boost immidiately and the throttle response is awesome. My tune was based on MBC
CX-7 2008 awd manual bnr s3
KostasCX-7 is offline   Reply With Quote
 Old 02-01-2012, 09:50 AM   #34
RichB's Avatar
Posts: 510   (View Stats)
RichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the worldRichB is the leader of the world
If you upgrade to the grimmspeed EBCS do still need a pill?
If you use an MBC inline with the stock boost controller I'm guessing you don't need a pill but do you just set your WGA to 0 and tune with the MBC?
2007 Cosmic Blue Mazdaspeed 3 GT
RichB is offline   Reply With Quote
 Old 02-01-2012, 05:12 PM   #35
Ziggo's Avatar
The grimmspeed ECBS in 3 port does not need a pill. In two port it probably will but I have no direct experience.
Zigatapatalka
Ask Me About My:
 Old 02-01-2012, 05:33 PM   #36
RichB's Avatar
That makes sense. Thanks!
 Old 02-05-2013, 10:11 AM   #37
Ru5tyNut5's Avatar
Posts: 24   (View Stats)
Ru5tyNut5 has a reputation beyond reputeRu5tyNut5 has a reputation beyond reputeRu5tyNut5 has a reputation beyond reputeRu5tyNut5 has a reputation beyond reputeRu5tyNut5 has a reputation beyond reputeRu5tyNut5 has a reputation beyond reputeRu5tyNut5 has a reputation beyond reputeRu5tyNut5 has a reputation beyond reputeRu5tyNut5 has a reputation beyond reputeRu5tyNut5 has a reputation beyond reputeRu5tyNut5 has a reputation beyond repute
I just installed a BNR stage 3 and so far have 0 control of my boost, just running on the spring. I was unaware that I was to add some kind of "Pill" or restrictor to the line between the turbo and the T so I will try that and hope I gain some sort of control, I'd sure like more than 14 psi....
'07 MazdaSpeed 6 GT
CorkSport SRI//CorkSport TIP//BNR Stage 3 turbo//Cobb EBCS//CorkSport FMIC//CorkSport Catted Downpipe//CorkSport OCC//CorkSport Short Shifter//CorkSport Front and Rear Sway Bars//CorkSport Lowering Springs//CorkSport skid tray//RX8 Wheels//CorkSport RMM//CorkSport Tranny Mount Insert//Cobb AP//CorkSport HPFP//CorkSport LED light kit
Ru5tyNut5 is offline   Reply With Quote
 Old 02-05-2013, 11:27 AM   #38
You can choose to either run a 3 port solenoid or run a Boost Dial with the OEM 2 port if you still have it. Let me know if you have any questions about this.
 Old 03-13-2013, 07:01 PM   #39
Mistersix's Avatar
Posts: 2,585   (View Stats)
Does the boost dial with the OEM 2 port require any pill size adjustment?
Edit: He's running a 3 port, nevermind.
 Old 03-13-2013, 07:39 PM   #40
No it does not. All you need to adjust is the dial itself.
Mistersix (03-14-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/my-experience-installing-tuning-bnr-stage-3-a-100942/
Turboaufladung - [ALLE] BNR Turbo Upgrades This thread Refback 03-01-2013 12:02 PM
[ALLE] BNR Turbo Upgrades - Turboaufladung - mazda-mps.de This thread Refback 11-13-2012 02:00 AM
ATR tuning A BNR Stage 3 Ziggo MazdaSpeed 3/6 - ECU Computer Tuning 246 06-19-2012 01:24 PM
Tuning a BTv102 Stage 1 Map posty MazdaSpeed 3/6 - ECU Computer Tuning 10 08-17-2011 07:15 PM
Stage 2 Tuning? Roguevice 2010 MS3 - ECU Computer Tuning 4 05-24-2011 05:20 PM
Cobb Tuning Stage 2 Suspension Package Blu Ace MazdaSpeed 3/6 - Suspension & Brakes 13 08-06-2008 08:18 AM
Page generated in 0.61775 seconds with 40 queries
