Like Tree10Likes
 Old 09-03-2013, 02:34 PM   #1
RE-ACTIONENGSPEED3's Avatar
Posts: 401   (View Stats)
Smile My new k4 Hybrid turbo
I have installed in my car. A new version of the stockish K4. So we feet a mitsubishi td05-20g cartidge ,the front wheel is made from ktsturbobilletx.com and it is a 56mm 11 blade wheel (gtx style) the aluminium is from garret with AR 70. The car seems to spool at 3300 rpm and i have full boost at about 3700rpm. The car boosts 27psi and at 6500rpm i have 22psi till redline.
I have some fuel cuts though that i have to find out a solution.I really like the car and the way that turbo has power till redline.
I will let you know for my progress from this thread...
theschrum, kritz, lito37 and 4 others like this.
2008 speed3
True red.
Pte 6466 & AWD Mode on !!!!
The Following 56 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
2.0t03speed (09-03-2013), 802MS3 (09-03-2013), alphasaur (09-03-2013), ArmanRus (09-04-2013), atvfreek (09-12-2013), bhamitgeek (09-12-2013), Bolted6 (09-12-2013), Boosted Beluga (09-04-2013), Brennan (09-03-2013), ciezczak1 (09-03-2013), cshunter (09-12-2013), daafisch (09-04-2013), dan7225 (09-03-2013), darkcherry (12-23-2013), DSIT995 (09-03-2013), Easter Bunny (09-05-2013), El_Diablo (09-04-2013), gsrtype1 (09-05-2013), Hammology (12-23-2013), helmetface (09-03-2013), himurax13 (09-03-2013), Hush (09-04-2013), ink28 (12-17-2013), J'sSpeed3 (09-04-2013), Keko (09-03-2013), killer-ms3 (09-03-2013), Koke382 (09-03-2013), kritz (09-03-2013), Lex (09-03-2013), manila (09-03-2013), mazdafreak (09-03-2013), memin (09-04-2013), Micha (09-04-2013), Mizzle (09-12-2013), obijack (09-03-2013), Pointless (09-03-2013), psychophyr (09-14-2013), radioflyer (09-03-2013), Ranyard (09-14-2013), redboat (04-07-2014), Roddiy (09-12-2013), sidekick (09-12-2013), skiptowncat (09-07-2013), SLOWHATCH (09-12-2013), smoogs12 (09-12-2013), SparkySparks (09-03-2013), speed3sailor (09-12-2013), SPEED6 KILLAH (10-12-2013), SpeedLife (09-14-2013), SpeedNess (09-03-2013), starscream (09-03-2013), Status Update (09-03-2013), Tomas (03-29-2014), trancehead (09-12-2013), uncorked11 (09-03-2013), Voltron (09-15-2013)
 Old 09-03-2013, 03:29 PM   #2
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
basically a sorta bolt-on evo IX turbo?
'08 CWP MS3 w/ T3 3071r
 Old 09-03-2013, 03:29 PM   #3
Nice little hybrid.
Do you have a compressor map for this? The drop in boost near redline could be from boost control alone. Are you running a 3 port for boost control? Also what is spring pressure?
 Old 09-03-2013, 04:07 PM   #4
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
How much was it?
Sent from my Galaxy S3 using Tapatalk 4 Beta
Also is the turbo water cooled? I don't see any ports for a banjo bolt on the side of the chra.
What are you doing for the wastegate?
Last edited by 2.0t03speed; 09-03-2013 at 04:07 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-03-2013, 04:20 PM   #5
Turbo_Steve's Avatar
Posts: 944   (View Stats)
Nice!!! Would love to see power numbers. Also who did the turbo? Cost? How much machine work?
Soon to come.
WHO KNOWS? A.D.D. FTW!
The Following User Says Thank You to Turbo_Steve For This Useful Post:
 Old 09-03-2013, 05:59 PM   #6
Koke382's Avatar
Posts: 4,361   (View Stats)
Yea more info pleaseeee
Sent from my SPH-L900 using Tapatalk 2
And subbed
2007 Mazdaspeed 3 GT
18x8.75 XXR 527 225/40/18r
New fucken miata build:
1993 Red Na6
Some suspension modz yo
Coilovers// Other shit
Last edited by Koke382; 09-03-2013 at 05:59 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-03-2013, 06:05 PM   #7
obijack's Avatar
Posts: 1,830   (View Stats)
malaka! j/k in for more info.
2014 Honda Grom-Red
2014 Yamaha Grizzly 350- Blue
The Following 4 Users Say Thank You to obijack For This Useful Post:
Easter Bunny (09-05-2013), Koke382 (09-03-2013), RE-ACTIONENGSPEED3 (09-04-2013), snailD (09-12-2013)
 Old 09-03-2013, 06:38 PM   #8
Mistersix's Avatar
Posts: 2,585   (View Stats)
Interesting. Hard to tell in the pics but i don't see a wastegate actuator. Are you running this external waste gate?
The Following User Says Thank You to Mistersix For This Useful Post:
 Old 09-03-2013, 08:34 PM   #9
fivefingerdeathpunch's Avatar
Posts: 437   (View Stats)
interested to see how many g/s this thing will flow
The Following User Says Thank You to fivefingerdeathpunch For This Useful Post:
 Old 09-04-2013, 12:17 AM   #10
It is familiar to evo, but it isn`t reverse style and it is only oil cooled....
2008 speed3
True red.
The Following 2 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
802MS3 (09-04-2013), Easter Bunny (09-05-2013)
 Old 09-04-2013, 12:28 AM   #11
Nice little hybrid.
I do not have a compressor map.The boost drop i think it is because i use a greddy profec b boost controller and it isn`t that accurate like the 3 port.I have it internal wg from forge custom fit this turbo and it has the red spring (14psi spring pressure).
That turbo made it a turbo specialist in my country Greece it is cold "turbo by spartalis".The cost without the forge wg is about 1150$.Have in mind that in my country the cost to buy a bolt on gtx is almost 2000$ with the custom fees and the shipping cost.
2008 speed3
True red.
Last edited by RE-ACTIONENGSPEED3; 09-04-2013 at 01:21 AM. Reason: MSF Database - Automerged Doublepost
atvfreek (09-12-2013), SLOWHATCH (09-12-2013)
 Old 09-04-2013, 01:21 AM   #12
Here is a clean 4 gear log ....
Have in mind tha pressure is at kpa and bat to C and i still run the oem map sensor....
2008 speed3
True red.
The Following 3 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
Easter Bunny (09-05-2013), SLOWHATCH (09-12-2013), superskaterxes (09-04-2013)
 Old 09-04-2013, 10:03 AM   #13
ekanddsm's Avatar
Posts: 167   (View Stats)
ekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the worldekanddsm is the leader of the world
Nice, It would be cool to see that map sensor signal, or actua boost level. Overall that a pretty healthy turbo. Nice Job.
ekanddsm is offline   Reply With Quote
 Old 09-04-2013, 10:38 AM   #14
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
Nice to see another kinda option.
I have some upgraded parts for the k04 soon also in the works....For way less than a BNR3.
memin likes this.
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
The Following User Says Thank You to mazdafreak For This Useful Post:
rob ms6gt (09-15-2013)
 Old 09-05-2013, 07:38 PM   #15
Care to share details?
Soon to come.
 Old 09-05-2013, 10:20 PM   #16
mazdafreak's Avatar
Groans: 124
I dont rly want to say yet, I have one thing for sure which is a simple wheel upgrade to push k04 a lil more to reach 350+whp.
But also have a whole cartridge+wheel upgrade in the works. Would like to test both before releasing anything else.
713whp/569wtq!
The Following 6 Users Say Thank You to mazdafreak For This Useful Post:
El_Diablo (09-12-2013), Koke382 (09-10-2013), rob ms6gt (09-15-2013), SLOWHATCH (09-12-2013), snailD (09-12-2013), Tokay444 (09-12-2013)
 Old 09-12-2013, 01:25 AM   #17
I found some free time and make some progress i have not hit the fuel cut, but i still have a very high hpfp pressure...
The car looks very good though...
Here is a 4th log and a vd with that log ......
I steel want to play with my vvt tables because they are still stock to see how it will reacts...
Turbo_Steve likes this.
2008 speed3
True red.
The Following 5 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
Cevaes_64 (09-12-2013), cshunter (09-12-2013), El_Diablo (09-12-2013), Roddiy (09-12-2013), speed3sailor (09-12-2013)
 Old 09-12-2013, 03:56 AM   #18
StayBroke's Avatar
Posts: 2,075   (View Stats)
Do I no what this is?
 Old 09-12-2013, 05:10 AM   #19
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
THIS IS SPARTA!
Sent from fastest ko4 Pu!
Nator is what it does.
The Following 2 Users Say Thank You to kritz For This Useful Post:
skiptowncat (09-12-2013), Tokay444 (09-12-2013)
 Old 09-12-2013, 05:11 AM   #20
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
looks like a fun turbo.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 09-12-2013, 12:48 PM   #21
speed3sailor's Avatar
Posts: 835   (View Stats)
speed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the world
im not too far away(italy). im currently saving up for a BNR but this looks pretty cool. how long did it take them to finish it?
also, do you have any installed pictures?
07 SILVER Speed3 , BNR S3- Tial 38mm EWG w/ stock mani- COBB AP- Ebay catless Downpipe- HTP 3in intake- Devils Own WMI (D10)- CX Racing FMIC- Autotech internals- Grimmspeed 3P EBCS- Denso ITV22- HKS super SQV- Bosch 3 bar - Damon PMM- JBR RMM- shift weight- EGR delete- TIGs- JBR RSB- Eibach springs- TR Motorsports 17x9- Hankook RS-3 255/40/17
Last edited by speed3sailor; 09-12-2013 at 12:48 PM. Reason: MSF Database - Automerged Doublepost
speed3sailor is offline   Reply With Quote
 Old 09-12-2013, 12:59 PM   #22
mazdafreak's Avatar
Groans: 124
Idk, do you? lol
713whp/569wtq!
 Old 09-12-2013, 01:30 PM   #23
StayBroke's Avatar
Idk, do you? lol
You just upgrading wheels right? Who is the company?
 Old 09-12-2013, 02:00 PM   #24
mazdafreak's Avatar
Groans: 124
Yup, a 50x65mm billet wheel, says its good for 350-375hp.
I have my own guy that rebuilds turbos and another guy that does all the machine work for him. R&D automotive in IL
713whp/569wtq!
 Old 09-12-2013, 02:54 PM   #25
It needs about 3-4 days and it is ready for use....
http://img163.imageshack.us/img163/8514/5mvf.jpg
http://img856.imageshack.us/img856/2796/9lwe.jpg
2008 speed3
True red.
The Following 4 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
cshunter (09-12-2013), El_Diablo (09-12-2013), rob ms6gt (09-15-2013), speed3sailor (09-13-2013)
 Old 09-13-2013, 12:37 AM   #26
I manage to make a dyno in a friends dynomite...
I make 383.9 whp .....
Here i have to say that my previous setup was a bnrstg3 and i have achieved almost the same power in the same dyno.The bnr was spooling faster but hybrid is much better after the 6000rpm....
2008 speed3
True red.
cshunter (09-13-2013), El_Diablo (09-13-2013), skiptowncat (09-13-2013)
 Old 09-13-2013, 04:07 AM   #27
Tokay444's Avatar
Groans: 793
i'm assuming "estimated" is crank hp?
Demodded.
The Seals
mazdafreak (09-13-2013)
 Old 09-13-2013, 08:58 AM   #28
are you at the same boost levels as before?
 Old 09-14-2013, 08:02 AM   #29
Yea estimated is the crank hp..
2008 speed3
True red.
 Old 09-14-2013, 08:17 AM   #30
Yes ecactly the same....I think that in higher boost levels the hybrid should made more power....
2008 speed3
True red.
 Old 09-14-2013, 08:23 AM   #31
Wildcard's Avatar
Posts: 595   (View Stats)
Wildcard is the leader of the worldWildcard is the leader of the worldWildcard is the leader of the worldWildcard is the leader of the worldWildcard is the leader of the worldWildcard is the leader of the worldWildcard is the leader of the worldWildcard is the leader of the worldWildcard is the leader of the worldWildcard is the leader of the worldWildcard is the leader of the world
Aren't hp and tq lines supposed to intersect at 5250rpm, always?
08 Mazdaspeed 3 GT
COBB APv2 // TR8 FMIC // CP-E Full Catted Exhaust // HTP 3" // Relentless Customs IM // JBR: TB TIG, Shifter Bushings, SSP // KMD's // Grimmspeed 3-Port // Damond RMM // Autolite XP5263's
Wildcard is offline   Reply With Quote
 Old 09-14-2013, 08:28 AM   #32
I`m soory but my english isn`t that good can you please explain me what do you mean?
2008 speed3
True red.
 Old 09-14-2013, 09:58 AM   #33
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
Το διάγραμμα που δημοσιεύτηκε δεν έχει νόημα. Οι δύο γραμμές που θα πρέπει να τέμνονται σε 5.250 στροφές ανά λεπτό.
The chart you posted does not make sense. The two lines should intersect at 5,250 revolutions per minute.
 Old 09-14-2013, 10:54 AM   #34
bislag's Avatar
Posts: 395   (View Stats)
bislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the world
Graph is skewed because it's in N*m. If you convert the torque numbers to ftlbs, it makes a lot more sense.
For example: Ballparking his 5250 numbers you're around 350 HP and 475 Nm, which converts to about 350 ftlbs.
bislag is offline   Reply With Quote
The Following User Says Thank You to bislag For This Useful Post:
btstarcher (12-17-2013)
 Old 09-14-2013, 10:59 AM   #35
i really don`t know if the lines should intersect at 5200 rpm ..
I just made a dyno and get that results...
2008 speed3
True red.
 Old 09-14-2013, 11:05 AM   #36
bislag's Avatar
Your graph is fine. Just threw a bunch of us off because we generally work in ft*lbs, not N*m.
RE-ACTIONENGSPEED3 (09-14-2013)
 Old 09-14-2013, 11:11 AM   #37
GPOP SHOP?
In reply to my email to them about another project a few weeks ago.
We have a custom Billet wheel upgrade for these that supports around 375HP available for $850 + shipping. This is if you send a core in, it includes a complete HP rebuild, billet wheel upgrade, turbine wheel modifications and a complete turbine housing port and polish. Let us know if you have any other questions on this or if you need anything else. Thank you,
Jim & Gerry, G-Pop Shop
Specializing in rebuilt and new turbos,"
And I am guessing this is who makes PG's turbo upgrade
Soon to come.
 Old 09-14-2013, 02:54 PM   #38
StayBroke's Avatar
Turbo lab was who I am going through.
 Old 09-15-2013, 03:19 PM   #39
mazdafreak's Avatar
Groans: 124
I have talked to turbo lab....They are just sketchy and dont kno if they offer warranty or what they actually do, like if ur having them upgrade the wheel, are they rebuilding the turbo also?? etc.
Got my billet wheel upgrade for $150, and will cost me under $100 for rebuild kit and less than a $100 for machining and balancing the turbo......Wheel should be here monday or tuesday.
713whp/569wtq!
The Following 2 Users Say Thank You to mazdafreak For This Useful Post:
cshunter (09-16-2013), speed3sailor (09-16-2013)
 Old 10-06-2013, 05:38 AM   #40
So after the 56mm wheel, i remove the turbo and i have place a 52,5mm wheel(sory i have not time for photos) in the same cartridge of course i have to change the aluminioum inlet because this is smaller a wheel.My first impression is that the car definately boosts sooner i will make some logs tonight and i will share it with you...I`m curius to see how this hybrid will reacts....
2008 speed3
True red.
cshunter (10-06-2013), El_Diablo (10-07-2013), lilred (10-06-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/my-new-k4-hybrid-turbo-154324/
For those that don't venture to MSF on the regular. AWESOME! This thread Refback 09-03-2013 04:02 PM
hybrid turbo speed3sailor Mazdaspeed3/6 General Discussion 1 02-09-2013 07:47 AM
Page generated in 0.60039 seconds with 38 queries
