(Thread Starter) | Neutral : +1 score My original BT setup was a 0.82 a/r t3 3071... and was plagued with a cracked manifold. When i finally pulled it off to start working on my new setup, I even found an unfinished weld on the manifold.... which was incredibly frustrating. That meant i had exh leaks since day 1 with that setup... and with a manifold that cost $1k plus 6 mos of waiting... was just unacceptable. So i set out to do it again, and hopefully right this time. I picked up a Borg Warner 88-75 from a local buddy for cheap: Full-Race Motorsports He gave me 2 different hot sides with it, one of which was a 1.0 a/r (t4 flanged) twin scroll. So i figured with only 2.3 liters of displacement, and a monster journal bearing turbo to spin, i'll need all the spool help i can get... thus a twin scroll manifold was in order. I figured, since i'm building it, and absolutely loathe working on a turbo in the stock location.... might as well go top mount. This was the first manifold i've ever built, so i hope it works out well. I used schedule 10 stainless cast elbows & piping, which has nearly double the wall thickness of my previous $1k manifold. Many people use sched 40... but i'm hoping sched 10 will cut it, especially with an additional brace between the flanges. In order for the hood to close... i had to cut and angle the compressor outlet some. It's a 3" O.D. compressor outlet lol. Here it is gonzo-fied. The turbo is a monster. Capable of 75 lbs/min. I then fabbed up a 3" down pipe to mate the monster turbo. I wanted to keep the car somewhat mild mannered off-boost, so i threw in a resonator pipe i had just laying around. Should help keep the volume down quite a bit. Also threw together an intake to feed the beast. This one is 3.25" I.D. but eventually i'll probably max the maf, and need to go to a 4" pipe. I already have the couplers and pipe to do this, just need to get a few other things squared away. For oil feed and return, i modded the oem lines by cutting them off part way, and welding on AN fittings. The oil return line was awfully close to the wastegates, and wouldn't easily route up under the CHRA without touching exh runners... and thats a def no-no. So i had to fab up a oil slide to bring the AN fitting out from under the turbo. Once that was done, it was time to start bolting shit up and get the dump tubes fabbed. First i threw on the manifold & twin gates. And routed the dumps down and out by the axle. This is a pic of the first part of the dumps. I still need to get a better shot of how the look complete, cause it's awesome. I'll update the post with the better pic when i have it. Here's a pic of the finished piping tacked together. Once the dumps were done, it was time to throw on the turbo and oil lines. You can see how the return line is far enough away from the WG's and turbo, which is good. I plan on putting some heat shielding around the return just to be safe. There was some bend in the return line, but no kink, so i think it should work fine. The feed line comes out from under the alternator... all the way under the manifold, up and around by the intake. It wasn't hooked up in this pic, but you can see the routing fairly well. Then throw on the down pipe and hook up the o2 sensors. You can see the oil feed line better in this pic. Then throw on the hot pipe section from the turbo outlet. Install the intake and MAF sensor. And voila.... one absolutely ridiculous looking turbo setup lol. The pictures don't really do it justice IMO, cause this things look insane in person. I started it up Sunday evening... but still need some more hose clamps, a boost 'T' for the WG's and coolant. It was making a clacking noise from under the valve cover, but i'm hoping it's just a lifter, and the noise will go away lol. Tonight i'm gonna start it again and let it warm up, and maybe even take it for a very light cruise. After a heat cycle, I'll also re-torque all the exhaust hardware. I hope to god the clack goes away.... hahaha.Next up on the list is HKS ignition amp, tap my cold pipe for wmi and a few other nick nacks. I have a triple gauge pod with an oil pressure gauge (courtesy of Matt Damond, big thanks) that needs to go on as well. And once all the hardware is vetted... it's time to tune and see what this setup can do.... oh and yea.... stock block.... so this will certainly be a good test for it's capabilities.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
| The Following 228 Users Say Thank You to djuosnteisn For This Useful Post: | -cj- (02-07-2011), 06Speed6 (02-07-2011), 09Speed3Z (02-07-2011), 09speedaddict (04-15-2013), 3dpilot (04-22-2013), 3mazdaspeed (02-08-2011), 4G63 (03-10-2011), 8.5MS3 (02-07-2011), 801MS3 (02-07-2011), 802MS3 (02-07-2011), 86AmishMs3 (06-11-2013), aaronc7 (04-05-2011), ABQ Speed6 (06-26-2011), ABSpeed3 (12-14-2011), Adam is so pro (04-29-2013), Addikted To Boost (02-07-2011), aggierandy (04-24-2013), AJ713 (02-10-2011), alexryan (04-23-2013), alien_sporez (06-16-2011), Amazon (02-07-2011), amggilly305 (07-11-2013), AmillieMS6 (03-07-2011), amoosenamedhank (02-07-2011), ARES28 (02-10-2011), asiandude74 (02-10-2011), AZRushki (02-07-2011), banditscout (02-13-2011), bcmurphy87 (06-18-2011), Biggs (02-07-2011), BigjohnB20 (02-07-2011), bioevolve (02-07-2011), Blackspeed (02-08-2011), BlueStreak (08-30-2011), BobtailedSnail (12-03-2011), Boonestafa (05-21-2013), breakfasteatre (04-22-2013), BrianB6 (02-07-2011), BrianZX10R (02-07-2011), Broxer (08-16-2011), cbusby (06-13-2011), charlesfist (05-17-2011), ChimmyChong (02-10-2011), Chriscote (02-16-2011), Ckmazdaspeed3 (02-10-2011), Click Here (02-07-2011), Coaststarlight (05-13-2012), cocoanton (04-12-2011), cpolly69 (02-07-2011), crtguns (05-22-2013), daafisch (02-07-2011), DaleNixon (02-08-2011), danesti (03-06-2011), Dano (02-07-2011), Darksun280 (02-07-2011), Dash08 (02-07-2011), dead-zone (07-24-2013), Decepticon (02-10-2011), derek13p (04-24-2013), DingoDave (06-14-2011), Docnox (02-07-2011), doubleflusher (02-08-2011), dougefresh_ (03-19-2011), Downmented (12-02-2011), EdgeAutosport.com (02-17-2012), efispeed (02-18-2011), essejkcamraw (02-08-2011), EwMPS (02-18-2011), faeker (05-06-2011), Fagwagon (02-08-2011), FantasmoNegro (02-18-2011), fastdreams (02-08-2011), Ferg (08-30-2011), fhaze (09-13-2011), fishin53 (02-07-2011), Fobio (02-07-2011), focoms3 (09-22-2011), forcedinduktion (02-10-2011), frivolous_rob (05-05-2011), fywdyl (02-07-2011), ganque (09-24-2011), gtlaw (02-07-2011), h.h.sk1nny (01-06-2012), h0ckeyman (05-22-2013), H3R3TIC (02-07-2011), Hamilton69 (02-12-2011), hamptotl (08-05-2011), helmetface (08-31-2011), I Love Brownies (02-07-2011), i8urgti (02-21-2011), Illmatic MS3 (02-11-2011), IshiKage (02-07-2011), J-Liss (08-23-2011), JacksonMS30 (02-07-2011), jack_hammer (02-07-2011), jax ms3gt (02-07-2011), jayspeed3 (02-10-2011), jeek (07-18-2013), JMEngineer (02-07-2011), jmhinkle (02-08-2011), JmkC (09-17-2011), josurr (09-20-2011), jracer (02-07-2011), Jsn_Rob (08-21-2011), jtspells (02-07-2011), Juyoung (04-23-2013), jv92red (02-07-2011), jwilkins88 (02-10-2011), karl-hungus (03-08-2011), Keemo577 (08-22-2011), KeysMS3 (02-07-2011), kilik2 (02-15-2011), kmac (02-10-2011), kunfu (02-07-2011), kylec_2003 (02-08-2011), LiEast (03-07-2011), locorasta (08-29-2011), LumberJack (05-23-2013), M4Nathan (02-10-2011), m4tic (02-07-2011), madvillain (02-07-2011), manelscout4life (02-07-2011), Manny (08-30-2013), MarkyMark (02-07-2011), mason (02-07-2011), MATT DAMOND (05-06-2011), MattJackson86 (02-07-2011), mazda.speed3 (02-07-2011), MazdaGaragePat (11-09-2012), mazdaspeed619sd (08-24-2011), mazdaspeedemon3 (05-28-2013), mazpro (02-07-2011), mdl3v8 (07-10-2013), MDRracing13 (02-10-2011), memin (07-07-2011), Menace1 (12-11-2012), merkinsquirrel (07-01-2011), Mfinlay04 (04-22-2013), MGM_GT3 (03-08-2011), Mistersix (08-07-2011), Mizzle (07-25-2011), Monotonous ONE (02-07-2011), MPSdriver (02-08-2011), mrdouble99 (04-23-2013), mrFanel (06-16-2011), mr_mazda329 (02-08-2011), MS3 Ventura (02-19-2011), MS3-a(sore)ASS-rex (02-07-2011), MS33SM (02-07-2011), ms3blackmica (10-01-2012), mtnrunner (02-07-2011), Nazarite (02-10-2011), Neverlift (02-10-2011), Night Wolf (06-22-2011), nighthawk358 (02-07-2011), NJSPEED3 (02-07-2011), NoLeftTurn (02-11-2011), NoRegrets (02-16-2011), NRSpeed (02-11-2011), nybe0010 (05-23-2013), nycMS3 (02-21-2011), obijack (03-08-2011), OgCoda (09-19-2011), onelove221 (07-18-2011), PapaSmurf (05-06-2011), phillyb (02-07-2011), Post pwned (08-07-2011), PPD369Speed3 (06-12-2013), psychophyr (02-07-2011), PunjabiPlaya (02-07-2011), qtrmile beast (02-07-2011), QwkEVO (12-27-2011), RayRayBauder (02-10-2011), Realgib3 (02-07-2011), rfinkle2 (06-14-2011), RhoadBlock (04-05-2011), Rich990 (06-10-2013), rigor (02-07-2011), Roddiy (04-22-2013), rodrigo (02-07-2011), Rokusek (07-17-2013), Scynfewl (02-12-2011), sellers (02-09-2011), SilverDemon (02-07-2011), spd6guy90 (02-07-2011), speed d3mon (03-07-2011), Speed freak (02-07-2011), speed23 (07-13-2013), Speed3eak (02-07-2011), SpeedLife (08-19-2013), SpeedNess (02-07-2011), SpeedSixxx (02-17-2011), speedtown (02-07-2011), speedtoz (02-08-2011), speed_3 (12-04-2011), spiker98 (02-07-2011), spnkr21 (02-07-2011), spoolin00 (02-07-2011), Sport6 (02-09-2011), stefan (02-07-2011), superskaterxes (02-07-2011), super_pablo_ (02-07-2011), taf0422 (02-09-2011), TexasSpeed3 (06-18-2011), themdamnstingrays (05-31-2013), the_caruch (02-07-2011), Toddy22587 (03-12-2011), Tomas (04-29-2013), trancehead (05-21-2013), triplejumper18 (02-07-2011), turboKart (09-05-2013), turd burglar (02-07-2011), uncorked11 (04-22-2013), vbt101 (04-28-2011), Vinnie (05-15-2011), wankular (02-07-2011), wette460 (04-13-2011), wolly6973 (02-08-2011), Worbit (08-29-2011), X-Man (02-07-2011), xcoldricex (02-07-2011), xdm88 (02-07-2011), xfeejayx (02-10-2011), xhymer (04-04-2011), xI Leveler Ix (04-22-2013), xPEPEx (04-07-2011), zpele (07-25-2011) |
![]() Join Date: Jan 2009 Location: Bangor PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,426
Groans: 88
| Not Ranked : 0 score fucking A dustin your Hot side on that turbo is so big that your Exhaust looks like a macaroni Noodle
__________________ 1995 honda civic. 1.6L slow 2007 Kawasaki ZX10r |
| The Following 5 Users Say Thank You to BrianZX10R For This Useful Post: | DaleNixon (02-08-2011), djuosnteisn (02-07-2011), LiEast (03-07-2011), mr_mazda329 (02-08-2011), SpeedSixxx (02-17-2011) |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 102
| Not Ranked : 0 score This looks fucking unbelievable!!!!! ![]() Fantastic job man. I cannot wait to see what thing can do when you start tuning. |
| The Following User Says Thank You to Click Here For This Useful Post: | djuosnteisn (02-07-2011) |
![]() Join Date: Aug 2009 Location: Albany, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 867
Groans: 39
| Not Ranked : 0 score skeet skeet skeet skeet skeet! clickin might be your vvt even, but either way, good luck man, looks foooookin amazing!
__________________ NO! No way am I havin a dick made outta hamburger! stocking out, buy my big turbo shit here, http://www.mazdaspeedforum.org/forum/forum/f229/bye-bye-big-turbo-dreams-82241/ more to come as stock shit arrives |
| The Following User Says Thank You to turd burglar For This Useful Post: | djuosnteisn (02-07-2011) |
![]() Join Date: Sep 2008 Location: CT/NY
Groans: 35
| Not Ranked : 0 score Craziness. I can't even handle how fucking awesome that looks. Can't wait to hear that puppy spool up!
__________________ ---------------------------------------------------------------------------- '06 Speed 6 Black MicaMazdaspeed SRI, Medieval inlet, Eibach Springs, Magnaflow cbe, 3 ebay catless dp, SU rmm, HKS ssqv, JBR stage 2 ssp Altered Customs fmic, Autotech fp internals Cobb AP, Stage 2+ 93 tweaked Centric blanks, EBC red pads Lotek center gauge pod: AEM wideband, Autometer boost and volts Tints, blacked emblems, spec-v front lip, Shark fin Redline MT-90, ITV-22s, Matt Damond OCC 13.66@102 Lebanon Valley 4/10/11 (sri, tp, rmm, ap) DO Meth kit waiting on install |
| The Following User Says Thank You to Docnox For This Useful Post: | djuosnteisn (02-07-2011) |
| Not Ranked : 0 score as always, excellent work Dustin! lovin your oil return fix....
| The Following User Says Thank You to Dano For This Useful Post: | djuosnteisn (02-07-2011) |
![]() Join Date: Mar 2010 Location: Atlanta GA
Rep Power: 277 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,077
Groans: 137
| Not Ranked : 0 score your the man btw |
| The Following User Says Thank You to Chriscote For This Useful Post: | djuosnteisn (02-07-2011) |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
| Not Ranked : 0 score dustin are you fucking serious? i hope your mind is the only thing thats blown
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
| The Following 5 Users Say Thank You to m4tic For This Useful Post: | djuosnteisn (02-07-2011), dougefresh_ (03-19-2011), Juyoung (04-23-2013), NoRegrets (02-16-2011), xcoldricex (02-07-2011) |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
| Not Ranked : 0 score very nice!
__________________ it's fun to do bad things |
| The Following User Says Thank You to jack_hammer For This Useful Post: | djuosnteisn (02-07-2011) |
![]() ![]() Join Date: Jun 2008 Location: Greenville, SC
Rep Power: 2562 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,586
Groans: 125
| Not Ranked : 0 score ibtw in before the win!
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 |
| The Following 2 Users Say Thank You to socks For This Useful Post: | 06Speed6 (02-07-2011), djuosnteisn (02-07-2011) |
![]() Join Date: Nov 2008 Location: Sanford/Orlando/Daytona Beach FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,682
Groans: 278
| Not Ranked : 0 score fucking tits. that set up is b-e-a-utiful. awesome work
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" |
| The Following User Says Thank You to IshiKage For This Useful Post: | djuosnteisn (02-07-2011) |
![]() Join Date: Apr 2010 Location: Houston, Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 35,474
Groans: 131
| Not Ranked : 0 score hot shit. need vids ASAP, even if they're like this guy: skip to 1:08 for the show
__________________ Cobb SRI CPE 75 duro RMM AP - tune in progress broke ass college student |
| The Following User Says Thank You to PunjabiPlaya For This Useful Post: | djuosnteisn (02-07-2011) |
| Banned ![]() Join Date: Feb 2010 Location: Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 500
Groans: 132
Groaned at 166 Times in 92 Posts
| Not Ranked : 0 score That thing is huge! How tight is the clearance against your hood? also: |
| The Following User Says Thank You to MS33SM For This Useful Post: | djuosnteisn (02-07-2011) |
![]() Join Date: Nov 2010 Location: Hershey, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 245
| Not Ranked : 0 score That turbo is insane!!! everything looks insane, but so so wonderful
__________________ 2006 Mazdaspeed6 Black Mica GT w/ Navi ~34k miles Sold 2008 Mazdaspeed3 Black Mica GT~55k miles NATOR PA IS NUMERO UNO |
| The Following User Says Thank You to Speed13 For This Useful Post: | djuosnteisn (02-07-2011) |
![]() Join Date: Apr 2009 Location: Great White North
Rep Power: 512 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,214
| Not Ranked : 0 score Nice setup man! I'm jealous. I'm definitely leaning towards a top mount setup now.... Did you do all this in your home garage? What kind of fabrication tools do you have access to??
__________________ Mod List: ATP 3071R @ 22 psi, Grimspeed in 3-port mode, Steedspeed Manifold, Snow Performance Stage 2 Meth Kit, Cobb AP, CP-E 3" Nano SRI, CP-E Big Inlet TIP, Cobb "Stage 2" Suspension Kit, CP-E FMIC, CP-E DP, CP-E HPFP, CP-E MM, TWM STS, Custom Tuned by Fobio. |
| The Following User Says Thank You to -cj- For This Useful Post: | djuosnteisn (02-07-2011) |
(Thread Starter) | Not Ranked : 0 score Not horrible actually. I'm gonna pull the liner off and put my turbo sock on the hot side. Things clear great though IMO.
You'd be surprised how much you can do with some basic tools and a lot of patience lol.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
| The Following 7 Users Say Thank You to djuosnteisn For This Useful Post: | -cj- (02-07-2011), I Love Brownies (02-07-2011), JBR (07-20-2011), Juyoung (04-23-2013), SilverDemon (02-07-2011), spoolin00 (02-07-2011), xdm88 (02-07-2011) |
![]() Join Date: Nov 2009 Location: Tempe, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,225
Groans: 65
| Not Ranked : 0 score Awesome man, that is beautiful. That thing is a monster, keep the cats away so they don't get sucked in. |
| The Following User Says Thank You to AZSPEED3 For This Useful Post: | djuosnteisn (02-07-2011) |
| The Following 14 Users Say Thank You to djuosnteisn For This Useful Post: | AZSPEED3 (02-07-2011), charlesfist (05-17-2011), cocoanton (04-12-2011), DaleNixon (02-08-2011), JacksonMS30 (02-07-2011), JMEngineer (02-07-2011), Juyoung (04-23-2013), kunfu (02-07-2011), LiEast (03-07-2011), MPSdriver (02-08-2011), Scynfewl (02-12-2011), Snotrocket (08-07-2011), spoolin00 (02-07-2011), xdm88 (02-07-2011) |
![]() | | #19 | ![]() |
Groans: 65
| The Following 2 Users Say Thank You to AZSPEED3 For This Useful Post: | DaleNixon (02-08-2011), djuosnteisn (02-07-2011) |
![]() | | #20 | ![]() |
![]() Join Date: Jul 2008 Location: Canton, Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,233
| Not Ranked : 0 score god dammit dustin. you make me feel like an automotive-dumbass when you post up shit like this. that setup is ridiculous! MUST HAVE VIDEOS ![]() i applaud you on your continued custom work to the platform ![]() ![]() ![]() ![]()
__________________ cp-e CAI, cp-e Turbo Inlet, cp-e catted DP, cp-e HPFP, cp-e flashes, cp-e Standback w/PNP, cp-e FMIC, TRZ RMM, TS Compact BOV (full re-circ), DDM 55W 6k HID's, Cobb RSB. HKS Hi-Power Exhaust, OCC |
| The Following User Says Thank You to the_caruch For This Useful Post: | djuosnteisn (02-07-2011) |
![]() | | #21 | ![]() |
![]() Join Date: Jun 2009 Location: Denver Colorado
Rep Power: 2697 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,601
^^ Dustins fabrication tool... Very nicely done sir! What kind of power are you thinking it will make? | |
| The Following 10 Users Say Thank You to JacksonMS30 For This Useful Post: | -cj- (02-07-2011), Dash08 (02-07-2011), djuosnteisn (02-07-2011), doubleflusher (02-08-2011), fishin53 (02-07-2011), i8urgti (07-10-2011), Juyoung (04-23-2013), madvillain (02-07-2011), mr_mazda329 (02-08-2011), spoolin00 (02-07-2011) |
![]() | | #22 | ![]() |
![]() Join Date: Jan 2010 Location: charles co, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,295
| Not Ranked : 0 score If you are going to blow the stocker you are not going to pussy out like the rest of us with just a little rod through the back of the block you are going to COMPLETELY destroy that fucker!!!!!! Cant wait to see this against that mustang you raced in the last vid or maybe you can catch up with that supra this time and have a rematch!!!! GOOD LUCK DJ i'm pulling for you!!!! ![]()
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport |
![]() | | #23 | ![]() |
![]() Join Date: Mar 2009 Location: Oceanside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 925
| Not Ranked : 0 score Looks sick man! must be nice to be sooooo close to being done after this long. Cant wait to see vids of this thing ripping and spinning all four!
__________________ Murdered out 2007 speed3 GT with navi. |
| The Following User Says Thank You to mtnrunner For This Useful Post: | djuosnteisn (02-07-2011) |
![]() | | #24 | ![]() |
![]() Join Date: Mar 2009 Location: Portlandia, Oregano
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,295
Groans: 196
| Not Ranked : 0 score You're gonna feed Kat to the turbo gods?
__________________ |
| The Following 4 Users Say Thank You to triplejumper18 For This Useful Post: | DaleNixon (02-08-2011), djuosnteisn (02-07-2011), I Love Brownies (02-07-2011), jmhinkle (02-08-2011) |
![]() | | #25 | ![]() |
| Fuck sushi rolls ![]() Join Date: May 2008 Location: Los Angeles
Rep Power: 12764 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,168
Groans: 356
| Not Ranked : 0 score looks great mr. hawkins , awesome that you took so many pictures as well. Cant wait to see this at a SEA LEVEL drag strip. keep kicking ass ese
__________________ 2007 Ms3 3071r fully bolted , retired and sold after 110k miles of abuse 2014 Black Track Pack premium , NA 4lyfe ...AED dyno tuned on E85 466.6whp / 406.8 TQ SAE |
| The Following User Says Thank You to rodrigo For This Useful Post: | djuosnteisn (02-07-2011) |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm hoping this turbo is big enough to bring sea level to me.
| The Following 64 Users Say Thank You to djuosnteisn For This Useful Post: | -cj- (02-07-2011), 8.5MS3 (02-07-2011), banditscout (02-13-2011), bcmurphy87 (06-18-2011), BobtailedSnail (12-03-2011), charlesfist (05-17-2011), Chriscote (02-07-2011), cocoanton (04-12-2011), cpolly69 (02-08-2011), DaleNixon (02-08-2011), danesti (03-06-2011), Darksun280 (02-07-2011), Dash08 (02-07-2011), DingoDave (06-14-2011), dougefresh_ (08-28-2011), efispeed (02-18-2011), essejkcamraw (02-08-2011), fishin53 (02-07-2011), Fobio (02-07-2011), I Love Brownies (02-07-2011), i8urgti (07-10-2011), JacksonMS30 (02-07-2011), jax ms3gt (02-07-2011), jmhinkle (02-08-2011), jracer (02-08-2011), jtspells (02-07-2011), Juyoung (04-23-2013), kunfu (02-07-2011), madvillain (02-07-2011), MATT DAMOND (05-06-2011), MDRracing13 (02-10-2011), MPSdriver (02-08-2011), mtnrunner (02-07-2011), NJSPEED3 (02-07-2011), NoRegrets (02-16-2011), psychophyr (02-07-2011), PunjabiPlaya (02-07-2011), qtrmile beast (02-07-2011), ReD BoY (09-09-2011), reidclark (09-18-2011), rodrigo (02-07-2011), Scynfewl (02-12-2011), SilverDemon (02-07-2011), Snotrocket (08-07-2011), spd6guy90 (02-07-2011), Speed freak (02-07-2011), Speed2006 (07-14-2015), Speed3eak (02-07-2011), spoolin00 (02-07-2011), Sport6 (02-09-2011), Stealth01 (02-07-2011), superskaterxes (02-07-2011), taf0422 (02-09-2011), the_caruch (02-07-2011), turd burglar (02-07-2011), wankular (02-07-2011), wette460 (04-13-2011), wolly6973 (02-08-2011), Worbit (08-29-2011), X-Man (02-07-2011), xdm88 (02-07-2011), xfeejayx (02-10-2011), ZoomZoomPSSH (02-07-2011) |
![]() | | #27 | ![]() |
Groans: 356
| Not Ranked : 0 score lol, well put.
![]() | | #28 | ![]() |
| Not Ranked : 0 score as i said the other night, lolz @ last march when you said your built motor setup would only take a month hahahaha hopefully it was all worth it!!! make us proud!!!
| The Following 5 Users Say Thank You to superskaterxes For This Useful Post: | Alpha (02-07-2011), djuosnteisn (02-07-2011), Juyoung (04-23-2013), MPSdriver (02-08-2011), NJSPEED3 (02-07-2011) |
![]() | | #29 | ![]() |
| Not Ranked : 0 score I think Dustin is trying to be the first to put an MZR rod into outerspace... |
| The Following 22 Users Say Thank You to JacksonMS30 For This Useful Post: | 09Speed3Z (02-07-2011), banditscout (02-13-2011), Broxer (09-06-2011), charlesfist (05-17-2011), cpolly69 (02-08-2011), DaleNixon (02-08-2011), Dash08 (02-07-2011), djuosnteisn (02-07-2011), easy (02-08-2011), i8urgti (07-10-2011), JMEngineer (02-07-2011), Juyoung (04-23-2013), kunfu (02-07-2011), MATT DAMOND (05-06-2011), Mazdaspeed3GT (08-19-2011), NoRegrets (02-16-2011), reidclark (09-18-2011), rigor (02-07-2011), Scynfewl (02-12-2011), Stealth01 (02-07-2011), vbt101 (04-28-2011), Worbit (08-29-2011) |
![]() | | #30 | ![]() |
![]() Join Date: Dec 2009 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,256
| Not Ranked : 0 score NASTY! I can't wait to have my fab guy tackle a nice top mount EFR setup!
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() |
| The Following User Says Thank You to Alpha For This Useful Post: | djuosnteisn (02-07-2011) |
![]() | | #31 | ![]() |
![]() Join Date: Sep 2009 Location: MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 71
| Not Ranked : 0 score Tits... that reminds me i need to get my rebuild going... fuck. |
| The Following User Says Thank You to R.MS3 For This Useful Post: | djuosnteisn (02-07-2011) |
![]() | | #32 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,452
Groans: 82
| Not Ranked : 0 score DJ, between you and jwilks I guess we're going to find out how much power these rods can take before they give out with a good tune. cue applause |
| The Following User Says Thank You to Speed3eak For This Useful Post: | djuosnteisn (02-07-2011) |
![]() | | #33 | ![]() |
| 2zz mr-s ![]() Join Date: Nov 2010 Location: katy, tx
Rep Power: 3483 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groans: 239
| Not Ranked : 0 score god i hate you |
| The Following User Says Thank You to dooderek For This Useful Post: | djuosnteisn (02-07-2011) |
![]() | | #34 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 43
| Not Ranked : 0 score Stock block... man... i cant even imagine the size of your nuts ![]() But if there´s anyone that can pull it of it´s you
__________________ Oversteer - when passanger screams. Understeer - when driver screams. |
| The Following 2 Users Say Thank You to X-Man For This Useful Post: | djuosnteisn (02-07-2011), Juyoung (04-23-2013) |
![]() | | #35 | ![]() |
| I <3 your mom ![]() ![]() Join Date: Jul 2008 Location: Long Beach, CA.
Rep Power: 14358 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,316
Groans: 293
| Not Ranked : 0 score I think half the forum wants to stick their dick in your turbo because that shit is fucking sexy. Nice job on all the fab work man. Seeing this makes me want to learn to weld. I'm tired of buying other peoples shit. I'd rather make my own. |
| The Following 10 Users Say Thank You to Dash08 For This Useful Post: | Alpha (02-07-2011), amoosenamedhank (02-07-2011), charlesfist (05-17-2011), DaleNixon (02-08-2011), djuosnteisn (02-07-2011), dougefresh_ (08-28-2011), JacksonMS30 (02-07-2011), Juyoung (04-23-2013), qtrmile beast (02-07-2011), Scynfewl (02-12-2011) |
![]() | | #36 | ![]() |
Groans: 239
| Not Ranked : 0 score i bet even in your car ill still run 15's |
![]() | | #37 | ![]() |
| Robust Mongoloid ![]() Join Date: Aug 2009 Location: South Charlotte, NC
Rep Power: 6481 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,137
Groans: 399
| So, uhhhhhh yeahhhhh, East Coast Meet in Myrtle in May. You bringie?!?!?!?!?!! SHOTGUN!!!! Hahahahahaha
__________________ ______________________ Built By NATOR Tons of Ricer Mods
| The Following 2 Users Say Thank You to 09Speed3Z For This Useful Post: | djuosnteisn (02-07-2011), qtrmile beast (02-07-2011) |
![]() | | #38 | ![]() |
| Fux Wit It ![]() ![]() Join Date: Mar 2008 Location: Li
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,795
Groans: 175
| Neutral : +1 score DJ you haven't learned from my fail? You're maf is going to hate life on that bend plus it really should be about 11 inches away from the turbo and 5-6 inchs away from any bend. MY 240 couldn't catch idle for shit off Decel being as close as yours is to the turbo and on a bend to boot. Pre pare you're self for tunning issues.
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous |
| The Following 2 Users Say Thank You to Darksun280 For This Useful Post: | djuosnteisn (02-07-2011), silvapain (02-08-2011) |
![]() | | #39 | ![]() |
Everything else looks like pure win though...
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | |
| The Following 2 Users Say Thank You to cld12pk2go For This Useful Post: | djuosnteisn (02-07-2011), jack_hammer (02-07-2011) |
![]() | | #40 | ![]() |
![]() Join Date: May 2009 Location: Chicago, IL
Rep Power: 10249 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,116
Groans: 136
In addition, you may have to rotate the MAF around while tuning to get the best (i.e. most linear) response in relation to engine/turbo RPM's. Don't get me wrong, I'm not hating; I just want the car to run as well as possible.
__________________ | |
| The Following 2 Users Say Thank You to silvapain For This Useful Post: | Darksun280 (02-08-2011), djuosnteisn (02-08-2011) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/my-twin-scroll-bw-s300sx-88-75-a-71706/ | ||||
| PERM's MS6 | This thread | Refback | 09-19-2012 11:10 PM | |
| Mazdaspeed 3 > Any Evo :) - Page 3 - evolutionm.net | This thread | Refback | 07-21-2011 07:18 PM | |
| Mazdaspeed 3 > Any Evo :) - Page 2 - evolutionm.net | This thread | Pingback | 07-13-2011 02:03 PM | |
| exhaust manifold $250 twin scroll | Justin Lee | MazdaSpeed 3/6 - Turbo Induction | 20 | 10-14-2013 08:08 PM |
| removing twin scroll divider | turd burglar | MazdaSpeed 3/6 - Turbo Induction | 11 | 05-12-2010 11:06 PM |
| Chrysler to build plug-in Ram test fleet, won't build Two Mode hybrid pickup | Haltech | Automotive News | 0 | 03-22-2010 10:10 PM |
| Twin-Scroll K04?!?!? | Mfinlay04 | Mazdaspeed3/6 General Discussion | 37 | 05-27-2009 06:28 PM |
