Like Tree9Likes
 Old 06-10-2013, 07:25 PM   #41
Mortose's Avatar
Posts: 2,441   (View Stats)
Groans: 39
Right now, @Lex; and I (mostly Lex) are working on a minor issue of the boost going a little higher than commanded. Once that is smoothed out, then comes the e85 revision.
I'm pretty much lex's puppet. He say do this, and without hesitation I do it. Lol
Give it a little tappy, a tap tap tap-a-roo
99 miata: sold
The Following User Says Thank You to Mortose For This Useful Post:
Lex (06-19-2013)
 Old 06-12-2013, 11:05 AM   #42
Mortose's Avatar
Groans: 39
Updated OP with a couple things, being that this turbo is gaining some popularity.
99 miata: sold
The Following 2 Users Say Thank You to Mortose For This Useful Post:
Gibbo (06-12-2013), Lex (06-19-2013)
 Old 06-19-2013, 09:35 AM   #43
Mortose's Avatar
Groans: 39
Update time!!!!
So, i'm on my 3rd revision of my E85 mix, and i will post logs this afternoon when i get home.
It seems, talking with @Lex; that i have a bit of an issue. Boost is not getting up to where we want it to be with as high as my WGDC is. The though is ether my DP cat is too restrictive, or there was not enough pre-load on the wastegate from the factory. I have a line on a catless DP, thanks to @RLam;.
Hopefully this aleviates the boost celing that we seem to have hit, and we can really open her up.
As of right now, the car pulls GREAT! my 60-100 is staying in the low 5 second range.
I'll post a VD with the logs this afternoon.
99 miata: sold
The Following 5 Users Say Thank You to Mortose For This Useful Post:
atvfreek (06-19-2013), fivefingerdeathpunch (06-19-2013), Lex (06-19-2013), RLam (06-19-2013), SpeedRebirth (06-19-2013)
 Old 06-19-2013, 06:48 PM   #44
Mortose's Avatar
Groans: 39
So here is the VD chart, and attached are the logs, as promised.
And it looks like I'll be installing the catless DP this sunday to help get that boost up.
99 miata: sold
DSIT995 (08-14-2013)
 Old 06-19-2013, 07:31 PM   #45
Godsarmy's Avatar
Posts: 160   (View Stats)
Godsarmy has a reputation beyond reputeGodsarmy has a reputation beyond reputeGodsarmy has a reputation beyond reputeGodsarmy has a reputation beyond reputeGodsarmy has a reputation beyond reputeGodsarmy has a reputation beyond reputeGodsarmy has a reputation beyond reputeGodsarmy has a reputation beyond reputeGodsarmy has a reputation beyond reputeGodsarmy has a reputation beyond reputeGodsarmy has a reputation beyond repute
Groaned at 3 Times in 1 Post
O man ill have to check this thing out sounds like its one bad ass turbo for us high elevation guys with the good spool
2008 speed3 HTA35R/CPE mani/TIAL44mm gate/HTP 3.5 INTAKE/MAZDASPEED CATBACK/JBR RMM/forge v1/greddy turbo timer/COBB AP/CNT catless downpipe/At internals/DO WATERMETH STAGE 2.5 KIT
zex intercoller sprayer/502whp443wtq 91 octane 26psi
Motegi 18X8
Powered By Purple Drank
Godsarmy is offline   Reply With Quote
The Following User Says Thank You to Godsarmy For This Useful Post:
Mortose (06-19-2013)
 Old 06-20-2013, 10:40 AM   #46
I'll just interrupt the car chat for a second here to say how great Josh has been to work with. We value each and every one of our customers and thank them all for the business.
Josh is an example of someone who went above and beyond. During the tuning process, we sent us a loaf of home made banana bread! He lives in CO and we are in Vancouver, Canada!
Thank you Josh!
Mortose likes this.
atvfreek (06-20-2013), fivefingerdeathpunch (06-20-2013), LumberJack (06-20-2013), Mortose (06-20-2013), omgvance (03-13-2014), RLam (06-21-2013)
 Old 06-24-2013, 10:10 PM   #47
Mortose's Avatar
Groans: 39
Ok, so not a HUGE update:
Swapped the down pipe on Sunday, thanks to @RLam;
side note: all cars should come with an "aftermarket" down pipe, because that took no time to swap out.
Lex put me on a "base" map for the new down pipe, as to not cause over boost. Also, i didn't adjust the waste gate pre-load, as i wanted to do one variable at a time. (also, its a bit of a pain in the dick to do, and i was just a little lazy). Boost was holding well on spring pressure, and now we are walking boost back up to see how it does. Once I'm back up to the 22-23 psi area, i'll do a comparison of spool between the catless and catted pipes just for gee-wiz info for all you little big turbo fans out there. Right now i'm on my second revision of the catless tune + E85.
A HUGE thank you to @Lex; for not trying to kill me from Canada for changing up parts like this, this late in the game as far as the tuning is concerned.
99 miata: sold
RLam (06-25-2013)
 Old 06-24-2013, 10:42 PM   #48
tbot's Avatar
Posts: 2,821   (View Stats)
Groans: 40
Right on man...good to see you making some head way.
I got everything installed on my car, but have an issue with the wastegate being open all the time, so need to trouble shoot that, and it sounds to me like I need to get on Lex's list for a tune...once I get this issue fixed that is.
Sent from my HTC One using Tapatalk 2
 Old 07-13-2013, 01:31 PM   #49
Mortose's Avatar
Groans: 39
UPDATE:
So, @Lex; and i have gone through a few revisions on the catless DP. I have attached the latest logs for your viewing pleasure.
Unfortunately, my clutch has begun the process of giving up on life. So, for the time being, i'm calling it as far as tuning until i can round up the funds to purchase/replace the clutch. I will be going with the ACT 6 puck sprung kit, with the streetlite flywheel.
ALSO: the "supercharger" noise that i was talking about, come to find out, it was the turbo leaking!!!! WTF. So i spoke with JP at Edge, and the first (and thankfully last) step was to tighten down the bolts that hold the bracket featured here:
this, luckily, sealed the leak that i had.
A special thanks to @EdgeAutosport.com; for being AWESOME and catering to those of us who come across the oddest issues.
I don't know if Lex would like to comment on how he feels the tune is? or how much harder he thinks we could push it.
99 miata: sold
atvfreek (07-13-2013), EdgeAutosport.com (07-16-2013), Lex (07-13-2013), Voltwings (07-13-2013), YABBAMZR (07-13-2013)
 Old 07-13-2013, 02:21 PM   #50
Just wrote you a long reply with another iteration. A couple of things need to be checked as to why the turbo isn't holding boost up top but aside from that it's doing all it can at that altitude and with 100*F IATs.
atvfreek (07-13-2013), Mortose (07-13-2013)
 Old 07-13-2013, 02:43 PM   #51
Mortose's Avatar
Groans: 39
Kewl beans lex!
Also, I'm trying to get a couple other nator CO BT guys to give me a log or two so I can do a spool comparison for folks wondering how this turbo stacks up at altitude.
99 miata: sold
 Old 08-02-2013, 10:23 PM   #52
unijabnx2000's Avatar
Posts: 35   (View Stats)
unijabnx2000 is just really niceunijabnx2000 is just really niceunijabnx2000 is just really niceunijabnx2000 is just really niceunijabnx2000 is just really nice
More updates?
unijabnx2000 is offline   Reply With Quote
 Old 08-03-2013, 01:31 PM   #53
Mortose's Avatar
Groans: 39
Unfortunately not. My clutch won't even hold through a 4th gear pull anymore. Luckily it's holding strong for day to day driving back and forth to work and what not.
I'm currently getting together the funds for the clutch/install, which isn't cheap by any means.
Once the clutch is in, I'll be getting back with @Lex; to put the final touches on the tune and possibly making some adjustments. Once it's all said and done, I'll hop on the same Dyno from my K04 run so that there can be a comparison.
99 miata: sold
Lex (08-07-2013)
 Old 08-29-2013, 10:53 PM   #54
Mortose's Avatar
Groans: 39
Small update: put in my order with ACT for the clutch. The ZX5-HDG6 - HD/Race Sprung 6 Pad kit.
Problem is, the pressure plates are out for heat treating, and it's a 2 week wait.
99 miata: sold
 Old 08-29-2013, 11:02 PM   #55
snailD's Avatar
Posts: 3,039   (View Stats)
i've been chilling on my pump gas map since my clutch started to slip. still fun at 22psi.
i probably could read more, but have you messed with your WGA at all? i tightened mine a but in order to run 26psi to redline
 Old 08-29-2013, 11:09 PM   #56
Mortose's Avatar
Groans: 39
Lex and I are going to see how it performs with a clutch that doesn't suck balls, and then go from there. If he feels like we could get more out of it, then I'll tighten the waste gate a little.
I'm really happy with this turbo. And it's going to be nice to see how it does in the cold fall/winter air.
99 miata: sold
 Old 09-27-2013, 11:22 AM   #57
Mortose's Avatar
Groans: 39
Well, got another update from ACT today. My order has been pushed to the 15th of October now.
Sorry to anyone who was hoping for results soon.
99 miata: sold
 Old 09-27-2013, 06:42 PM   #58
Jeff23spl's Avatar
Posts: 2,237   (View Stats)
Damm for your clutch!
It s a good writting, i was looking at this turbo also just before i got a deal on a 2871 cast wheel and the GTX2867 seem to flow almost the same with a 4mm smaller wheel!!!
I'm surprise that you got boost about 5-600rpm higher than k04 because i experience about the same with the 2871 and i was expecting a better response from the smaller one...(Something more close to the k04 like 200rpm...) Can it be just because of your altitude, engine deliver less torque at low rpm so less flow to run the turbine ?
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 09-27-2013, 10:10 PM   #59
Mortose's Avatar
Groans: 39
The altitude does screw us here. It slows our spool a little, as well as peak boost levels are affected.
You can search around, at the same boost levels, cars at altitude flow less g/s. At 24 psi I'm barely over 300 g/s.
99 miata: sold
 Old 10-09-2013, 06:29 PM   #60
maxspeed3's Avatar
Posts: 386   (View Stats)
maxspeed3 is the leader of the worldmaxspeed3 is the leader of the worldmaxspeed3 is the leader of the worldmaxspeed3 is the leader of the worldmaxspeed3 is the leader of the worldmaxspeed3 is the leader of the worldmaxspeed3 is the leader of the worldmaxspeed3 is the leader of the worldmaxspeed3 is the leader of the worldmaxspeed3 is the leader of the worldmaxspeed3 is the leader of the world
Can you post a driving video of the snail? I want to hear the sexiness!
Current ~2013 WRX STI~
2007 Mazdaspeed3 GT Stocked Out and Sold
maxspeed3 is offline   Reply With Quote
 Old 10-09-2013, 06:36 PM   #61
Mortose's Avatar
Groans: 39
Yea, I can try knocking it out this weekend.
99 miata: sold
maxspeed3 (10-09-2013)
 Old 10-09-2013, 07:27 PM   #62
Mortose's Avatar
Groans: 39
@maxspeed3;
Side note: I see your in MN. what is the premium octane up there? Lol
I'm from north of Duluth, and am planning a trip home early next year. Lol
99 miata: sold
 Old 10-10-2013, 07:10 AM   #63
maxspeed3's Avatar
Originally Posted by Mortose View Post
@maxspeed3;
Most places have 91 as premium. BP has 93 octane and Super America has 92 as there premium. Same with Holiday also has E85! Both 91 & 93 are very easy to find around where I live. I would assume Duluth, being a larger city would have 91 & 93, and most likely E85.
 Old 10-10-2013, 07:53 AM   #64
Mortose's Avatar
Groans: 39
that works. What really sucks, is that i lived 60 miles north of Duluth, in a town of 2800 people, with 1 stop light.
99 miata: sold
 Old 10-16-2013, 10:46 AM   #65
Mortose's Avatar
Groans: 39
Update:
So, little change of plans. Because ACT was taking there sweet time, i contacted @EdgeAutosport.com; and talked to JP, who got a unit shipped THAT DAY!!!!!!! so i should be seeing it late this week, because i'm too lazy (and working) to drive to denver to pick it up.
@maxspeed3; sorry i didn't get to that video man. some pretty substantial life altering things came up. But i didn't forget about ya. I'm going to wait till the clutch is in, and broken in, that way i can get a true WOT pull, instead of a half assed pull because fail clutch.
99 miata: sold
 Old 10-16-2013, 11:22 AM   #66
maxspeed3's Avatar
Update:
No worries at all man! Hope everything works out well for you! Once you have the video the will be a lot better!
 Old 10-17-2013, 01:29 PM   #67
Mortose's Avatar
Groans: 39
Thanks again to edge!!! Install will be next week some time!
99 miata: sold
Dimenus (10-17-2013)
 Old 10-24-2013, 08:04 PM   #68
Mortose's Avatar
Groans: 39
Picking up the car tomorrow. Slight delays at the shop here in town, but not to terrible.
@Lex; are you ready to put the finishing touches on the tune?! (I know your gunna be busy with sema by the time the clutch is fully broken in)
99 miata: sold
 Old 11-04-2013, 10:55 AM   #69
Mortose's Avatar
Groans: 39
So, after some slight other issues, i finally got the car back friday afternoon.
Overall, UPP here in town did a fantastic job on my clutch. No adjustments needed to be made after the fact.
I will be doing a full write up on the shop in the Nator CO section for others to use as referance.
Looking to put another 200-250 miles on the clutch before i go ape shit and WOT everywhere because race car, so expect another update most likely by next weekend.
99 miata: sold
atvfreek (11-04-2013)
 Old 11-04-2013, 11:07 AM   #70
maxspeed3's Avatar
And a video of the spooling with pulls!
The Following User Says Thank You to maxspeed3 For This Useful Post:
Mortose (11-04-2013)
 Old 01-28-2014, 04:09 PM   #71
Mortose's Avatar
Groans: 39
THREAD REVIVAL!!!!
Ok, so over the past week or so, me and lex finaly got back together to finish this bad boy up. I'm at work right now, so i don't have the logs, but i'll post those when i get home tonight.
For now, all i can say is that this car pulls like a frieght-Train all the way through the rev range, and i can't even think about punching it in anything lower than 3k in 3rd or i'll just spin. @Lex; did a terrific job on the tune, as always. I would reccomend him to ANYONE looking for a tune.
As a teaser, i have this chart from lex. When i get home i'll post the MSF standard 1.01 with logs.
File Type: jpg 1510741_10152165971212416_1942551664_n.jpg (73.0 KB, 86 views)
asrautox likes this.
99 miata: sold
Godsarmy (01-28-2014), Lex (01-28-2014), SarcasticOne (01-28-2014), snailD (01-28-2014), YABBAMZR (01-28-2014)
 Old 01-28-2014, 05:06 PM   #72
THREAD REVIVAL!!!!
Just sent you another map Josh. I got an idea that may work to get you a couple more ponies. Give it a shot and let's see if it makes a difference on your setup .
Mortose (01-29-2014), snailD (01-28-2014)
 Old 01-28-2014, 05:11 PM   #73
snailD's Avatar
glad to see this running solid! If i didn't do my own tuning i'd go to @Lex;, he always works hard to get all the issues figured out and every one of his customers are happy. great job guys.
The Following 4 Users Say Thank You to snailD For This Useful Post:
Lex (01-28-2014), Mike@Stratified (01-29-2014), Mortose (01-29-2014), MZRSPEED (01-28-2014)
 Old 01-29-2014, 07:34 PM   #74
asrautox's Avatar
Posts: 196   (View Stats)
asrautox is the leader of the worldasrautox is the leader of the worldasrautox is the leader of the worldasrautox is the leader of the worldasrautox is the leader of the worldasrautox is the leader of the worldasrautox is the leader of the worldasrautox is the leader of the worldasrautox is the leader of the worldasrautox is the leader of the worldasrautox is the leader of the world
Is this on 91? If so, really impressive. If not, still impressive
Tapatalking out of my ass
2011 PB EVOX GSR | FBO + E85
(Sold) 2008 Black Mica MS3 | Cobb AP | UR DP+TP | HTP 3" | CS TMIC | CS BPV | Autotech HPFP | CPE RMM | JBR SSP | Koni Yellows | Cobb RSB | SPC Camber Arms | E40 Self Tune - 295whp/327wtq Uncorrected @ 5600' ASL
2014 Triumph Street Triple R
asrautox is offline   Reply With Quote
 Old 01-29-2014, 09:45 PM   #75
Mortose's Avatar
Groans: 39
Alright, here is the graph with the logs, sorry its a day late.
99 miata: sold
The Following 3 Users Say Thank You to Mortose For This Useful Post:
mituc (01-30-2014), NCspecV81 (01-29-2014), YABBAMZR (01-30-2014)
 Old 01-29-2014, 09:48 PM   #76
Mortose's Avatar
Groans: 39
Nope, this is on corn.
99 miata: sold
 Old 01-29-2014, 10:14 PM   #77
6000 feet altitude does take its toll on what the turbo can do.
 Old 01-29-2014, 10:19 PM   #78
NCspecV81's Avatar
Posts: 2,867   (View Stats)
Nice. Though I do have one quick question. You have the same intake as myself but when hitting 4.52v on MAF I"m only hitting 315g/s and yours is 367g/s. Is that an elevation thing or is my MAF cal off?
 Old 01-29-2014, 10:22 PM   #79
msantana101's Avatar
Posts: 1,517   (View Stats)
Gahhh I've been debating if/when I go BT to get either this or a BNR. This just made the decision even harder
FreekTuned
 Old 01-29-2014, 10:27 PM   #80
Mortose's Avatar
Groans: 39
Honestly, i haz no idea. lol. you would have to ask @Lex; about the maf cal.
Who did your's?
and realize that this power output is at 6300 feet ASL, so sea level would put down more.
99 miata: sold
Last edited by Mortose; 01-29-2014 at 10:27 PM. Reason: MSF Database - Automerged Doublepost
msantana101 (01-30-2014), NCspecV81 (01-29-2014)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/nator-co-gtx2867-145312/
Big Turbo GTX - Page 2 - Mazda 3 Quebec This thread Refback 01-31-2014 03:33 PM
GTX2867 417hp atvfreek 2010 MS3 - Dyno Sheets/Discussions 227 11-05-2013 12:09 PM
GTX2867 Turbo Kit - mismatched Banjo Bolt twowheelrides 2010 MS3 - Big Turbo Builds 6 05-12-2013 05:46 AM
GTX2867! EdgeAutosport.com EdgeAutosport.com 237 12-10-2012 10:33 PM
Page generated in 0.57318 seconds with 31 queries
