![]() | | #81 | ![]() |
Groans: 111
| Not Ranked : 0 score
I'm so jealous when I see people pushing so much timing up top where I can't push more than like 12-12.5 degrees on pump gas at even slightly lower air flow, and this makes me want WMI
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
![]() | | #82 | ![]() |
![]() Join Date: Apr 2013 Location: Wilkesboro, North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,221
Sorry mortose didn't mean to thread jack. | |
![]() | | #83 | ![]() |
![]() Join Date: Feb 2011 Location: Aurora, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,094
Groans: 39
(Thread Starter) | Not Ranked : 0 score No worries man. If ya learn somthing, then its all good with me. lol.
__________________ 2008.5 Metropolitan Grey Mica: Sold 99 miata: sold 2011 Wicked White Evo X: built motor and efr7163 w/ full flex fuel TRex - "i dont care if it is a soccer mom in a mini van, if that whore launches on me im going at it like im racing a supra....just so i can bask in the sweet sweet tears of their defeat" |
![]() | | #84 | ![]() |
![]() Join Date: Oct 2012 Location: Golden, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31
| Not Ranked : 0 score You're not kidding. For reference, what's the most you've seen from a K04 at this altitude?
__________________ 2011 PB EVOX GSR | FBO + E85 ![]() (Sold) 2008 Black Mica MS3 | Cobb AP | UR DP+TP | HTP 3" | CS TMIC | CS BPV | Autotech HPFP | CPE RMM | JBR SSP | Koni Yellows | Cobb RSB | SPC Camber Arms | E40 Self Tune - 295whp/327wtq Uncorrected @ 5600' ASL 2014 Triumph Street Triple R |
![]() | | #85 | ![]() |
| Not Ranked : 0 score The MAF is scaled for the E85 fuel being used and to get his AFRs in check at above 2.50 load. The AFRs are right on target and fueling is correct and that's what matters.
![]() | | #86 | ![]() |
Groans: 39
(Thread Starter) | Not Ranked : 0 score So, for everyone who is following this thread for results and impressions, it has now come to a close. We all know sometimes things just fall in our laps, and that happened to me. I scored a deal on a lightly used, unmodded 2011 Evo X. No longer do i have the speed. For final impressions of this turbo: I have ridden in 3071's, 3076's, and 35r's. Out of all the turbo setups, I feel this one is the best for anyone looking for a good daily driving turbo setup that still makes fantastic power. I know I never hit the dyno, but i have a buddy who is looking to buy the speed, and i should be able to convince him to hit the dyno before he heads to germany. VD, with the 1.25 correction factor we see on the dyno's up here, with my last logs had me at about 415/450 to the wheels. I know this is probably pretty generous, as previously discussed in this thread (at lenght, lol) but it gives comparison to the KO4 numbers I had. Tuning with @Lex; was a pleasure the WHOLE time, and I couldn't be happier with the results and the customer service. I reccomend Stratified to ANYONE looking for a tune. Never once did I worry about my car doing something crazy. Lex always had the answers to put my mind at ease when I was over reacting from some small issue. lol Thanks again to @EdgeAutosport.com; for all the support and the great deal on parts, i'll be hitting you guys up for the evo as well. And thanks to @atvfreek; and @snailD; for answering my random questions through this whole process.
| The Following 7 Users Say Thank You to Mortose For This Useful Post: | ArmanRus (02-04-2014), atvfreek (02-03-2014), fivefingerdeathpunch (02-04-2014), Lex (02-04-2014), Poohster (02-03-2014), snailD (02-03-2014), Status Update (02-03-2014) |
![]() | | #87 | ![]() |
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
| The Following User Says Thank You to atvfreek For This Useful Post: | Mortose (02-03-2014) |
![]() | | #88 | ![]() |
| Not Ranked : 0 score LOL, I just traded my Speed for a 2011 Evo X as well! Lot's of Nator CO peeps going this route it seems..
| The Following User Says Thank You to asrautox For This Useful Post: | Mortose (02-03-2014) |
![]() | | #89 | ![]() |
![]() Join Date: Feb 2010 Location: SLC, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,720
| Not Ranked : 0 score damn! BUT i'm thinking your going the enjoy the new ride and will probably stick around here for a bit
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 |
| The Following User Says Thank You to snailD For This Useful Post: | Mortose (02-03-2014) |
![]() | | #90 | ![]() |
Groans: 39
And to rag on brownies.
__________________ 2008.5 Metropolitan Grey Mica: Sold 99 miata: sold 2011 Wicked White Evo X: built motor and efr7163 w/ full flex fuel TRex - "i dont care if it is a soccer mom in a mini van, if that whore launches on me im going at it like im racing a supra....just so i can bask in the sweet sweet tears of their defeat" | |
![]() | | #91 | ![]() |
![]() Join Date: Oct 2008 Location: MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 603
| Not Ranked : 0 score Congrats on the new ride. Sorry to see you go. I have been intrigued with GTX2867r by reading your thread and all the successful stories of this turbo that I am in your foot steps. Thank you for all your insight and sharing with the community.
__________________ 06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP RPM: Sport Springs, Shark Fin, LED side markers CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount |
| The Following User Says Thank You to Poohster For This Useful Post: | Mortose (02-03-2014) |
![]() | | #92 | ![]() |
| The Following User Says Thank You to Lex For This Useful Post: | Mortose (02-04-2014) |
![]() | | #93 | ![]() |
| Not Ranked : 0 score All is forgiven for going DSM if you leave your avatar alone. Congrats on the new ride.
| The Following User Says Thank You to JgamB For This Useful Post: | Mortose (02-04-2014) |
![]() | | #94 | ![]() |
Groans: 39
And @Lex; you ever think about tuning DSM's? lol
__________________ 2008.5 Metropolitan Grey Mica: Sold 99 miata: sold 2011 Wicked White Evo X: built motor and efr7163 w/ full flex fuel TRex - "i dont care if it is a soccer mom in a mini van, if that whore launches on me im going at it like im racing a supra....just so i can bask in the sweet sweet tears of their defeat" Last edited by Mortose; 02-04-2014 at 01:32 PM. | |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/nator-co-gtx2867-145312/ | ||||
| Big Turbo GTX - Page 2 - Mazda 3 Quebec | This thread | Refback | 01-31-2014 03:33 PM | |
| GTX2867 417hp | atvfreek | 2010 MS3 - Dyno Sheets/Discussions | 227 | 11-05-2013 12:09 PM |
| GTX2867 Turbo Kit - mismatched Banjo Bolt | twowheelrides | 2010 MS3 - Big Turbo Builds | 6 | 05-12-2013 05:46 AM |
| GTX2867! | EdgeAutosport.com | EdgeAutosport.com | 237 | 12-10-2012 10:33 PM |
