Like Tree48Likes
 Old 12-16-2011, 07:23 PM   #1
keefover's Avatar
Posts: 624   (View Stats)
keefover is the leader of the worldkeefover is the leader of the worldkeefover is the leader of the worldkeefover is the leader of the worldkeefover is the leader of the worldkeefover is the leader of the worldkeefover is the leader of the worldkeefover is the leader of the worldkeefover is the leader of the worldkeefover is the leader of the worldkeefover is the leader of the world
Groans: 42
Groaned at 49 Times in 11 Posts
Neutral  +1 score
Default Nator SoCal Wetting your bitches vages one Twin Turbo Build at a time
So after much deliberation I have decided to post up some pics a little early. She is still in the fabrication stages so it will still be a bit till she is battle tested but I am hoping for some fun results.
First a little history about this puppy. I picked her (2006 MS6 GT w/o Navi) up for the cool price of 13,200.00 with 47k on the clock back in late may. After throwing about 4k at her to get her bolted tragedy struck. Turns out you need a fuel pump cam rider after all (long story). I ended up sheering the fuel pump plunger but before that had the chance to fail it stopped the intake cam in its place causing the cam gear bolt to sheer. I.E.. catastrophic head failure. I haven't had to chance to inspect the valves yet but I am expecting the worst.
The build-
The block will still be useable and will be receiving a full rebuild to include Forged Wiseco pistons Forged Pauter rods. A full set of ARP bolts and studs will be the toothpick keeping this delicious sammach together. I was going to build the head along with the block but it looks as if I will be running into fueling problems long before I max out the flow on the head so she will be rebuilt back to factory specs.
The heat-
The Exhaust manifold is constructed out of Schedule 20 302 SS.
The balls-
I will be running twin K04's. The original plans for the exhaust mani were to run runners 1 with 4 and 2 with 3. Turns out that due to space constraints these plans had to you out the window. I will be using runners 1 with 2 and 3 with 4 to spool these shits. The fabrication of the down pipe has proven to be the biggest pain in the ass yet but she is a fucking beauty. If it wasn't so small around (3in) I would fuck it. VIP's you know what I'm talking about The down pipe will be a slip fit design.
The Blow-
I will be using 2in od aluminum piping on the pressure side y'ed into 3in down to the IC for the hot side. I am using a no name 3in in 3in out same side intercooler. The Cold side will be 3in as well connecting back up to the engine bay where a coupler will bring it up to 3.5in od to mate up with a tredstone 3.5in maf housing. I will be running a blow through maf setup using honeycomb air straightener before the maf to counter turbulence. Set up courtesy of @bcmurphy87. Meth will also be included in my setup controlled by an Aquamist HFS-5.
The tune-
Perm nigga . Nughf said.
All the parts are bought and paid for and I am in the process of fabing up the oil and coolant lines. If anyone has any stock coolant lines they can throw my way it would be appreciated. Now the fucking pictures!!!
Oh and @Derigo has his filthy little Asian hands in the build as well
Feel free to ask any questions, make any suggestions, or go fuck yourself. Thanks for looking and enjoy.
Update:
Blow thru setup is nearly complete, I just need to install the air straightener and she will be done. The BOV flange is going to be mounted as shown in the added pic. I have chosen to install it pre maf so I can VTA and impress all 1 of my Asian friends without problems. I will be running a 50mm Tial BOV (should be big enough to do the job). As you can see I had to give up a little crash bar Ill keep keep my fingers crossed that I won't ever miss it. I am going to need to re primer and paint the exposed metal areas to prevent future corrosion. Part of the inner fender had to be removed as well to accommodate the 3inch cold and hot pipes. I don't know if I have pics but I can get some. This is essentially it for the fab stages of the build. I will be pulling the motor and building the engine these coming weeks. I will also be rebuilding the turbos. Ill keep you all in the loop. Till then enjoy the new pics. Thanks again for looking
Overspeed Motorsports
Southern California's only Mazdaspeed performance expert
keefover is offline   Reply With Quote
The Following 113 Users Say Thank You to keefover For This Useful Post:
06Speed6 (01-20-2012), 802MS3 (12-21-2011), 86AmishMs3 (12-22-2011), aaronc7 (01-29-2012), adrianspd6 (09-05-2012), almcbs (11-19-2013), araw (03-05-2012), ASHMS3 (01-28-2012), AZSPEED3 (03-02-2012), Bleupit80 (05-21-2014), BlueStreak (01-04-2012), bmylez (01-11-2012), BobtailedSnail (01-20-2012), Boosted Beluga (01-30-2012), breakfasteatre (02-14-2012), burn813 (08-24-2012), bwspeed (12-26-2011), Coaststarlight (01-20-2012), codykemmet (08-25-2012), CorkSport (01-31-2012), crazyp (12-24-2011), CWP_MS3 (05-08-2012), daafisch (01-18-2012), Dahouse702 (01-10-2012), darkcherry (01-11-2012), Dash08 (12-21-2011), dereeek (03-19-2012), derek13p (05-08-2013), dizzydtrain (03-31-2012), djuosnteisn (02-05-2012), Docnox (01-28-2012), DoMiNic (02-13-2013), doubleflusher (05-08-2012), dougefresh_ (12-23-2011), drknyte (12-24-2011), Easter Bunny (08-23-2012), EdgeAutosport.com (12-21-2011), EL F00LI0 (12-16-2011), Eric28243 (04-05-2012), ESB Jiu JItsu (07-25-2012), Ferg (01-18-2012), fishin53 (12-26-2011), funka09 (08-17-2012), Geo13 (04-14-2012), GLORIFIEDBOZO (01-30-2012), Gr8Speed (02-18-2014), h.h.sk1nny (01-20-2012), Hamilton69 (01-30-2012), Hammology (09-27-2013), helmetface (03-04-2012), JacksonMS30 (02-06-2012), jm211 (02-02-2013), JohnMS3 (12-16-2011), Jonathan92c (08-25-2012), josurr (03-12-2012), jracer (12-18-2011), K7addict (01-10-2012), kmac (12-21-2011), KusteLokal (05-22-2012), maisonvi (02-14-2013), manelscout4life (08-25-2012), maxspeed3 (08-13-2012), mazdafreak (12-21-2011), Mazdazilla6 (05-02-2014), Mchart (08-25-2012), meicalnissyen (02-10-2012), Menace1 (02-13-2013), Micha (06-09-2012), midoritora (01-23-2012), Monotonous ONE (05-08-2012), MPSdriver (12-22-2011), MS3inDC (05-01-2012), MS3MYK (12-21-2011), Ms3_Miami (12-16-2011), Neverlift (12-16-2011), nighthawk358 (06-23-2012), NJSPEED3 (12-23-2011), Oliverms3 (10-10-2012), PapaSmurf (03-02-2012), paveltol (08-12-2012), psychophyr (12-21-2011), QwkEVO (01-10-2012), redmnsterut (05-08-2012), rigor (12-21-2011), Roddiy (06-23-2012), rtabagaboy (01-17-2012), Scribbles (01-04-2012), Seatime3 (06-17-2012), SKiZ0TT (01-11-2012), SleeperHatch (12-22-2011), SLOWHATCH (12-21-2011), speed23 (12-21-2011), Speed3eak (07-26-2012), SpeedSixxx (04-03-2012), SwineFLU (02-24-2012), TexasSpeed3 (03-04-2012), thehead (03-19-2012), TiGraySpeed6 (12-16-2011), Todd98SE (03-26-2013), Tomas (08-21-2012), Tommy (08-12-2012), TurboDreams (12-23-2011), TWOptSL0W (03-12-2012), uncorked11 (12-16-2011), Vader (01-30-2012), wankular (12-21-2011), Whiteboy (12-21-2011), wolly6973 (01-24-2012), xdm88 (03-04-2012), xfeejayx (01-11-2012), xtasy (01-11-2012), yurples (02-14-2013), Zdraveca (12-26-2011)
 Old 12-16-2011, 08:15 PM   #2
EL F00LI0's Avatar
Posts: 703   (View Stats)
EL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the world
This. Is. Going. To. Be. Epic!!!!!
I need to see this beast once its running.
Tapatalka
nswartz19 likes this.
2008 MAZDASPEED 3 GT
| Cobb SRI | Cobb XLE BPV | SURE TIP | SURE RMM | Resonators Deleted | TurboXs Catless DP |
| Cobb AP Stage 2+ | PG/Godspeed FMIC | BC Coilovers | Evo X Wheels | 245/40/18 Hankook RS3 |
| Cquence Drilled/Slotted Rotors | Hawk HPS Pads | TWM STS | Glowshift Boost Gauge | Sti V Limited Front Lip |
EL F00LI0 is offline   Reply With Quote
The Following User Says Thank You to EL F00LI0 For This Useful Post:
keefover (01-07-2012)
 Old 12-16-2011, 08:26 PM   #3
zpele's Avatar
Posts: 1,654   (View Stats)
zpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the world
Groans: 354
Groaned at 213 Times in 109 Posts
Well its gonna be cool but may I ask the following..... What's the point?
2012 Shelby GT500 - Roush Axleback ~ JLT Oil Separator ~ JLT 123mm intake ~ Ngauge ~ Lund Tuned ~ smaller pulley ~ xpipe (loud as fuck now)
2007 Mazdaspeed6 (SOLD) - COBB SRI ~ Gutted Stock Midpipe ~ HKS BPV ~ JBR RMM ~ AWR PMM ~ AWR TMM ~ Juggernaught Rear Diff Mount ~ Dreadnaught Rear Diff Mount ~ ACT Stage 2 Clutch ~ ITV22s ~ AP(self fucking tuned in a week fuckers) ~ Autotech Internals ~ eBay Downpipe ~ Poke Sub thingy
zpele is offline   Reply With Quote
The Following 2 Users Say Thank You to zpele For This Useful Post:
BAT-man (12-02-2013), Phoenix Speed3 (03-04-2012)
 Old 12-16-2011, 08:30 PM   #4
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
^ power. duh faggot
Past Mazdas & Speeds
The Following 14 Users Say Thank You to Neverlift For This Useful Post:
BPASPEED (12-18-2011), CWP_MS3 (05-08-2012), Easter Bunny (12-21-2011), Fail_6 (08-25-2012), keefover (01-07-2012), Menace1 (02-13-2013), Micha (03-10-2013), Ms3_Miami (12-17-2011), SpeedSixxx (04-03-2012), TexasSpeed3 (03-26-2013), WAHBAM (02-25-2012), Whiteboy (12-21-2011), Worbit (01-30-2012), xfeejayx (01-11-2012)
 Old 12-16-2011, 08:52 PM   #5
zpele's Avatar
Groans: 354
Originally Posted by Streets View Post
^ power. duh faggot
Lol the h8rs keep on h8n. Hey Bob hows your gaymobile running?
 Old 12-16-2011, 09:05 PM   #6
Neverlift's Avatar
Groans: 1,143
The Following 4 Users Say Thank You to Neverlift For This Useful Post:
keefover (01-07-2012), ms3destroyer (03-26-2013), Pu Manchu (12-16-2011), xI Leveler Ix (03-04-2012)
 Old 12-16-2011, 08:48 PM   #7
keefover's Avatar
Groans: 42
What he said^
The Following User Says Thank You to keefover For This Useful Post:
 Old 12-16-2011, 08:49 PM   #8
TRSpeed's Avatar
Posts: 1,537   (View Stats)
TRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the world
WOW Jordan thats pretty fucking....
GAY!!
lol jk I love hose Downpipes =)
Ill be goint BT around Jan or Feb =)
2008.05 True Red Mazdaspeed3
Lex Tuned
GTX3071r | 38mm Tial WG | Hallman MBC
Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod |
Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM |
Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs
TRSpeed is offline   Reply With Quote
The Following 2 Users Say Thank You to TRSpeed For This Useful Post:
keefover (01-07-2012), Phoenix Speed3 (03-04-2012)
 Old 12-16-2011, 08:53 PM   #9
keefover's Avatar
Groans: 42
Believe it or not this was actually cheaper than building a big turbo Build and I expect to see equal results. Plus it's badass as a motherfucker
The Following 9 Users Say Thank You to keefover For This Useful Post:
Boosted Beluga (01-30-2012), Danish (12-21-2011), Docnox (01-28-2012), Micha (03-10-2013), Ms3_Miami (12-27-2011), SLOWHATCH (12-21-2011), SpeedSixxx (04-03-2012), TexasSpeed3 (03-26-2013), Worbit (01-30-2012)
 Old 03-04-2012, 11:38 PM   #10
Phoenix Speed3's Avatar
Posts: 714   (View Stats)
Phoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the world
equal results... Ok I know we talked about whether or not it will work so here is a baseline log to compare towards your car when it is up and running. You will be using the same tuner so no major differences except my fwd fail and your awd. It isn't so much of "IF" it works but HOW WELL it works compared to a BT.
The ultimate test is to compare it to @derekdoo's monstrous 6031 that BARELY fits in his engine. Although I am sure his turbo was much less $$ then what you're doing. Correct me if wrong please.
Phoenix Speed3 is offline   Reply With Quote
 Old 03-05-2012, 04:07 PM   #11
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Do you think the running engine oil level will sit low enough in the pan to allow for proper drainage? I'm thinking about machining another hole in the block and welding a fitting on there.
As already stated, you'll be fine.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 12-16-2011, 09:02 PM   #12
aanguia1's Avatar
Posts: 291   (View Stats)
aanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the worldaanguia1 is the leader of the world
Groaned at 32 Times in 8 Posts
PURE FUKEN ANAL SEX!!!!!
nuff said.
Edit: subbed for results
Sent from my LG-P999 using Tapatalk
aanguia1 is offline   Reply With Quote
The Following User Says Thank You to aanguia1 For This Useful Post:
 Old 12-16-2011, 09:02 PM   #13
uncorked11's Avatar
Posts: 1,238   (View Stats)
Groans: 165
This is going to be sick.
New....Camaro SS/RS
Stocked out selling parts.
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
The Following User Says Thank You to uncorked11 For This Useful Post:
 Old 12-17-2011, 08:02 PM   #14
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
Big props for originality and fab skills.
2007 CTS-V - Trying to sell
 Old 12-17-2011, 11:10 PM   #15
bcmurphy87's Avatar
Posts: 1,435   (View Stats)
looks good if you have any questions on the blow thru hit me up
06 Speed6 GT- Sold
The Following 2 Users Say Thank You to bcmurphy87 For This Useful Post:
djuosnteisn (02-05-2012), keefover (01-07-2012)
 Old 12-21-2011, 12:36 PM   #16
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
moved per op's request
The Following User Says Thank You to dooderek For This Useful Post:
 Old 12-21-2011, 01:41 PM   #17
Whiteboy's Avatar
Posts: 2,032   (View Stats)
Whiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the world
Groans: 142
Jordan, will you have my babies?
~My Mod List: ETS TMIC; CP-E SRI; COBB TIP; CP-E DP; CP-E RMM; CP-E Safe Seals; ITV-22's; GHL SS CBE; TWM STS w/bushings; Autotech HPFP Internals; AP (Stratified by Lex); Matt Damond OCC; CP-E Triple Gauge Pod w/ Prosport Premium Boost, AFR, and Oil Pressure Gauges; JBR Eliminator Shift Knob~
Whiteboy is offline   Reply With Quote
The Following User Says Thank You to Whiteboy For This Useful Post:
 Old 12-21-2011, 02:17 PM   #18
bigx5murf's Avatar
Posts: 235   (View Stats)
bigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond reputebigx5murf has a reputation beyond repute
Groaned at 20 Times in 10 Posts
Neutral  -1 score
its been done before, conclusion, not worth the extra effort.
Shore Motorsports: Fabrication & Installation
Twin turbo Miata done, second time around - Miata Turbo Forum - Home to the Turbo Miata
bigx5murf is offline   Reply With Quote
The Following 2 Users Say Thank You to bigx5murf For This Useful Post:
i8urgti (01-29-2012), Phoenix Speed3 (02-25-2012)
The Following 3 Users Say NO Thank You to bigx5murf For This Un-useful Post:
drknyte (12-24-2011), keefover (01-07-2012), sLow6 (01-30-2012)
 Old 12-21-2011, 02:44 PM   #19
keefover's Avatar
Groans: 42
Originally Posted by bigx5murf View Post
Where in this thread did you read I was building it on a Miata?
The Following 5 Users Say Thank You to keefover For This Useful Post:
Coaststarlight (01-20-2012), Rich-PMS (12-21-2011), SLOWHATCH (12-21-2011), SpeedSixxx (04-03-2012), Tokay444 (12-23-2011)
 Old 12-21-2011, 09:19 PM   #20
bigx5murf's Avatar
Where has it ever been proven on an inline 4 results would beat a traditional big turbo setup?
Props you have access to skills, and equipment to make it happen. But it's alot of extra complexity for a bit more low end.
Alpha (12-22-2011), keefover (01-07-2012)
 Old 12-24-2011, 05:15 PM   #21
nothing to see here....
drknyte's Avatar
Posts: 501   (View Stats)
drknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the world
Groans: 39
Groaned at 43 Times in 18 Posts
That's a fucken miata ass clown!!!
Not a Speed!
2008 Mazdaspeed 3 GT in Black Mica:
60ft: 2.167
1/8: 9.052
1/4: 13.922 @ 100.37
(26psi tire pressure & stock tires)
CP-E CAI; CP-E Turbo Inlet Pipe; CP-E RMM; Engals ETD; TRZ TM; PG ExhMani; JBarone Shifter Weight, E4 Performance Shift Knob; Solid Shifter bushings; JBarone SSP
drknyte is offline   Reply With Quote
The Following User Says Thank You to drknyte For This Useful Post:
 Old 12-21-2011, 02:26 PM   #22
MSFer87's Avatar
Posts: 1,162   (View Stats)
Groans: 83
So if I get my ricer math correctly 2 (K04)s = 1 (gt3071 or 3076)? You must not wear underwear, because your balls don't fit. Good luck with this shit I admire the boldness and amount of innovation going into this build.
The Following 2 Users Say Thank You to MSFer87 For This Useful Post:
keefover (01-07-2012), SpeedSixxx (04-03-2012)
 Old 12-21-2011, 04:36 PM   #23
ColonR's Avatar
Posts: 1,453   (View Stats)
ColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the worldColonR is the leader of the world
this will be fucking dope! that downpipe is sexy!
1992 miata, track beast here I come with 2 bride seats!! (current)
3076r speed6 owner (traded)
2000 camaro 415rwhp thru midwest chassis fab (sold)
ColonR is offline   Reply With Quote
The Following User Says Thank You to ColonR For This Useful Post:
 Old 12-21-2011, 04:46 PM   #24
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Why wouldn't you run them in a compound setup?
NATOR PA
 Old 12-21-2011, 04:53 PM   #25
mason's Avatar
Posts: 946   (View Stats)
it takes skills to do this, whats the science behind this? (how it works better?)
The Following User Says Thank You to mason For This Useful Post:
 Old 12-21-2011, 05:04 PM   #26
2zz mr-s
dooderek's Avatar
Groans: 239
lol mason, the science is its cool hahaha
The Following 2 Users Say Thank You to dooderek For This Useful Post:
keefover (01-07-2012), Worbit (01-30-2012)
 Old 12-21-2011, 05:20 PM   #27
spnkr21's Avatar
Posts: 2,827   (View Stats)
Aren't those considered throwaway turbos?
2012 WRX HB w/mudflaps yo!
 Old 12-21-2011, 06:49 PM   #28
keefover's Avatar
Groans: 42
The 1.8 VW guys consider them upgrades. I guess it just depends on how you look at it. I looked at it like this. (BT 1500.00, DP 150.00 ,Mani 650.00, intake/tip/maf housing 200.00, fmic and piping 350.00, oil/coolant lines 80.00, extra parts and fab 75.00+) these numbers are under rated give or take a couple hundred but you get the idea. (Twin Turbo set up Extra turbo 50.00 shipped, Rebuild kit 80.00, fab up mani/intake/ic piping 1700.00, fmic 150.00, couplers and clamps 150.00, maf housing/air straightener 90.00, oil and coolant line fab 90.00, Perm tune Priceless.. ) you get my point. Its not like Im shelling out a shit load of cash beyond the cost of a 3076 build. BESIDES I HAS TWO FUCKING TURBOS!!!!!! I am also chasing the idea that it will spool faster then a 3076, but being as no one has ever built one I guess we will just have to wait and see.
SpeedSixxx likes this.
Easter Bunny (01-18-2012), jracer (12-21-2011), SLOWHATCH (01-04-2012), SpeedSixxx (04-03-2012), Worbit (01-30-2012)
 Old 12-21-2011, 05:31 PM   #29
MS3MYK's Avatar
Posts: 1,967   (View Stats)
Oh my lord! This thing is gonna be amazing!!!! Can't wait to see this thing up and running.
2008.5 CWP Speed3 GT - SOLD /
1991 Ford Mustang LX 5.0 SSP
The Following User Says Thank You to MS3MYK For This Useful Post:
 Old 12-21-2011, 05:45 PM   #30
mason's Avatar
yeah, it looks cool, but why is it cool?
 Old 12-21-2011, 05:53 PM   #31
2zz mr-s
dooderek's Avatar
Groans: 239
because theres two turbos!!!
The Following 4 Users Say Thank You to dooderek For This Useful Post:
BobtailedSnail (01-20-2012), keefover (01-07-2012), WAHBAM (02-25-2012), Worbit (01-30-2012)
 Old 12-21-2011, 06:32 PM   #32
keefover's Avatar
Groans: 42
You ever sit down to take a shit and your cock hits the water? Thats what its going to feel like every time I drive this mother fucking thing.
Fuck Science. Nigga I gots two turbos!!!!!
Big_Burd likes this.
Last edited by keefover; 12-21-2011 at 06:32 PM. Reason: MSF Database - Automerged Doublepost
The Following 14 Users Say Thank You to keefover For This Useful Post:
BBongEd (08-30-2012), Brennan (01-30-2012), CWP_MS3 (05-08-2012), djuosnteisn (02-05-2012), Docnox (01-28-2012), Easter Bunny (01-18-2012), mason (12-22-2011), Micha (03-10-2013), Roddiy (06-23-2012), SLOWHATCH (01-04-2012), SpeedSixxx (04-03-2012), TexasSpeed3 (03-04-2012), WAHBAM (02-25-2012), Worbit (01-30-2012)
 Old 12-21-2011, 06:57 PM   #33
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
balls running around in cali with this setup. whens the car need to be inspected?
'08 CWP MS3 w/ T3 3071r
keefover (01-07-2012), xI Leveler Ix (03-04-2012)
 Old 12-21-2011, 07:40 PM   #34
keefover's Avatar
Groans: 42
NEVER>>> NEBRASKA PLATES
The Following 2 Users Say Thank You to keefover For This Useful Post:
Micha (03-10-2013), SpeedSixxx (04-03-2012)
 Old 12-21-2011, 08:51 PM   #35
Rich-PMS's Avatar
Posts: 1,461   (View Stats)
Rich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the worldRich-PMS is the leader of the world
Groans: 68
Awesome build.
You should be able to break 425who pretty easily
A k06 on a small 4cyl would be a fun car to play around with, and basically with 2 k04s it's like having 2 1.6L motors, each getting blown by a k04
So you have a 2.3L k08, or some crazy shit.
I'd highly suggest you get good raisers so you can vent all the heat from the extra turbo.
Rich-PMS is offline   Reply With Quote
 Old 12-21-2011, 10:17 PM   #36
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
Subbin to see this shit happen!
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
The Following User Says Thank You to mazdafreak For This Useful Post:
 Old 12-22-2011, 01:51 AM   #37
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
Derek showed me a sneak peak at the last nator
2009 CWP Speed3
The Following User Says NO Thank You to SleeperHatch For This Un-useful Post:
dooderek (12-22-2011)
 Old 12-22-2011, 03:15 AM   #38
keefover's Avatar
Groans: 42
Saaaaaaaaay Whaaaaaaaaaaat. Im going to lynch that mother fucker. If Taylor Swift told Derek she would blow him if he wouldn't tell anyone he would fuck that up. Half the reason I put this shit up before it was done is because he leaked it to half the Nator San Diego peeps anyways. Steeling props for my shit.
Does this make me Punisher 7?
Last edited by keefover; 12-22-2011 at 03:45 AM. Reason: MSF Database - Automerged Doublepost
 Old 12-22-2011, 09:39 AM   #39
http://www.youtube.com/watch?v=gPWOFmhBE20&feature=fvst
Haha its fuckn sick bro and he's excited I think.
Sent from my Epic Win Avatar
2009 CWP Speed3
 Old 12-22-2011, 10:05 AM   #40
kmac's Avatar
Posts: 1,792   (View Stats)
I must say I'm very impressed and I love u .
First 500whp stock block mazdaspeed3 (503whp 423wtq)
<3 Tokay.
The Following 2 Users Say Thank You to kmac For This Useful Post:
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/nator-socal-wetting-your-bitches-vages-one-99820/
can it be done - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 10-07-2015 11:39 AM
Sequential turbos - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 11-16-2013 03:59 PM
MPS BL Garret GTX Konzept - Seite 2 This thread Refback 07-31-2013 12:56 PM
?????????? - ??????? (??????????, ???????, ??????) This thread Refback 02-20-2013 07:42 AM
Random MS3 Chat Thread - Page 38 This thread Refback 02-14-2012 04:31 PM
NATOR NM wetting your girls vag one BT build at a time. PapaSmurf 2010 MS3 - Big Turbo Builds 1040 10-18-2013 08:35 AM
Video: Hennessey beats 2011 Nissan GT-R again, this time with twin-turbo Escalade Haltech Automotive News 1 04-13-2011 03:22 PM
Page generated in 0.80902 seconds with 46 queries
