 Old 07-10-2015, 08:16 PM   #1
Jkelley's Avatar
Posts: 218   (View Stats)
Jkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the world
I'm proud to say! All problems fixed. When mechanic removed EGR, he clamped the wrong hose - the water outlet from the reservoir. Thanks for the help guys. And special thanks to @meicalnissyen for showing the cooling diagram which caused us to relook over everything.
2008 Mazda Mazdaspeed3 GT (True Red) SOLD
~Mods: ATP GTX3071r IWG, JBR Tru 3.5" WP, UR V2 3" catless DP & TP, Tr8+JBR FMIC, Turbosmart BPV, CP-e HPFP, NGK 6510, Bosch 3bar MAP, Cobb 3-port EBCS, PERM PCV Plate, Damond OCC (1sealed, 1 VTA), Kozmic 1°/Damond 2° EGR Delete, Corksport seals, CP-e RMM 75A, JBR side MM 80A, Cobb AP V2, spin-on oil conversion, KSport Coilovers, SPC Performance Camber Arms, JBR IM/TB TIG, SURE Anchors
~~332whp @5300rpm / 354wtq @4800rpm @ 21psi on 91oct FREEKTUNED
~~380whp @6500rpm / 367wtq @4800rpm @ 20psi on e33 FREEKTUNED
2007 Mazda CX-7 (Burgundy Wine) SOLD
Jkelley is offline   Reply With Quote
The Following User Says Thank You to Jkelley For This Useful Post:
meicalnissyen (07-11-2015)
I need direction! Speedy McMuffin Mazdaspeed3/6 General Discussion 6 07-17-2014 06:52 PM
Point me in right direction celery952 MazdaSpeed 3/6 - Turbo Induction 16 03-23-2012 05:00 PM
Page generated in 0.23201 seconds with 22 queries
