![]() Join Date: Jul 2008 Location: Raeford, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 154
(Thread Starter) | Not Ranked : 0 score and the car does not stay on. It cranks up then dies immediately, just like when you install an intake for the first time, and turn the MAF backwards. (lol) But the maf is not backwards, I've tried it both ways. The only other thing I can say about the Intake side, is that I had my ECU reflashed for the 3.5" Maf housing. Could this be the problem? Also, I removed the stock boost control solenoid and I am using the grimmspeed EBC only, could this be it? (yes it is connected to where the stock solenoid went to) So I need some thoughts as to why a car will turn on, then turn off immediately... -theres gas in the tank -all fuel lines are connected properly -MAF is not facing the wrong way (lol) -Yes I have the whole intake connected -Spark Plug wires are connected **Update 14 April** Got my ecu back and still... still not running right. I've already talked to Josh and he assured me that CPe Flashed the ecu. He is also trying to figure out why its not working. Heres a video, exactly whats happening right now
__________________ 2012 Mazdaspeed3 LSM Should have gotten a speed6 2008 Mazdaspeed3 GT Black Mica [sold] Built motor, Etc. 383 hp 401 tq GTX2867R @ 25 psi Last edited by 7mileshome; 04-14-2010 at 04:07 PM. |
![]() Join Date: Jan 2009 Location: ME, Kittery
Rep Power: 1818 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,848
| Not Ranked : 0 score What kind of intake do you have?
__________________ 2012 WRX HB w/mudflaps yo! |
(Thread Starter) | Not Ranked : 0 score the cp-e 3.5" maf, it comes with a filter, so it looks just like a nano setup.
__________________ 2012 Mazdaspeed3 LSM Should have gotten a speed6 2008 Mazdaspeed3 GT Black Mica [sold] Built motor, Etc. 383 hp 401 tq GTX2867R @ 25 psi |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score maf is connected? does fuel pressure die? |
![]() Join Date: Dec 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 358
Groaned at 49 Times in 36 Posts
| Not Ranked : 0 score Fuses?.. maybe fuel? or you could just pay 100 buks and get it diagnosed by a tech
__________________ Mazdaspeed6,2006, 46k miles. COBB AP* Gt3076, 19psi. CPE dp (catless), Dnp Mani 38-EWG, CorkSport Dual CB, CPE BIG MAF SRI, Big Turbo Inlet, CPE Fuel Pump, HKS SSQ Black out edition, Ported stock intake Mani, Intake mani spacer (PT), 2 step colder plugs, FMIC Custom 3.5 inch core, Meth (PT), OCC, BSD, TTFMM, CPE Rear Diff, CPE engine Mount, H&R Springs, Whiteline Rear Sway Bar, Stage 1 short shifter kit Base+bushings, Rotora Break Rotors All 4 (Slotted), Techna fit Brake Lines, Ebc red Stuff pads All 4, Enkei PF01 18's Wrapped in 245/40/18 Falkanzzzz ... Stock clutch until i get some funds. I HAZ THE FASTEZ CAR ALIVE!!!!!!!!!!!! REDBULL FTW |
| Not Ranked : 0 score Try a stock maf to make sure indeed your ecu was flashed, just to rule it out as a possibility. Also, keep an eye on afr's when it does start, and fuel trims maybe.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
| The Following 3 Users Say Thank You to djuosnteisn For This Useful Post: |
| Not Ranked : 0 score So it is 3.25 and you did get the flash? Does your Maf housing fit a can of soda in it?
| The Following User Says Thank You to spnkr21 For This Useful Post: | www.cp-e.com (04-08-2010) |
| ALL-IN. ![]() Join Date: Jan 2009 Location: Alberta
Rep Power: 1397 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 872
Groans: 30
| Not Ranked : 0 score Are you getting any CELs? |
(Thread Starter) | Not Ranked : 0 score maf is connected, fuel pressure is fine.
yes I got a P0113 IAT, high Intake air temp (??) what im thinking right now is ether CP-e did not actually do the flash, or my MAF is bad somehow.
__________________ 2012 Mazdaspeed3 LSM Should have gotten a speed6 2008 Mazdaspeed3 GT Black Mica [sold] Built motor, Etc. 383 hp 401 tq GTX2867R @ 25 psi | |||
![]() Join Date: May 2009 Location: N Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 523
Groans: 77
| Not Ranked : 0 score that sux ron. so it would actually start up then run for a lil bit then dies? am i right?
__________________ 2008.5 MAZDASPEED3 GT TRUE RED ***GONE*** ![]() 2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19 |
Groans: 1,940
| Not Ranked : 0 score iat is measured at the maf, it has to be related to the maf or the flash. |
| The Following User Says Thank You to phillyb For This Useful Post: | 7mileshome (04-08-2010) |
Groans: 78
| Not Ranked : 0 score Yes, it is definitely the maf. Is it completely seated down with the o-ring sealed? I had a hell of a time with my maf sensor last week. If you have someone near by, you could always go grab their maf sensor to borrow for 30 minutes to test like I did haha. |
Groans: 30
| Not Ranked : 0 score Is the MAF all shmagged up? Could be dirty or like mad said, a seating issue. |
| Not Ranked : 0 score take a picture of it |
(Thread Starter) | Not Ranked : 0 score yea hopefully dizzin can come to the rescue wth a maf. lol. maf is not dirty I cleaned it up with MAF cleaner and I cleaned the connectors with electronics cleaner. and what am I taking a picture of?
| Approved MSF Vendor ![]() Join Date: May 2008 Location: Beltsville, Maryland
Rep Power: 2499 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 425
| Not Ranked : 0 score One of two things here.... My prediction: 1. Not the xcelXL and you have the flash so its not running right which will turn on and then stumble and die immediately. 2. You have the xcelXL and the big maf flash was ommited. Do me a favor. Take a picture of a soda can in the maf housing and reinstall a factory intake or standard cai / sri and try turning the car on. Doing these two tasks will let me know the problem. Thanks |
| The Following User Says Thank You to www.cp-e.com For This Useful Post: | FreeFlyFreak (04-19-2010) |
| Not Ranked : 0 score I was saying to take a pic of the maf housing. Cp-e beat me to it. |
Rep Power: 1790 ![]() Thanks: 2,239
Groans: 62
I don't know what to do anymore. | |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score Is this what you needed to see? I will update once I get a hold of another intake, I just sold my nano and my xcel DAMMIT!
![]() | | #20 | ![]() |
| Not Ranked : 0 score Now take a picture of your sister.
| The Following 11 Users Say Thank You to djuosnteisn For This Useful Post: | 7mileshome (04-09-2010), andre0121 (04-17-2010), AndyMS3 (04-08-2010), BUNGEEZZ (04-09-2010), doubleflusher (04-14-2010), Fullmetal (04-19-2010), kgb (04-19-2010), kilik2 (04-10-2010), madvillain (04-08-2010), phillyb (04-08-2010), wankular (04-08-2010) |
![]() | | #21 | ![]() |
Groans: 78
| Not Ranked : 0 score with a soda can in her........ 'er nevermind.. |
| The Following 9 Users Say Thank You to madvillain For This Useful Post: | andre0121 (04-17-2010), AndyMS3 (04-08-2010), djuosnteisn (04-08-2010), doubleflusher (04-14-2010), FreeFlyFreak (04-19-2010), kilik2 (04-10-2010), phillyb (04-08-2010), predapio (04-16-2010), wankular (04-08-2010) |
![]() | | #22 | ![]() |
![]() Beeker - you has PM | |
![]() | | #23 | ![]() |
(Thread Starter) | Neutral : +1 score Ok, FWIW... I hooked Dizzin's Nano up, and the car started right up. I tried his MAF and my MAF just to make sure. That leaves only one conclusion...
| The Following User Says Thank You to 7mileshome For This Useful Post: | djuosnteisn (04-09-2010) |
![]() | | #24 | ![]() |
| Not Ranked : 0 score Handled. We'll get your ecu flashed and have it back out to you. Guys - in the future these tech issues are really easy for me to fix. If you just PM me or email me I am very quick to answer since all the emails go to my phone. Posting up on here gets answers from guys who don't even realize your running a completely different ecu. These flashes that allow BIG power aren't being tested on customer cars. We have locals who have been running them for multiple 1000s of miles. Their results just don't get posted because they are beta testers/shop cars. If something doesnt work its usually something stupid like only 2/3 flashes got loaded. Just let me know. |
| The Following 2 Users Say Thank You to www.cp-e.com For This Useful Post: | 7mileshome (04-09-2010), kilik2 (04-10-2010) |
![]() | | #25 | ![]() |
Groans: 77
| Neutral : -1 score flashing FAIL
![]() | | #26 | ![]() |
| Not Ranked : 0 score Do your flashes work dizzi???
![]() | | #27 | ![]() |
Groans: 77
![]() | | #28 | ![]() |
| Not Ranked : 0 score Oh
![]() | | #29 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 944
Groans: 127
Groaned at 40 Times in 31 Posts
![]() | | #30 | ![]() |
![]() Join Date: Mar 2010 Location: fort stewart ga
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 119
| Not Ranked : 0 score so.....hows it run???
__________________ [SIGPIC][/SIGPIC]07 MS3 GT Cpe cai, Corksport turbo back, Hks bov, Trz dog bone, Cobb ap, Cobb knob, Stage 2 JB ssp ![]() |
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score soon as I get my ECU back from CP-E... I will let you know! ; )
![]() | | #32 | ![]() |
| Not Ranked : 0 score Cagey just called to tell me he is struggling for traction in 4th and we aren't NEAR done tuning |
| The Following 2 Users Say Thank You to www.cp-e.com For This Useful Post: | djuosnteisn (04-10-2010), kilik2 (04-10-2010) |
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score Update... video in first post...
![]() | | #34 | ![]() |
![]() Join Date: Dec 2009 Location: Fontucky, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,096
Groans: 1,364
| Not Ranked : 0 score This is a private video. If you have been sent this video, please make sure you accept the sender's friend request. |
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score fixed... also car runs fine with stock intake box
![]() | | #36 | ![]() |
Groans: 77
| Not Ranked : 0 score woohoo!!! how bout the standback - don't u have to set something in there? did u drive around with the stock box yet?
![]() | | #37 | ![]() |
![]() Join Date: Apr 2010 Location: atlanta ga
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score now thats where i want to be big turbo and fast as balls where o where to begin good luck i know the car is going to run great |
![]() | | #38 | ![]() |
Is it because you are using a product proven not to work you are upset? | |
![]() | | #39 | ![]() |
Groans: 1,364
![]() | | #40 | ![]() |
Groans: 77
| Not Ranked : 0 score what did i say now? lol
| cbe ideas | speedms6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 2 | 11-20-2009 12:05 AM |
| Guys ... any ideas | johnnyspeed6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 25 | 06-16-2009 10:12 AM |
| What should I put into my ms3?? i need ideas!! | phantomspeed3 | Mazdaspeed3/6 General Discussion | 13 | 12-29-2008 08:09 AM |
| not sure what my issues are... ideas? | myms3 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 12 | 04-11-2008 01:46 PM |
