 Old 04-14-2010, 05:34 PM   #41
7mileshome's Avatar
Posts: 350   (View Stats)
7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world7mileshome is the leader of the world
well Im going to have to figure something out. The car is running with a normal size maf, but not with the xcelXL... Ive done everything I can on my end, and I believe Josh when he says it was flashed.
Ive asked a couple of other people with the XL maf and flash.... they all say their car started right up...
Jake is there any way I could modify the settings on the SB to get it to run correctly?
2012 Mazdaspeed3 LSM
Should have gotten a speed6
2008 Mazdaspeed3 GT Black Mica [sold]
Built motor, Etc.
383 hp 401 tq GTX2867R @ 25 psi
7mileshome is offline   Reply With Quote
 Old 04-14-2010, 05:43 PM   #42
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
i think jake and dizzin should get in a cage.
right fucking now.
glad this was handled in a timely matter.
i don't think there needs to be any sb/cpe bashing.
shit just happens sometimes.
there are a lot of misunderstandings about the sb, i believe.
madvillain (04-14-2010)
 Old 04-14-2010, 05:53 PM   #43
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
7mile we are going to conference call...pm me your number
 Old 04-14-2010, 06:02 PM   #44
dizzin9's Avatar
Posts: 1,807   (View Stats)
Groans: 77
lol. i love cp-e!!! not only i have 3 of their products in my car, i'm advertising them for free!
that's right... on top of COBB!
 Old 04-14-2010, 06:09 PM   #45
phillyb's Avatar
Groans: 1,940
jake, i think dizzin be trollin you.
 Old 04-15-2010, 04:31 PM   #46
7mileshome's Avatar
Default Re: Need some ideas
Today's headline... F M L
More to follow....
Built motor, Etc.
The Following User Says Thank You to 7mileshome For This Useful Post:
madvillain (04-15-2010)
 Old 04-15-2010, 05:35 PM   #47
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
HUH?
What voltage do you see from the maf sensor?
I wonder if you have a hardware issue with the standback.
Does the problem happy with the bypass plug also?
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 04-15-2010, 05:53 PM   #48
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
More to follow....
RUT ROH!
FreeFlyFreak (04-19-2010)
 Old 04-15-2010, 08:00 PM   #49
7mileshome's Avatar
HUH?
Does the problem happen with the bypass plug also?
input was about .85-1.05 output was around 2.30-2.80
This was after I modified the MAF table through the standback.
Yes I had the same issue even when the SB is not connected
Built motor, Etc.
 Old 04-15-2010, 10:42 PM   #50
Captain
That's like a 30% increase.
Not sure if you do or don't have the proper flash right now, but going from a stock maf size to a 3.25" maf housing is an increase of 70+%. I bet you'd still have a hard time starting the car (super lean) with just a 30% increase, but it certainly should have helped i would think.
www.permtuning.com
7mileshome (04-19-2010)
 Old 04-15-2010, 11:00 PM   #51
madvillain's Avatar
Groans: 78
I hope I don't run into this problem tomorrow, I've got ants in my pants.
7mile- still the same problem? Start and die?
 Old 04-16-2010, 07:37 AM   #52
dizzin9's Avatar
Groans: 77
More to follow....
FUUUUUUUUUUUCK!!!!!!!! i just read your text msg
lemme know ron if u need my help
 Old 04-16-2010, 07:50 AM   #53
Ron. Check your pm's. Should help a bit.
7mileshome (04-16-2010)
 Old 04-16-2010, 11:12 AM   #54
7mileshome's Avatar
Yes thanks Jake, I really appreciate your support!
Built motor, Etc.
 Old 04-16-2010, 12:26 PM   #55
dizzin9's Avatar
Groans: 77
this is REALLY disappointing...
 Old 04-16-2010, 12:55 PM   #56
Captain
www.permtuning.com
 Old 04-16-2010, 01:20 PM   #57
dizzin9's Avatar
Groans: 77
it's hard to be out of the loop huh?
 Old 04-16-2010, 01:32 PM   #58
Captain
Your so loopy.
www.permtuning.com
Last edited by djuosnteisn; 04-16-2010 at 01:32 PM. Reason: MSF Database - Automerged Doublepost
felt (04-16-2010), madvillain (04-16-2010)
 Old 04-16-2010, 01:33 PM   #59
dizzin9's Avatar
Groans: 77
7mileshome will be posting here soon...
The Following User Says Thank You to dizzin9 For This Useful Post:
djuosnteisn (04-16-2010)
 Old 04-16-2010, 02:59 PM   #60
felt's Avatar
Posts: 1,504   (View Stats)
Groans: 1,364
And they'll make you do the boogey dance.
felt is offline   Reply With Quote
 Old 04-16-2010, 03:13 PM   #61
tbot's Avatar
Posts: 2,821   (View Stats)
Groans: 40
wow now i'm curious as to wtf is going on...
 Old 04-16-2010, 03:50 PM   #62
meelo88's Avatar
Posts: 557   (View Stats)
meelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the worldmeelo88 is the leader of the world
yeah me too..subbed
"If I can't fix it, it was meant to be broken"
[SIGPIC][/SIGPIC] 2007 MazdaSPEED 6 Titanium Grey
TUNED BY NISHAN
POWER
SpeedPerformanc3 Wiseco Pistons (88mm)::Manley Forged H-Beams::BNR S3::Bosch 3Bar Map Sensor::CP-E Ex Mani::SBC Stg 2 Clutch::JBR RMM 80a::JBR STG II SRI::JBR Boost Tubes::JBR BPV Return::JBR SSP::CS TMIC::CS DP::Stratified 3 Port EBCS::Stratified Guardian Angel::TurboXS RP::Custom 3" Catback Exhaust::KMD 2.1::Flex Innovations Ground Kit::Turbosmart BPV::MD OCC::TWM Stage 1::BC Coilovers::Hawks HPS::EGR Delete::SURE Dreadnaught::SURE Juggernaut::SURE TIG
COSMETIC AND AUDIO
Mori H1 Proj Retrofit::DDM 3k HID Fogs::RPM Rear LED Reflectors::RPM Side LED Reflectors::Morel Elate 6 2W 6.5" Components::Morel Maximo 5C 5.25" Coaxial::Arc Audio KS300.4::Arc Audio KS1000.1::Audison BitOne.1::Zapco ST4
meelo88 is offline   Reply With Quote
 Old 04-16-2010, 03:54 PM   #63
Captain
www.permtuning.com
 Old 04-16-2010, 04:31 PM   #64
dizzin9's Avatar
Groans: 77
it's tough when u fuck shit up twice and leave somebody hanging...
 Old 04-16-2010, 04:41 PM   #65
Captain
Try stock maf again and see if it fixes it. However unlikely that the maf flash could have been over looked, i guess it's still technically a possibility.
At least i thought i remember OP put on a stock maf and everything looked normal, correct afr's, engine idled, etc.
www.permtuning.com
Last edited by djuosnteisn; 04-16-2010 at 04:41 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-16-2010, 04:55 PM   #66
Captain
Talked to jake, and all i can say is hmmmmm.... and shiiiiittttt.
This is not a good loop to be in.
www.permtuning.com
 Old 04-16-2010, 08:22 PM   #67
madvillain's Avatar
Groans: 78
Dustin, you're scaring me.
 Old 04-17-2010, 07:55 AM   #68
Captain
Don't be scurred lol.
Its just not a good loop for OP.
www.permtuning.com
 Old 04-17-2010, 09:32 AM   #69
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
wow - i didn't see this until now
this is almost the same story as silverdemon - what's up with the flashes not happening/not taking on the ecu???
silverdemon went thru the same thing with the new big maf/flash but his worked on the smaller stock housing....
is there any potential that the different year's ecu's initial programs vary just a little and are causing issues with flashes not taking???
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 04-17-2010, 09:47 AM   #70
dizzin9's Avatar
Groans: 77
when was this?
 Old 04-17-2010, 09:56 AM   #71
cpolly69's Avatar
Groans: 27
the week before cpe's big dyno day
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 04-17-2010, 10:01 AM   #72
dizzin9's Avatar
Groans: 77
so did he eventually had the car running with the big maf?
 Old 04-17-2010, 10:40 AM   #73
cpolly69's Avatar
Groans: 27
well i should let him respond
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
 Old 04-17-2010, 11:44 AM   #74
SilverDemon's Avatar
Posts: 3,034   (View Stats)
Yes, I eventually got the car running with the big MAF.....it had to re-flashed
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 04-17-2010, 06:53 PM   #75
madvillain's Avatar
Groans: 78
Mine fired right up with the big maf.
 Old 04-19-2010, 08:16 AM   #76
The way our flashes work is we record your ecu so we can always revert back. We check three boxes when we do all three and we write. Then we record your post flash. Everything is tracked by vin.
There are a few options going on -
1. His ecu wouldn't take the flash for some reason which we've seen like twice in the 3-4 years we've been flashing (both ms6's)
2. Something was letting in A LOT of unmetered air or out A LOT of metered air. Not sure if he tried a stock maf housing after we sent it back again.
3. It didn't get flashed again (highly unlikely but always a possibility)
We have never had problems however with our flashes beyond it not getting put on or overlooked (2-3 times in its history) and then we just relash it and it fires up correctly right away. There is no variability - we write the same flashes to the ecu's. If its written it works which is why so many people are fired up and working. If it doesn't work you can't scale a smaller maf to this size to get it to work as we are getting it to work. We are HARD encoding things into the ecu's. I haven't had time to talk to 7mileshome as I have been out of town but he'll be supported whatever the situation.
7mileshome - i need you to pm me your vin number so i can check what your ecu flash looks like on our computer. We'll know what was done with that vin number because we have your before and after images of your ecu. We have every person's before and after image that we have ever done. It sounds like there were compounding factors that led to the car not idling right or staying on with the big maf. If you try to put it on a stock car it wont stay on because not enough air is registered so the car will die out.
I am currently in another state still at the air port waiting for my flight. When I get back in town I will finish investigating why 7mileshome's car wouldn't run the big maf. We have 20+ cars running it with no issues. We even have two still on k04's who wanted to try it (the rest are big turbo).
Dizzin - you may be a supporter of us but you are sitting here trying to stir the pot. Our flash is identical on every car it gets on. If it gets over looked we get it back and reflash it and it works. If it didnt - there was something else playing a roll. We have over 1000 flashes out in the speed platform. We would greatly appreciate it if you either stayed out of the threads or stop trying to stir the pot. We take care of our customers even in situations where something else was the cause of a problem - which in this situation it 100% was because of the scaling that was performed by the OP. Regardless - we will be there for him to help him fix any issues. We have been here from day 1 and support this platform and the owners more than any other company out there.
 Old 04-19-2010, 08:46 AM   #77
dizzin9's Avatar
Groans: 77
guess u don't know what happened then...
 Old 04-19-2010, 10:52 AM   #78
7mileshome's Avatar
I gave Josh my vin no over the phone before I sent it back again, does that mean
he checked it, and realized that it was not flashed the first time?
I want to believe this is the case, honestly think that the second time I sent it
that it was flashed. Regardless, how practical is it that I send my ECU back and forth? Each time I take a chance that it will be damaged, and I will have to buy a new one? There has to be a way for CP-E to check the flash before sending it back to the customer.
Yes I posted here saying the stock housing worked like money.
Hey, I agree. Theres no way it was not flashed, again, right?
Which is exactly what happened when I tried to turn the car on in the video I posted.
I have a receipt when I purchased the full control flash that has my vin no on it, shouldn't CP-E already have it? You guys do keep receipts right?
Now, Jake, lets not get into the blame game. That is unprofessional. I sent several PMs asking you to help me get the car running, and the only responses I got were, what's your number, and were going to do a conference call. I send my number 2 or 3 times, never got one call. The "scaling" that was done because the car was not sending enough fuel to even get the car to start and idle. I thought you did not get those PMs about me trying to adjust settings on the SB, because I never got a response.
So I will ask you again, what parameters does the 3.25" MAF flash actually effect? I think every paying customer deserves to know this so they understand exactly what is being changed on their ECU. There is no other way to prove that it was actually done, OR that it was done, and the ECU did not take it.
Yes you are right on about that. Thats exactly why you cant just run any size maf housing with out adding fuel. I was able to get the car to idle just about normal by adding fuel through the standback. LOL, alot of fuel.
And until I can figure out what the flash was supposed to change, I will never know why the car would not just start up.
Built motor, Etc.
Last edited by 7mileshome; 04-19-2010 at 10:52 AM. Reason: MSF Database - Automerged Doublepost
dizzin9 (04-19-2010)
 Old 04-19-2010, 03:51 PM   #79
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
Feel out of the loop???...............
Blown Motor
Now you dont....... :gulp:
Suspension:
 Old 04-19-2010, 03:56 PM   #80
cpolly69's Avatar
Groans: 27
Questions -
Is there a possibility there's an issue of interaction of flashes with some of the oldest and earliest versions of the full control flash ??
Both you and Silverdemon had the very first FCF right?
While I realize this is unrelated, I know SilverDem was told that he had to push the dsc button when you start the car in order to turn on the fcf. That is a difference , because I know that it makes not difference if I do anything with that button my abs throttle goes 84% when I floor it. My car was flashed just a month ago.
Could there be other differences? Could these differences not work together?
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
cbe ideas speedms6 MazdaSpeed 6 - Engine, Transmission & Driveline 2 11-20-2009 12:05 AM
Guys ... any ideas johnnyspeed6 MazdaSpeed 6 - Engine, Transmission & Driveline 25 06-16-2009 10:12 AM
What should I put into my ms3?? i need ideas!! phantomspeed3 Mazdaspeed3/6 General Discussion 13 12-29-2008 08:09 AM
not sure what my issues are... ideas? myms3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 04-11-2008 01:46 PM
Page generated in 0.55401 seconds with 31 queries
