 Old 08-09-2012, 12:26 PM   #1
Sickspeed3's Avatar
Posts: 71   (View Stats)
Sickspeed3 is a glorious beacon of lightSickspeed3 is a glorious beacon of lightSickspeed3 is a glorious beacon of lightSickspeed3 is a glorious beacon of lightSickspeed3 is a glorious beacon of lightSickspeed3 is a glorious beacon of light
Groaned at 75 Times in 8 Posts
Default New Build
I'm currently deployed right now and I have a little bit of time left and I've been doing some research on parts for my build. I currently have these parts for my build:
Spare Block machined .20 over
Cp pistons 8:5:1—
Pauter Rods
Main and Rod bearings—
Here's a list of things that I'm going to order( if you have any suggestions please let me know):
Arp head studs
Arp main studs
DCR VVT Actuator
Cosmetic head gasket—
New oil pump seals—
Rear main seal—
ACT 6 puck clutch flywheel still undecided—
I'm currently on a gt3076 22psi—
fully bolted—
AP
Tuned—
Sickspeed3 is offline   Reply With Quote
The Following User Says Thank You to Sickspeed3 For This Useful Post:
Seatime3 (08-09-2012)
 Old 08-09-2012, 12:34 PM   #2
You will also need all the oem washers and bolts for the timing components and the flywheel bolts. There might be a few other things but they are not coming up right now.
 Old 08-09-2012, 12:45 PM   #3
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
why drop compression? no need. go 9.5:1.
07 MS3
The original Genpoo Hater
chuckms6 (08-10-2012)
 Old 08-09-2012, 01:30 PM   #4
3Gee Tee's Avatar
Posts: 1,533   (View Stats)
Safer to run mo' bewst lol.
But fuck safety; because racecar.
 Old 08-09-2012, 01:51 PM   #5
Sickspeed3's Avatar
Lower compression idk I might be getting a gt35r so my thought was to be more safe.
I also have thrust washer and flywheel bolts
They way I was thinking remove my motor and have both my engine and short block
on stands. Then just start swapping everything onto my short block.
Last edited by Sickspeed3; 08-09-2012 at 01:51 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-09-2012, 06:31 PM   #6
Realgib3's Avatar
Posts: 2,443   (View Stats)
1) Don't lower compression
2) Don't run standard ARP Head Studs (run ptp's studs or L19 studs straight from ARP)
3) Don't run a Cometic HG (run stock HG)
4) Streetlite FW FTW
5) Coat the bearings and anything else you can afford to do
6) Run a bigger turbo
 Old 08-10-2012, 11:59 AM   #7
Sickspeed3's Avatar
Coat the bearings? This is new to me what am I coating them with? The goal is to still have a reliable DD. With the stock head stock IM but built bottom end what is potential of my setup with 5 th port no meth
 Old 08-10-2012, 01:27 PM   #8
Sickspeed3's Avatar
How much can bottom end handle without sleeves?
 Old 08-10-2012, 10:16 PM   #9
chuckms6's Avatar
Posts: 1,618   (View Stats)
I think you need to do some research before committing to a motor build. No one has reached the structural limits of anything but the rods on this motor. Direct injection also allows for much more compression compared to port injection.
Tapatalking
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
 Old 08-11-2012, 06:04 AM   #10
Sickspeed3's Avatar
Tapatalking
I am doing my research but that was just a curious question. Ive built motors before just never messed with this platform. But thanks for answering my question, no one knows yet.
 Old 08-11-2012, 10:10 AM   #11
Realgib3's Avatar
Yeah the most power we've seen thus far without sleeves is into the low 700's, but it may take considerably more, no one really knows.
Also, the coating is basically an anti-friction coating. @Alpha has looked a lot into different company's coatings from what I remember.
 Old 08-11-2012, 10:54 AM   #12
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Streetlite FW
Realgib3 (08-11-2012)
 Old 08-11-2012, 11:41 AM   #13
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
The L19 head studs are RIDICULOUSLY expensive. I grabbed some Cosworth head studs from MAPerformance for a really good price, and they had them in stock.
Also, I don't like the idea of dropping compression, but if you have the pistons already...
I would also just get a whole new oil pump. No sense in risking your new toy for a $150 part.
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 08-11-2012, 01:15 PM   #14
Sickspeed3's Avatar
I really appreciate it guys, helping me a lot in the planning of all this. Anything else please continue to let me know. Who sells the oil pump 150? The only place I've seen was street unit.
 Old 08-16-2012, 03:12 PM   #15
Sickspeed3's Avatar
Alright so here's my updated list from help from you guys and my own research:
Stock HG
DCR VVT Actuator
ARP Head and Main studs
PTP windage tray
Cosworth BSD
OEM Crank Pulley Bolt
Oil Pump
Timing Chain(if needed)
Oil pump strainer Tube
Oil Pump O ring gasket
Rear Main Seal
Friction washers x3( who sales them)
I'm just trying to get a definent list together to make this built organize and as painless as possible. But I have a question, I know there is a Camshaft alignment tool and a TDC tool. As I was looking through the Manuel theres this one special tool for the (Oil Pump Driven Sprocket) is this tool really needed, has anyone has experience with
Removing sprocket without using this special tool. Thanks again.
The Following 2 Users Say Thank You to Sickspeed3 For This Useful Post:
phate (08-16-2012), Realgib3 (08-16-2012)
 Old 08-16-2012, 03:32 PM   #16
Eth Fiend
phate's Avatar
You can use the spanner wrench from an angle grinder on the oil pump sprocket, or just use a small punch through one of the sprocket holes to hold it in place.
The friction washers are only available through Mazda. Let me know if you need part numbers, I just placed a HUGE order for the entire timing system and whatnot on the front of the engine.
-06 MS6
Speed_j23 (08-16-2012)
CJM's Build CJM 2010 MS3 - Build Diaries 3 04-06-2012 03:47 PM
Report: Fiat to build Alfa Romeo SUV alongside Jeeps in America, build small car in Italy Haltech Automotive News 0 09-02-2011 07:20 AM
Theory: Build before Build demonspeed MazdaSpeed 6 - Engine, Transmission & Driveline 5 02-10-2009 06:52 PM
Page generated in 0.35660 seconds with 27 queries
