| Banned ![]() ![]() Join Date: May 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 75 Times in 8 Posts
(Thread Starter) | Not Ranked : 0 score Spare Block machined .20 over Cp pistons 8:5:1— Pauter Rods Main and Rod bearings— Here's a list of things that I'm going to order( if you have any suggestions please let me know): Arp head studs Arp main studs DCR VVT Actuator Cosmetic head gasket— New oil pump seals— Rear main seal— ACT 6 puck clutch flywheel still undecided— I'm currently on a gt3076 22psi— fully bolted— AP— Tuned— |
| The Following User Says Thank You to Sickspeed3 For This Useful Post: | Seatime3 (08-09-2012) |
| Not Ranked : 0 score You will also need all the oem washers and bolts for the timing components and the flywheel bolts. There might be a few other things but they are not coming up right now. |
Groans: 433
| Not Ranked : 0 score why drop compression? no need. go 9.5:1.
| The Following User Says Thank You to Chimmike For This Useful Post: | chuckms6 (08-10-2012) |
![]() Join Date: Jul 2012 Location: Tampa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,432
| Not Ranked : 0 score Safer to run mo' bewst lol. But fuck safety; because racecar. Sent from my iPhone using Tapatalk
__________________ '08 Speed3 - Cobb sri/cp-e rmm/18x8 RX-8 rims (DynoJet @ 254 whp/295 wtq) '99 Miata - Ground Control coilovers/Bilstein Sports/Racing Beat F&R sway bars/Go Miata strut tower brace/Jackson Racing header/MSM muffler/15x7 Kudo Racing wheels |
(Thread Starter) | Not Ranked : 0 score Lower compression idk I might be getting a gt35r so my thought was to be more safe.
They way I was thinking remove my motor and have both my engine and short block on stands. Then just start swapping everything onto my short block. Last edited by Sickspeed3; 08-09-2012 at 01:51 PM. Reason: MSF Database - Automerged Doublepost | |
![]() Join Date: Jan 2009 Location: Cleveland, OH
Rep Power: 3292 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,280
| Not Ranked : 0 score 1) Don't lower compression 2) Don't run standard ARP Head Studs (run ptp's studs or L19 studs straight from ARP) 3) Don't run a Cometic HG (run stock HG) 4) Streetlite FW FTW 5) Coat the bearings and anything else you can afford to do 6) Run a bigger turbo |
(Thread Starter) | Not Ranked : 0 score Coat the bearings? This is new to me what am I coating them with? The goal is to still have a reliable DD. With the stock head stock IM but built bottom end what is potential of my setup with 5 th port no meth |
(Thread Starter) | Not Ranked : 0 score How much can bottom end handle without sleeves? |
![]() Join Date: Nov 2010 Location: rockledge fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,125
| Not Ranked : 0 score I think you need to do some research before committing to a motor build. No one has reached the structural limits of anything but the rods on this motor. Direct injection also allows for much more compression compared to port injection. Tapatalking
__________________ DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob Megan Racing Coilovers 13.7@ 96 w/1.8 60ft (SRI, AP) 13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's) ![]() |
(Thread Starter) | Not Ranked : 0 score I am doing my research but that was just a curious question. Ive built motors before just never messed with this platform. But thanks for answering my question, no one knows yet. |
| Not Ranked : 0 score Yeah the most power we've seen thus far without sleeves is into the low 700's, but it may take considerably more, no one really knows. Also, the coating is basically an anti-friction coating. @Alpha has looked a lot into different company's coatings from what I remember. |
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
| Not Ranked : 0 score Streetlite FW
__________________ |
| The Following User Says Thank You to helmetface For This Useful Post: | Realgib3 (08-11-2012) |
| Not Ranked : 0 score The L19 head studs are RIDICULOUSLY expensive. I grabbed some Cosworth head studs from MAPerformance for a really good price, and they had them in stock. Also, I don't like the idea of dropping compression, but if you have the pistons already... I would also just get a whole new oil pump. No sense in risking your new toy for a $150 part.
| The Following User Says Thank You to phate For This Useful Post: | Realgib3 (08-11-2012) |
(Thread Starter) | Not Ranked : 0 score I really appreciate it guys, helping me a lot in the planning of all this. Anything else please continue to let me know. Who sells the oil pump 150? The only place I've seen was street unit. |
(Thread Starter) | Not Ranked : 0 score Alright so here's my updated list from help from you guys and my own research: Stock HG DCR VVT Actuator ARP Head and Main studs PTP windage tray Cosworth BSD OEM Crank Pulley Bolt Oil Pump Timing Chain(if needed) Oil pump strainer Tube Oil Pump O ring gasket Rear Main Seal Friction washers x3( who sales them) I'm just trying to get a definent list together to make this built organize and as painless as possible. But I have a question, I know there is a Camshaft alignment tool and a TDC tool. As I was looking through the Manuel theres this one special tool for the (Oil Pump Driven Sprocket) is this tool really needed, has anyone has experience with Removing sprocket without using this special tool. Thanks again. |
| Not Ranked : 0 score You can use the spanner wrench from an angle grinder on the oil pump sprocket, or just use a small punch through one of the sprocket holes to hold it in place. The friction washers are only available through Mazda. Let me know if you need part numbers, I just placed a HUGE order for the entire timing system and whatnot on the front of the engine.
| The Following User Says Thank You to phate For This Useful Post: | Speed_j23 (08-16-2012) |
| CJM's Build | CJM | 2010 MS3 - Build Diaries | 3 | 04-06-2012 03:47 PM |
| Report: Fiat to build Alfa Romeo SUV alongside Jeeps in America, build small car in Italy | Haltech | Automotive News | 0 | 09-02-2011 07:20 AM |
| Chrysler to build plug-in Ram test fleet, won't build Two Mode hybrid pickup | Haltech | Automotive News | 0 | 03-22-2010 10:10 PM |
| Theory: Build before Build | demonspeed | MazdaSpeed 6 - Engine, Transmission & Driveline | 5 | 02-10-2009 06:52 PM |
| Build-a-Bull: Automobile mag helps build the first production Lambo LP560-4 | Haltech | Automotive News | 0 | 04-01-2008 05:20 PM |
