![]() | | #41 | ![]() |
![]() Join Date: Dec 2009 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,256
| Not Ranked : 0 score ![]() Best of luck with the new setup man!
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() |
![]() | | #42 | ![]() |
| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
![]() | | #43 | ![]() |
![]() Join Date: May 2009 Location: Little Neck, NY
Rep Power: 3771 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,108
Groans: 326
| Not Ranked : 0 score in for win |
![]() | | #44 | ![]() |
| Not Ranked : 0 score Haha! Sorry, sometimes I just post quick. I just saw it and it hit me in the face. Seriously though, it sounds like a bad ass setup man!
| The Following User Says Thank You to Alpha For This Useful Post: | NJSPEED3 (07-22-2010) |
![]() | | #45 | ![]() |
Groans: 113
(Thread Starter) | Not Ranked : 0 score Well i purchased all the small shit no one thinks about. Oil line fittings $150, 3" vband clamp $16, 4" inlet $200. Turbo gets here saturday i think i should be able to install just about everything pending some of these parts come in. ill take some pictures later on today of the current status. I removed the alternator last night so i could pull of the oil feed line to the turbo. Im going to do my oil lines similar to SSinstaller except my return line will be completely new atp sells a fitting that is mazda specific for the block side of the return line. Stay tuned |
| The Following 5 Users Say Thank You to NJSPEED3 For This Useful Post: | Alpha (07-22-2010), djuosnteisn (07-27-2010), dougefresh_ (05-14-2011), madvillain (07-22-2010), MS3-a(sore)ASS-rex (07-23-2010) |
![]() | | #46 | ![]() |
Groans: 78
| Not Ranked : 0 score FUCK that banjo bolt to the oil feed behind the alternator. I hate it, I hate it so deeply.
__________________ [Precision 5557 T4 flanged Journal Bearing Turbo][Race Roots Ceramic Coated T4 Manifold][Race Roots 3" V-Band Catless Downpipe][Race Roots Under-Car FMIC kit][CXracing 18"x31"x3" IC Core][Tial 44mm EWG With 0.9Bar Spring][Cobb AP][Full Str33tunit Mount Set][Madvillain 4" Inlet/Intake][Cp-e xcelXL Maf Housing][Devilsown Meth Injection Kit][HKS Ignition Amplifier][Cp-e Catback Exhaust][HKS bov][PTP IM Spacer][Whoosh EGR Delete][AEM Digital Boost Gauge][Matt Damond OCC Kit][Trunk Mounted Optima Battery with KnuKonceptz Kit][Madvillain ECU box][TWM Short Shifter][BC Coilovers][Cobb Rear Sway Bar][Falken Azenis rt615's][Eibach Pro 25mm Spacers] |
| The Following User Says Thank You to madvillain For This Useful Post: | xcoldricex (07-22-2010) |
![]() | | #47 | ![]() |
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | |
![]() | | #48 | ![]() |
Groans: 113
(Thread Starter) | Not Ranked : 0 score Well Tyler did most of the work on this, you can find almost everything from atp or siliconeintakes.com Here's the list of stuff i purchased last night from atp. The only thing missing on this list is the -10an hose for the oil return feed. Im waiting on Tyler to mock his up in order to know how to angle it right and have the proper lenght of the hose. GRT-GSK-008 Oil Return Gasket - GT Series 1 $3.00 $3.00 ATP-FLA-019 Oil Return Flange with integrated -10 Flare for GT15 Through GT35R$29.00 ATP-MS3-015 Oil Return/Drain Fitting for Mazdaspeed3 $29.00 ATP-OIL-021 -4 size Oil inlet fitting for GT28/30/35R with built-in restrictor $12.00 CUSTOM-OIL-FEED-LINECustom Oil Feed Line - Built to Order #4 (-4 AN) size Steel $10.00 END1: STRAIGHT $5.00 END2: STRAIGHT $5.00 LENGTH: 22 $11.00 i ordered from Speedwaymotors.com the fitting that you need welded to the stock oil feed line to transition to -4an ss braided hose. 6177104 STEEL WELD BUNG FITTING, AN4 MALE 1 $2.99 Tyler or i will post the missing info on the return hose when he mocks it up this weekend. |
| The Following 3 Users Say Thank You to NJSPEED3 For This Useful Post: |
![]() | | #49 | ![]() |
![]() Join Date: Jan 2009 Location: Bangor PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,426
Groans: 88
| Not Ranked : 0 score so excited for u gerry. cant wait.
__________________ 1995 honda civic. 1.6L slow 2007 Kawasaki ZX10r |
| The Following User Says Thank You to BrianZX10R For This Useful Post: | djuosnteisn (07-27-2010) |
![]() | | #50 | ![]() |
Groans: 78
| Not Ranked : 0 score I'm going to make a detailed, picture full, big turbo shopping list thread this weekend after I finish taking some measurements.
| The Following 2 Users Say Thank You to madvillain For This Useful Post: | FreeFlyFreak (08-02-2010), MS3-a(sore)ASS-rex (07-23-2010) |
![]() | | #51 | ![]() |
![]() Join Date: Jan 2009 Location: ME, Kittery
Rep Power: 1818 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,848
| Not Ranked : 0 score so you need an oil restrictor with the gt turbos? Or is that built into the stock oil feed line?
__________________ 2012 WRX HB w/mudflaps yo! |
![]() | | #52 | ![]() |
Groans: 113
![]() | | #53 | ![]() |
Groans: 78
| Not Ranked : 0 score yeah well the stock oil feed line, at the turbo end, has a restrictor in it from what I understand. With my journal bearing turbo I just use a straight 4an line, no restrictor needed.
![]() | | #54 | ![]() |
| Not Ranked : 0 score Well I'm using the stock oil feed line right now for my gt turbo so I should be all set I think. Please tell me if I'm wrong so I can change it haha. I can't get my car to smoke so that's a good sign.
| The Following User Says Thank You to spnkr21 For This Useful Post: | djuosnteisn (07-27-2010) |
![]() | | #55 | ![]() |
Groans: 113
(Thread Starter) | Not Ranked : 0 score Alot of guys run the stock oil feed line from what i've been told Tim, seems to be working. Im just wondering how much oil pressure the stock banjo bolt is spraying into the turbo cartridge. Maybe someone could chime in! |
![]() | | #56 | ![]() |
Groans: 224
| Not Ranked : 0 score Oh man Gerry you're geting close! Still kinda pissed I couldn't get you a better deal on that turbo, damn you mark! Jk <3
![]() | | #57 | ![]() |
![]() Join Date: Jul 2008
Rep Power: 1791 ![]() Thanks: 2,239
Groans: 62
| The Following 4 Users Say Thank You to MarkyMark For This Useful Post: | djuosnteisn (07-27-2010), mr_mazda329 (07-24-2010), MS3-a(sore)ASS-rex (07-23-2010), NJSPEED3 (07-23-2010) |
![]() | | #58 | ![]() |
| Not Ranked : 0 score Well it is a different banjo bolt that ATP recommended. That probably is the restrictor you're right. Thanks man!
| The Following 3 Users Say Thank You to spnkr21 For This Useful Post: |
![]() | | #59 | ![]() |
Groans: 113
(Thread Starter) | Not Ranked : 0 score the stock banjo bolt is a restrictor just like the atp restrictor they just look different. Im just not sure if they have the same size restrictor. Maybe Bnoon could fill us in on this. Last edited by NJSPEED3; 07-24-2010 at 05:44 AM. |
| The Following User Says Thank You to NJSPEED3 For This Useful Post: | dougefresh_ (05-14-2011) |
![]() | | #60 | ![]() |
Groans: 113
(Thread Starter) | Not Ranked : 0 score Im still kinda unsure about my fmic set up. I was really pissed the Brice fucked me on an unfinished kit. I have to make brackets to sustain the Godspeed core, which is not a big deal. Core size 24" x 9" x 3" end to end 30" with 3" inlets. Their piping is 2.5". Its exactly like Tyler's fmic expect for the bov position. The cobb core is identical except its 8" tall. I think i can fit the RR piping with the Cobb core. Here's some pictures of the fmic and of the car's current status. Let me know what you guys think? Last edited by NJSPEED3; 11-10-2010 at 05:46 PM. |
| The Following 8 Users Say Thank You to NJSPEED3 For This Useful Post: | djuosnteisn (07-27-2010), doubleflusher (07-24-2010), dougefresh_ (05-14-2011), madvillain (07-23-2010), pharoh (07-24-2010), predapio (07-24-2010), www.cp-e.com (07-23-2010), _Toxic_ (07-24-2010) |
![]() | | #61 | ![]() |
Groans: 113
(Thread Starter) | Not Ranked : 0 score Turbo came in this afternoon its a gt3076 t3 .82 a/r with a 4" inlet and 2" out. Thanks again to Mark From StreetUnit. This thing was purchased on Tuesday and here i am on Saturday with a new turbo SU FTW!. I took tuns of pics of the turbo and some of the manifold and downpipe mocked up to give you guys an idea on what a t3 vband set up looks outside the car. Let me know what you think? |
| The Following 8 Users Say Thank You to NJSPEED3 For This Useful Post: | BrianZX10R (07-25-2010), djuosnteisn (07-27-2010), doubleflusher (07-24-2010), dougefresh_ (05-14-2011), Dre (07-27-2010), madvillain (07-24-2010), pharoh (07-24-2010), predapio (07-24-2010) |
![]() | | #62 | ![]() |
Groans: 113
(Thread Starter) | Not Ranked : 0 score More pics of the turbo mocked up! |
| The Following 7 Users Say Thank You to NJSPEED3 For This Useful Post: | djuosnteisn (07-27-2010), doubleflusher (07-24-2010), Dre (07-27-2010), FreeFlyFreak (08-02-2010), madvillain (07-24-2010), pharoh (07-24-2010), predapio (07-24-2010) |
![]() | | #63 | ![]() |
Groans: 113
(Thread Starter) | Not Ranked : 0 score A few more here, i may have gone over board on the pictures haha anyway enjoy! Just know that when you go on Su site and look up a 3076 you're actually looking at my turbo haha. |
| The Following 12 Users Say Thank You to NJSPEED3 For This Useful Post: | djuosnteisn (07-27-2010), doubleflusher (07-24-2010), dougefresh_ (05-14-2011), Downmented (02-14-2012), Dre (07-27-2010), FreeFlyFreak (08-02-2010), ganque (08-17-2011), madvillain (07-24-2010), pharoh (07-24-2010), predapio (07-24-2010), stefan (07-24-2010), wankular (08-02-2010) |
![]() | | #64 | ![]() |
| Fuck sushi rolls ![]() Join Date: May 2008 Location: Los Angeles
Rep Power: 12764 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,168
Groans: 356
| Not Ranked : 0 score how fast did u say that table goes??
__________________ 2007 Ms3 3071r fully bolted , retired and sold after 110k miles of abuse 2014 Black Track Pack premium , NA 4lyfe ...AED dyno tuned on E85 466.6whp / 406.8 TQ SAE |
| The Following 11 Users Say Thank You to rodrigo For This Useful Post: | djuosnteisn (07-27-2010), doubleflusher (07-24-2010), dougefresh_ (05-14-2011), Dre (07-27-2010), FreeFlyFreak (08-02-2010), mr_mazda329 (07-24-2010), NJSPEED3 (07-24-2010), NRSpeed (07-24-2010), pharoh (07-24-2010), rigor (12-10-2010), ZoomZoomPSSH (07-25-2010) |
![]() | | #65 | ![]() |
Groans: 113
| The Following 5 Users Say Thank You to NJSPEED3 For This Useful Post: | djuosnteisn (07-27-2010), doubleflusher (07-24-2010), pharoh (07-24-2010), rigor (12-10-2010), stefan (07-24-2010) |
![]() | | #66 | ![]() |
Groans: 78
| Not Ranked : 0 score Lookin good Gerry! WHat inlet are you going to run again?
| The Following User Says Thank You to madvillain For This Useful Post: | NJSPEED3 (07-24-2010) |
![]() | | #67 | ![]() |
Groans: 113
![]() | | #68 | ![]() |
Groans: 224
| Not Ranked : 0 score Man that looks great Gerry! Get that dump tube fabbed up so you can go fast already!
| The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post: | NJSPEED3 (07-24-2010) |
![]() | | #69 | ![]() |
Groans: 78
| Not Ranked : 0 score The reason I ask is because your cartridge housing is much more compact than mine. The RR manifold already places the turbo a bit further towards the passanger side in comparison to the PG/stock manifold placement. Your smaller cartridge further pushes the compressor side even further towards the passenger side. You may need to extend the end of your inlet to reach the compressor inlet using these: one of these: Turbo Piping and one of these: Silicone Turbo Hoses I could be totally wrong, its been a while since I've seen one of cp-e's inlets tubes, but I really don't know if it will work as is.
![]() | | #70 | ![]() |
Groans: 113
![]() | | #71 | ![]() |
Groans: 78
| Not Ranked : 0 score Install everything then do the oil lines. Make sure you clock the turbo correctly. The oil feed should be facing directly upwards, the oil drain directly downwards. make sure you drop the turbo down on the axle (I usually put a small box or a piece of foam to rest it on down there, THEN bolt the manifold on the head. I wasn't thinking once and torqued the manifold down all tight then was like FUCK, forgot the turbo. then do the DP last, thats the easy part.
![]() | | #72 | ![]() |
![]() ![]() Join Date: Jul 2008 Location: Old Bridge NJ
Rep Power: 22834 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,276
Groans: 309
| Not Ranked : 0 score Damn Gerry, you dont fuck around..nice going.
__________________ Dash08: I don't see the whole pedophile thing, But Predapio is a dirty old bastard. So, I wouldn't rule it out entirely. That's also why he fits in here. We're all a bunch of filthy, perverted, arrogant, pessimistic, self-righteous assholes who find entertainment at other peoples expense. What a lovable bunch we are!! |
| The Following User Says Thank You to predapio For This Useful Post: | djuosnteisn (07-27-2010) |
![]() | | #73 | ![]() |
Groans: 113
(Thread Starter) | Not Ranked : 0 score WOOT Thats great news Tyler that means i could slap this bitch on right now. one more question im still waiting on the steel fitting to weld on the oil feed line. So the alternator can't go on the car until thats done. Will i be able to install the alternator back on after the tb,mani and dp are on the car? |
| The Following User Says Thank You to NJSPEED3 For This Useful Post: | djuosnteisn (07-27-2010) |
![]() | | #74 | ![]() |
| Not Ranked : 0 score I can tighten down the oil feed line with the alternator on.
| The Following 2 Users Say Thank You to spnkr21 For This Useful Post: | djuosnteisn (07-27-2010), NJSPEED3 (07-24-2010) |
![]() | | #75 | ![]() |
Groans: 78
| Not Ranked : 0 score You technically can install the oil feed with the alternator in, but its not worth it, not to me at least. Maybe if you have just the right wrench. I installed/uninstalled my oil feed line with the alternator on the first time but it is just so much easier to just take it off. You can get the alternator on/off with the manifold and turbo mounted, just not the downpipe, well it'd make your life more difficult than necessary.
![]() | | #76 | ![]() |
Groans: 113
(Thread Starter) | Not Ranked : 0 score Im still missing the inlet and all my oil lines for the turbo, i decided to maock the turbo with the mani and see how this whole thing is going to come together.Everything went in smoothly. I just cant see how im going to be able to hook up some sort of inlet with the current location of the compressor. The car heater lines run basically in front of the compressor inlet and one of them is metal. The shifter cables are also right in that area there. Any ideas? I have a few but i'd like to see what you guys come up with? My other major issue is the RaceRoots cold pipe for their fmic. I noticed prior to doing the install that it was very different than Tyler's, so is the manifold by the way. the cold pipe is basically to short. The obv flange is also in a retarded location which i brought up to Brice prior to the install. The bov flange on Tyler's set up is right next to the throttle body like every other fmic set our cars use. Mines is basically next to the core you can see the HKS flange on some pics. Brice told me they relocated the bov flange because of fitment issues. The funny thing Tyler has no fitment issues with his. From the pictures its obvious someone Fucked up. I will have no choice but to fix it myself at this point, but Brice if you're reading this please respond to my emails and lets come to an agreement on this. Thats about it for now until more parts come in. |
| The Following 4 Users Say Thank You to NJSPEED3 For This Useful Post: | djuosnteisn (07-27-2010), FreeFlyFreak (08-02-2010), IshiKage (07-25-2010), mr_mazda329 (07-25-2010) |
![]() | | #77 | ![]() |
![]() Join Date: Dec 2008 Location: Marlton, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score looks good !!!
__________________ 2009 Mazdaspeed3 SOLD! Summit Point Main 1:32.725 (on all seasons) Lime Rock Park 1:05.419 (R888) Pittsburgh Int. 1:09.594 (R888) NJMP Lightning 1:21.203 (R888) 2013 Ford Mustang GT NJMP Lightning - 1:25.04 (stock car with 235/18 pirelli all seasons) NJMP Lightning - 1:20.087 (modded car with 245 summers) Pocono North - 1:06.xx (Dunlop SP600 245x18) wet Pocono North - 1:00.655 (275mm Conti Slicks) Lime Rock - 1:07.2 (Dunlop SP600 245x18) 1989 Honda CRX Si VIR Full Course - slowww Summit Point Main 1:35.230 Renault Spec Racer Lime Rock Park 1:04 VIR Full Course 2:30 |
![]() | | #78 | ![]() |
![]() ![]() Join Date: Jun 2008 Location: Greenville, SC
Rep Power: 2562 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,586
Groans: 125
| Not Ranked : 0 score looks like you have the coolant lines backwards. not that it matters, as long as you get hoses to them. swapping them might make it easier.
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 |
| The Following User Says Thank You to socks For This Useful Post: | djuosnteisn (07-27-2010) |
![]() | | #79 | ![]() |
| Approved MSF Vendor ![]() Join Date: May 2008 Location: Beltsville, Maryland
Rep Power: 2499 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 425
| Not Ranked : 0 score We'll get this taken care of. I've got the ideas I mentioned to you on gchat.
__________________ Website: www.cp-e.com Facebook: www.facebook.com/gocpe Twitter: www.twitter.com/gocpe |
![]() | | #80 | ![]() |
Groans: 113
Thanks Jake i appreciate all you're help ! | |
| Stock Block BT build threads | xcoldricex | MazdaSpeed 3/6 - Big Turbo Builds | 50 | 07-13-2010 08:37 AM |
| How many ppl running BT's with stock block? | SpeedSixxx | MazdaSpeed 3/6 - Turbo Induction | 20 | 11-08-2009 12:30 PM |
| engine build with stock compression | Jessed87 | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 06-12-2009 11:55 PM |
| Safe Horsepower on stock engine build? | cl45music | MazdaSpeed 3 - Engine, Transmission & Driveline | 36 | 02-17-2009 07:27 AM |
| So...Turbo/motor limits on stock block & internals? | 94jedi | MazdaSpeed 3/6 - Turbo Induction | 26 | 05-31-2008 08:01 AM |
