![]() | | #81 | ![]() |
Groans: 78
| Not Ranked : 0 score
__________________ [Precision 5557 T4 flanged Journal Bearing Turbo][Race Roots Ceramic Coated T4 Manifold][Race Roots 3" V-Band Catless Downpipe][Race Roots Under-Car FMIC kit][CXracing 18"x31"x3" IC Core][Tial 44mm EWG With 0.9Bar Spring][Cobb AP][Full Str33tunit Mount Set][Madvillain 4" Inlet/Intake][Cp-e xcelXL Maf Housing][Devilsown Meth Injection Kit][HKS Ignition Amplifier][Cp-e Catback Exhaust][HKS bov][PTP IM Spacer][Whoosh EGR Delete][AEM Digital Boost Gauge][Matt Damond OCC Kit][Trunk Mounted Optima Battery with KnuKonceptz Kit][Madvillain ECU box][TWM Short Shifter][BC Coilovers][Cobb Rear Sway Bar][Falken Azenis rt615's][Eibach Pro 25mm Spacers] |
| The Following 2 Users Say Thank You to madvillain For This Useful Post: | djuosnteisn (07-27-2010), xcoldricex (07-25-2010) |
![]() | | #82 | ![]() |
![]() Join Date: Dec 2009 Location: used to be NJ, now hamburg germany
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,615
Groans: 140
Groaned at 116 Times in 64 Posts
| Not Ranked : 0 score gerry next time pharoh and myself are over pls make sure the neighbor chicks are poolside again. thx!
| The Following 3 Users Say Thank You to stefan For This Useful Post: |
![]() | | #83 | ![]() |
![]() Join Date: Jan 2009 Location: Bangor PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,426
Groans: 88
| Not Ranked : 0 score gerry cant wait for u to get it up and running so we can do some runs does that manifold put your turbo in a different position then a stock manifold would cause mine worked out fine with the inlet
__________________ 1995 honda civic. 1.6L slow 2007 Kawasaki ZX10r Last edited by BrianZX10R; 07-25-2010 at 08:49 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to BrianZX10R For This Useful Post: | djuosnteisn (07-27-2010) |
![]() | | #84 | ![]() |
| Approved MSF Vendor ![]() Join Date: May 2008 Location: Beltsville, Maryland
Rep Power: 2499 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 425
| Not Ranked : 0 score Yes - it is not stock location and brice didn't include parts promised so they have to make their own inlets.
__________________ Website: www.cp-e.com Facebook: www.facebook.com/gocpe Twitter: www.twitter.com/gocpe |
![]() | | #85 | ![]() |
| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
(Thread Starter) | Not Ranked : 0 score Thanks for the insight Tyler! Im sure many here are waiting on that race Brian we will do this my man! Yes this manifold is very different than the stock manifold location. You Turbo kit is a direct bolt on Brian that shit had better fit fine, im dealing with an entire different beast. |
| The Following User Says Thank You to NJSPEED3 For This Useful Post: | djuosnteisn (07-27-2010) |
![]() | | #86 | ![]() |
Groans: 88
| Not Ranked : 0 score thats sucks gerry. toe your car to JM fabrication and they will make u everything u need
__________________ 1995 honda civic. 1.6L slow 2007 Kawasaki ZX10r |
| The Following User Says Thank You to BrianZX10R For This Useful Post: | NJSPEED3 (07-25-2010) |
![]() | | #87 | ![]() |
| Not Ranked : 0 score Not worth the extra money. This can be done at home and look great for much less than paying to have it done. Two aluminum 3.5" pipes and 3 couplers (2 straight one 60 or 90 coupler) and you are set!! One of the couplers being a 4-3.5" for turbo to first 3.5" pipe.
| The Following User Says Thank You to www.cp-e.com For This Useful Post: | NJSPEED3 (07-25-2010) |
![]() | | #88 | ![]() |
Groans: 78
| Not Ranked : 0 score Gerry, you're getting there man. With the welding equipment and tools you have the world is in your hands man. Start taking shit apart and make your own stuff. Its less expensive and more importantly it is much much more satisfying, this is the realization I've come to in the past week or so since I've began to redo all of my shit.. AGAIN. Good luck tomorrow man. As I said, don't worry about calling me.
| The Following User Says Thank You to madvillain For This Useful Post: | NJSPEED3 (07-25-2010) |
![]() | | #89 | ![]() |
Groans: 113
(Thread Starter) | Not Ranked : 0 score You're nuts Brian I love this shit! Fabricating,installing,reinstalling,talking shit,installing some more is half the fun! If it was easy we would all have super fast street cars! On another note I will definitely come see JM Fab for a sexy screamer! |
| The Following 2 Users Say Thank You to NJSPEED3 For This Useful Post: | BrianZX10R (07-25-2010), djuosnteisn (07-27-2010) |
![]() | | #90 | ![]() |
Groans: 113
(Thread Starter) | Not Ranked : 0 score I have a fucking cold from going in and out of the house sweating FMC!I didnt get much done last night, except for relocation the coolant lines that were in the way of the turbo inlet. Im kinda stuck until more parts come in. |
![]() | | #91 | ![]() |
Groans: 224
| Not Ranked : 0 score Fawk! Those parts need to get here, this things supposed to be done by Sunday!!
![]() | | #92 | ![]() |
Groans: 78
| Not Ranked : 0 score Must put car back together before gerry, must put car back together before gerry, must put car back together before gerry.
| The Following 2 Users Say Thank You to madvillain For This Useful Post: | MS3-a(sore)ASS-rex (07-27-2010), NJSPEED3 (07-27-2010) |
![]() | | #93 | ![]() |
Groans: 113
(Thread Starter) | Not Ranked : 0 score Between my 2 year old and this cold i not getting much progress! I also just started this 4 days ago. Since i've had to order a few things. Today i received the final pc for my oil feed line ill post pics up later. If i had everything here I could have it all done in a day im sure, but watching Tyler build before me makes things easier lol. I should have everything here by friday the lastest. Maybe sundays is do able! |
| The Following 3 Users Say Thank You to NJSPEED3 For This Useful Post: |
![]() | | #94 | ![]() |
| Not Ranked : 0 score Dayum son... I need to navigate away from my sub'd threads more often.... this is gonna be a very very very nice setup. Looks amazing man!
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
| The Following User Says Thank You to djuosnteisn For This Useful Post: | madvillain (07-27-2010) |
![]() | | #95 | ![]() |
![]() Join Date: Feb 2009
Rep Power: 151849 ![]() Thanks: 55,993
Groans: 1,443
| Not Ranked : 0 score We race Sunday?
__________________ Evo VIII - 9.93 @ 150.05 - CAI and LEDs Beanfab / Tuned by Nishan |
| The Following User Says Thank You to doubleflusher For This Useful Post: | MS3-a(sore)ASS-rex (07-27-2010) |
![]() | | #96 | ![]() |
Groans: 224
| Not Ranked : 0 score That depends flush, if you come to sonic I can guarantee I can get all of you races. I'm actually set to run a turbo'd SI and a G8. And I've got some big guns in store for Gerry
![]() | | #97 | ![]() |
![]() Join Date: Dec 2008 Location: Marlton, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score which sonic?
__________________ 2009 Mazdaspeed3 SOLD! Summit Point Main 1:32.725 (on all seasons) Lime Rock Park 1:05.419 (R888) Pittsburgh Int. 1:09.594 (R888) NJMP Lightning 1:21.203 (R888) 2013 Ford Mustang GT NJMP Lightning - 1:25.04 (stock car with 235/18 pirelli all seasons) NJMP Lightning - 1:20.087 (modded car with 245 summers) Pocono North - 1:06.xx (Dunlop SP600 245x18) wet Pocono North - 1:00.655 (275mm Conti Slicks) Lime Rock - 1:07.2 (Dunlop SP600 245x18) 1989 Honda CRX Si VIR Full Course - slowww Summit Point Main 1:35.230 Renault Spec Racer Lime Rock Park 1:04 VIR Full Course 2:30 |
![]() | | #98 | ![]() |
Groans: 88
| Not Ranked : 0 score the sonic by me in pa
![]() | | #99 | ![]() |
Groans: 224
| Not Ranked : 0 score Sonic in Bensalem. On street rd just off 95, thread-jacking ftw! Sorry Gerry
![]() | | #100 | ![]() |
Groans: 113
(Thread Starter) | Not Ranked : 0 score On the quest for the right oil/coolant turbo lines! |
| The Following User Says Thank You to NJSPEED3 For This Useful Post: | djuosnteisn (07-28-2010) |
![]() | | #101 | ![]() |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
| Not Ranked : 0 score those parts are shiny.
__________________ it's fun to do bad things |
| The Following User Says Thank You to jack_hammer For This Useful Post: | NJSPEED3 (07-28-2010) |
![]() | | #102 | ![]() |
Groans: 113
(Thread Starter) | Not Ranked : 0 score I barely worked on the car last night. I felt like crap from this stupid cold. I did manage to mock up the turbo with the new oil restrictor and oil feed line as well as both coolant lines. My Manifold has some bracing from the turbo flange to the head flange. One of the braces is perfectly aligned with the oil line of course. So i purchased this 90 4na male to female znd it did the Trick. Still have to play with the coolant lines. here's a pic of that fitting! |
| The Following 2 Users Say Thank You to NJSPEED3 For This Useful Post: | djuosnteisn (07-28-2010), doubleflusher (07-28-2010) |
![]() | | #103 | ![]() |
| Not Ranked : 0 score Gerry, i'm gonna be in the custom oil / coolant line game very very soon. Can you please post up more details? Or even better, make a new thread and call it "how to, custom oil / coolant lines". Considering how common the custom turbo setups are on our platform, i think this is something that should be common knowledge, or at least documented extremely well. .... I'll make philly get yo deck wet when he's out there as payment
| The Following User Says Thank You to djuosnteisn For This Useful Post: | doubleflusher (07-28-2010) |
![]() | | #104 | ![]() |
Groans: 113
(Thread Starter) | Not Ranked : 0 score It Feels like Christmas everyday around here out of this box an custom 4" inlet shall arise. Stay Tuned. I also ordered some some thermo sleeves 1/2" and 3/4" for the coolant lines. http://www.thermotec.com/products/14...mo-sleeve.html Last edited by NJSPEED3; 07-28-2010 at 11:19 AM. |
| The Following 4 Users Say Thank You to NJSPEED3 For This Useful Post: | djuosnteisn (07-28-2010), doubleflusher (07-28-2010), madvillain (07-28-2010), MS3-a(sore)ASS-rex (07-28-2010) |
![]() | | #105 | ![]() |
Groans: 78
__________________ [Precision 5557 T4 flanged Journal Bearing Turbo][Race Roots Ceramic Coated T4 Manifold][Race Roots 3" V-Band Catless Downpipe][Race Roots Under-Car FMIC kit][CXracing 18"x31"x3" IC Core][Tial 44mm EWG With 0.9Bar Spring][Cobb AP][Full Str33tunit Mount Set][Madvillain 4" Inlet/Intake][Cp-e xcelXL Maf Housing][Devilsown Meth Injection Kit][HKS Ignition Amplifier][Cp-e Catback Exhaust][HKS bov][PTP IM Spacer][Whoosh EGR Delete][AEM Digital Boost Gauge][Matt Damond OCC Kit][Trunk Mounted Optima Battery with KnuKonceptz Kit][Madvillain ECU box][TWM Short Shifter][BC Coilovers][Cobb Rear Sway Bar][Falken Azenis rt615's][Eibach Pro 25mm Spacers] | |
| The Following 2 Users Say Thank You to madvillain For This Useful Post: | djuosnteisn (07-28-2010), NJSPEED3 (07-29-2010) |
![]() | | #106 | ![]() |
| Not Ranked : 0 score Definitely! Big thanks!
![]() | | #107 | ![]() |
Groans: 78
| Not Ranked : 0 score Make any good progress today Gerry? I just remembered. I still have an extra cp-e fmic hot pipe, its 2.5" obviously, but if you needed it for the aluminum let me know. You can have it, just pay shipping for it. This may make your life easier if you want to try to make the RR kit work, which I still think you should so that you can sell your cobb kit and get $700.
![]() | | #108 | ![]() |
Groans: 88
| Not Ranked : 0 score i say keep the cobb kit
| The Following User Says Thank You to BrianZX10R For This Useful Post: | djuosnteisn (07-29-2010) |
![]() | | #109 | ![]() |
| THE NJ NATOR CAUCASIAN ![]() Join Date: Aug 2009 Location: New Jersey
Rep Power: 14688 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26,109
Groans: 50
| Not Ranked : 0 score COBB core > Godspeed core... |
| The Following User Says Thank You to pharoh For This Useful Post: | djuosnteisn (07-29-2010) |
![]() | | #110 | ![]() |
Groans: 224
| Not Ranked : 0 score The way the RR kits piping is run is awesome though. I would think it'll be similar to yours mad?
| The Following User Says Thank You to MS3-a(sore)ASS-rex For This Useful Post: | NJSPEED3 (07-29-2010) |
![]() | | #111 | ![]() |
Groans: 78
| Not Ranked : 0 score Yeah his hotpipe is identical to mine, but the cold pipe is way off. I don't know what happened there. Apparently they changed the design due to fitment issues, yet mine fits beautifully. I agree that the Cobb kit is better.. but personally I'd rather have the $700 if I had another kit in my hands that could be within reason of making it work.
| The Following 2 Users Say Thank You to madvillain For This Useful Post: | djuosnteisn (07-29-2010), NJSPEED3 (07-29-2010) |
![]() | | #112 | ![]() |
![]() Join Date: Jan 2009 Location: Newark, NJ
Rep Power: 1040 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,110
Groans: 661
| Not Ranked : 0 score gerry let me know when your done with this so i can check it out. i would offer to help but i wood probably just get in the way |
| The Following User Says Thank You to manelscout4life For This Useful Post: | NJSPEED3 (07-29-2010) |
![]() | | #113 | ![]() |
Groans: 113
(Thread Starter) | Not Ranked : 0 score ATP has fmc! Im waiting on a 10an male flange for the oil return line. They shipped me a barbed flange by mistake on monday.The right one was supose to be here today. I just got off the phone with them and they never processed it. So now looks like Tuesday. I can see Tyler's smile now... I was on a roll yesterday. I expexted to have the Turbo,manifold, oil & coolant lines, then i could reinstall the alternator back on and downpipe. So the first thing i did is finish my oil feed line, checked for good clearance and went to install it on the motor. Here comes the fucking FAIL! FML!!!!!!!!!!!!!!! When i intalled my SST a year ago i fucked up a few threads on the motor side of the oil feed line. So i had the car towed to my mechanic and he was able to fix it. Well yesterday afternoon i realized what he actually did. He simply removed the cocked bolt an retorqued it with half the threads gone. An aluminum block and a steel bolt are a deadly combination! Basically since i didnt know there were only a few threads,when i went to torque the bolt down on the block, i finished destroying the rest of the threads. The bolt was just spinning freely. This was around 8pm last night. I think i caught an instant fever! After i calmed down a bit i started looking into a solution. With a small mirror i was able to look into the bolt hole. So to my surprise the hole is around 25-30mm deep. The banjo bolt only goes into the block around 10mm, that leaves me 15-20mm left. Luckily for me my tenant owns a machine shop as well as my neighbor next door. He is making me a new banjo bolt 5mm longer than the stocker FTW. Hopefully this will resolve my fail. I should have it done later on today ill post pictures for you guys. Dont worry Bnoon you can have the mazda banjo bolt market for yourself lol. Here are some pictures of how im hooking up my oil feed line from the stock line to 4an braided line. |
| The Following 7 Users Say Thank You to NJSPEED3 For This Useful Post: | djuosnteisn (07-29-2010), doubleflusher (07-29-2010), jack_hammer (07-29-2010), kilik2 (07-31-2010), madvillain (07-29-2010), MS3-a(sore)ASS-rex (07-29-2010), pharoh (07-29-2010) |
![]() | | #114 | ![]() |
Groans: 50
| Not Ranked : 0 score Yo, Gerry... Your inlet pipe looks like its doing a FIST PUMP in that pic!!!! |
| The Following 3 Users Say Thank You to pharoh For This Useful Post: |
![]() | | #115 | ![]() |
| Banned ![]() Join Date: Sep 2009 Location: La Crosse, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 309
| Not Ranked : 0 score nice no more fail now...get her running...need to see some good results |
| The Following User Says Thank You to holeinmypocket For This Useful Post: | NJSPEED3 (07-29-2010) |
![]() | | #116 | ![]() |
| Not Ranked : 0 score Fuck that feed line looks great. So did you simply cut the oem one, and use a compression fitting to the an adapter? That doesn't sound too bad. So line is stainless too afaik, so i wonder if one could even just weld an adapter on some how... hmmm...
![]() | | #117 | ![]() |
Groans: 78
| Not Ranked : 0 score Fuck yeah Gerry, everything looks great especially that inlet. Is that fitting on your oil feed welded? You're a crazy fucker for mounting your turbo and everything up on the head, taking it all out again, and you're going to put it back in. While ive done it 10 times now unfortunately each time I HAD to, I respect you for doing it voluntarily hahah. I just may be able to beat you man, just maybe.
| The Following User Says Thank You to madvillain For This Useful Post: | djuosnteisn (07-29-2010) |
![]() | | #118 | ![]() |
Groans: 113
Scott Thank you so much for helping us all out man. Ill be contacting you tomorrow! | ||
| The Following 6 Users Say Thank You to NJSPEED3 For This Useful Post: | djuosnteisn (07-30-2010), doubleflusher (07-30-2010), FreeFlyFreak (08-02-2010), madvillain (07-29-2010), MS3-a(sore)ASS-rex (08-02-2010), SilverDemon (07-30-2010) |
![]() | | #119 | ![]() |
Groans: 78
| Not Ranked : 0 score =0 you got some of scotts seals?
| The Following 4 Users Say Thank You to madvillain For This Useful Post: | djuosnteisn (07-30-2010), doubleflusher (07-30-2010), NJSPEED3 (07-30-2010), SilverDemon (07-30-2010) |
![]() | | #120 | ![]() |
| Not Ranked : 0 score Hahahahahahaha, i got some scott seals too
| The Following 3 Users Say Thank You to djuosnteisn For This Useful Post: |
| Stock Block BT build threads | xcoldricex | MazdaSpeed 3/6 - Big Turbo Builds | 50 | 07-13-2010 08:37 AM |
| How many ppl running BT's with stock block? | SpeedSixxx | MazdaSpeed 3/6 - Turbo Induction | 20 | 11-08-2009 12:30 PM |
| engine build with stock compression | Jessed87 | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 06-12-2009 11:55 PM |
| Safe Horsepower on stock engine build? | cl45music | MazdaSpeed 3 - Engine, Transmission & Driveline | 36 | 02-17-2009 07:27 AM |
| So...Turbo/motor limits on stock block & internals? | 94jedi | MazdaSpeed 3/6 - Turbo Induction | 26 | 05-31-2008 08:01 AM |
