Like Tree3Likes
  • 1 Post By XLT_66
  • 1 Post By Evan@COBB
  • 1 Post By XLT_66
 Old 05-23-2012, 10:04 AM   #1
XLT_66's Avatar
Posts: 850   (View Stats)
XLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the world
Default Oil Feed Line: ATP Banjo Setup....Restrictor?
Okay, so I have an oil leak between the turbo and this part from ATP:
-4 size Oil inlet fitting for GT28/30/35R with built-in restrictor : atpturbo.com
I've tried two different fittings, both of them brand new. The turbo is brand new as well. For whatever reason, the inverted flare is not sealing well. It must be something on the turbo side of the fitting that is nicked or whatever. Once the oil gets warm and I build any sort of pressure over 60 psi...it starts a slow ooze from the oil feed port on the turbo, pushing past the threads.
Now, from what I understand is that while Garret BB turbos have some sort of restrictor built into the CHRA these days, that if you make over 80-85 psi of oil pressure then you'll want to run the little restrictor fitting I linked to as well.
Well, obviously that setup is not working for me. So, I'm looking to swap to this:
22" Low profile -3 LINE Kit for GT25R through GT35R turbos : atpturbo.com
and seal it all off with crush washers instead of the flare.
Only problem I see is that this banjo bolt offers a much larger orifice than that little restrictor pill offered. It seems like I still need a restrictor, right?
I've talked to a couple of people who claim that with the ATP Drop in kits, that they send it with that banjo setup only...and people don't run any sort of restrictor on the oil feed. Is this correct?
The only other option I'm toying with is throwing this in there between the block and the turbo to act as my restricor (and filter, to boot):
Forced Performance Turbochargers: FP -4 AN Inline Filter
Any opinions on using the banjo setup on these cars with no restrictor? I'm supplying oil from the factory location where I cut and welded a -4 fitting to the hardline/banjo coming from the block and ran a SS -4 line to the turbo.
The banjo setup would make install MUCH easier with how my manifold is routed so, really, I'd love to go that route.
Discuss
2009 CWP MS3 Sport
Built Motor and Twinscroll T3 35r - 415WHP/400WTQ - 93 Pump Gas, No Meth - Mustang Dyno
Custom Tubular Manifold - HTP 3.5" Intake - 3" V-Band TBE - Custom COBB FMIC - COBB EBCS - COBB 44mm WG - KW V2 Coilovers
SOLD!
2008 Toyota Tacoma TRD Sport 4x4
XLT_66 is offline   Reply With Quote
The Following User Says Thank You to XLT_66 For This Useful Post:
rfinkle2 (05-23-2012)
 Old 05-23-2012, 11:15 AM   #2
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
If you're using the stock oil line, ATP has said a restrictor is unnecessary.
As for oil leak, you using teflon tape? I always had to use teflon tape on that joint (flare fitting to restrictor) and the flare was usually a 90*.
07 MS3
The original Genpoo Hater
 Old 05-23-2012, 01:45 PM   #3
Master of Hard Parts
Evan@COBB's Avatar
Posts: 240   (View Stats)
Evan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the worldEvan@COBB is the leader of the world
Groaned at 8 Times in 2 Posts
FWIW, ATP seems to think that if you are using the stock oil feed, then a banjo bolt setup will not cause any problems.
So, I'll end up with is this:
-Stock oil feed line coming from block with a -4 male welded to it
- -4 SS hose with -4 straight females on either end, 20" length
- FP Inline Restrictor/Filter (not a must have...but I already ordered it)
- ATP Low Profile -4 Banjo
Not sure when I'll get all the stuff. In the mean time, I'm leaking/burning oil.
320 miles on the new motor/turbo. Running strong. Ready to crank it up.
Hard Parts Engineer - Mazda Expert Group
2009 MS3 Sport - Built Motor//Twinscroll 35R//Everything Else - SOLD!
2008 Toyota Tacoma TRD Sport 4x4 - Current Daily Until Next Turbo Car
Evan@COBB is offline   Reply With Quote
The Following User Says Thank You to Evan@COBB For This Useful Post:
rfinkle2 (06-01-2012)
 Old 06-01-2012, 01:24 PM   #4
XLT_66's Avatar
I installed the FP inline restrictor/filter as well as a new -4 line and low profile -4 banjo bolt. Seems to be working great.
Current hitting about 20 PSI on the tune. Trying to get everything dialed in nice before turning it up.
2009 CWP MS3 Sport
SOLD!
 Old 06-01-2012, 01:34 PM   #5
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
Be careful with that filter.
If it does it's job, it may seriously restrict oil flow to the turbo.
Make sure to check it often.
Beanfab / Tuned by Nishan
The Following User Says Thank You to doubleflusher For This Useful Post:
 Old 06-01-2012, 01:47 PM   #6
XLT_66's Avatar
Yeah. I'll check it pretty often for awhile and then, after awhile, I'll just check it when I do oil changes.
If it appears that it doesn't seem to catch much anyway then I'll full the filter out and just use it as a restrictor.
2009 CWP MS3 Sport
SOLD!
 Old 06-01-2012, 06:09 PM   #7
mason's Avatar
Posts: 946   (View Stats)
i use a banjo on the oil feed, no restictor. works great.
 Old 06-01-2012, 07:52 PM   #8
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
i went 20k on my ATP GT3076 with stock banjo and no restrictor and never had a problem. i have he same setup on mt GTX35R now too.
im personally not a fan of inline filters for the reasons drew stated. its much easier to ruin a CHRA from oil starvation then from some dirty oil running through it............
whats why the car has an oil filter
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
86AmishMs3 (06-05-2012)
gt3076 oil feed banjo size pearl_ms3 MazdaSpeed 3/6 - Big Turbo Builds 14 01-13-2011 03:09 PM
Bnoon Banjo turbo restrictor bolt tburton101 MazdaSpeed 3/6 - Turbo Induction 24 07-13-2009 10:06 AM
Page generated in 0.30986 seconds with 25 queries
