Like Tree439Likes
 Old 08-23-2012, 03:07 PM   #81
Fail_6's Avatar
Posts: 2,305   (View Stats)
Fail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the worldFail_6 is the leader of the world
Found the solenoid, but there's no instructions online about which wires to splice. I'm not touching it. Not gonna risk fucking this up soooooooooooo close to wrapping up. All ready talked to baystate and they said it'd be 10 mins for them to fab the reducer and dump tube. So, as of right now this is the only thing slowing me down. If anything I'm gonna try to find a shop to wire it.
Another day wasted. Unmotherfuckingbelievable
2006 Black Mica MS6 GT
FreekBuilt Longblock, Manley 9.5:1, Manley H Beams, BW S300SX 6268 1.00 A/R, Dual Tial 38mm MVR EWG, Twinscroll Tubular Top Mount, EGR Delete, Labontes Stage 2 Meth Kit w/ D10, Grimmspeed 3 port EBCS, 3 Bar Map Sensor w/ Matt Jackson Harness, PERM 4" Intake, Cp-E HPFP, CX Racing FMIC, HKS SSQV V3, NGK IX 6510's, Toyota Injector Seals, PERM Catless 3" Turboback w/ dual Magnaflow Magnapaks, PERM Top Mount Valve Cover, PNP Intake Mani, BSD, ACT ZX4-HDG6, Bilstein HD Shocks, H & R Springs, Stoptech Slotted Rotors w/ API Ceramic Pads, JBR Heavy Shift Knob
Stock motor w/ GT2871r:
380 awhp, 375 awtq @ 24 psi (e85 only)
- 13.1 @ 110, 2.1 60 ft
Fail_6 is offline   Reply With Quote
 Old 08-23-2012, 03:07 PM   #82
Fail_6's Avatar
This would be the solenoid correct? @atvfreek
The Following User Says Thank You to Fail_6 For This Useful Post:
atvfreek (08-23-2012)
 Old 08-23-2012, 05:27 PM   #83
Fail_6's Avatar
Frustrating as hell, but I figured I need to do my due diligence and try to figure this out on my own. There are simply no writeups available or video instructions like the evos/stis, so hell I don't mind documenting it now.
@atvfreek I apologize for picking your brain, but I'm 90% sure based on Perrin's info on other writeups/pics the harness below is the one I need to splice. Fits snug with the solenoid on the K04. If this is what I'm looking for, I'd assume I crimp it to the 2 wires coming off the ebcs. Question is which wire crimps to which? Ones blue and white, the other is green.
Also, wtf happens to the 3 left overs down bottom?
The Following 2 Users Say Thank You to Fail_6 For This Useful Post:
802MS3 (08-23-2012), atvfreek (08-23-2012)
 Old 08-23-2012, 05:31 PM   #84
atvfreek's Avatar
Posts: 7,787   (View Stats)
It's just a two pin connector so it doesn't matter which wire goes to what.
Those other connectors look like they may be the o2 sensor connectors. There should be 3 of those.
Freekn tappin
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
dougefresh_ (08-23-2012), Fail_6 (08-23-2012)
 Old 08-23-2012, 05:42 PM   #85
Fail_6's Avatar
Ok, that sounds good. I can definitely patch that together. And I'll be following the ewg setup per Perrin.
And yea there's 3 just dangling. I mean there's nothing for them to connect to anymore, so are they just hanging since there's nothing to plug them into or what should I do with these? Actually I think I recall you saying plug them into each other or something
***Edit: Yea I forgot the dp is still out.....that's what those connect to......
0_o
 Old 08-23-2012, 07:50 PM   #86
Block8head's Avatar
Posts: 4,345   (View Stats)
Groans: 206
Been freaking busy as hell,sorry man..
Since all your questions already been answered, i just want you to know that the spring on the WG is good for up to 17 psi.
If you want more boost you will need to order a different spring..
O4 350z "Money pit"
06 MS6 "Gone"
BOSTON STRONG
The Following User Says Thank You to Block8head For This Useful Post:
Fail_6 (08-24-2012)
 Old 08-23-2012, 10:35 PM   #87
dexter_5000's Avatar
Posts: 407   (View Stats)
dexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the worlddexter_5000 is the leader of the world
So did you make it over to the shop for the work?
dexter_5000 is offline   Reply With Quote
The Following 2 Users Say Thank You to dexter_5000 For This Useful Post:
darkcherry (08-24-2012), Fail_6 (08-24-2012)
 Old 08-24-2012, 08:13 PM   #88
Ihatefwd's Avatar
Posts: 986   (View Stats)
Ihatefwd is the leader of the worldIhatefwd is the leader of the worldIhatefwd is the leader of the worldIhatefwd is the leader of the worldIhatefwd is the leader of the worldIhatefwd is the leader of the worldIhatefwd is the leader of the worldIhatefwd is the leader of the worldIhatefwd is the leader of the worldIhatefwd is the leader of the worldIhatefwd is the leader of the world
Did I hear a big turbo speed6 running today?!?!?!?
2008 Phantom Black Evo X GSR Sight Sound Spoiler with Navigation
2011 kona Blue Mustang GT 5.0 Premuim 6spd manual - traded with 2nd child on the way. Will miss this car!
2009 MGM Speed3 GT - traded
Ihatefwd is offline   Reply With Quote
The Following 2 Users Say Thank You to Ihatefwd For This Useful Post:
 Old 08-24-2012, 09:34 PM   #89
Fail_6's Avatar
@Ihatefwd Possibly
@Block8head Sounds good, I won't be running any big boost though until I install my mounts and what not. Plus it's about to get cold. Gonna be switching to the winter map soon anyways. Haven't forgot about what we discussed either. I'll keep you updated
@dexter_5000 Fabrication indeed was done by baystate. @Jh8909 Because I do alot of business with them, they actually didn't charge me for the work. I'll ask them tomorrow what they would charge for the one you asked about. Overall came out great and works like it should. I think I have a leak though since I had to take it apart and didn't tighten it down all the way fml....
 Old 08-24-2012, 10:01 PM   #90
Fail_6's Avatar
Default Installing the Perrin 3 port EBCS
Granted this only applies if you have an EWG, but it's still kind of crazy there was no real documentation available on wiring it, especially for a Mazdaspeed 6 or Mazdaspeed 3 (I'm spelling so it'll come up with a google search), so here goes.
First, you want to have this guide handy: http://www.perrinperformance.com/sha.../asmint720.pdf
That's the link for the instruction pdf. Very helpful in walking you through what ports to use and how, depending on if it's going to be for IWG or EWG.
Regardless, you want to locate your egr. It's the black piece with a grey 6 pin connector attached, but there should actually be another black 2 pin connector wrapped together with it. Look a few posts back if you're unsure of what it looks like, or for a pic of what it connects to. I've attached 2 pics though, one of where it sits in the engine, and a seperate close up.
You'll be reusing the 6 pin connector, but you'll be splicing into the 2 pin. In my case I cut it, and then crimped them as pictured. I also saved the stock connector in case I need to stock out for whatever reason. Doesn't matter which line connects to which; it just needs a source. You'll want to remove the rubber sheathe over it, or you'll cut the factory connect too short, like I did
Tidy up your work, mount it and you're done.
People may all ready know how to do this, and this very well may be written somewhere all ready, but for those of us taking on their first build, this sort of shit comes in handy.
 Old 08-24-2012, 10:18 PM   #91
Jh8909's Avatar
Posts: 1,457   (View Stats)
Groans: 130
Groaned at 8 Times in 7 Posts
Originally Posted by PartiAudiMazdarati View Post
@Ihatefwd Possibly
yeah if you could just have them make an exact copy of what you have that would work. that looks great by the way.
 Old 08-24-2012, 11:21 PM   #92
Fail_6's Avatar
All right folks, the moment we've been waiting for. First start up
Clearly from the pic, yes, the other line was also loose...I smell of e85 and oil..
And a quick drive
Still some work to do. Like I mentioned, I have a leak somewhere, which I'll be tracking down. That'll straighten out the fuel trim issue. Also having the dump tube fabbed tomorrow, then need to give her another once over. Gasket for the dp is also trash, so we'll need a new one, and a bolt for the v band clamp. Also need to fab a real mount for the ebcs. Honestly, right now I'm just going for a reliable setup, so I probably won't be pushing any more than the 17 psi the spring will allow. Pretty satisfied overall with the quality of the build though.
Many thanks to @darkcherry for helping a bro out when both his rides are down, and helping to install shit. Same goes for @dexter_5000 driving an hr to come help and @Ihatefwd for the frequent whiplash just a phone call away. I also appreciate the jack/jack stands @jpfrisch87 and the tent @BigJimMs3. And of course my boy @atvfreek for letting me pick his brain. Small shit, but it means a lot to me.
Very good build and I look forward to getting her dialed in and helping other peeps cross into the unicorn realm hahahaha.....I'll have updates on the setup soon.
franz likes this.
The Following 10 Users Say Thank You to Fail_6 For This Useful Post:
atvfreek (08-25-2012), BigJimMs3 (08-25-2012), Block8head (08-25-2012), darkcherry (08-24-2012), dexter_5000 (08-25-2012), Eighty8 (08-25-2012), Ihatefwd (08-26-2012), jpfrisch87 (08-25-2012), snailD (08-25-2012), xI Leveler Ix (08-26-2012)
 Old 08-25-2012, 05:21 AM   #93
atvfreek's Avatar
Glad to see her up and running D. With that ewg spring of 12psi, you can typically run 2 times spring pressure. Soooooo we will be able to run 21psi no problem and let the fun begin. Just get that dump tube fabbed up, give her a good once over and we can dial her in
Freekn tappin
Fail_6 likes this.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 6 Users Say Thank You to atvfreek For This Useful Post:
BigJimMs3 (08-26-2012), Block8head (08-25-2012), darkcherry (08-25-2012), dexter_5000 (08-25-2012), dougefresh_ (08-26-2012), Ihatefwd (08-26-2012)
 Old 08-25-2012, 04:39 PM   #94
Fail_6's Avatar
Went up to baystate earlier. Dave was pretty busy, so didn't have a chance to fab up the dump pipe. Said we're going to be looking at Mon or Tues more than likely. That sucks
SOOOOO, mr fabricator here tried to heat wrap the temp dump tube and protect from heat. The picture shows how that went......
Big issue is the leak I have. Afrs are crazy at idle, literally ranging from stoich 14.7 up to 20 .....short terms are stuck at +25. Then I drive and we're 14.7, dip the throttle and it's 12-13's and wot is the 11.4 target. I've checked the intake, inlet, replaced the worm gear for the fmic.....I'm fucking baffled here. Suggestions are welcome
 Old 08-25-2012, 05:10 PM   #95
do a boost leak test with a compressor then.
The Following User Says Thank You to dexter_5000 For This Useful Post:
 Old 08-25-2012, 07:16 PM   #96
Fail_6's Avatar
I actually think I know what the issue is now.
Seems the car idles and runs stoich when first started and driving normally. As the heat increases, the a/f slowly runs leaner and leaner. Took a drive with Brian (with the v6 6) and gave him a pull or 2. Car was 14.7 and climbed to 16 before I left. Came back and it was 19-20 a/f, with stfts +25. Think heat is the enemy here.
Time to heat wrap some shit and see if that changes things
 Old 08-25-2012, 07:32 PM   #97
StayBroke's Avatar
Posts: 2,075   (View Stats)
Is that dump tube messed up anything yet the way it sits???
I would not go wot with that there, i would be afraid of getting something extremely hot in the engine bay.
The Following User Says Thank You to StayBroke For This Useful Post:
 Old 08-25-2012, 08:17 PM   #98
snailD's Avatar
Posts: 3,039   (View Stats)
holy shit darnell you have the best commentary! i hope you figure everything out tho and glad the car is running! (watching second vid now)
Fail_6 likes this.
The Following User Says Thank You to snailD For This Useful Post:
BigJimMs3 (08-27-2012)
 Old 08-25-2012, 08:31 PM   #99
dead-zone's Avatar
Posts: 442   (View Stats)
dead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the world
Groaned at 53 Times in 17 Posts
@PartiAudiMazdarati post some logs. Heat should not play such a big role. I are getting some big diff there.
dead-zone is offline   Reply With Quote
 Old 08-25-2012, 10:16 PM   #100
Fail_6's Avatar
Yea I've been relaxing a lot by default lol.....really don't wanna punch it until I figure out what this lean at idle issue is. Doesn't happen during the normal drive, and luckily the wastegate barely opens putting around town
I took some logs earlier, so I'll prolly be able to post tomorrow if I get a chance
 Old 08-26-2012, 10:14 PM   #101
Fail_6's Avatar
Definitely thinking the heat is causing the afr irregularity, mainly since it's the only lead I have lol.....fortunately found the gasket today after doing a little searching earlier. I'm holding off on ordering since it looks fairly generic, and I think baystate could possibly have one on hand.
Took some logs tonight, and some yesterday. As the car warms, it slowly creeps from 14.7 to around 15-16, then take a drive and we're in the 19+ range when I come to a stop. Long terms are starting to look fucked now as well. One's a cruise log, then another wot, and then cruising to a stop to show the afr changes. If anyone notices anything that I might've missed feel free to pull my coat haha....tune is targeting about 16 psi with 9 or so timing, so veeeeeeery conservative haha
 Old 08-26-2012, 10:19 PM   #102
darkcherry's Avatar
Posts: 930   (View Stats)
darkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the worlddarkcherry is the leader of the world
Found out my car is doing the exact same thing as yours.
mods:
Do wmi 50/50, freek tune 306hp/350tq.
blitz bov, cpe hpfp, tmic, excel nano sri, tip, blue duro rmm, 3" ss catted dp, 3" ss cs cat back exhaust, Cobb AP, sure short cut, counter weight, twm stage 1&2, ms cf shift knob, msd dh, autoexe rear brace, whiteline rsb, tt rear diff mount, awr pmm , winter=stock wheels w/winter tires / summer=18x8 adr hyp black wheels w/bfg force kdw, eibach sportline springs. Soon to come: bt, slotted rotors, cf fi hood
darkcherry is offline   Reply With Quote
 Old 08-26-2012, 10:23 PM   #103
Fail_6's Avatar
Whaaaaaaaaaaaat? GTFO lol.....the weather? Fuck's going on here. Ugh.....forced induction wtf
 Old 08-26-2012, 10:28 PM   #104
snailD's Avatar
your afrs look to be pretty spot on, did I miss something? lol. your fuel trims vary in every log, leading me to believe there is some inconsistency/leak in your intake/ic. i would think a good thing to log would be coolant temps considering you think there is some kinda heat issue.
i think what you are noticing, when you get the 19+ lean afr is when letting off the throttle, the ecu will go to 29.3 afr when coasting in gear at speed, and letting off the gas a bit will get it to start doing this. with your ltft being +20 under 5.7g/s you are prob just seeing this go lean earlier than you would with a tigher maf cal.
dougefresh_ (08-29-2012)
 Old 08-26-2012, 10:31 PM   #105
darkcherry's Avatar
Yea, that p2187 code was lean at idle. Looking at my dh the maf is at 3g/s and my stft are around 18-25 and ltft is around iirc 22-25 but only after sitting at idle. Once i drive they both go down to about 0. Was thinking vacuum leak. At work for the overnight and will look at it tomorrow when i get out. Also found out the meth tank is leaking from the suction/feed line on the bottom of tank. Will take out in am and seal it with some windshield adhesive. Hopefully i dont have to take it back apart again after the adhesive. I may as well replace it at that point. Lol hows the ride doing? Besides your fuel trims. Lol
mods:
The Following User Says Thank You to darkcherry For This Useful Post:
Fail_6 (08-27-2012)
 Old 08-26-2012, 11:01 PM   #106
Ihatefwd's Avatar
Damn D, get this shit straight bro. my car shows Afr 17 range when I close throttle but I think D means when he stops after a drive and just idles he is around 19 Afr which is not right.
The Following 3 Users Say Thank You to Ihatefwd For This Useful Post:
BigJimMs3 (08-27-2012), dougefresh_ (08-29-2012), Fail_6 (08-27-2012)
 Old 08-26-2012, 11:50 PM   #107
darkcherry's Avatar
Just googled online for my dtc and was reading rhoadblock on 6crew encountered the same code i have and he found out he installed his air filter on too far up the pipe on his setup, now that i think of it i had moved air filter further up on pipe when i was going to try and install meth tank in front of air filter like @Lakespeed6 but he has a shorter sri. I am going to put the filter back in its original spot and give that a try. Btw is it possible that your maf cal is out of whack? Or maybe your airfilter is on too far? It maybe just a little thing like so. Its worth a shot and check it out.
mods:
The Following 3 Users Say Thank You to darkcherry For This Useful Post:
dexter_5000 (08-27-2012), dougefresh_ (08-29-2012), Fail_6 (08-27-2012)
 Old 08-27-2012, 05:31 AM   #108
snailD's Avatar
true. i didnt see anything in the logs tho where this happened, it was always at speed when he got the lean dip, otherwise i saw 14.7-14.8
Fail_6 (08-27-2012)
 Old 08-27-2012, 05:42 AM   #109
atvfreek's Avatar
D, fix that exhaust leak and then we will recheck it. You are chasing your tail at this point, especially KNOWING you have a leak
Your maf cal was spot on as well, until you did your WMI setup. Go over everything and check for leaks. Also make sure your nozzle is completely secured in the coldpipe
Hit it on the head. He is using the same maf housing as when he had the k04. So just going from one turbo to the next isn't going to change the maf cal by 20% in the first breakpoint, but have the others spot on. Typically if you have high fuel trims only at idle, it is due to a vacuum/intake leak. Then once you come off idle, trims get better, due to less engine vacuum. Knowing Darnell has an exhaust leak, he has to fix that first. Then we can re-evaluate the trims. If they are still off by 20% then we will need to look elsewhere.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 5 Users Say Thank You to atvfreek For This Useful Post:
darkcherry (08-27-2012), dexter_5000 (08-27-2012), dougefresh_ (08-29-2012), Fail_6 (08-27-2012), snailD (08-28-2012)
 Old 08-29-2012, 10:13 AM   #110
Fail_6's Avatar
Got around to ordering the new gasket. Baystate didn't have one. Also had a more permanent dump tube made. This will eventually be dumped back into the dp though when I have time to have it fabbed. Also bought some maf cleaner, so will be cleaning the maf sensor and see if it helps any. Problem is the damn screws in the housing are stripped.......and they're like a centimeter long fml.....hoping I can order some more or pick up some replacements from the hardware store. Updates to come
 Old 08-29-2012, 10:27 AM   #111
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Mine were off that bad after at idle, but due to a crushed TB gasket, but I've since fixed that. Damn leaks. I hope yours gets sorted when the exhaust is fixed. I know I still have a vac leak somewhere (al la trims and was going lean at idle), but I since my compressor doesn't work and can't do a proper leak check, I said fuck it, and threw fuel at idle and now it's 'fine' afr 14.7 at idle, lol. I'm not suggesting doing this (read= don't do this), but for me it's fine, as my wot afrs are reasonable, and I just need to pass inspection. I don't have any days to burn in the driveway.
Best of luck, and I hope it works out for you soon! Just a word of advice... once you get it all straightened out and start having more fun.... don't get too greedy
I have some extras, but damn if I remember the size. They are also different... they're regular phillips heads and about 1/4" long, maybe a bit longer. I'm pretty sure they are the same thread and pitch as stock. I stripped one (bc not hex and bc maf off too much, lol), so I picked up a few spares to have just in case. You're welcome to some, or just bring one of yours into an ACE hardware or something. HD often doesn't have small metric bolts, especially around here.
Fail_6 likes this.
Last edited by dougefresh_; 08-29-2012 at 10:27 AM. Reason: MSF Database - Automerged Doublepost
 Old 09-04-2012, 09:27 AM   #112
Fail_6's Avatar
Ok, as promised @dougefresh_ (I was tired last night, so no energy to upload)
Disregard the fucked up ltft's lol....lean at idle hasn't been fixed due to location unknown gasket lol...
Other than that, this looks solid as hell. Don't ask me where the hell the addln 1-2 psi came from, possibly just because it was a semi cool night. It's way more potent than the k04 though, evidenced by 329 g/s at 17 psi vs the k04's 285 g/s or so at 20 psi. Afr holds great, bats are slightly higher but new fmic will fix that. Fuel pump is loving life, and load never broke 2.3. Wastegate duty is wonderful as well, she's hardly working. Definitely feels quicker than the time suggest, but we still haz tuning to do
dougefresh_ and dexter_5000 like this.
dougefresh_ (09-05-2012)
 Old 09-04-2012, 10:03 AM   #113
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Which FMIC are you going with D?
Playing catch-up now with your thread as I've been quite busy.
Get meth
 Old 09-04-2012, 11:02 AM   #114
Fail_6's Avatar
cxracing.....I know, its struggling lol. It worked well enough on the k04, but its not too great with the 28. I see garrett and ets have cores that don't require destroying the crash bar, but meth doesn't sound too bad either. Exhaust leak damn sure ain't helping as well
 Old 09-04-2012, 11:09 AM   #115
greg08's Avatar
Posts: 480   (View Stats)
Def get the one in the picture. The other one should hold good with just one upgrade
 Old 09-04-2012, 11:20 AM   #116
Fail_6's Avatar
Hell I'm just trying to figure what problem to fix first. Once the leak and lean at idle are dealt with, I'll have to start doing my homework on meth setups or a better fmic........fml
 Old 09-05-2012, 05:55 AM   #117
jrlms6's Avatar
Posts: 1,436   (View Stats)
jrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the worldjrlms6 is the leader of the world
It's never ending haha. But glad to see everything's on it's way.
BTW, @PartiAudiMazdarati, did you end up dynoing before the 2871 to the see the difference?
2006 Mazdaspeed6 GT - SOLD
Titanium Gray Metallic
SURE Aeros | SURE Sidewinder
Forge V1 | CPE TMIC
Magnaflow CBE | Corksport DP | TXS RP
COBB AP | Autotech Internals
JBR SSP | JBR Shift Weight | JBR Knob
Denso ITV22
2012 MS3 w/Tech - Hit and traded
Velocity Red Mica
COBB SRI | COBB TIP
2006 Mazdaspeed6 GT - Totaled
Liquid Platinum Metallic
CS Stage 2 | COBB AP | CPE HPFP
2006 Mazdaspeed6 GT
Black Mica
CS Stage 2 | CS BPV | CS TBE
COBB AP | CPE HPFP | CPE TMIC
DM RMM
jrlms6 is offline   Reply With Quote
 Old 09-05-2012, 11:04 AM   #118
Fail_6's Avatar
@jrlms6 Nopers, I suck. Alex was super busy, and just didn't have the time to fit me in. My vds all ranged btwn 280-305 awhp, depending on dd or track map. Sounds about right based on 60-100 times, but would've still been nice to have a legit dyno
 Old 09-05-2012, 11:40 AM   #119
Looking good. It's crazy seeing how much more air a BT can flow at the same psi as a stocker. Looks like you're running a bit rich up top w/ no kr. You may consider pulling a little fuel there as that can most definitely cause knock. If you have a leak, and fix it, keep in mind you may go leaner when the leak is fixed. My wot afrs move around a bit as well despite a nice cal due to a minor leak that I dont have the time/compressor to fix :/ Just take your time and fix what needs fixing and you should be solid. You're in good hands with All Freek
Fail_6 likes this.
 Old 09-05-2012, 12:03 PM   #120
atvfreek's Avatar
Right now his tune targets 11.4 and is on super conservative everything. That is just a quick little map I made with a couple psi over spring pressure. Once he fixes his exhaust leak, I can tune with confidence. Haha. I certainly don't want to be tuning around a known issue, then he fixes it, and fuck we gotta start over, or worse, something breaks.
Speaking of whacky idle afrs and +20 ltft at idle. Here is your fix @PartiAudiMazdarati
P2187
Overnight that gasket man, and lets get this bitch rollin
dougefresh_ likes this.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 3 Users Say Thank You to atvfreek For This Useful Post:
BigJimMs3 (09-05-2012), darkcherry (09-05-2012), dougefresh_ (09-05-2012)
JBR Goodness!! EdgeAutosport.com EdgeAutosport.com 20 11-06-2012 10:51 AM
I Haz Teh Goodness Stealth01 MazdaSpeed 6 - Engine, Transmission & Driveline 33 09-18-2012 03:48 PM
More purple goodness. lvmazdaspeed3 MazdaSpeed 3/6 - Wheels & Tires 8 10-16-2009 02:31 PM
Thank goodness for cruise night Haltech Automotive News 0 05-10-2009 04:10 PM
Page generated in 0.65738 seconds with 34 queries
