 Old 07-19-2010, 10:43 PM   #1
cageyvet's Avatar
Posts: 715   (View Stats)
Default passenger motor mount issue?
The lone issue that I have to fucking work out with the car is whether my passenger motor mount is bad or if I need to redo my downpipe. Initially, my setup was not doing this but over time my downpipe is rubbing towards the passenger side of the car. Depending on how much load on the car is applied in 1st-3rd effects how promiment it rubs. I'm assuming it has to be the passenger mount b/c I've had the car up on a lift and there's no play in the exhaust v-band connection to the turbo and flange to the CBE. In addition, this has been an issue that has just developed. However, I have not seen any residue leaking coming from the mount.
 Old 07-20-2010, 06:46 PM   #2
turd burglar's Avatar
Posts: 1,895   (View Stats)
Groans: 39
dont remember who it was cagey but some guy on here did a how to on reinforcin your pass motor mount. if its not blown up it looked pretty easy. it was a 1/4" thick L shaped aluminum piece wedged inbetween the mount. here ya go Stiffen your Passenger Motor Mount - DIY
and is your tranny okay then i assume?
NO! No way am I havin a dick made outta hamburger!
stocking out, buy my big turbo shit here, http://www.mazdaspeedforum.org/forum/forum/f229/bye-bye-big-turbo-dreams-82241/ more to come as stock shit arrives
 Old 07-24-2010, 03:23 PM   #3
cageyvet's Avatar
problem solved ordered a set of SU mounts!!!
Stiffen your Passenger Motor Mount - DIY enganear MazdaSpeed 3 - How-To's 90 09-14-2015 01:49 PM
PMM failure + AWR passenger motor mount install jamesthebikeguy MazdaSpeed 3 - Engine, Transmission & Driveline 21 08-11-2014 12:02 AM
problem with darkstar top passenger motor mount allmotor95pgt MazdaSpeed 3 - Engine, Transmission & Driveline 16 07-23-2009 03:46 PM
Page generated in 0.23172 seconds with 21 queries
