![]() Join Date: May 2010 Location: Florida is home
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 1
__________________ God invented turbo lag to give V8's a chance. |
![]() Join Date: Aug 2009 Location: Albany, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 867
Groans: 39
| Not Ranked : 0 score alot
__________________ NO! No way am I havin a dick made outta hamburger! stocking out, buy my big turbo shit here, http://www.mazdaspeedforum.org/forum/forum/f229/bye-bye-big-turbo-dreams-82241/ more to come as stock shit arrives |
![]() Join Date: Feb 2010 Location: Hamilton, NJ
Rep Power: 168 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32
| Not Ranked : 0 score What mods do you have now? Wouldn't exactly call 400whp reliable |
| The Following User Says NO Thank You to mazdaspeed joel For This Un-useful Post: |
(Thread Starter) | Not Ranked : 0 score Right now I have a cp-e intake, turbo inlet, race pipe, hks exhaust, 1 step colder plugs and a cobb tune. Sitting at 294whp to the wheels riight now. I haven't done an intercooler or dp because I am still deceiding if I want a bigger turbo. If I do get a bigger turbo do I need internals with it? Would 350whp be a better number for a reliable car? Just trying to get realistic options here.
![]() Join Date: Sep 2009 Location: NE PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,832
Groans: 109
| Not Ranked : 0 score why would you want 400hp to the front wheels? to rear wheels that's already a good amount...
__________________ Mk7 GTI |
| The Following User Says NO Thank You to HLR Element For This Un-useful Post: |
![]() Join Date: Dec 2009 Location: Fontucky, California
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,096
Groans: 1,364
| Not Ranked : 0 score Dude...Because he wants it, don't answer a question with a question man, if cagey, cruzito, conso and all the other big turbo guys did it, it was because they wanted to, and they're damn happy with the results. |
| The Following 5 Users Say Thank You to felt For This Useful Post: | MarkyMark (06-09-2010), nighthawk358 (06-08-2010), NJSPEED3 (06-13-2010), TheNewGuy (06-15-2010), turd burglar (06-08-2010) |
Groans: 111
| Not Ranked : 0 score You can get to 400WHP or more but you're going to need these (at least): - forged rods and pistons; - a larger turbo, something from the same class as a gt35 to be safe (gt3071 is going to get you near 350-370whp on this engine AFAIK); - definitely a FMIC; - possibly a more efficient radiator; - a complete set of engine mounts; - strong arms, because you're going to fight your wheel even in 5th or 6th (go bodybuilding TODAY ! );- possibly another car as a DD because this is going to be a bitch to drive in heavy traffic (it will be noisy because of the exhaust and stiffer engine mounts, it will rattle on a wide RPM range, it will tear your brains apart when the air conditioning kicks in, it will be lazy at low rpm, and so on). You can avoid rebuilding the engine with forged parts by aiming lower, like 330-350whp and limiting the boost/load/torque below 3500rpm to values closer to stock (say, 16-17PSI/300lbft to be safe). However, you're still going to need to upgrade your turbo (gt28 or gt30 for 350whp) and get a FMIC. If you want to keep things simple you can run with a TMIC if you aim even lower, 300-330whp, and use a reworked k04 or a gt28. Probably the intake and exhaust you have now will do for both situations, but at least for the first two situations you will need a downpipe. Also, don't forget that this is still a FWD car. Even if you'll get a good suspension and set it right, tuning a FWD to deliver more than 350 pounds of torque to the wheels will destroy the balance of the car, may limit its cornering capabilities because of the violent traction and sharp/violent throttle response, and you will be able to use that power only at high speeds (you will spin the wheel in 3rd and even 4th and frankly I don't find fun to have a scary car - only if it's scary for the others ).
| The Following User Says NO Thank You to mituc For This Un-useful Post: |
Groans: 1,364
I kid. I kid. | |
![]() Join Date: Mar 2010 Location: Washington
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 778
Theres few people running 3076 turbos making 350+ whp on stock internals doing fine..I havnt seen anyone running 400+whp on stock internals....Its really hard to say with this car...I would suggest upgrading the internals to be on the safe side and you have money to spend. Rods-pistons-bearings-head gasket-apr headbolts-your looking around 17-1800 bucks....are you gonna do the labor yourself? or have a shop do it? so you have to factor that in..which can be couple grand easily...then theres the turbo selection. 3071-3076 atp turbos are bolt on units that can give you 350 whp+...thier fairly expensive 15-1800 dollar range depending where you buy it. Alot of people like T3/4 turbos cause theres alot of options with them and you have the ability to run bigger exhaust housings that the atp gt series. The word on the "streets" is using a .82 a/r or at the very least .63 a/r for this car...then its time for a reliable turbo manifold.....alot of people use ProtegeGarage or DNP...I myself would look at Xtremeboost or Pt-performance...possibly SteedSpeed once legit numbers come out..depending on which one you buy you could spend 450-900 bucks for turbo mani. Just depends on how far you wanna go..how much money you wanna spend..and how much power you want..and how simple you want it. Im no expert..shit when it comes to big turbo, theres some guys in here you really wanna pay attention too..sometimes I wish they would respond to my turbo upgrade threads more *cough*...but anyways...thats atleast a baseline from my tiny bit of knowledge. Good luck and hope you get something figured out.
__________________ 2009 MS3 COBB AP COBB INTAKE COBB/TURBOXS TBE DNP TURBO MANIFOLD CXRACING FMIC TURBOSMART BPV JBARONE RMM TURBOSMART BPV JBARONE SHIFTERPLATE COBB RSB KONIG WHEELS/HANKOOK TIRES TIM BAILEY PROTUNE 291WHP/310WTQ *AWD MUSTANG DYNO* | |
| Banned ![]() Join Date: Sep 2009 Location: La Crosse, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 309
| Not Ranked : 0 score 40 psi on the stock turbo i think is what he meant Last edited by holeinmypocket; 06-09-2010 at 03:12 AM. |
[QUOTE=zx2man;545250]294 whp without a downpipe or a aftermarket intercooler..impressive..what kind of dyno? Not sure what dyno it was. I got it tuned at Big Valley Performance in Orlando. The dyno they had was above ground, kinda cool. I think it was a dynojet though.
__________________ God invented turbo lag to give V8's a chance. Last edited by lsorr1975; 06-09-2010 at 06:52 AM. Reason: MSF Database - Automerged Doublepost | |
Groans: 111
But any slight abuse of this car may end up with fried pistons or cracked sparks because of the extreme heat, or with bent/broken rods because of the very high boost with poorly cooler air at mid rpm.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
![]() Join Date: Jan 2010 Location: Pittsburgh
| Not Ranked : 0 score if you are worried about cost effective reliable HP get a sr20det or a dsm for a project car, daily drive the MS3. [/story] |
| The Following 2 Users Say Thank You to integrrac For This Useful Post: | Dre (06-13-2010), madvillain (06-09-2010) |
![]() Join Date: May 2009 Location: Little Neck, NY
Rep Power: 3771 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,108
Groans: 326
another couple grand to build the motor so its "somewhat" reliable, SB instead of AP | |
Groans: 433
| Not Ranked : 0 score IMO 400whp is possible on stock rods because a turbo with that flow capability won't make enough boost down low to risk bending 'em like the stock K04 will.
| The Following 2 Users Say Thank You to Chimmike For This Useful Post: | holeinmypocket (06-09-2010), NJSPEED3 (06-13-2010) |
I think as some of the stock internals BT guys put more miles on thier cars, then that will be the proof. One thing I have noticed is alot of ms3 owners dont put to many miles on thier cars. I hope to see many BT stock internals guy running 330-380 whp saying yep still running strong after 50-75,000 miles.
__________________ 2009 MS3 COBB AP COBB INTAKE COBB/TURBOXS TBE DNP TURBO MANIFOLD CXRACING FMIC TURBOSMART BPV JBARONE RMM TURBOSMART BPV JBARONE SHIFTERPLATE COBB RSB KONIG WHEELS/HANKOOK TIRES TIM BAILEY PROTUNE 291WHP/310WTQ *AWD MUSTANG DYNO* | ||
![]() | | #19 | ![]() |
![]() Join Date: Mar 2010 Location: Tampa/Zephyrhills, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 80
| Not Ranked : 0 score Not sure what dyno it was. I got it tuned at Big Valley Performance in Orlando. The dyno they had was above ground, kinda cool. I think it was a dynojet though.[/QUOTE] so this place protunes on AP? I might need to check it out. I live in the tampa area and cant seem t find any "good" shops that will tune the AP on our cars. |
![]() | | #20 | ![]() |
![]() Join Date: Jan 2009 Location: Bangor PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,426
Groans: 88
| Not Ranked : 0 score Because 383 whp to the front wheels is not enough
__________________ 1995 honda civic. 1.6L slow 2007 Kawasaki ZX10r |
![]() | | #21 | ![]() |
Groans: 78
| The Following 3 Users Say Thank You to madvillain For This Useful Post: |
![]() | | #22 | ![]() |
| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
| Not Ranked : 0 score I briefly read over all the posts and didnt see anyone mention build cost. A decent build with minimal head work will run you around $5k A complete turbo kit will run you another $4k if you get everything new this includes,fmic, 4" inlet, intake big maf,turbo(3071,3076,35r) headers,ewg, dp, oil lines, coolant lines. New clutch and flywheel $800 All motor mounts $450 meth kit $400 tuning solution $1400 SB+full control flashes a must to get 400whp / pro dyno tune ($250+/-) Hpfp $667 (cpe most reliable on the market) cbe $600 You can add alot more but this would be the bare minimum needed for 400whp Grand total Fail is $13317.00 Go see Mark At StreetUnit.com he'll hook you up!! |
| The Following 2 Users Say Thank You to NJSPEED3 For This Useful Post: | madvillain (06-13-2010), spnkr21 (06-13-2010) |
![]() | | #23 | ![]() |
Groans: 39
| Not Ranked : 0 score it'll also cost you a new tranny. sorry cagey!
![]() | | #24 | ![]() |
| The Following User Says Thank You to integrrac For This Useful Post: | madvillain (06-16-2010) |
![]() | | #25 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score as everyone else has already said.......Alot with this car |
![]() | | #26 | ![]() |
| pewpew ![]() ![]() Join Date: Apr 2008 Location: NoVA
Rep Power: 760 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,124
Groaned at 9 Times in 9 Posts
| Not Ranked : 0 score the first thing you need to do is take the whole "reliable" idea out of your head. in the end, we're still driving a 4 banger, and 400whp from 4 cylinders of 1st gen DISI is NOT a reliable thing to do. you obviously have shown that you need a reasonable DD, so quit barkin up the MS3 tree and find a platform that's been properly established and known to reliably make well over 400whp. |
| The Following User Says Thank You to Sacrilicious For This Useful Post: | MPSdriver (06-17-2010) |
![]() | | #27 | ![]() |
Groans: 111
| Not Ranked : 0 score Well, a reliable 400WHP DD is either a car that has about this power stock, or one that can be modded to get there with about the same mods you need to get a MS3 to 290-300WHP (evo X FQ400, Ford Focus RS, Impreza STI, and the list can continue). Anything else will have a more or less disturbing impact on reliability and ride comfort. So if you want 400WHP you need to get your mind straight and figure out exactly what you want: a DD or a rally car. Because the 400WHP MS3 will be a lot closer to a rally car (maintenance and comfort wise).
![]() | | #28 | ![]() |
Groans: 109
| Not Ranked : 0 score lol, your car is insane and i hope to see it soon. But i guess for me i wouldn't want so much, i spin the front wheels enough as it is lol, didn't mean for my other post to sound as a statement of don't do it. If anything, it's just fun modding a car and if you can live with this car making that power with all those mods, do it.
![]() | | #29 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,186
| Not Ranked : 0 score It's sad but true. 400whp on this car and having it as a "reliable daily driver" is not practical unless you have ALOT of cash to throw around. I'm at 330whp and this is my daily driver and I can't see doing much more to it without compromising the quality of the ride. I still have the cat on b/c I dont want to go deaf at stoplights, lol.
__________________ T3 GTX 3076R .82 a/r, ATP wide-mouth turbo inlet, CPE FMIC, 3.25" MAF custom intake, HKS BPV, Steedspeed T3 Exh. mani, CPE High Output Fuel Pump, Streetunit MM, CP-E side mounts, Mazdaspeed CBE, v-band custom DP, TiAL 38mm EWG, DO stg 2 meth 75/25 w/ do7, 3.5 bar MAP, Cobb AP, TWM solid shifter base bushings, BC racing 32 way adj. coilovers, Mazdaspeed camber links, 18" Bronze Enkei wheels |
| Shifter play | amoosenamedhank | MazdaSpeed 6 - Engine, Transmission & Driveline | 11 | 05-11-2010 08:22 AM |
| Too Much Shaft Play? | superskaterxes | Mazdaspeed3/6 General Discussion | 13 | 04-03-2009 08:17 AM |
| K04 shaft end play, how much is OK? | bnoon | MazdaSpeed 3/6 - Turbo Induction | 11 | 03-03-2009 07:49 AM |
| shaft play | b-ron | MazdaSpeed 3/6 - Turbo Induction | 8 | 08-19-2008 08:49 AM |
