 Old 08-18-2015, 02:09 PM   #1
Rich990's Avatar
Posts: 274   (View Stats)
Rich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the world
I applied dei reflect-a-gold to the undersides of the end tanks with some pretty good results.
2007 Velocity Red MS6
Go... BNR S3v2 / COBB APv3 / Snow Performance WMI + DO7 / nator'd DP / test pipe / HTP 3" SRI & TIP / 3 bar MAP / Autotech HPFP / NGK LTR7 / Stratified 3 port / Custom 3" TMIC / EGR delete / CP-E RMM / Turbine Tech FDM / CP-E RDM / Whiteline RSB / H&R springs / Powerbrake GT rotors / Endless MX72 Brakepads
Parts stockpile... Wiseco 88mm's / Manley H beams
Turbo stockpile... Borg Warner S200SX 7670 / GTX3071 / K04
Ex: 2007 Black Mica MS3 - stage 2 mods - 280 whp, 306 tq (321 whp / 358 tq before "stockout", on BNR S2 + meth)
Ex: 2010 Velocity Red MS3 - Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust
5500 ft altitude FTL
MSF in South Africa
Rich990 is offline   Reply With Quote
Full Race Exhaust Manifold/Exhaust Combo mr.speedy3 MazdaSpeed 3 - Engine, Transmission & Driveline 14 01-29-2015 07:56 PM
UR mid pipe upgrade not compatible with CS axle back exhaust pfp22972 2010 MS3 - Engine, Transmission & Driveline 5 08-15-2014 07:09 PM
Manifold or tmic next? Cdone MazdaSpeed 3/6 - Build Diaries 61 06-17-2012 12:31 PM
Page generated in 0.23483 seconds with 22 queries
