 Old 08-10-2015, 11:44 AM   #1
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Default Performance exhaust manifold compatible with a TMIC
I've been searching the forum sections as well as our vendors (approved MSF vendors or just vendors) web sites and even if the exhaust manifold options are multiple I was unable to find any that states specifically that it's compatible with a TMIC.
The reasons why not going FMIC are multiple (mainly regulations) so I'm trying to get the maximum from my setup by going around this problem (I'm spraying meth so the IC problem is fixed pretty much).
So are there any such manifolds TMIC compatible? I know DOC is not, JB is not, CP-e is way too high and I'm 100% sure it is not.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
aromig (08-10-2015)
 Old 08-10-2015, 11:47 AM   #2
RapeBuilt, if you can find one.
Otherwise, considering your location, I would have one custom made.
mituc (08-11-2015)
 Old 08-10-2015, 11:52 AM   #3
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
My Full Race EM is very close to the hot pipe on my ETS TMIC, but it does work.
The Following 4 Users Say Thank You to silvapain For This Useful Post:
brandon3212 (08-11-2015), mituc (08-11-2015), neganox (08-10-2015), WetzMS3 (08-11-2015)
 Old 08-10-2015, 12:41 PM   #4
Full-Race fit with my CP-e TMIC on a gen2.
mituc (08-11-2015), silvapain (08-11-2015), WetzMS3 (08-11-2015)
 Old 08-10-2015, 12:57 PM   #5
dale_gribble's Avatar
Posts: 4,720   (View Stats)
That XS Power header clears a TMIC. Mine does. Just have a machine shop inspect the mounting surfaces and welds before installing on account of some quality issues.
MINI H1 6.0 - CAR LED TAILS
 Old 08-10-2015, 06:41 PM   #6
Poohster's Avatar
Posts: 353   (View Stats)
Hmmmm! I am planning to install a CP-e with a ceramic coat with a CP-e TMIC. I didn't think there was a clearance issue. I'll have to ask CP-e.
06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP
CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount
Poohster is offline   Reply With Quote
The Following User Says Thank You to Poohster For This Useful Post:
aromig (08-10-2015)
 Old 08-11-2015, 05:32 PM   #7
Poohster's Avatar
Was told that CP-e exhaust manifold has no clearance issues with CP-e TMIC.
aromig (08-11-2015)
 Old 08-11-2015, 05:49 PM   #8
brandon3212's Avatar
Posts: 425   (View Stats)
I was interested in this as well, just never made a thread.
If all of the above fit than I would imagine that 99% of aftermarket manifolds would work with a TMIC.
07 Speed 3
 Old 08-11-2015, 09:09 PM   #9
SparkySparks's Avatar
Posts: 1,314   (View Stats)
Fitting and not being too close are two different things. CP-E seems to be the only readily available and quality manifold that had no clearance issues.
On Order:
Coming Soon:
DIY Projects:
aromig (08-11-2015)
 Old 08-12-2015, 06:08 AM   #10
Rich990's Avatar
Posts: 274   (View Stats)
Rich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the world
If you're willing to ship from South Africa, a friend of mine builds these.
Link
R 10,500 is about USD 840.
2007 Velocity Red MS6
Go... BNR S3v2 / COBB APv3 / Snow Performance WMI + DO7 / nator'd DP / test pipe / HTP 3" SRI & TIP / 3 bar MAP / Autotech HPFP / NGK LTR7 / Stratified 3 port / Custom 3" TMIC / EGR delete / CP-E RMM / Turbine Tech FDM / CP-E RDM / Whiteline RSB / H&R springs / Powerbrake GT rotors / Endless MX72 Brakepads
Parts stockpile... Wiseco 88mm's / Manley H beams
Turbo stockpile... Borg Warner S200SX 7670 / GTX3071 / K04
Ex: 2007 Black Mica MS3 - stage 2 mods - 280 whp, 306 tq (321 whp / 358 tq before "stockout", on BNR S2 + meth)
Ex: 2010 Velocity Red MS3 - Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust
5500 ft altitude FTL
MSF in South Africa
Rich990 is offline   Reply With Quote
 Old 08-12-2015, 06:10 AM   #11
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
The stock mani with the heat shield off heat soaks the tmic like a mofo. You better have meth on deck if you plan to run with a aftermarket mani close to the tmic.
neganox (08-12-2015)
 Old 08-12-2015, 03:00 PM   #12
Ceramic coating is highly recommended.
silvapain (08-12-2015)
 Old 08-18-2015, 02:09 PM   #13
Rich990's Avatar
I applied dei reflect-a-gold to the undersides of the end tanks with some pretty good results.
MSF in South Africa
Full Race Exhaust Manifold/Exhaust Combo mr.speedy3 MazdaSpeed 3 - Engine, Transmission & Driveline 14 01-29-2015 07:56 PM
UR mid pipe upgrade not compatible with CS axle back exhaust pfp22972 2010 MS3 - Engine, Transmission & Driveline 5 08-15-2014 07:09 PM
Manifold or tmic next? Cdone MazdaSpeed 3/6 - Build Diaries 61 06-17-2012 12:31 PM
Page generated in 0.32479 seconds with 30 queries
