 Old 12-05-2012, 09:19 AM   #1
pinkcheese's Avatar
Posts: 339   (View Stats)
pinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the worldpinkcheese is the leader of the world
It's about time for an update on this. I did a complete Retune on the car, Using TPS vs RPM for primary fueling map. And Map for the modifier. To help Monitor progress I found I can use AEM logs in exported text format as a valid file type for VD.
I was unable to get the logs past 6,500RPm I'm getting to much interference with the ignition system, So I wasn't able to rev it out to 8,200 like I wanted too. Still need to do quite a bit more work with boost control settings. Right now It's setup with a set Duty cycle at 45% and feedback isn't enabled to keep a steady psi.
Here is where I'm sitting on a rough tune. I adjusted weight for my current car's weight + driver.
pinkcheese is offline   Reply With Quote
The Following User Says Thank You to pinkcheese For This Useful Post:
leon78 (12-05-2012)
BorgWarner aquires Haldex Haltech Automotive News 0 12-20-2010 07:20 AM
Bullseye / Borg Warner .55 A/R T3 S256 Turbo, Need input! JumpingJackson MazdaSpeed 3/6 - Turbo Induction 5 09-03-2009 07:45 AM
Page generated in 0.25362 seconds with 21 queries
