 Old 10-07-2011, 03:54 PM   #41
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
Ah yes, see, it doesn't say you can't run a second restrictor. So if you accidentally ran the *same size* restrictor right next to it, no harm no foul.
2007 CTS-V - Trying to sell
 Old 10-07-2011, 04:17 PM   #42
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
No it doesn't say you can't run a second restrictor. But like you said you can run the same size restrictor with out causing harm to the turbo
SPEED6 KILLAH is offline   Reply With Quote
 Old 10-07-2011, 04:52 PM   #43
EL F00LI0's Avatar
Posts: 703   (View Stats)
EL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the worldEL F00LI0 is the leader of the world
Here's what I have....bb pics ftl, couldnt find my t3i
2008 MAZDASPEED 3 GT
| Cobb SRI | Cobb XLE BPV | SURE TIP | SURE RMM | Resonators Deleted | TurboXs Catless DP |
| Cobb AP Stage 2+ | PG/Godspeed FMIC | BC Coilovers | Evo X Wheels | 245/40/18 Hankook RS3 |
| Cquence Drilled/Slotted Rotors | Hawk HPS Pads | TWM STS | Glowshift Boost Gauge | Sti V Limited Front Lip |
EL F00LI0 is offline   Reply With Quote
 Old 10-07-2011, 04:55 PM   #44
bmylez's Avatar
Groans: 31
Haha...that won't tell you if it's a restrictor. You need a picture of the HOLE. Also, take a picture of the turbo oil inlet.
 Old 10-07-2011, 05:12 PM   #45
EL F00LI0's Avatar
The hole is just straight through no restriction I can tell you that much lol.
i'll go take a pic of the inlet now.
 Old 10-07-2011, 05:33 PM   #46
EL F00LI0's Avatar
Here's the inlet
Hole Shot
Oil Feed
As you can tell I found my camera lol.
 Old 10-07-2011, 05:39 PM   #47
bmylez's Avatar
Groans: 31
Yeah, no restriction from what I can see, in any of those. So you need the restrictor I posted a link to. I'm using it and my turbo ain't blowin oil everywhere
 Old 10-07-2011, 05:42 PM   #48
EL F00LI0's Avatar
That's what I figured thanks for clarifying man you have been a lot of help!
Tapadatass
 Old 10-07-2011, 05:50 PM   #49
bmylez's Avatar
Groans: 31
Also, I noticed you said you were going to put a 3" to 4" reducer on the compressor so you can use the 4" CP-e inlet. Not gonna happen. The CP-e inlet is silicone, not an aluminum pipe, so it will not go into a coupler. Maybe look into the ATP 3" TIP instead.
 Old 10-07-2011, 06:13 PM   #50
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
that feed you will need a dj oil line to connect to that
at 104000 2 bent rods
tuned by nishan
 Old 10-07-2011, 06:15 PM   #51
EL F00LI0's Avatar
What I was going to do was use one of the metal connectors that can join the couplers together. Don't have the link on my phone or id post it up.
@rigor, thanks for the heads up, ill pm him.
Tapadatass
 Old 10-07-2011, 07:17 PM   #52
bmylez's Avatar
Groans: 31
Yes, but if you put a coupling piece in there, it's going to move the TIP too far over and it will hit the battery box. Oh, actually, I should tell you...my 2.5" TIP didn't even fit with a Steed manifold and the turbo I have now. So you should really look into ECU relocation at a minimum.
 Old 10-07-2011, 08:28 PM   #53
relocation the battery to the trunk and relocation the ecu were the battery use to be at so you will have alot of room just a thought...
 Old 10-07-2011, 08:53 PM   #54
turd burglar's Avatar
Posts: 1,895   (View Stats)
Groans: 39
Is that my old turbo? If so theres no built in restrictor, and the piece used to connect the -4an line is just a -4an threaded connection
Dont believe he'll wanna use a restrictor on a journal bearing turbo. Just pour the oil to er
NO! No way am I havin a dick made outta hamburger!
stocking out, buy my big turbo shit here, http://www.mazdaspeedforum.org/forum/forum/f229/bye-bye-big-turbo-dreams-82241/ more to come as stock shit arrives
Last edited by turd burglar; 10-07-2011 at 08:53 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to turd burglar For This Useful Post:
rigor (10-08-2011)
 Old 10-07-2011, 09:05 PM   #55
bmylez's Avatar
Groans: 31
Ummm...that's very bad advice. Try running a full -4AN line to a turbo and see what happens to the seals in about 5 min.
 Old 10-08-2011, 12:39 AM   #56
Groans: 39
The only thing cooling a journal bearing turbo is oil. When I was gonna run a holset hx35 at first the holset website strongly advised against using a restrictor in a journal bearing turbo. Ball bearing bad yes. Jb it's better without one from everything I've read. Especially cuz at idle our oil pressure can dip to crazy low psi, and any restriction is gonna make that a dangerous game
 Old 10-08-2011, 05:22 AM   #57
bmylez's Avatar
Groans: 31
Ok, well I've heard of several people blowing past their oil seals, hopping online and going "My turbo is smoking, whyyyy??" and everyone goes, "Are you running a restrictor?" and they say "Ohhhhhh." Anyway, the .065" restrictor is almost double the size of the .035" restrictor you use for BB turbos. If you run a full -3AN line without restrictor to a JB turbo, you should be fine, but you won't find me ever running a -4AN line without one.
 Old 10-08-2011, 11:15 AM   #58
EL F00LI0's Avatar
When I was doing research on this turbo, I read a lot on the srt forums that they kept blowing their seals after a couple weeks and just like @bmylez said they go on and ask why it happened and the other members asked if they were running a restrictor or not.
 Old 10-08-2011, 12:02 PM   #59
EL F00LI0's Avatar
Saw this when I was looking for ecu relocation
Id love to do this, just wish there was some kind of how to me=electrical retard.
The Following User Says Thank You to EL F00LI0 For This Useful Post:
Realgib3 (10-08-2011)
 Old 10-08-2011, 12:48 PM   #60
Groans: 39
Pry the fucker over there lol or ask mason, he did it on his Vegas build thread
 Old 10-08-2011, 07:26 PM   #61
rigor's Avatar
Groans: 40
been running w/o restrictor 9000 miles! everyone fails to realize is their is one @ the block connection, and you want a little more oil to a journal bearing ......
tuned by nishan
 Old 10-08-2011, 07:32 PM   #62
EL F00LI0's Avatar
Awesome, thanks for clarifying!
Tapadatass
 Old 10-08-2011, 07:46 PM   #63
kmac's Avatar
Posts: 1,792   (View Stats)
No restrictor here, I have a 6262 precision no problems .
 Old 10-08-2011, 09:06 PM   #64
bmylez's Avatar
Groans: 31
Ah yes, I forgot to mention, I have a custom oil feed because my oil feed port threads decided to strip out. So I do not have the restriction of the factory feed. I always forget about that. If you put this turbo on a non-factory turbo car, you would need to run a restrictor.
Carry on...
rigor (10-08-2011)
 Old 10-08-2011, 09:30 PM   #65
EL F00LI0's Avatar
God I just wanna start my build! I haven't worked on my car in like 2 months, I think I'm having withdrawls. I need an oil change so I guess ill do that and see if that satisfies my cravings to work on my car lol.
Tapadatass
 Old 10-09-2011, 07:28 AM   #66
bmylez's Avatar
Groans: 31
Might help a little, haha...
 Old 10-15-2011, 09:05 AM   #67
4G63's Avatar
Posts: 1,479   (View Stats)
Groans: 123
So what's the decision? I'm assuming ur getting rid of the turbo for another one?
2003 Evo VIII
 Old 10-15-2011, 09:21 AM   #68
EL F00LI0's Avatar
I haven't given it much thought tbh. I posted about selling it to that guy in the thread to give it a shot but I guess he didn't want it. I want to keep this turbo, I really do. Its just the damn inlet is 3" and there's only atp's inlet which doesn't look like a very good design imo and I have read bad reviews on it. If I can sell it, ill do it and get the billet cea 5557 with the ported s housing and begin the build. I bought a new camera so my money is back to going into my car lol
Tapadatass
4G63 (10-18-2011)
 Old 10-15-2011, 10:25 AM   #69
Groans: 39
Dude just email pte. They will sell you a ported housing for $65 bucks plus you return the original last time I talked to em lol
 Old 10-15-2011, 11:00 AM   #70
EL F00LI0's Avatar
I already did, that housing doesnt fit with the standard 5557 wheel, its only for the cea wheel they said... -__-
 Old 10-15-2011, 12:48 PM   #71
Groans: 39
Hmmm, not what they told me but maybe things have changed or somethin
 Old 10-15-2011, 02:04 PM   #72
EL F00LI0's Avatar
Ill try calling them tonight and see what the answer is.
Tapadatass
 Old 10-29-2011, 12:27 AM   #73
EL F00LI0's Avatar
Small update, I am in the process of having htp make me a 3" inlet/intake. That way I could run this turbo and have a full 3" intake.
And I ordered my flanges/ewg tube to rebuild my manifold from atp tonight. I need opinions on either ceramic coating the manifold or header wrapping it.
 Old 11-19-2011, 07:59 PM   #74
EL F00LI0's Avatar
Got my inlet in the mail today! Its so nicely built. Very happy with htp's product!
86AmishMs3 (11-21-2011)
 Old 11-19-2011, 08:06 PM   #75
bmylez's Avatar
Groans: 31
I want one of those! How much?
 Old 11-19-2011, 08:15 PM   #76
4G63's Avatar
Groans: 123
Is that HTP in St Louis by chance?
2003 Evo VIII
 Old 11-19-2011, 08:29 PM   #77
EL F00LI0's Avatar
$120 for the inlet + $16 for shipping = $136 total
Yes thats the one!
Here's their website for anyone interested, they are a little slow at emailing you back but once they confirm what you want made, its made in a day and shipped out the next. Mine arrived in 2 days! They can make it with or without the recirc tube and also can add a 3" maf to the end of it so its one full 3" intake/inlet and they will include a filer.
Hi-Tuned Performance | Home
4G63 (11-19-2011)
 Old 11-21-2011, 09:59 PM   #78
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Nice, i might just do this with a 3"-4" reducer.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 11-22-2011, 10:30 AM   #79
EL F00LI0's Avatar
I've got a black one I could send you for free, I dont need it.
86AmishMs3 (11-24-2011)
 Old 11-24-2011, 11:16 PM   #80
86AmishMs3's Avatar
Groans: 338
thanks but htp will be providing it. But I told them they should stock this item. Cheaper option then CPE. And it has the same flow potential of CPE's. All around Win.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
R.I.P. PTE 5557 cageyvet MazdaSpeed 3/6 - Big Turbo Builds 30 12-19-2010 07:56 PM
pte 5557 .63 ar, cpe sb, 420 whp cageyvet MazdaSpeed 3/6 - Dyno Sheets/Discussions 129 07-25-2010 05:33 PM
PTE 5557 @ 17-18psi cageyvet MazdaSpeed 3/6 - Dyno Sheets/Discussions 40 04-16-2010 08:11 PM
Page generated in 0.56500 seconds with 27 queries
