  • 1 Post By MS3-a(sore)ASS-rex
 Old 07-22-2013, 09:35 AM   #1
FamiliaGT's Avatar
Posts: 276   (View Stats)
FamiliaGT is the leader of the worldFamiliaGT is the leader of the worldFamiliaGT is the leader of the worldFamiliaGT is the leader of the worldFamiliaGT is the leader of the worldFamiliaGT is the leader of the worldFamiliaGT is the leader of the worldFamiliaGT is the leader of the worldFamiliaGT is the leader of the worldFamiliaGT is the leader of the worldFamiliaGT is the leader of the world
Default Quality PTP Equipment...
So to paint the picture for you, a good friend of mine with probably one of the first 07 MS3's to hit the US soil back in 06', fully built his bottom end just over a year ago, and he decided to go with PTP's tubular manifold for the build, using a GT2871R. He got the car built and put together and ended up putting a total of 7k miles on it within the year before parking it. had an issue with an exhuast leak he thought was at one of the V Band fittings at the wastegate. After fighting it for a few days total, we finally got the turbo seperated from the manifold and both parts out of the car. Not only was there a minor exhuast leak at the wastegate flanges, but what we found after only 7k miles was stunning, but thinking on it, not a huge suprise knowing PTP's quality history. Not only a full crack all the way around cyl 1's tube, but around cyl 3's as well. The Bracket supporting the wastegate flange was cracked as well. Sorry, but no where near acceptable from a $700 manifold.
So, my buddy ordered a CP-E complete 3076 kit we are in the process of shoving back in the car. pictures of that to come, but heres the star product of this thread.
EDIT: I realize the pictures arent the best and I missed cyl 3, but will get those pics up Wednesday when I head back over to work on the car.
2007 Sunlight Silver Mazdaspeed3 - Bolted and tuned. SOLD
2013 Velocity Red Bicolor Mazdaspeed3 w/ Tech - CS Test Pipe, CS Catback, CS Mudflaps, CS rear motor mount insert.
1988 Mazda 323 GT Factory Turbo - Eagle Rods, Supertech Forged Pistons, Mazdaspeed oil Pump, Mazdaspeed Motor Mounts, Mazdaspeed clutch, CX Racing FMIC custom kit, HKS SSQV, HKS MBC, AEM intake, CorkSport adjustable Cam Gears, Gates Racing T-Belt, Oil Catch Can, Intrax Lowering Springs, Tokico struts, Cork Sport front Strut Bar, GTX Recaro Factory Seats. Daily Driven.
FamiliaGT is offline   Reply With Quote
The Following 5 Users Say Thank You to FamiliaGT For This Useful Post:
BigRedSpecial (07-22-2013), breakfstincluded (07-25-2013), CamSpeed360 (07-30-2013), Easter Bunny (07-25-2013), Tomas (07-27-2013)
 Old 07-22-2013, 09:42 AM   #2
If that mani is ancient, I can believe the fail. Most did back in the day, and they learned. Although PTP is banned here for shit pumps/service back in the day, i would make contact to see if warranty applies.
The Following 7 Users Say Thank You to Raider For This Useful Post:
CamSpeed360 (07-30-2013), Downmented (07-22-2013), Easter Bunny (07-25-2013), FamiliaGT (07-22-2013), JTMS3 (07-23-2013), SLOWHATCH (07-22-2013), Vader (07-22-2013)
 Old 07-22-2013, 09:45 AM   #3
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
Also, i might suggest that when you make initial contact, you do it with kind words initially. John is a bit temper mental and if you contact him and decide to be an ass, then he will most likely tell you to fuck off. lol
700HP CLUB
11.479@124mph
#DIX
The Following 5 Users Say Thank You to Downmented For This Useful Post:
Boosted Beluga (07-22-2013), Dano (07-26-2013), Easter Bunny (07-25-2013), Raider (07-22-2013), SLOWHATCH (07-22-2013)
 Old 07-22-2013, 09:59 AM   #4
psychatog's Avatar
Posts: 6   (View Stats)
psychatog can only hope to improve
Groaned at 9 Times in 5 Posts
Can't really blame the manifold without seeing the rest of the exhaust. If he cheaped out and had a dp without a decent flex section it could have caused the failure.
psychatog is offline   Reply With Quote
The Following 2 Users Say NO Thank You to psychatog For This Un-useful Post:
Easter Bunny (07-25-2013), triplejumper18 (07-27-2013)
 Old 07-22-2013, 10:07 AM   #5
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
Groans: 56
Did he use the bracket under the turbo?
Needed: Driver mod
 Old 07-22-2013, 10:10 AM   #6
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
If I'm not mistaken John had those manifolds made by ETS. If they were I'm surprised it cracked, their welds are usually very good.
Monotonous ONE likes this.
NATOR PA
The Following 3 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
LumberJack (07-29-2013), Monotonous ONE (07-25-2013), triplejumper18 (07-27-2013)
 Old 07-22-2013, 10:30 AM   #7
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Groans: 145
thats a pretty crack
2011 MS3"Princess GRU"
GT2876r
E85 FREEKTUNE
 Old 07-22-2013, 11:15 AM   #8
FamiliaGT's Avatar
Manifold is less then a year old (Use wise). If I recall, when we initailly got it for the build, it had some noticable fitment issues, so it went back to john to be corrected. Down pipe was a properly modified CS DP with a flex wastegate dump pipe attached. Turbo was also supported. Theres just no call for it.
Never once treated any vender of a failed part like an ass, Ive learned that years ago if you want a positive outcome of the situation. John will be contacted to try and get it fixed. But the nice this is the CP-E kit comes with a new cast manifold with V bands and should be much nicer for this set up. Well, for $6k it should.
The Following 2 Users Say Thank You to FamiliaGT For This Useful Post:
El_Diablo (07-22-2013), Poohster (07-22-2013)
 Old 07-23-2013, 10:24 AM   #9
psychatog's Avatar
Not surprised it cracked bc the Cs DP doesn't have a flex section and I doubt he had a 6" flex in his tp bc nobody makes a tp with a 6" flex for the car. A manifold cracking under these conditions has nothing to do with the welds but everything to do with the downstream exhaust.
 Old 07-23-2013, 10:27 AM   #10
trf5000's Avatar
Posts: 2,290   (View Stats)
OK.
Fuckin Brownie.
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
 Old 07-23-2013, 10:28 AM   #11
psychatog's Avatar
+ if it was made by Ets those guys back purge and use filler on their manifold welds which is all you can ask for
 Old 07-25-2013, 01:23 PM   #12
FamiliaGT's Avatar
Absolutely false, but welcome to the forums......
 Old 07-25-2013, 01:31 PM   #13
KusteLokal's Avatar
Posts: 2,664   (View Stats)
Groans: 124
Originally Posted by trf5000 View Post
OK.
Fuckin Brownie.
he has 5 total posts (as oif this post) and 3 of them in this thread.
 Old 07-25-2013, 01:33 PM   #14
tbot's Avatar
Posts: 2,821   (View Stats)
Groans: 40
Who the fuck is this faggot?
And lookey here:
Seems to me everything was done right...
File Type: png Screen Shot 2013-07-25 at 1.31.29 PM.png (63.4 KB, 284 views)
The Following 2 Users Say Thank You to tbot For This Useful Post:
Easter Bunny (07-25-2013), FamiliaGT (07-25-2013)
 Old 07-25-2013, 08:50 PM   #15
FamiliaGT's Avatar
Apparently doesn't know how to read....
Also, not having a flex section in the exhaust is not a likely cause of welds to break on a manifold.
CamSpeed360 (07-30-2013), LumberJack (07-29-2013)
 Old 07-25-2013, 09:11 PM   #16
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
IIRC, only long downpipes tend to have flex sections.
Kyle who is the friend who got the cpe turbo kit?
 Old 07-26-2013, 02:11 PM   #17
psychatog's Avatar
Jesus you'll are fucking retards. Congrats on thinking that a flex section between the WG/and dp is all that's needed. There should be a 6" flex section before the cat back exhaust bc we do have a long dp and the manifold is not cast. I understand "you" gotta be an asshole when shit fails and you wanna blame someone else. BTW, zero fucks are given.
Easter Bunny (07-26-2013), triplejumper18 (07-27-2013)
 Old 07-26-2013, 02:32 PM   #18
sidekick's Avatar
Posts: 3,093   (View Stats)
Those cracks are likely due to fatigue from heat. Either lower grade stainless or improper welding/purging techniques most likely. This is why EMs like the CP-E are nice.
Did he have any way of monitoring EGTs? Can you post a picture of the inside of the runner? If he didn't back purge and then just ground down the sugaring on the backside, that could cause issues like this. Stainless can very sensitive to heat input during welding and can lose it's strength if it is overheated excessively. Same can happen with extremely high EGTs. If the welds become weakened by excessive heat due to EGTs, even small stresses could then crack it.
 Old 07-26-2013, 02:41 PM   #19
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
is psychatog John?
The Following 7 Users Say Thank You to Dano For This Useful Post:
breakfstincluded (07-26-2013), CamSpeed360 (07-30-2013), Kyle Undefined (07-26-2013), ms3blackmica (07-30-2013), NJSPEED3 (07-28-2013), trf5000 (07-26-2013), triplejumper18 (07-27-2013)
 Old 07-26-2013, 02:46 PM   #20
is psychatog John?
you mean cageyvet?
oops, he done got banned. hmm, IP says Houston...
Last edited by Raider; 07-26-2013 at 02:46 PM. Reason: MSF Database - Automerged Doublepost
Easter Bunny (07-26-2013), NJSPEED3 (07-28-2013), trf5000 (07-26-2013)
 Old 07-26-2013, 03:40 PM   #21
Trail of Fail
Dano's Avatar
hahaha
my 2nd choice...and considering you've already taken the opportunity to discover its from Houston...seems to fit nicely pending other evidence.
or 3rd choice is just a brownie being brown....ur I mean faggot pink.
btstarcher (07-27-2013)
 Old 07-26-2013, 03:48 PM   #22
Sideswipe Magnet
Kyle Undefined's Avatar
Posts: 3,378   (View Stats)
Groans: 332
Only steers and queers come from Texas...
Emerald Green 2002 Miata
Mods:
Waiting list:
Full vinyl wrap
Events:
LynzeCs bottom bitch.
 Old 07-26-2013, 06:35 PM   #23
^from Texas, not a cow.
 Old 07-26-2013, 06:53 PM   #24
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
Crack kills!!!
Beanfab / Tuned by Nishan
The Following User Says Thank You to doubleflusher For This Useful Post:
 Old 07-26-2013, 08:29 PM   #25
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
I'd wrap it in duct tape, say it's heat wrap and sell it on 24/7. Then sit back and enjoy the show.
The Following 2 Users Say Thank You to jdmage_mx5 For This Useful Post:
CamSpeed360 (07-30-2013), triplejumper18 (07-27-2013)
 Old 07-27-2013, 07:42 AM   #26
triplejumper18's Avatar
Posts: 2,569   (View Stats)
Groans: 196
Fucking PTPenis John, hahahaha.
 Old 07-27-2013, 07:53 AM   #27
btstarcher's Avatar
Posts: 4,852   (View Stats)
I'm from Texas, also not a cow....also running PTP internals for 30k miles without incident.
SnailTune in progress
 Old 07-27-2013, 08:29 AM   #28
m4tic's Avatar
Posts: 4,928   (View Stats)
@FamiliaGT; how much for that GT28?
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 07-29-2013, 10:39 PM   #29
FamiliaGT's Avatar
Sorry m4tic, Plans are already in the works for it to make its way onto my 13'.
Ladies and circle jerks, I give you "Atmosphere" by cp-e!
Don't look to far into there being two turbos, its not a "TT" kit.....
And the Down Pipe is out of the picture obviously, but its still oh so very beautiful!
The Following User Says Thank You to FamiliaGT For This Useful Post:
Code Monkey (07-29-2013)
 Old 07-29-2013, 10:53 PM   #30
708
Erich's Avatar
Posts: 4,274   (View Stats)
1) John designed his manifold, only did the first 2 himself, one of which he sent to ETS for them to duplicate. Every other manifold John has sold has been his design fabricated by ETS.
2) John really has no desire to be on MSF at this point. He is happy to work with anybody in the Mazda community that asks, but realized it was in the best interest of his sanity and stress level just to stay away from here. Beyond that, he really doesn't have time. I can guarantee he isn't creating accounts to browse or troll here.
3) As mentioned by somebody else, give him a call and be respectful when talking to him. You are likely to get the same attitude in return and also warranty service on the manifold (if it is still in warranty, don't remember what the warranty is on the manifolds.) I know of one other one that cracked. The weld failed on the support going from a runner to the waste gate runner and then the waste gate runner cracked.
4) TripleJumper should probably go back to SpeedForums where his cocksucking at least got him a moderator position. Oh wait.... never mind.
btstarcher (07-30-2013)
 Old 07-29-2013, 10:58 PM   #31
love the downpipe EWG design
Page generated in 0.49826 seconds with 40 queries
