 Old 07-08-2010, 10:21 AM   #1
emmons85's Avatar
Posts: 70   (View Stats)
emmons85 has much to be proud ofemmons85 has much to be proud ofemmons85 has much to be proud ofemmons85 has much to be proud ofemmons85 has much to be proud ofemmons85 has much to be proud ofemmons85 has much to be proud ofemmons85 has much to be proud ofemmons85 has much to be proud of
Default Question about stock boost pressure
I was just curious. What is the factory boost psi and how much can you increase the factory turbo to and still be safe? Right now I have a sri, greddy rs bov, and catback. I don't know if this makes a difference. Also, if I can increase the boost pressure, will my ecu read that more pressure is comming through and electronically limit it back to the stock psi? Thanks in advance
Sent from my Droid using Tapatalk
emmons85 is offline   Reply With Quote
 Old 07-08-2010, 11:08 AM   #2
integrrac's Avatar
Posts: 95   (View Stats)
integrrac has a reputation beyond reputeintegrrac has a reputation beyond reputeintegrrac has a reputation beyond reputeintegrrac has a reputation beyond reputeintegrrac has a reputation beyond reputeintegrrac has a reputation beyond reputeintegrrac has a reputation beyond reputeintegrrac has a reputation beyond reputeintegrrac has a reputation beyond reputeintegrrac has a reputation beyond reputeintegrrac has a reputation beyond repute
The K04 is designed to provide reliable, long-term service as long as its performance parameters are not exceeded. Driving the car at engine speeds above 5800 rpm with 15spi or greater boost significantly increases the exhaust temperature measured inside the K04 turbine housing. This signals that the maximum efficiency of the turbocharger has been exceeded, and that the energy produced by the turbine housing is now converting to heat rather than accelerating the compressor wheel faster. Unless a careful and extended idle-down is performed at the end of every hard driving session, the rapid heat build-up from high boost/high rpm operation causes the turbine shaft to soften, and allows the inconel turbine head to droop. The result is an imbalance that ultimately leads to a shaft failure.
Lots of people use the Cobb AP to tune for higher boost levels, it might give you a little more umph but at the end of the day the turbo is at the end of it's efficiency range on the stock settings as it is.
integrrac is offline   Reply With Quote
The Following User Says Thank You to integrrac For This Useful Post:
Cheeto (05-18-2012)
 Old 07-10-2010, 10:59 AM   #3
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Stock is 15.6PSI, but the car doesn't really hold that consistantly with the stock tune.
I think it is fair to say that the stock turbo can make a shit-ton more power/torque than the stock tune requests.
Just don't expect much over 300whp with it.
Here is what I have squeezed out of the stock snail:
http://www.mazdaspeedforum.org/forum/foru...66-9wtq-53665/
rfinkle2 (02-09-2012)
weird tire wear pattern. stock tires. stock rim. stock suspention. stock tire pressure what's up with this? labikesrcool MazdaSpeed 3/6 - Wheels & Tires 21 11-30-2015 03:32 PM
Drop in Boost Pressure Jujiro_Prodigy_31 MazdaSpeed 3/6 - Turbo Induction 4 01-12-2010 04:04 PM
Stock boost pressure Brum-Ole MazdaSpeed 3/6 - Turbo Induction 2 12-17-2009 03:44 AM
HELP ME!! Pressure plate question Bigbody250 2010 MS3 - Engine, Transmission & Driveline 2 11-30-2009 11:05 PM
Page generated in 0.25340 seconds with 22 queries
