 Old 02-18-2014, 09:27 AM   #1
Douggievee's Avatar
Posts: 71   (View Stats)
Douggievee is just really niceDouggievee is just really niceDouggievee is just really niceDouggievee is just really niceDouggievee is just really nice
Default Question on switching from MBC to EBC
The previous owner of my car had a TurboXS MBC installed, right now holding around 10.5 psi from what my AP is telling me. I'm ordering a Cobb 3 port EBC and I was wondering if this is something I can just install and let the ECU adjust how it wants until I start working with my E-Tuner or if I should hold off installing until I'm ready to load the new tune on there?
2006 Mazdaspeed6 GT: Autotech Fuel pump, GT3071R, Cobb AP FreakTune, 3" Custom Magnaflow Turboback Dual Exhaust, Mazdaspeeed intake/turbo inlet tube, NGK XI 1 step colder plugs, Fidanza Flywheel, EGR/VTCS Delete, Cobb EBC, Cross drilled rotors, Corksport BPV, TSW Nurburgrings, Techna-Fit SS Clutch Line
Douggievee is offline   Reply With Quote
 Old 02-18-2014, 03:57 PM   #2
rymanmazda's Avatar
Posts: 1,531   (View Stats)
Groans: 122
3 port requires tuning while 2 port doesn't.
Freektune: 400whp/387awtq
-Autocross Setup-
Other Rides:
The Following 2 Users Say Thank You to rymanmazda For This Useful Post:
Agent_Orange (02-18-2014), jm211 (02-19-2014)
 Old 02-18-2014, 06:06 PM   #3
Douggievee's Avatar
OK so waiting for my tuner to have a base tune set before installing it is best?
 Old 02-18-2014, 06:11 PM   #4
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
To take full advantage of the EBCS it should be plumbed in interrupt mode. This requires re-working the WGDC table.
So yes, might as well wait until tuning time.
 Old 02-18-2014, 06:22 PM   #5
Douggievee's Avatar
awesome, thanks guys for the info. still learning this car.
 Old 03-06-2014, 12:16 PM   #6
Douggievee's Avatar
How exactly can i hook this up as a 2 port while making it easy to change over to a 3 port? Im trying to install this tomorrow without the tuning for the time being but will change it to 3 port in a month or so. Im just not sure which of the 3 ports not to hook up
 Old 03-06-2014, 12:18 PM   #7
mr.speedy3's Avatar
Posts: 1,690   (View Stats)
Cobb has a document showing how to set it up on their site.
 Old 03-06-2014, 01:22 PM   #8
rymanmazda's Avatar
Groans: 122
@Douggievee;
Here you go:
https://static.cobbtuning.com/cobbtu...structions.pdf
-Autocross Setup-
Other Rides:
 Old 03-06-2014, 01:29 PM   #9
Originally Posted by rymanmazda View Post
These are the 3 port interrupt setup instructions.
You can run this solenoid in 2 port mode.
All you need to do is to cap off port 3 and then just connect the port 2 to your turbo inlet pipe and port 1 to the top port on your wastegate actuator.
Make sure the bottom port on the wastegate actuator is still attached to the compressor housing barb at the bottom.
Here's a diagram of setting up a 3 port in 2 port mode:
http://stratifiedauto.com/images/3P%...eed%20Mode.png
Douggievee (03-07-2014), rymanmazda (03-06-2014)
 Old 03-06-2014, 05:19 PM   #10
rymanmazda's Avatar
Groans: 122
Oopps sorry! I just copied the link I had on my favorites bar from when I installed mine. I thought those had the instructions for 2 port and 3 port. Now that I think about it, Grimmspeed's instructions has the instructions for both.
My bad. Thanks for the save @Lex;
-Autocross Setup-
Other Rides:
The Following User Says Thank You to rymanmazda For This Useful Post:
Lex (03-13-2014)
 Old 03-06-2014, 03:56 PM   #11
Douggievee's Avatar
Thank you everyone. That's a big help.
switching oil? blackms3_71 Mazdaspeed3/6 General Discussion 9 11-17-2013 12:17 AM
Switching from SB to AP... need help MS3 Ventura MazdaSpeed 3/6 - ECU Computer Tuning 23 12-20-2010 11:15 PM
switching to sythetic oil phillyb MazdaSpeed 3 - Engine, Transmission & Driveline 61 04-19-2010 03:15 AM
Switching to MBC cpolly69 MazdaSpeed 3/6 - Turbo Induction 10 09-20-2009 06:43 PM
Page generated in 0.30777 seconds with 24 queries
