Closed Thread
 Old 03-07-2015, 09:04 PM   #1
CajunBud876's Avatar
Posts: 87   (View Stats)
CajunBud876 has a reputation beyond reputeCajunBud876 has a reputation beyond reputeCajunBud876 has a reputation beyond reputeCajunBud876 has a reputation beyond reputeCajunBud876 has a reputation beyond reputeCajunBud876 has a reputation beyond reputeCajunBud876 has a reputation beyond reputeCajunBud876 has a reputation beyond reputeCajunBud876 has a reputation beyond reputeCajunBud876 has a reputation beyond reputeCajunBud876 has a reputation beyond repute
Default Questions/Help w/BT Build
Hello Gents,
Currently I'm awaiting to deploy to Kuwait/Iraq. When I get back I plan on either a) Purchase Speed 6 (Build Ultimate Sleeper) b) Purchase New Ford Focus RS (320HP AWD). I have a little experience with the Speeds. I owned a Speed6 for roughly 6 months before getting T-Boned at intersection by a pot head and owned a 2010 Speed 3 for 2 years before selling before deployment. Currently my DD is Ram1500 and weekend is a 600HP 3000GT.
Goals for build:
1) Something that requires little to no fabrication
2) 500-600 WHP w/E-85 Daily Drivable
3) Sleeper
What type of budget am I looking at (Want to stay under 15k) I will build the engine and assemble everything. Only thing I will outsource will be the head work and machining of course.
1) What turbo? (Love the GTX Turbos)
2) What are some supporting mods for drivetrain that will be needed.
I will continue doing some research on here. This thread will help me start researching and pricing out this build and help finding parts. Any advice/guidance or link to proven build will be greatly appreciated.
CajunBud876 is offline
 Old 03-08-2015, 09:27 AM   #2
After countless hours of research seems like the CPE shop is almost a one stop shop for the entire build. A little pricey for what everything is but if the R&D is good Im fine with paying for it.
I'm thinking their GTX 3076R Atmosphere Kit should work perfectly to hit Mid 500's on E-85, and have some type of low end spool. I remember in my 2.3 Focus back in the day use to spool up around low 4k. I don't know if their crate engines are worth it however. I haven't done the cost analysis but I think I can build a engine that can easily handle that power for about 2-3k.
Cant find much in the form of beefing up the drivetrain except for rear diff and motor mounts. Need to start looking at some clutch options now. Taking recommendations on clutches.
 Old 03-08-2015, 04:23 PM   #3
derp_ms6's Avatar
Posts: 297   (View Stats)
derp_ms6 is the leader of the worldderp_ms6 is the leader of the worldderp_ms6 is the leader of the worldderp_ms6 is the leader of the worldderp_ms6 is the leader of the worldderp_ms6 is the leader of the worldderp_ms6 is the leader of the worldderp_ms6 is the leader of the worldderp_ms6 is the leader of the worldderp_ms6 is the leader of the worldderp_ms6 is the leader of the world
Check out this thread:
The Official MS3MS6 Aftermarket Bolt-On Turbo Thread
derp_ms6 is offline
 Old 03-08-2015, 10:46 PM   #4
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
The Atmospheric kit with it's recirc'd EWG dp will definitely be sleeper but meh. I'd go PTE 6266 Edgeautosport kit w/ Cp-e manifold and have a dp fabbed for the PTE vband even if you said nah to fabbing. Kozmic has made a dump tube for the MS6's now aswell so you can request your MS3 kit without the MS3 DP and MS3 Dump tube and get the Kozmic MS6 dump. The Gen2 CEA 6266 was ran at 823whp on Bryce's MS3 so that shows you what kinda headroom you'd have on the setup.
-PTE Turbo Kit for MS3 which will need a fabbed DP
Precision Turbo Kit V-Band Ball Bearing Turbo Mazdaspeed 3 2007-2013
-44mm EWG dump tube for Cp-e Mani w/ on MS6
Kozmic Motorsports Dump Tube for 44mm Wastegate/CP-E Manifold Mazdaspeed 6 2006-2007
-6th Port kit needed for 500whp+ worth of fuel
http://www.edgeautosport.com/manufac...ts-sixth-port-
injection-kit-mazdaspeed-3-mazdaspeed-6-2006-2013/
OR
-SP63 PI fuel kit (if you run 8th Port injectors on JMF manifold)
SPEED PERF6RMANC3 Port Injection Fuel Kit For Mazda MZR-DISI - SPEED PERF6RMANC3
-JMF Intake Sheet Metal Intake Manifold
JM Fabrications V2 Intake Manifold For Mazda MZR-DISI - SPEED PERF6RMANC3
-Clutch Masters Twin Disk clutch if you plan on revving and shifting higher with a built head
EdgeAutosport.com - Advanced Search
-Built Motor from SP63 if you can't find any local MPS-friendly shops who can build a DISI motor
SPEED PERF6RMANC3 Built Long Block For Mazda MZR-DISI - SPEED PERF6RMANC3
-Built/Ported head from SP63
SP63 Custom Headwork for Mazda MZR-DISI - SPEED PERF6RMANC3
-Bosch 4Bar Map sensor
Bosch 4 Bar Map Sensor For Mazda MZR-DISI - SPEED PERF6RMANC3
You're gonna need OCC obv (possibly dual w/ Perm PVC Plate), Mounts (including diff), Axles eventually and a few more electronics parts. This parts combo ^ is kinda like a budgetless build and far from necessary to achieve 500whp-600whp but fuck it lol
impossible is offline
The Following 3 Users Say Thank You to impossible For This Useful Post:
Agent_Orange (03-09-2015), CajunBud876 (03-09-2015), ItsNox (03-14-2015)
 Old 03-08-2015, 10:53 PM   #5
impossible's Avatar
Groans: 30
I did basically all the leg work for you but you still need a shit load of reading to comprehend E85 on these cars and fueling woes as you're not making 500whp on stock injectors w/ E85 (as you commented above). You'll likely be running out of fuel around 400whp without Auxilary fueling like methanol injection or 5th/6th/8th Port injectors. Checkout the Big Turbo build section and do ALOT of reading and look for the baller 600whp builds and take notes or contact those guys for tips/help
The Following 2 Users Say Thank You to impossible For This Useful Post:
Agent_Orange (03-09-2015), ItsNox (03-14-2015)
 Old 03-09-2015, 03:05 AM   #6
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
A member since 09 and your still that ignorant about the platform?
What have you been doing? Jacking off in the corner?
Follow @impossible;'s advice and your good to go.
Agent_Orange is offline
impossible (03-09-2015)
Closed Thread
Engine build questions JDMCRX MazdaSpeed 3 - Engine, Transmission & Driveline 0 06-18-2014 07:06 AM
MS6 Engine Build Questions RogerH MazdaSpeed 6 - Engine, Transmission & Driveline 3 05-23-2013 06:28 PM
questions about my build SlickDevil 2010 MS3 - Engine, Transmission & Driveline 19 04-26-2012 08:04 PM
Stupid questions about BT build I am considering. dsmluck MazdaSpeed 3/6 - Turbo Induction 198 08-09-2011 11:33 AM
A few build questions....... jracer MazdaSpeed 3/6 - Big Turbo Builds 11 02-21-2011 02:04 PM
Page generated in 0.29137 seconds with 23 queries
