Like Tree11Likes
 Old 11-27-2015, 11:26 AM   #41
mikelevi's Avatar
Posts: 362   (View Stats)
mikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the world
did u prime the fuel pump? did u prime the turbo?
I primed the fuel pump, haven't installed the turbo yet.
Current Build: 2006 MS6 GT
Power: BNR S3V2, Freektune 3.5" Intake, PnP Intake Manifold PC Wrinkle Black, Custom 3" Magnaflow CBE, M2 Ebay DP, CS Injector Seals, TR8L FMIC, Autotech Internals, GFB BOV 70/30, JBR OCC, EGR Delete and Block Plate, GS EBCS, Cobb AP v2, NGK IX @.026, Bosch 3 Bar MAP and Harness
Looks and Feels: AWR 80 Duro Trilogy Mounts, Bilstein B6, CPE and TT diff mount, Whiteline RSB, LED Tails, 18x8 +43 MB Battles Gunmetal, PC valve cover and IC piping Black Chrome II
mikelevi is offline   Reply With Quote
 Old 11-27-2015, 11:37 AM   #42
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
So I tapped the connection and now it finally turns over but all its going is cranking. I checked the hpfp ground since I missed that last time but nothing. No check engine codes, not really sure what to do next
Is your battery charged? Try jumping it now that it's turning over. Just try to get all the easy stuff out of the way.
 Old 11-27-2015, 03:55 PM   #43
mikelevi's Avatar
Code b1318. Maybe it is my battery now? I'll get a charger on it tomorrow and reassess.
Edit: looks like b1318 is for my low key fab battery. Think it's still a mechanical issue. I checked fuel pressure when cranking, came up to 800, does that seem right?
Anything I should look at for spark or ignition on the monitor to help diagnose?
 Old 11-27-2015, 08:55 PM   #44
mikelevi's Avatar
Side question:
So I was just looking through extra bolts and old parts and see the small little spacer that came with the TIG for the manifold. Do I really need to take the manifold back off to put that shit on?
 Old 11-27-2015, 09:05 PM   #45
Yes. Pray you did not crack the mani.
Easter Bunny (12-03-2015), ItsNox (11-29-2015)
 Old 11-30-2015, 09:33 PM   #46
mikelevi's Avatar
Got the spacer in on the manifold, checked all connections and re-assembled. Battery fully charged and still just cranked without getting going. Took a couple logs and watched the Act fuel pressure. First 10 cranks never registered above 50 psi. Then all the sudden it sounded like it was getting some gas or fire but still wouldn't connect. Noticed the psi went to 800-1000 and stayed there even after crank attempts. I gave up for the night, have way too much other shit to do.
 Old 12-01-2015, 12:07 PM   #47
mikelevi's Avatar
Here are some logs if anyone wants to throw in their 2 cents.
 Old 12-01-2015, 03:50 PM   #48
mikelevi's Avatar
Got it running. Sounds like complete shit but maybe I just need to let it run a while.
 Old 12-01-2015, 07:45 PM   #49
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
If you get it running you need to keep an eye on fuel pressure because the first two logs only show 70 psi which means the HPFP isn't doing it's job. Do NOT let it run if pressure is that low. Also, log it
Cheapspeed likes this.
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
Micha (12-07-2015)
 Old 12-02-2015, 09:18 PM   #50
mikelevi's Avatar
Fuel pressure is stable at 570 at idle, and 800-2000 under driving load. My idle pulley is a fucking wibble wobble. Not sure if the belt is crooked on it or what but it's shaking like a dog shitting razor blades.
Also hearing like a rocks in dryer coming from the far left side of the fuel rail/manifold area. Not really sure what that is? Power steering fluid was almost empty on start up.
Cruising around under really light load and registered a 7.7 kr. Can it get that high for partial throttle?
 Old 12-03-2015, 03:36 AM   #51
MSP611's Avatar
Posts: 2,291   (View Stats)
i would say ur rattle and idler pulley is the culprit of ur high KR... fix those bitches asap and see...
In progress:
 Old 12-03-2015, 08:58 AM   #52
mikelevi's Avatar
So Im confused here. When I removed the VTCS i removed the actuator rod and everything with it and tapped and plug the hole. I was looking though edge and see this
Yeah, I definitely removed that. I though the TPS was inside the Throttle body? Making sure I dont need to reinstall this with the cut actuator to engage the sensor.
 Old 12-03-2015, 09:04 AM   #53
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
Just an FYI for future reference when @maisonvi; and myself accidentally flooded some B12 into his cylinders it ran like crap for a bit.....and smelled awful. We just hooked a battery charger up and cranked that SOB until it started. That's the remedy.
Silver 2007 Speed3 GT
 Old 12-03-2015, 09:09 AM   #54
mikelevi's Avatar
Same here, I think I was being a bit of pussy cranking it. It just didnt want to overheat the starter. It took a good 10-15 second crank to get it going. Plus the first 20 cranks did not register above 75 for fuel pressure. I think I'll definitely run meth so I dont have to clean the valves as much, that job really was a pain in the ass.
HawkeyeGeoff likes this.
The Following User Says Thank You to mikelevi For This Useful Post:
HawkeyeGeoff (12-03-2015)
 Old 12-03-2015, 10:02 AM   #55
MSP611's Avatar
Tht is the VCTS actuator sensor if im not mistaken (may not be 100% technical name) but it goes to the actual actuator on the VCTS and i think is wat sent the signal to the ecu to tell If VCTS was fully open or closed...
You will throw a code without tht sensor unless u wired in a resistor.
In progress:
 Old 12-03-2015, 10:08 AM   #56
mikelevi's Avatar
Edge has it listed as the Throttle Position Sensor, I was just making sure. I looked up the images of the TPS on Ellis and it says its in the TB. Ok, I'll stop fretting.
 Old 12-03-2015, 10:09 AM   #57
Groans: 33
This is how my tensioner and idler pulley looks like after 70k. Made an aweful sound at 50%+ throttle and it sounds like yours is way worse. Just ordered the CS pulley kit to replace them
Mazdaspeed6 -06
290 AWHP / K04
The Following 2 Users Say Thank You to SpeedRebirth For This Useful Post:
impossible (02-14-2016), mikelevi (12-03-2015)
 Old 12-03-2015, 03:05 PM   #58
mikelevi's Avatar
Here is a log with that weird KR just for reference.
 Old 12-03-2015, 03:32 PM   #59
mikelevi's Avatar
I dont know if its my imagination or not? Does the VTCS delete and PnP manifold or injector seal upgrade make any difference in noise. Either that or cleaning the valves, did anyone hear it sound different?
https://youtu.be/abUlWw54x_w
 Old 12-03-2015, 04:22 PM   #60
Cheapspeed's Avatar
My car has hit up to 8kr at part throttle. But I have low compression in #3 and maybe #2 now.
impossible (02-14-2016), Micha (12-07-2015)
 Old 12-03-2015, 04:28 PM   #61
ItsNox's Avatar
Posts: 3,076   (View Stats)
Cleaning valves and injector seals wont make a difference in sound. VTCS delete will make the car sound like shit on cold start but I believe that goes away once warm. Not sure about PnP mani.
The clicking sounds like normal injector noise. However the harmonic rhythm that seems to be in sync with the serpentine belt doesn't sound right to me.
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
 Old 12-03-2015, 04:34 PM   #62
mikelevi's Avatar
Yeah the clicking Im use to around the HPFP, but this clicking is coming from the manifold area. As for the harmonic rhythm noise Im almost positive is coming from the idle pulley.
 Old 12-03-2015, 04:37 PM   #63
ItsNox's Avatar
Do you think its possible you fucked something up when you torqued the mani down without a gasket? Maybe consider pulling the mani and inspecting the injectors/seals. Perhaps you jacked something up when hulking out after rounding out that injector bolt.
'06 Mazdaspeed 6 GT
- Miltuned
 Old 12-03-2015, 05:12 PM   #64
mikelevi's Avatar
Its probable that I fucked something up, ha. I guess the only thing I can do, is take it apart and look at it when I install the turbo. To me its more unlikely that the injectors would be messed up. The seals went on great, the holes were clean and everything seated correctly. If anything its the manifold or valves. Since that one fucker wouldnt seat right maybe its still not seating properly?
 Old 12-03-2015, 11:07 PM   #65
MSP611's Avatar
doubt u did anything to the valves unless u left a scribe in there lol... i would change ur pulleys/belt and see where tht takes the sound and go from there before i rip apart the intake mani again
In progress:
 Old 12-04-2015, 07:42 AM   #66
Cdnspeed6's Avatar
Posts: 139   (View Stats)
Cdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond repute
start the car without the Serp Belt to see if the noise goes away, the car will run without it just not too long as it'll be running off the battery
Cdnspeed6 is offline   Reply With Quote
 Old 12-07-2015, 02:25 PM   #67
mikelevi's Avatar
I'll be taking out the K04 this week and dropping in the turbo. Reading through old build threads and others to make sure I have everything and is good before I dive in.
Need a little clarification. Do I need a different set up from from is already on the turbo for the oil return line? Will the installed braided line not work for the MS6?
From the photos on edge's EWG kit, it looked like this line comes with the kit for the speed 6 but other threads are making me think otherwise, and a ridiculous fabbed S fitting is needed to for the return.
 Old 12-07-2015, 02:34 PM   #68
pyro's Avatar
Posts: 11   (View Stats)
pyro is on a distinguished road
It wont work. Been there... Do you have the sharp bend for the wastegate?
pyro is offline   Reply With Quote
 Old 12-07-2015, 02:36 PM   #69
ItsNox's Avatar
I was under the ridiculous fabbed S line fitting impression. Thats part of why I went BNR. Drop in. Probably gonna go S4 for the same reason.
'06 Mazdaspeed 6 GT
- Miltuned
 Old 12-07-2015, 02:39 PM   #70
mikelevi's Avatar
Ughh, if it isn't one thing it's another.
 Old 12-07-2015, 03:01 PM   #71
ItsNox's Avatar
@Code Monkey; has a thread floating around here. When i have time I'll dig it up.
This might help
http://www.mazdaspeedforum.org/forum/foru...thread-188010/
'06 Mazdaspeed 6 GT
- Miltuned
Code Monkey (12-07-2015)
 Old 12-07-2015, 03:11 PM   #72
Cheapspeed's Avatar
I used the fitting that came with the kit. Worked for me. If you want an AN-10 fitting I think I have 1 or 2, though. I bought it with the same thoughts you had about the drain, I have and MS3 with stock manifold, though.
 Old 12-07-2015, 04:33 PM   #73
Hahahahhhahhahaa, I am still recovering from that fail, good luck OP.
ItsNox (12-07-2015), mikelevi (12-07-2015)
 Old 12-07-2015, 06:25 PM   #74
mikelevi's Avatar
FUCK, anyone having extended deals on an S3/S4? Thinking about just starting over and selling this thing.
The Following 2 Users Say Thank You to mikelevi For This Useful Post:
Code Monkey (12-07-2015), ItsNox (12-07-2015)
 Old 12-07-2015, 06:41 PM   #75
Meh, at least try to see if the fucking line fits on your car or how close it is. You could probably shave off 1/8" or a bit more from the oil line flange, or if you know exactly the angle the line should run at, you could cut off a couple threads from the flange and have that big nut welded or spot welded to the flange?
 Old 12-07-2015, 08:06 PM   #76
ItsNox's Avatar
Im with @Code Monkey; give that bitch a go. We need moar EWG goodness. My buddy hacked up his k04 line and used an AN fitting + flexible stainless line and got it to work on his IWG GT3076. It was something like that at least.
'06 Mazdaspeed 6 GT
- Miltuned
The Following 2 Users Say Thank You to ItsNox For This Useful Post:
Code Monkey (12-07-2015), Micha (12-07-2015)
 Old 12-07-2015, 09:35 PM   #77
mikelevi's Avatar
Well I have a potential buyer lined up if I want it. I read that I can just cut the return line in half and attached a -10AN fitting?
If I can get my money back from the GTX, and instead go with S3/S4, might be worthwhile especially if someone is still running a deal. I do like to fact that I can be 800 RPM more responsive, and honestly, my motor build wouldn't be until next summer, who knows if Id ever get to it.
With my goal of pushing the limits of the stock block 375-400 awhp, should I just switch up the build? Any issues with the lines on the S4? I know its the same housing but the issue is the EWG hotside, no fitment issues right?
 Old 12-07-2015, 10:21 PM   #78
Micha's Avatar
Posts: 3,436   (View Stats)
All the BNR turbos are IWG.
 Old 12-07-2015, 11:14 PM   #79
ZX299's Avatar
Posts: 149   (View Stats)
ZX299 has a reputation beyond reputeZX299 has a reputation beyond reputeZX299 has a reputation beyond reputeZX299 has a reputation beyond reputeZX299 has a reputation beyond reputeZX299 has a reputation beyond reputeZX299 has a reputation beyond reputeZX299 has a reputation beyond reputeZX299 has a reputation beyond reputeZX299 has a reputation beyond reputeZX299 has a reputation beyond repute
I'm running the GTX3076 on my MS6 albeit IWG. For the drain line I bought two 60 degree an-10 fittings, a weld on an-10 fitting for the cut stock drain line. The 60 degree fitting seem to be almost perfect depending on where you cut the stock drain line, I had to slightly bend one of them to get it line up.
2007 Mazdaspeed 6 GT: JBR Shift knob, Circuitworks catless downpipe & 3.5" custom dual exhaust, JBR TRU 3.5" intake, GTX3076, XSPower V3 manifold, Autotech internals, Accessport V3, Damond Motorsports Full EGR delete, DM Dual OCC kit, CXracing FMIC. AWR 88 Duro RMM, GFB Respons TMS.
ZX299 is offline   Reply With Quote
The Following User Says Thank You to ZX299 For This Useful Post:
ItsNox (12-08-2015)
 Old 12-08-2015, 07:18 AM   #80
ItsNox's Avatar
Whoa now buddy maybe I never read your power goals prior. If your goals are sub 400, S3 is the way to go for simplicitys sake. I'm hitting 375-390awhp/390awtq on my BNR + meths. And I'm not even using meth for fuel nor do I have a down pipe. My tuner knows I want my tune a bit conservative so I'm sure there is still a little room on the table. I can find a Vdyno if you like.
S4 if you want 450. When I build I'll be dropping in an S4.
'06 Mazdaspeed 6 GT
- Miltuned
Micha (12-08-2015), mikelevi (12-08-2015)
Watch and listen to Jon Olsson drift his Rebellion R2K up a snowy peak Haltech Automotive News 0 04-12-2014 05:20 PM
China's record-breaking bridge spawns new record for 24-mile Lake Pontchartrain Causeway Haltech Automotive News 0 07-17-2011 10:10 AM
Page generated in 0.59832 seconds with 31 queries
