 Old 03-22-2015, 08:15 AM   #1
armyman's Avatar
Posts: 30   (View Stats)
armyman has a spectacular aura aboutarmyman has a spectacular aura about
Default restrictor bolt on BNR stage 3
Can I use the restrictor bolt on the BNR stage 3 or does it need the oil?
CPe HPFP, Corksport Mazdaspeed 6 power series catted downpipe, Corksport TMIC, Corksport MZR Bypass valve, Cooling Mist W/M injection with cmgs, JBR Tru-3.5 Wide Path Full aluminum Intake System, Denso ITV-22, intank 265 L fuel pump, rear engine mount, EGR block off plate, XS stainless steel exhaust manifold ceramic coating, BNR stage 3 turbo, Stratified Mazda 3 Port Electronic Boost Control Valve, Stratified tune, HKS Twin Power
armyman is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/restrictor-bolt-bnr-stage-3-a-186062/
restrictor bolt on BNR stage 3 This thread Refback 06-20-2015 11:30 PM
Page generated in 0.21874 seconds with 20 queries
