 Old 06-16-2011, 07:07 AM   #1
RhoadBlock's Avatar
Posts: 793   (View Stats)
Groaned at 7 Times in 4 Posts
Default RhoadBlock's build finally commences
Welp, I had finally installed my temporary 3071 bolt on. Enjoyed it but rolled into it too much without a tune yet. Sunday nite it spiked at about 28psi and I started feeling power loss. I limped about one more mile with a shit storm of black smoke behind me before it died right at the turn light before the bar where my buddies were at. (I love that I got AAA too btw haha). Pulled the bumper off, loaded up the car & had it towed home.
There was oil all over the engine bay near the left intake runner. Pulled the intake mani & it was full of chocolate milk but I didn't see anywhere in the block where I may have thrown a rod. Then I noticed a huge crack in the mani on the left runner right at the end of the runner which explains all the oil in the bay.
So my conclusion is I just blew the head gasket. I'm going to harbor freight today to pick up a compression tester. Gonna check that out.
Then yesterday after spending all day in a 130* attic (don't work on your car when you're exhausted and sleepy) I got home and rushed to get my car up on jack stands among other stuff I needed to get done before I had to leave at 7. Got the rear up, moved to the front. Evidently started lifting the car up by the fucking radiator bracket. Wheels were about 3-4" off the ground and the bracket snaps, radiator end tank busts open, all the coolant ends up on my driveway. Radiator gets all mangled up from the jack smashing it when the car dropped. So that was my last straw.
After the compression test I'm gonna pull all the parts I won't need & post them up for sale.
Still figuring out the a/r I want to run. I wanna run the redline out to maybe 7200. I'm thinking twin scroll T4 GT35 with .90 or so a/r. 9.5:1 pistons & I plan out boring out .1 l & sleeving it. Something like CP-E's silly $6k+ deal but for a price that I can source out locally for a LOT less.
I'm just in the planning stages now. But I plan on pulling the motor & gathering parts asap. I want to be 100% complete with a solid safe & reliable tune that I can beat the shit out of the car on the track.
Needless to say I'll be on here a lot more frequently. Kick back, relax & help me out thru this journey fellas. The beers on me.
Logan
2007 MS6 - broked & gone
2006 MS6 - less broked
The Following 11 Users Say Thank You to RhoadBlock For This Useful Post:
Chriscote (06-25-2011), Ckmazdaspeed3 (06-16-2011), djuosnteisn (03-21-2012), dougefresh_ (06-17-2011), essejkcamraw (06-16-2011), jracer (06-16-2011), Monotonous ONE (06-16-2011), MPSdriver (06-16-2011), TexasSpeed3 (03-17-2012), triplejumper18 (06-16-2011), zpele (06-27-2011)
 Old 06-16-2011, 07:17 AM   #2
JMEngineer's Avatar
Posts: 2,122   (View Stats)
What the hell did you do to get to a curb weight of 3100lb??
-GTX2867R Coming Soon
 Old 06-16-2011, 11:53 AM   #3
RhoadBlock's Avatar
Gutted the car as much as I could at the time. If it isn't physically necessary to drive I took it out for the most part. But there's a few more things I plan to do. I should be able to get it under 3000 when I'm done.
 Old 06-16-2011, 12:16 PM   #4
Navy_Mech2's Avatar
Posts: 484   (View Stats)
Damn that sucks bad. I used to follow your build thread on SU. You still have the orange rims on the car?
KILLAH BUILT
 Old 06-16-2011, 04:10 PM   #5
essejkcamraw's Avatar
Posts: 922   (View Stats)
holy big hotside batman! .90 on a 35r is huge. is this going in the stock location, or are you thinking top mount setup? i think with a 35r in stock location on the speed6 it is a really tight fit.
From built & Big turbo to Miata Gheys
 Old 06-16-2011, 05:55 PM   #6
RhoadBlock's Avatar
I still have the orange wheels, tho I'm letting a buddy borrow them for the moment since someone stole his HREs.
The turbo isn't going in the stock location. I'm doing a top mount mani, tho I haven't decided if I want to do a custom tubular or just do Leen's for sake of ease. I know you all LOVE Leen's shit right now, but I've always been a firm equal length tubular guy. Plus they look better imo. I haven't made up my mind tho. I'm still in the very early planning stages. Also I'm not 100% on the a/r either. I remember Dustin and others saying a .90 on a TS T3 became a bottle neck. I know T4s are bigger so I may not need quite as high of an a/r. Again, still researching and planning.
 Old 06-17-2011, 10:55 PM   #7
i like leens stuff but, nothing beats a solid tubular set up, plus it just looks good. although a steedspeed mani will be lot easier and likely cheaper to come by than a custom tubular set up.
im lookin forward to seein this come together, always nice to have BT setup guys locally.
 Old 06-18-2011, 05:10 PM   #8
RhoadBlock's Avatar
Originally Posted by glanata View Post
im local to u too... more like 30 to 40 mins away lol im thinking about going bt 3071r, after i get my coilovers lol ur car looks sick! u rubbing at all? im runing 18x9.5 +38 on 225 45 tires, im getting bc coiovers and the adjustable ball joints, i was wondering whats ur camber set at? thanks
I'm damn near positive I told you every aspect of my wheel setup in your wheel thread on 24/7. I rubbed a little bit with my 19x9.5 +25 225/35 & about -2/-4 f/r camber. I did a lot of fender work to make it work tho. Once this build is done I'm picking up some 17x9 RPF1s and probably running 255/40 tires. I'll go with whatever size will yield me the best track time tho. From here on out it's pretty much all out performance.
Thanks sir. Hit me up anytime and we can chill/check out the ride. I may need a ride in your car to keep me motivated to get my MS6 running lol.
Last edited by RhoadBlock; 06-18-2011 at 07:48 PM. Reason: gonna run 255/40s...not 225s
 Old 06-16-2011, 07:50 PM   #9
RhoadBlock's Avatar
I'm going to have my buddy who's amazing at welding aluminum weld that crack shut. I'll be reusing it since it's been ported and polished and I'm not about to do that shit again. Using it until a damn intake mani gets released finally at least.
The Following 2 Users Say Thank You to RhoadBlock For This Useful Post:
dougefresh_ (06-17-2011), MS33SM (06-16-2011)
 Old 06-16-2011, 08:06 PM   #10
theschrum's Avatar
Posts: 1,031   (View Stats)
28psi eh? Are you using the stock BCS or MBC.
08 Speed 3|SOLD
 Old 06-16-2011, 08:49 PM   #11
RhoadBlock's Avatar
It was the damn stocker. I was gonna pick an MBC from a buddy of mine this weekend and get it in there but the motor blew it's load before I could get it in.
 Old 06-16-2011, 08:58 PM   #12
MS33SM's Avatar
Posts: 1,821   (View Stats)
MS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the world
Groans: 132
Groaned at 166 Times in 92 Posts
A SURE TIG and a cracked #1 runner.....i lost count on how many that is.
Can we declare that a dead product yet?
MS33SM is offline   Reply With Quote
 Old 06-17-2011, 10:41 AM   #13
MarkyMark's Avatar
Posts: 1,624   (View Stats)
Groans: 62
lol, nice try!
MarkyMark is offline   Reply With Quote
The Following 3 Users Say Thank You to MarkyMark For This Useful Post:
aaronc7 (06-17-2011), skeeter149 (06-27-2011), themytb (07-13-2011)
 Old 06-18-2011, 05:31 PM   #14
Tech/Sales@EM's Avatar
Posts: 1,173   (View Stats)
Tech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the worldTech/Sales@EM is the leader of the world
Groaned at 28 Times in 11 Posts
Dude thats worse than I originally thought from your texts. Ouch. GL on the build up brosky
Tech/Sales@EM is offline   Reply With Quote
 Old 06-16-2011, 09:08 PM   #15
RhoadBlock's Avatar
This was a PTP one from way back when. I hadn't caught any threads about the cracked runners tho. Guess I hadn't lurked enough. Damn. Thanks for the insight tho. It won't be going back on.
 Old 06-16-2011, 09:11 PM   #16
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
Looks more like the PTP spacer.
Please tell me you didn't have those side bolts in.
The Following User Says Thank You to jmhinkle For This Useful Post:
 Old 06-16-2011, 09:22 PM   #17
RhoadBlock's Avatar
No they didn't fit. I just bolted it back with the 6 bolts facing the block.
Tapatalk stole $2.99 from my build fund.
 Old 06-17-2011, 06:39 AM   #18
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
I'm local to you man. I'll give you a handy for the 3071r lol. I'd like to check out the build sometime, I'm about 30 mins from you.
07 MS3
The original Genpoo Hater
 Old 06-17-2011, 08:32 AM   #19
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
You won't see it 90% of the time either way. Glad you're ditching that jank ass mani bro. 5 bolts to the head tho, not 6. Looking forward to this build man! Choose your wg spring wisely because getting that ewg off on the top mount is a royal pita!
 Old 06-17-2011, 02:10 PM   #20
RhoadBlock's Avatar
Def bro. Once it all starts hit me up & u can come check it out.
5 to the head & 1 more on the bottom near where the EGR mounted at. I used those 6. I'll figure out the wg spring. Maybe I'll have an equal length fabbed up where the wg is easier to access.
The Following User Says Thank You to RhoadBlock For This Useful Post:
 Old 06-17-2011, 07:32 PM   #21
glanata's Avatar
Posts: 23   (View Stats)
glanata is on a distinguished road
2007 black mica mazdaspeed 6 gt, cobb sri, corksport tip, altered customs ic piping, cx racing ic core 29x9x3, hks bov ssq3, m2 performnace catless dp, 3 inch single exhaust , cobb ap stage 2,itv's 22, xxr 522 chrominum black wheels 18x9.5 +38 offset, tein stechs....bc coilovers coming soon
glanata is offline   Reply With Quote
 Old 06-18-2011, 07:47 PM   #22
RhoadBlock's Avatar
Yeah I know, but it could have been a lot worse. The block seems to still be good. I went to do the compression test today but the kit I picked up is a gay one. I got a cylinder leak kit, figuring it'd do the same thing, but I need an actual compression test kit. I'll be picking one up either tomorrow or Monday. Will report those numbers and then start pulling all my parts and posting them up for sale, and getting the head ready for work, then start on pulling the block. Depressed and excited at the same time.
 Old 06-20-2011, 08:18 PM   #23
RhoadBlock's Avatar
Did the compression test tonight.
Cylinder #1: 168 psi
#2: 205 psi
#3: 0 psi
#4 252 psi
Soooooo, yeah. Crazy variation and cylinder 3 is definitely frigged. A buddy of mine thinks I probably spun the rod bearing. I've already got the DP, exhaust, intake mani, and intake stuff pulled. Tomorrow I'll pull the exhaust mani and turbo and try to get it all posted up for sale. Then I'll start pulling everything off so I can pull the block, see the damage and start getting it all worked on. I'll slowly be pulling other things to post up for sale: things I'm replacing/upgrading/removing, etc. Eventually I'll have the ACT race clutch/flywheel, probably the TWM stuff, Standback, etc. If anyone is interested in anything else (stock parts, or mods) PM me. I'll let you know if/when I'm yanking it.
Stay tuned.
_______________
dougefresh_ (06-20-2011), essejkcamraw (06-20-2011)
 Old 06-20-2011, 11:49 PM   #24
man that sucks to hear, good luck with everything man, hopefully you get this thing going.
oh and BTW, if your intake mani is ported, id be very interested in it
 Old 06-25-2011, 12:09 AM   #25
RhoadBlock's Avatar
Got most of the bolt-on/accessory pieces off the car tonight. Just the little stuff left before I'm able to get the block pulled. Searching around local machine shops that are known for good head work and block boring. If anyone has had any good experiences or knows of any legit shops in the Tampa area let me know. Once I source out a good shop I'm gonna have them start on port/polishing the head and boring the block.
I'll try to have FS pics of all the stuff I'm selling. The FMIC is pretty much accounted for. I think the DNP mani is too. Other than that I'll have an MS3 Xcel Nano, Nviscid for big turbos, GT3071 IWG bolt on, Catless 3" CP-E DP & My custom cat back. Also got the factory seats, seatbelt tensioners, airbags never deployed, etc.
Please don't clutter up this thread with dibs or asking for prices, what parts I'm selling, will I sell this or that or whatever. Send me a PM or wait until the FS thread shows up in the FS section.
dougefresh_ (06-25-2011), jracer (06-25-2011)
 Old 06-25-2011, 06:24 AM   #26
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
Clearwater cylinder head did my work . Good prices, and a guy there ports speed3/6 heads
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 06-25-2011, 11:34 AM   #27
steedspeed's Avatar
Posts: 582   (View Stats)
steedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the world
Car looks hot! Shame you blew the pistons but sometimes it's nice to know that you have no choice but to go big with a built motor.
steedspeed is offline   Reply With Quote
 Old 06-25-2011, 12:36 PM   #28
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
Yeah, if you have the money! There are some people on here like spnkr who are screwed when stuff breaks.
Luckily my turbo hasn't died or something else lame like that. I'm still planning on getting your manifold...one of these damn days!!!
2007 CTS-V - Trying to sell
 Old 06-25-2011, 12:26 PM   #29
Axle Breaker
jmhinkle's Avatar
Groans: 162
Not true. No one has blown from big power yet. He didn't have any kind of tune on this car. Says so in first post. Plenty of us running big power and big psi on stock motors now.
The Following 4 Users Say Thank You to jmhinkle For This Useful Post:
Alpha (06-28-2011), Chriscote (07-08-2011), EdgeAutosport.com (03-21-2012), rfinkle2 (06-28-2011)
 Old 06-27-2011, 04:43 PM   #30
RhoadBlock's Avatar
Got most everything pulled off the block. Now I just need a buddy to come over and give me a hand unbolting the tranny and removing the block. He's gonna let me borrow his crane. He lives 5 minutes from me but lining up our work schedules is such a pita.
Got a big part out sale up in the F/S engine section.
 Old 06-28-2011, 07:34 AM   #31
jracer's Avatar
Groans: 89
remove the tranny and the engine as one...
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 06-28-2011, 07:36 AM   #32
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
Yes.
Beanfab / Tuned by Nishan
The Following User Says Thank You to doubleflusher For This Useful Post:
jracer (06-28-2011)
 Old 06-27-2011, 04:55 PM   #33
m4tic's Avatar
Posts: 4,928   (View Stats)
you made sure theres no hole behind #3 right?
sorry to hear... but how much for the gt30?
wait i found it
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 06-27-2011, 06:44 PM   #34
RhoadBlock's Avatar
No hole. My buddy is pretty sure I just spun a rod bearing. I'm hoping he's right. But I won't know until I get the block pulled and opened up. Hoping to get that done by this weekend, if not in the next few days.
 Old 06-28-2011, 07:49 AM   #35
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
EXTREME PSI : Your #1 Source for In Stock Performance Parts this shits on that 35R
NATOR PA
 Old 06-28-2011, 11:07 AM   #36
RhoadBlock's Avatar
Yeah idk wtf I was talking about. I'm definitely gonna do it that way since I gotta pull out my clutch & flywheel anyway.
 Old 06-28-2011, 12:50 PM   #37
RhoadBlock's Avatar
I've been debating between BW & ATP. My buddy has a solid discount thru ATP tho so I can probably get a TS GT35 or 40 for half the price. That kinda speaks a lot.
dougefresh_ (06-28-2011)
 Old 07-07-2011, 09:31 PM   #38
RhoadBlock's Avatar
Did some serious work tonight. Stephan came over and gave me a hand pulling the motor out tonight. The garage is a mess. Motor, tranny & differential pulled. Tranny and diff pulled off. Tranny is full of grease and gunk. Clutch & flywheel pulled off. I thought I had a 6 puck sprung hub. Turns out I had an unsprung hub. Pretty shitty for daily driving. After maybe 10-12k miles the clutch is shot. As it turns out, race clutches aren't meant to last lots of miles and be daily driven on the street.
After that we pulled the valve cover. Everything looked just fine. Decided to pull the oil pan before we called it a night. BTW, I fucking LOVE my F2 oil pan baffle!!!! I may be lucky as hell after seeing the beginning of the damage. Granted I won't know until tomorrow for sure when I pull the head off, but my fingers are crossed. The verdict: blown rod #3. The oil pan baffle took all the brunt of the force of the thrown rod. From what I can see there is no damage to the oil pan. Or the block for that matter. The rod shattered, and the only damage I can see is on this piece here bolted to the bottom of the block around the rods.
I may still be able to use my stock block and head. Cross your fingers for me guys. Once I get the head pulled and everything removed from the head and block, I'll start sourcing out companies to bore and sleeve the block for me. I think I found 2 that look pretty good. As long as the block looks good, the foundation work will begin asap. I'll post up with some more pics tomorrow. For now, the couple I could get tonight.
I guess this explains the zero compression is cylinder 3. We'll see how the cylinder walls look and if the piston was damaged too. Pics tomorrow.
The Following 7 Users Say Thank You to RhoadBlock For This Useful Post:
Chriscote (07-08-2011), djuosnteisn (03-21-2012), doubleflusher (07-08-2011), dougefresh_ (07-07-2011), essejkcamraw (07-08-2011), galens47 (03-05-2014), Monotonous ONE (07-08-2011)
 Old 07-07-2011, 09:41 PM   #39
Glad to see you're making good progress bro. Keep up the good work, and thanks for all the pics!
 Old 07-08-2011, 10:08 AM   #40
RhoadBlock's Avatar
Also, the shot to shit clutch. the friction plate had grooves in it from where it was worn down to the rings. So this is what you can expect from an ACT race clutch/fly kit. I ordered a 6 puck sprung hub, but it was definitely unsprung as you can see. And it was completely toast after 10k miles.
The Following 3 Users Say Thank You to RhoadBlock For This Useful Post:
doubleflusher (07-08-2011), mason (07-08-2011), Monotonous ONE (07-08-2011)
Toyota Highlander production commences in Indiana Haltech Automotive News 0 10-10-2009 12:10 PM
Finally got some proof...the Forge BPV really does help build a bit more boost. Smokehouse MazdaSpeed 3/6 - Turbo Induction 45 05-14-2009 09:47 AM
Theory: Build before Build demonspeed MazdaSpeed 6 - Engine, Transmission & Driveline 5 02-10-2009 06:52 PM
Page generated in 0.64700 seconds with 37 queries
