Like Tree10Likes
 Old 11-10-2010, 11:58 PM   #81
mtnrunner's Avatar
Posts: 864   (View Stats)
mtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the world
forgot to ask earlier, what do you mean when you say your exhaust is grounding out?
Murdered out 2007 speed3 GT with navi.
mtnrunner is offline   Reply With Quote
The Following User Says Thank You to mtnrunner For This Useful Post:
rigor (11-11-2010)
 Old 11-10-2010, 11:59 PM   #82
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
can you due a test to see which spring it has?
or is it by color only
at 104000 2 bent rods
tuned by nishan
 Old 11-11-2010, 12:04 AM   #83
rigor's Avatar
Groans: 40
the exhaust is hitting the body some were( mtnrunner)
tuned by nishan
 Old 11-11-2010, 12:05 AM   #84
jwilkins88's Avatar
Posts: 3,675   (View Stats)
Groans: 126
I think it's by color, but if you take the vacuum line that's running to your boost gauge, and run it to your wastegate, check your boost with the dashhawk, you should be able to tell.
If you still boost 22 psi, it's your spring
The Following User Says Thank You to jwilkins88 For This Useful Post:
rigor (11-11-2010)
 Old 11-11-2010, 12:08 AM   #85
mtnrunner's Avatar
i just searched the info and it looks like by color only.
TiAL Sport.com
i wasnt sure exactly which wastegate you have so i figured to just link the technical page for tial. click on the spring pressure for the wastegate you have and it will tell you what springs create what boost. again all i can see is that its only based on color.
its like jwilkins and i are in a race, haha.
Last edited by mtnrunner; 11-11-2010 at 12:08 AM. Reason: MSF Database - Automerged Doublepost
rigor (11-11-2010)
 Old 11-11-2010, 12:11 AM   #86
rigor's Avatar
Groans: 40
ahh might rock 22 psi
tuned by nishan
The Following User Says Thank You to rigor For This Useful Post:
djuosnteisn (11-11-2010)
 Old 11-11-2010, 12:13 AM   #87
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
yo video...before i go to bed...make it happen
rigor (11-11-2010)
 Old 11-11-2010, 12:15 AM   #88
rigor's Avatar
Groans: 40
couple more min
tuned by nishan
 Old 11-11-2010, 12:23 AM   #89
rigor's Avatar
Groans: 40
here you go, i went about half throttle maybe 3/4, it was the 2nd drive so wasn't sure what to expect
if i could learn to shut my mouth, while recording lol
tuned by nishan
Last edited by rigor; 11-11-2010 at 12:23 AM. Reason: MSF Database - Automerged Doublepost
The Following 9 Users Say Thank You to rigor For This Useful Post:
djuosnteisn (11-11-2010), jracer (11-11-2010), jwilkins88 (11-11-2010), madvillain (11-11-2010), MS3-a(sore)ASS-rex (11-18-2010), NJSPEED3 (11-12-2010), rodrigo (11-11-2010), turd burglar (11-11-2010), zx2man (11-11-2010)
 Old 11-11-2010, 12:26 AM   #90
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
"looks a lil lean?"
niggah floor it!!!! shits gonna look pig rich cruisin!!!!
hahahah nervous huh??? im o be shittin bricks when i get mine running.... praying to baby jesus i dont go VTA block
car sounds like pure sex though +1+1+1+1
The Following 6 Users Say Thank You to rodrigo For This Useful Post:
3mazdaspeed (11-13-2010), djuosnteisn (11-11-2010), jracer (11-11-2010), jwilkins88 (11-11-2010), NJSPEED3 (11-12-2010), rigor (11-11-2010)
 Old 11-11-2010, 12:32 AM   #91
rigor's Avatar
Groans: 40
i was hoping nothing would hit the ground, ill do a better one later
rofl^^^
tuned by nishan
zx2man (11-11-2010)
 Old 11-11-2010, 09:40 AM   #92
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
This thread is pure win.
Justin, to play it safe, order a smaller spring from tial, and swap it out. It's the only way to be certain IMO, and doesn't cost much at all.
Also, you need to do a full pressure check on the entire intake track and listen for boost leaks. For all you know, you have a leak on your WG line and that's why it's not opening up.
I know you got it all 99% done, but don't get lazy now. Would be a shame to see all this hard work end in tears.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
jracer (11-11-2010), jwilkins88 (11-11-2010), NJSPEED3 (11-12-2010), rigor (11-11-2010), Snappy (09-18-2015)
 Old 11-11-2010, 09:45 AM   #93
Captain
i think i used some tiny shit (green)one size down from 3/32 and it was to small and for some reason the green does not work as good as the orange so ill go p/u some 3/32 seemed to work great and im running 100% argon.
worked good with my dumb ass @ the helm lol
Green is pure tungsten. I prefer it for aluminum cause it balls up nicely on the tip and gives you a nice broad arc with high frequency. Don't use this electrode on steel, you'll get arc blow (hard to control arc). And 3/32 is actually the better size for aluminum cause shit gets hot, but i guess 1/16 may work okay.
Orange is 2% ceriated tungsten. It's good for steel, but i think 2% lanthiated is better (yellow). It seems to hold up to the heat best out of all, but for the small stuff we do, ceriated works fine.
well im whore out, i went out on a crew today, and they worked my ass off!!
This quote just doesn't sound right man.... lol.
www.permtuning.com
 Old 11-11-2010, 06:59 PM   #94
rigor's Avatar
Groans: 40
it is a 22-23 psi spring tested her out today yo!!
here is a data log
and i rolled into it real easy, but the boost comes on right now!! that is one bad ass turbo!
you think ill scatter it @ 22-24?
old tune is still a little fat, but this is 3rd mind you, i didn't want to load it that hard, if it was lean! and i think the kr is the exhaust hitting the tub.
it scared the fuck out of me on the way home, spun them in 4th @ about half throttle, on a pass, on dry pavement! had to back out of it !! ya!
haha
cagey, your nuts! this thing is ridiculous!
you may want to consult a dr about your power obsession, you to dj
cams gtfo!
tuned by nishan
The Following 5 Users Say Thank You to rigor For This Useful Post:
djuosnteisn (11-12-2010), jracer (11-12-2010), jwilkins88 (11-11-2010), madvillain (11-11-2010), NJSPEED3 (11-12-2010)
 Old 11-11-2010, 07:15 PM   #95
rigor's Avatar
Groans: 40
ya i agree with you dj the small shit just melts, im going back to the bigger3/32,, actually i tried the small stuff and it wouldn't work, so i went back to the bigger stuff
and ill do a pressure check! this weekend!!
dude it runs awesome!!
tuned by nishan
 Old 11-11-2010, 07:46 PM   #96
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
Fuck man it looks awesome. Love what you did with the IC core. Great to see it running
I wish I could have gotten my shit done this fast. Started in April and STILL not done. Have to drive 200 miles if I even want to touch the car.
rigor (11-11-2010)
 Old 11-11-2010, 07:57 PM   #97
rigor's Avatar
Groans: 40
2 weeks 4 days yo! and i made most of my junk and lenny if that bov goodie is hoggin up some power!, it can have it !!
the mtr spins up so free, compared to before, i don't think i have any restrictions or turbulence
tuned by nishan
The Following 4 Users Say Thank You to rigor For This Useful Post:
 Old 11-11-2010, 08:52 PM   #98
meeker13's Avatar
Posts: 282   (View Stats)
meeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the worldmeeker13 is the leader of the world
I like the fact u went with the water cooled tial gate! I might have to upgrade eventually, let me know how it works! And again...very nice setup! I wish someone in my neck of the woods had a BT speed 3/6. I'm all alone here in CO.
GT28_COBB AP_COBB SFI_ETS IC_DNP MANI_TIAL 44MM EWG_CP-E INLET_CP-E DP_CP-E 3'' CB_TURBOSMART EBOOST2 EBC_OEM BPV_SURE DREDNAUGHT_KONIG ZERO'S_EIBACH SL SPRINGS
meeker13 is offline   Reply With Quote
The Following 2 Users Say Thank You to meeker13 For This Useful Post:
jwilkins88 (11-11-2010), rigor (11-11-2010)
 Old 11-11-2010, 09:08 PM   #99
rigor's Avatar
Groans: 40
their a couple speeds here, but their all tiny turbo
tuned by nishan
 Old 11-11-2010, 09:34 PM   #100
turd burglar's Avatar
Posts: 1,895   (View Stats)
Groans: 39
soon my friend, soon... like 4 months lol
NO! No way am I havin a dick made outta hamburger!
stocking out, buy my big turbo shit here, http://www.mazdaspeedforum.org/forum/forum/f229/bye-bye-big-turbo-dreams-82241/ more to come as stock shit arrives
The Following 2 Users Say Thank You to turd burglar For This Useful Post:
jwilkins88 (11-12-2010), rigor (11-11-2010)
 Old 11-11-2010, 09:37 PM   #101
meeker13's Avatar
Yea there's a shit load of speed3's here but no BT's as far as I know.
I'd really like to run another BT speed6 or even a ms3.
The Following 3 Users Say Thank You to meeker13 For This Useful Post:
djuosnteisn (11-12-2010), jwilkins88 (11-12-2010), rigor (11-11-2010)
 Old 11-11-2010, 09:39 PM   #102
madvillain's Avatar
Groans: 78
I don't get the point of a water cooled wastegate? Anyone care to try to push some sense into my head?
The Following 2 Users Say Thank You to madvillain For This Useful Post:
 Old 11-11-2010, 09:55 PM   #103
Groans: 39
its neat, and i guess it just gives less chance for things to expand too much and crack? no clue really
 Old 11-11-2010, 10:16 PM   #104
rigor's Avatar
Groans: 40
keeps the thing cool i guess, its processing 1500 deg gas so it gets hot!
tuned by nishan
 Old 11-11-2010, 10:22 PM   #105
rigor's Avatar
Groans: 40
turd you should go with the .5557, you won't be disappointed.
it is crazy and it spools fast! it is better in all aspects imho
tuned by nishan
 Old 11-11-2010, 10:31 PM   #106
zx2man's Avatar
Posts: 1,356   (View Stats)
zx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the worldzx2man is the leader of the world
I do believe that is Creed's plan..its just matter of money and time for that overworked bastard.
Just carious at what rpm are you seeing full spool rigor? I was thinking around 20 psi on 2.3 litler motor a 5557 .63 ar should see full spool around by 3800 rpm.
Are you gonna keep boost in the 20's are dial her down to 17 like you originaly figured you would run?
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
JBARONE SHIFTERPLATE
COBB RSB
KONIG WHEELS/HANKOOK TIRES
TIM BAILEY PROTUNE 291WHP/310WTQ *AWD MUSTANG DYNO*
zx2man is offline   Reply With Quote
The Following User Says Thank You to zx2man For This Useful Post:
rigor (11-11-2010)
 Old 11-11-2010, 10:43 PM   #107
rigor's Avatar
Groans: 40
it seems fine! but i don't know,
it pulls so hard, it kinda scares me! that it might shit a rod, but i don't know.
im sure it will spool a lil earlier than that, and i was so concerned about lag, but its way better all around cause, i pull a mtn and it builds a lil boost to pull the hill, and it still does with np.
and pulls better in first too, a lot smoother, 1/4 throttle in first, is better than wot with stocker haha
tuned by nishan
 Old 11-11-2010, 11:01 PM   #108
mtnrunner's Avatar
have you tried messing with the wastegate lines at all to see if it changes your boost?
 Old 11-11-2010, 11:02 PM   #109
rigor's Avatar
Groans: 40
no they worked me like a dog today
tuned by nishan
 Old 11-12-2010, 12:32 AM   #110
jwilkins88's Avatar
Groans: 126
Drive to STL... I'll run ya
The Following 2 Users Say Thank You to jwilkins88 For This Useful Post:
meeker13 (11-12-2010), rigor (11-12-2010)
 Old 11-12-2010, 01:20 AM   #111
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
Glad ya got it running !! Looks like it's a blast to drive ! I want BT !!
Congrats....
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
The Following User Says Thank You to jracer For This Useful Post:
rigor (11-12-2010)
 Old 11-12-2010, 07:07 AM   #112
madvillain's Avatar
Groans: 78
yeah with no tune at all I'm spooling by 3800 or so. Its much faster than I expected. Still though, if it's hitting 5psi in the early 3k's that is still more than enough to get you going. 5psi is still pretty significant, its not like the stock turbo.
it just doesn't feel completely dead before spool, thats all I'm saying. Mid-throttle is a hell of a lot more responsive than the stock turbo.
jwilkins88 (11-12-2010), rigor (11-12-2010)
 Old 11-12-2010, 07:17 AM   #113
rigor's Avatar
Groans: 40
i figured out what happened, i ordered a 1.6 bar not 16psi. so that is why im going over boost 23.20 is their target, so it is right on! crap im an idiot!
i think you could choose between psi or bar while ordering, just to make it confusing haha
tuned by nishan
djuosnteisn (11-12-2010), jwilkins88 (11-12-2010), mtnrunner (11-12-2010), rodrigo (11-12-2010)
 Old 11-12-2010, 07:32 AM   #114
meeker13's Avatar
Maybe next summer...! But then again thats a long way to travel to get my ass kicked
 Old 11-12-2010, 07:47 AM   #115
jwilkins88's Avatar
Groans: 126
I doubt you'd get your ass kicked. I think it'd be a really good race. You, rigor, and madvillain have sexier setups than I do anyway.
rigor (11-12-2010)
 Old 11-12-2010, 08:30 AM   #116
Captain
I'll be down to race in about a month
www.permtuning.com
jwilkins88 (11-12-2010), meeker13 (11-14-2010), rigor (11-12-2010)
 Old 11-12-2010, 08:46 AM   #117
jwilkins88's Avatar
Groans: 126
Haha... I don't think there's going to be a Mazdaspeed in existence that will be able to beat you in about a month. Your shit is ridiculous, son
djuosnteisn (11-12-2010), rigor (11-12-2010)
 Old 11-12-2010, 11:27 AM   #118
mtnrunner's Avatar
rigor, we should race as i am a pretty well modded stock turbo and you have the same mods but a sick ass turbo. we could show everyone how much of a difference the turbo actually makes. haha, i never mind loosing to cars that are cooler than mine anyways.
The Following 5 Users Say Thank You to mtnrunner For This Useful Post:
jwilkins88 (11-12-2010), meeker13 (11-14-2010), rigor (11-12-2010), rodrigo (11-12-2010), turd burglar (11-12-2010)
 Old 11-12-2010, 04:42 PM   #119
jracer's Avatar
Groans: 89
more videos please.. and fucking floooor it !!!
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
The Following 2 Users Say Thank You to jracer For This Useful Post:
mtnrunner (11-12-2010), rigor (11-12-2010)
 Old 11-12-2010, 04:54 PM   #120
essejkcamraw's Avatar
Posts: 922   (View Stats)
dustin, you can tune me and ill come race
GTK-450 turbo build matgod MazdaSpeed 3/6 - Big Turbo Builds 18 09-09-2013 08:00 PM
Big turbo kit, build one or not? ptperformance Mazdaspeed3/6 General Discussion 33 10-12-2008 02:55 PM
Page generated in 0.57957 seconds with 31 queries
