Like Tree63Likes
 Old 12-04-2013, 10:44 AM   #1
sl33py24's Avatar
Posts: 677   (View Stats)
sl33py24 is the leader of the worldsl33py24 is the leader of the worldsl33py24 is the leader of the worldsl33py24 is the leader of the worldsl33py24 is the leader of the worldsl33py24 is the leader of the worldsl33py24 is the leader of the worldsl33py24 is the leader of the worldsl33py24 is the leader of the worldsl33py24 is the leader of the worldsl33py24 is the leader of the world
Default Sl33py big turbo Diary
Well I bought a big turbo built gen1 from @mason; ..we'll begin where he left off so hopefully soon I can start updating everyone on how things are going. Right now at this moment we're trying to get the maf Cal dialed in then the tuning starts. its pushing 344 horsepower and 394 foot pounds of torque.
MKT.COM/IRONSTONE-VAPES
BEST VAPES BEST PRICES
sl33py24 is offline   Reply With Quote
The Following User Says Thank You to sl33py24 For This Useful Post:
bstover17 (01-19-2014)
 Old 12-04-2013, 11:05 AM   #2
Have you found the solution to the surging issues that Mason was having?
Micha (12-04-2013)
 Old 12-04-2013, 11:09 AM   #3
sl33py24's Avatar
It was the maf cal now that's more dialed in then what he had its almost gone... still get the surging when I let off the throttle at mid boost but I think it's the waste gates
2morrow I will be getting another maf cal revision and working one some of the kinks before the tuning starts... its set at 20 psi hoping to push it to 25 psi well see how it goes
Last edited by sl33py24; 12-04-2013 at 11:09 AM. Reason: MSF Database - Automerged Doublepost
 Old 12-04-2013, 11:09 AM   #4
What were your ltft's before and after?
And be careful you'll quickly approach the limits of the stock engine. Be prepared for a build if you want to get the full power out of your setup.
Koke382 (12-04-2013)
 Old 12-04-2013, 11:13 AM   #5
sl33py24's Avatar
They were all over the place... The maf could not read any of the incoming air whatsoever correctly
I was getting 12 to 15 mpg before now at 21 to 23 mpg
A soon as tax time starts I'm going to go build motor
Last edited by sl33py24; 12-04-2013 at 11:13 AM. Reason: MSF Database - Automerged Doublepost
 Old 12-04-2013, 11:21 AM   #6
Koke382's Avatar
Posts: 4,361   (View Stats)
Did u check compression yet? How about popping dipstick issue at that low of boost?
sent from my peepee
2007 Mazdaspeed 3 GT
18x8.75 XXR 527 225/40/18r
New fucken miata build:
1993 Red Na6
Some suspension modz yo
Coilovers// Other shit
 Old 12-04-2013, 11:22 AM   #7
sl33py24's Avatar
No 2morrow we will and fix that dip stick issue.... u coming over 2morrow koke
 Old 12-04-2013, 11:25 AM   #8
Koke382's Avatar
I think I might actually go and help out if my gf goes to visit her mom at the hospital. Ill let u guys know asap.
sent from my peepee
1993 Red Na6
 Old 12-04-2013, 11:26 AM   #9
sl33py24's Avatar
OK cool bring a compression tester lol and I hope your mother in law does better bro
Koke382 likes this.
 Old 12-04-2013, 11:34 AM   #10
lilred's Avatar
Posts: 5,792   (View Stats)
Bored at work is see haha
tapafuck
Koke382 likes this.
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
sl33py24 (12-04-2013)
 Old 12-04-2013, 11:35 AM   #11
sl33py24's Avatar
Aways
Koke382 likes this.
 Old 12-05-2013, 05:24 PM   #12
mason's Avatar
Posts: 946   (View Stats)
AWESOME push this mother fucker!!!!!!
 Old 12-05-2013, 05:25 PM   #13
sl33py24's Avatar
Always getting some work done tonight I'll update 2morrow
 Old 12-05-2013, 05:28 PM   #14
mason's Avatar
ohhhhhhhh great........... nice cal!!!!!
 Old 01-18-2014, 12:43 PM   #15
sl33py24's Avatar
Well the stock motor didn't last too long running 28psi now real build thread will start once I get a new block and crank uploadfromtaptalk1390074190097.jpg
nattun likes this.
 Old 01-18-2014, 01:18 PM   #16
Koke382's Avatar
I told u bro. Popping dipsticks was the first indicator that your motor was gonna gom should of checked compression from the get go. Good luck on your build. Hope u have it up and running soon.
sent from my peepee
1993 Red Na6
calizoomzoom (01-19-2014)
 Old 01-18-2014, 01:23 PM   #17
sl33py24's Avatar
Got about 3k to 4 k for rebuild once it's done it's gonna be a beast
 Old 01-18-2014, 02:18 PM   #18
Koke382's Avatar
3 to 4k? Doesn't randy charge 1300 to take motor out amd them 1300 to put motor in?
Machine work is like 1200 to 1500
Pistons and rods should be like 800 to 1200 for both and then how much does he charge for labor?
sent from my peepee
Also is he done with hoods car? How long has that been?
Did u check logs? How was your car running before it blew? Did u also spray meth? Were u tunned for it? Cuz u need a tune to spray that much meth. If u were tunned maybe having it turnned off wasn't a good idea
sent from my peepee
1993 Red Na6
Last edited by Koke382; 01-18-2014 at 02:18 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-18-2014, 02:23 PM   #19
sl33py24's Avatar
It was already had a light knocking sound and tuned for meth. It was just a ticking time bomb . .... I'm taking the motor out and my cuz own a machine shop in El monte to do the rebuild since randy isn't coming back until march
 Old 01-18-2014, 02:25 PM   #20
Koke382's Avatar
Then maybe you shouldn't have had randy tunning it if it was making knocking sounds bro. Especially piping dipstick and shit like that. Well maybe your car will be build faster then if randy was doing it.
sent from my peepee
1993 Red Na6
The Following 2 Users Say Thank You to Koke382 For This Useful Post:
Little John (01-19-2014), Micha (01-19-2014)
 Old 01-18-2014, 02:28 PM   #21
sl33py24's Avatar
It was making weird noise when I bought it.. I just finished it off
 Old 01-18-2014, 02:44 PM   #22
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
You should of left it on low boost til the problems were fixed or you built your motor. :-\
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 01-18-2014, 02:50 PM   #23
sl33py24's Avatar
Had to give the wife the push to say yes
The Following 2 Users Say Thank You to sl33py24 For This Useful Post:
ItsNox (01-19-2014), lilred (01-18-2014)
 Old 01-18-2014, 05:15 PM   #24
lilred's Avatar
Lol. But babe now I HAVE to build the motor....
tapafuck
sl33py24 likes this.
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
ItsNox (01-19-2014), sl33py24 (01-18-2014)
 Old 01-19-2014, 08:20 AM   #25
Micha's Avatar
Posts: 3,436   (View Stats)
LOL@Having Randy tune your car. When will people listen? That guy can pull a motor and fix it, can't tune in ATR worth a shit. And he won't even put all your parts back on when you pay him to do it.
Just ask @Little John;
Koke382 and LumberJack like this.
I am slow again.
I modded it a little.
The Following 4 Users Say Thank You to Micha For This Useful Post:
happykat (01-19-2014), Koke382 (01-19-2014), Little John (01-19-2014), LumberJack (01-19-2014)
 Old 01-19-2014, 08:25 AM   #26
Koke382's Avatar
Some people just worship him too much. I get shit talked for telling it like it is. But some people will learn the hard way.
sent from my peepee
LumberJack likes this.
1993 Red Na6
 Old 01-19-2014, 11:31 AM   #27
sl33py24's Avatar
I honestly can say anything bad about Randy he's helped me out so much with all the problems I've had with both cars. His tune on my first speed was a great smashin on people on a fucking maf cal. And this new speed it was my fault racing this s*** out of it when I knew I shouldn't have because that motor wasn't going to be able to handle that kind of power nothing to do with the tune. He told me not to race it and baby it
 Old 01-19-2014, 11:39 AM   #28
Micha's Avatar
Dude, I am being completely honest when I say that he is not a good tuner by any means.
He couldn't do a MAF CAL on johns car after he fixed it and couldn't figure out why. We figured it out when John got the car back.
But good luck with your car honestly.
I am slow again.
The Following 3 Users Say Thank You to Micha For This Useful Post:
bstover17 (01-19-2014), Little John (01-19-2014), LumberJack (01-19-2014)
 Old 01-19-2014, 11:50 AM   #29
Little John's Avatar
Posts: 494   (View Stats)
Little John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the worldLittle John is the leader of the world
Groans: 55
For real Randy didn't put on the most basic of parts on my car when I paid him to do so. Then I have to spend an extra um hour while he fucked up map after map. I installed my parts correctly flashed my map from my legit tuner and gussed what happen, the fucking car ran prefect. You should have never bought that car. WASTE OFF MONEY.
Little John is offline   Reply With Quote
The Following 3 Users Say Thank You to Little John For This Useful Post:
LumberJack (01-19-2014), Micha (01-19-2014), Sterling (01-19-2014)
 Old 01-19-2014, 11:58 AM   #30
krazycoble's Avatar
Posts: 662   (View Stats)
krazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the worldkrazycoble is the leader of the world
Koke382 and Little John like this.
Stratified Tuned 2011 MS3 | 410 HP - 402 TQ | Dynojet 10-21-12
krazycoble is offline   Reply With Quote
The Following 7 Users Say Thank You to krazycoble For This Useful Post:
Boosted Beluga (01-19-2014), bstover17 (01-19-2014), calizoomzoom (01-19-2014), Koke382 (01-19-2014), Little John (01-19-2014), Micha (01-19-2014), Sterling (01-19-2014)
 Old 01-19-2014, 11:59 AM   #31
Koke382's Avatar
Same heree he gave up on my tume cuz he couldn't get my fueling right. I kepy getting fuel cut and my AFR was all over tue place. He blamed it on my intake. After I got tunned by someone else all my issues went away
sent from my peepee
1993 Red Na6
The Following 4 Users Say Thank You to Koke382 For This Useful Post:
Elwood617 (01-19-2014), Little John (01-19-2014), Micha (01-19-2014), Sterling (01-19-2014)
 Old 01-19-2014, 12:30 PM   #32
Elwood617's Avatar
Posts: 541   (View Stats)
Elwood617 is the leader of the worldElwood617 is the leader of the worldElwood617 is the leader of the worldElwood617 is the leader of the worldElwood617 is the leader of the worldElwood617 is the leader of the worldElwood617 is the leader of the worldElwood617 is the leader of the worldElwood617 is the leader of the worldElwood617 is the leader of the worldElwood617 is the leader of the world
Just throwing this out there, just had a guy on another site ignore good advice about a sub par tuner. He spun a bearing in his car, due to the shoddy tune. The guy didn't listen to others experience, and kept telling us what a good guy the tuner is.
Sent from my MB886 using Tapatalk
Koke382 likes this.
It's all about the PMA
Elwood617 is offline   Reply With Quote
The Following 3 Users Say Thank You to Elwood617 For This Useful Post:
 Old 01-19-2014, 03:42 PM   #33
Koke382's Avatar
Also I know u guys ran and told randy shit already its all good keep acting like kids. Not the first time am I right? @Micha;
Proven tuners know their shit and have tunned numerous cars. Some of u have huge egos and are fan boys and need to just learn for yourselves and make your own opinions because no one will back u up whem ur shit blows. In the end its your pockets getting fucked not your tunners.
This isnt shit talking. This is giving advice and stating facts. Yes facts because will 2as warned by numerous nator members not to buy the car and also to check the compression.
sent from my peepee
Micha likes this.
1993 Red Na6
Elwood617 (01-19-2014), Micha (01-19-2014)
 Old 01-19-2014, 03:56 PM   #34
Wow, not to be an ass but I saw this coming. The engine wasn't built and has a 3582. So you decided to turn up the boost? Even if the engine was having issues you shouldn't have driven on it. To be honest I'm completely surprised you haven't already been grilled. Had you parked the car earlier you would be able to build just by popping in new rods and pistons. Now you have to get a new crank and block. How do you know you didn't send any shrapnel into the head?
It actually does bother me that all you had to say was this is how you had to convince your wife. Is it really that hard to sit her down and tell her that the car will explode if you continue driving? Most women are pretty easy to reason with when you tell them that the smart route is the one that will save enough money to go on a small vacation.
As for the tuner I don't know who this guy is but any smart tuner would realize you're on the stock block and a turbo this big would blow your shit faster than a coke hooker on charlie sheen.
Koke382 and ItsNox like this.
The Following 4 Users Say Thank You to Mazdazilla6 For This Useful Post:
ItsNox (01-20-2014), Koke382 (01-19-2014), Little John (01-19-2014), Sterling (01-19-2014)
 Old 01-19-2014, 04:01 PM   #35
sl33py24's Avatar
I have the block and crank and head ready just need pistons and rods..... my wife knew it was gonna blow sometime soon. This just made it easier. She's excited to see what it can do with a built motor
That stock handled 30 psi for 5k miles driving it hard on cheap autolite spark plugs. Now it's time for some real power ....
Last edited by sl33py24; 01-19-2014 at 04:01 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say NO Thank You to sl33py24 For This Un-useful Post:
 Old 01-19-2014, 04:21 PM   #36
LumberJack's Avatar
Hated to see this coming, but plenty of people have warned about Randy's tunes, my little sister could make the same changes in ATR and would have the same results, a fucking noob can do a MAF cal better than he can. When Josh and I saw Travis' timing tables, Josh and I put him on a map we had to get his car home safely without it blowing up. A timing table should NEVER EVER LOOK LIKE A ROLLER COASTER, Travis' timing was unbelievably bad. Randy can pull a motor and build a motor, but please do yourself a favor and get a REAL TUNER.
Not to mention, John paid the man for something and got less than what he paid for which is completely unacceptable in every sense of the meaning.
GL on your build man, hopefully you'll get the right parts to make big power, and by right parts I don't mean Std Manley H-beams, and OTS wiseco pistons. Get head studs and not ARP and if you think you're gonna make big power it's going to take a lot of Aux fueling and a good intake manifold... Best of luck to you
Koke382 likes this.
10.36@148 Fastest Gen 2
The Following 3 Users Say Thank You to LumberJack For This Useful Post:
ItsNox (01-20-2014), Koke382 (01-19-2014), Micha (01-19-2014)
 Old 01-19-2014, 04:25 PM   #37
sl33py24's Avatar
Randy didn't up the boost he left it at 20 psi. When I put the gs boost control it started over boosting but I just kept driving it like that. What happened had nothing to do with randy. He told me to drive easy since their was knocking and we had to find out why but I didn't listen to him. I just drove it hard and I blow it up... I also noticed that my son played with the meth settings it was on 100% on at 5 psi
CarlitoSpeed3 (01-19-2014), Little John (01-19-2014)
 Old 01-19-2014, 04:28 PM   #38
LumberJack's Avatar
Soooo, either that is a piss poor excuase or you're admitting to your own ignorance, either way it's pretty stupid.
Like I said, build it the right way and take your time. Skimping on parts while trying to make big power is the last you ever want to do.
Boosted Beluga (01-19-2014), Elwood617 (01-19-2014), Sterling (01-19-2014)
 Old 01-19-2014, 04:30 PM   #39
sl33py24's Avatar
I just didn't give a fuck so I like I said I blow it up. If I have the money to blow it 100 times that's on me.....
 Old 01-19-2014, 04:37 PM   #40
Koke382's Avatar
Spensa 100 times damn
sent from my peepee
1993 Red Na6
The Following 3 Users Say Thank You to Koke382 For This Useful Post:
Boosted Beluga (01-19-2014), Little John (01-19-2014), Micha (01-19-2014)
Bag's 6 build diary rtabagaboy MazdaSpeed 3/6 - Build Diaries 16 09-17-2016 02:04 AM
Diary Testing sgtiger2 2010 MS3 - Build Diaries 2 07-08-2012 06:21 PM
Page generated in 0.55307 seconds with 31 queries
