Like Tree11Likes
 Old 03-10-2012, 04:06 AM   #81
Phoenix Speed3's Avatar
Posts: 714   (View Stats)
Phoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the worldPhoenix Speed3 is the leader of the world
Originally Posted by TRSpeed View Post
Exactly. ^^^^
And Brendan I thought I was awesome wtf!
Sent from my DROID4 using Tapatalk
You're not THAT awesome, but close enough.
Brenden :thumbup:
tapatalk whore
Phoenix Speed3 is offline   Reply With Quote
 Old 03-10-2012, 02:44 PM   #82
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
Here's a picture of the rigged up BPV so it doesn't leak air. @JP@edgeautosport.com
Sent from my Epic Win Avatar
2009 CWP Speed3
 Old 03-10-2012, 03:12 PM   #83
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
Damn, that's hella tyte...
2007 CTS-V - Trying to sell
 Old 03-10-2012, 03:58 PM   #84
JP@edgeautosport.com's Avatar
Posts: 887   (View Stats)
Oh my god, did someone throw up on that and let it harden over night to seal it?
Why did you guys block it off anyway? Did you try to see if it held boost with it just VTAed so you could just run VTA until you figured out the recirc location? If the intake didn't have the recirc location to begin with, this would have just been a VTA setup.
I didn't read this whole thread so maybe I'm totally off on what you guys are doing.
@Daddy Chinkus
 Old 03-10-2012, 05:05 PM   #85
@Daddy Chinkus
Maybe he can explain but when it was VTA the car didnt run well
2009 CWP Speed3
 Old 03-10-2012, 11:39 PM   #86
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
Ugh gale you fucking idiot.that's not something you fucking show people. Anyway
Jp the cobb bpv design is fairly odd. The vta cap actually fits on the "vent" side and leaves the recirc side open. Issue here is it leaks air at idle, quite a bit too through the recirc side. And yes I adjusted the sprring to no change. Not sure if cobb intentionally designed the bpv to leak I know some actually are. In contrast my turbosmart had the cap off on the recirc side which was the opposite for the cobb. Another thing I recommended gale to buy a new bpv/bov and this was only temp. His car was running like dog shit, he had to work that night and he lives a good 40 min away. It was also getting pretty darn late. I guess its my fault for vnot properly educating gale but it works, and being pressed for time imaking something "clean" wasn't my top prioity.
The Following User Says Thank You to dooderek For This Useful Post:
aviator79 (05-18-2012)
 Old 03-11-2012, 03:49 AM   #87
Its ok Derek I know it isn't going to be permanent. Daddy Chinkus FTW
2009 CWP Speed3
 Old 03-18-2012, 09:28 PM   #88
Update..
Injector seals in and Bosch 3Bar Map installed as well.
Still having big issues with boost creep and trying to figure it out with Lex
2009 CWP Speed3
The Following 2 Users Say Thank You to SleeperHatch For This Useful Post:
atvfreek (03-19-2012), Broxer (03-18-2012)
 Old 03-19-2012, 04:59 AM   #89
atvfreek's Avatar
Posts: 7,787   (View Stats)
Do you mind posting a log of this creep.
Tappin
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
Broxer (03-19-2012)
 Old 03-19-2012, 12:27 PM   #90
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
From what I've seen big inlets and catless exhausts have the most issues with creep...hence why I ended up buying a catted downpipe after the fact
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following 2 Users Say Thank You to 86AmishMs3 For This Useful Post:
atvfreek (03-19-2012), Broxer (03-19-2012)
 Old 03-19-2012, 01:25 PM   #91
Tappin
Sure heres 2 logs. First is a 3rd gear log of me easing into the thorttle to watch the boost. Same with the 4th gear log.
2009 CWP Speed3
 Old 03-19-2012, 02:09 PM   #92
atvfreek's Avatar
That looks very similar to what @Broxers and stangs gtx3071's were doing. Once we brought the boost up in the lower rpm's and made the turbo work, boost became stable and controlled all the way through through the rpm's.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
Broxer (03-19-2012), SleeperHatch (03-19-2012)
 Old 03-19-2012, 02:16 PM   #93
Big intakes, opened exhaust, and inefficient WG designed = creep and spikes
First thing to try is to reduce preload on the WG arm/flapper.
What happens when Broxer floors it at 4500-5000 RPM instead of starting at 3000 so the boost stabilizes? You can't get away from a shitty WG design - you can only work around it with throttle control and increasing backpressure.
Cale, post datalog 84 where you're flooring it at 4200 RPM.
Last edited by Lex; 03-19-2012 at 02:16 PM. Reason: MSF Database - Automerged Doublepost
86AmishMs3 (03-27-2012), atvfreek (03-19-2012), SleeperHatch (03-19-2012)
 Old 03-19-2012, 02:21 PM   #94
Broxer's Avatar
Posts: 875   (View Stats)
Broxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the world
Groans: 90
It's stable. I'll get a log to post later.
2012 Triumph Street Triple
SOLD -- 2010 Velocity Mica Red MS3
ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM
Broxer is offline   Reply With Quote
The Following User Says Thank You to Broxer For This Useful Post:
 Old 03-19-2012, 02:26 PM   #95
If it's stable then there's something different about your setup in terms of preload or intake/exhaust flow. You can't use a boost controller to turn boost down below what the WG on spring pressure alone can do.
atvfreek (03-19-2012), Broxer (03-19-2012), SleeperHatch (03-19-2012)
 Old 03-19-2012, 02:32 PM   #96
Broxer's Avatar
Groans: 90
Here's a timeline of what i've experienced:
Turbo in running on spring pressure: Hit boost cut (22.5psi) near redline. Otherwise built boost really slowly.
Trying to use stock BCS... which i had hooked up incorrectly. Cause boost to go from like 3psi to 22.5 in like 1-2 seconds.
Grimmspeed: boost built slowly and still hit boost cut near redline. Once @atvfreek got the boost to come on faster, around 20psi at 4k rpm then it stopped creeping.
In fact we were able to dial it down to ~19psi @ redline because I was hitting my MAF cap and gettin cut.
If I got any of that wrong atvfreek, feel free to correct me.
The Following 3 Users Say Thank You to Broxer For This Useful Post:
atvfreek (03-19-2012), Lex (03-19-2012), SleeperHatch (03-19-2012)
 Old 03-19-2012, 02:35 PM   #97
So you were just experiencing slow boost response and then creep. Cale is experiencing spiking and creep as well. On just spring pressure if he floors it at 4k RPM then boost goes to 24psi. First thing to do for him is to decrease the preload.
 Old 03-19-2012, 02:40 PM   #98
Broxer's Avatar
Groans: 90
I have my preload set to 0. I had it set to 4 turns tighter but changed it when i was getting spiking on the stock BCS.
The Following 2 Users Say Thank You to Broxer For This Useful Post:
 Old 03-19-2012, 04:03 PM   #99
Heres datalog84 for you smart guys. I'll see if I can get that preload fixed on wednesday morning.
Also got my Go Fast Bits BOV to replace the Cobb one that wouldn't run in VTA mode very well.
2009 CWP Speed3
 Old 03-19-2012, 07:29 PM   #100
atvfreek's Avatar
Datalog 84 certainly looks different than the other logs posted. Boost is doing whatever it wants. Hopefully decreasing the preload as lex suggested will take care of that 24psi spike.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
Lex (03-19-2012)
 Old 03-27-2012, 03:01 PM   #101
Update: Reduced the preload yesterday and spikes are gone but there is still a little creep but we can finally start tuneing.
Also noticed in order to reduce the preload the once the head is off the swiveling piece and the nut is loosened you cannot turn the head like most videos show you have to actually spin the entire actuator arm and in order to do that you must remove the 2 nuts that hold the wastegate to the turbo, pull it down spin the arm a few times then bolt it back up. It was a little annoying but not hard at all.
2009 CWP Speed3
Broxer (03-27-2012)
 Old 03-27-2012, 03:06 PM   #102
Broxer's Avatar
Groans: 90
haha it was a pain the arse to get my wga out because that coolant hard line is right behind it.
Getting that arm back on the flapper was a PITA too. Definately needed 2 ppl.
Is your boost oscillation under control now?
 Old 03-27-2012, 03:11 PM   #103
Haha yeah I had my pops up top just slip the arm on the flapper took him like 2 seconds while I tightened the nut and got everything buttoned up. Having two people is nice don't have to keep getting up from under the car and going back under multiple times. The hardline actually wasn't even an issue for me. I'll attach a few of my newest logs so you can see. Although I am just on spring pressure right now so remember that when looking. Oscillation seems down and spikes arn't there but creeps for sure are still there but should be managable because I wanted to run 24psi anyways.
2009 CWP Speed3
86AmishMs3 (03-27-2012), Broxer (03-27-2012)
 Old 03-27-2012, 03:20 PM   #104
Broxer's Avatar
Groans: 90
Mine was creeping similar to that on spring pressure. The oscillation prolly wont be evident until you get the BCS hooked up.
 Old 03-27-2012, 11:09 PM   #105
86AmishMs3's Avatar
Groans: 338
Compressed air is your friend in that situation. Muscleing on the arm back on is no easy task...unless you have a air compressor.
problem is youre at 24psi @5800 rpms.....Add another 1000rpms and you might be 26-27psi. You're uncatted right.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
Last edited by 86AmishMs3; 03-27-2012 at 11:09 PM. Reason: MSF Database - Automerged Doublepost
 Old 03-27-2012, 11:35 PM   #106
2zz mr-s
dooderek's Avatar
Groans: 239
father of gale is a boss
SleeperHatch likes this.
SleeperHatch (03-28-2012)
 Old 03-28-2012, 02:05 AM   #107
Yeah but were also still at the beginning of the tune. I have a catted CNT downpipe, so its just a high flow cat.
2009 CWP Speed3
 Old 03-28-2012, 02:11 AM   #108
86AmishMs3's Avatar
Groans: 338
Wow you're still creeping with a cat..well once you dial in some more timing you should see less creep.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 03-28-2012, 02:38 AM   #109
QwkEVO's Avatar
Posts: 484   (View Stats)
QwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the worldQwkEVO is the leader of the world
Sleeper, sorry for the thread hijack, I just want to possibly avoid the same potential problem.
Crap, I hope I dont have this problem when I do my install this weekend. I also have the Cobb BPV, although it works fine currently in hybrid mode on the stock K04. I have the 14 psi spring in my 3071GTX. You guys think I should take the preload off before installing? I didnt port the WG housing either, wonder if I should do some minor porting of that half moon shaped area?
I'm running a Vibrant DPBE which does have a high flow cat. I have a corksport downpipe...
Any suggestions to help me avoid this potential issue?
08 MS3 //PTP Injector seals & stud kit //CP-E RMM //Corksport Sway Bar // Koni Yellow Sports // Eibach Pro Kit Springs // Enkei 18" PF01's //
QwkEVO is offline   Reply With Quote
 Old 03-28-2012, 02:52 AM   #110
Yes port the WG and you won't have nearly as many creep or spiking problems. Also if your running a recirc tube still on the inlet then the Cobb BPV is perfectly fine. My inlet is essentially just a bent 3'' aluminum pipe. Preload is easily adjustable as well kind of annoying but not hard to do at all.
2009 CWP Speed3
 Old 04-04-2012, 10:13 PM   #111
TRSpeed's Avatar
Posts: 1,537   (View Stats)
TRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the world
Gale any updates?
2008.05 True Red Mazdaspeed3
Lex Tuned
GTX3071r | 38mm Tial WG | Hallman MBC
Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod |
Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM |
Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs
TRSpeed is offline   Reply With Quote
 Old 04-05-2012, 08:21 AM   #112
driver311's Avatar
Posts: 1,769   (View Stats)
I found that the wg hole definately needs to be opened as far as possible. Pretty much as far as you can go without seeing the opening with flapper shut. Also adding a high flow cat helps a ton and doesnt affect flow harder at all. ON a 400whp car expect to lose about 3-5whp. Magnaflow cats sell for about $85 dollars and make the car sound so much beter in my eyes with 3in exhaust. I guess its all preference but I hate my car sounding loud like a civic or srt. lol
Mazdaspeed
The Following 2 Users Say Thank You to driver311 For This Useful Post:
86AmishMs3 (04-09-2012), Broxer (04-05-2012)
 Old 04-05-2012, 11:57 AM   #113
Well I might have to open it more then. Tuning was going great amd spikes were gone and creep was controlled and now all of a sudden I'm spiking to 30psi again, Lex thinks something might have popped off which sounds most likely ill be checking soon but since I'm sick and feel like I have the bubonic plague it won't be today.
2009 CWP Speed3
Lex (04-05-2012)
 Old 04-05-2012, 01:42 PM   #114
2zz mr-s
dooderek's Avatar
Groans: 239
AMATEUR
 Old 04-08-2012, 03:19 PM   #115
So I've decided I'm really tired of trying to deal with this damn IWG so I'm going to be getting Daddy Chinkus's manifold and wastegate and just run EWG and be done with it!
2009 CWP Speed3
The Following 3 Users Say Thank You to SleeperHatch For This Useful Post:
Broxer (04-08-2012), Lex (04-08-2012), uncorked11 (04-20-2012)
 Old 04-08-2012, 03:43 PM   #116
Your motor will thank you from sparing it from the overboost!
 Old 04-08-2012, 10:23 PM   #117
2zz mr-s
dooderek's Avatar
Groans: 239
is your engine even capable of handling parts from a car with un adulterated power?
 Old 04-08-2012, 10:55 PM   #118
Haha yes it is very capable
2009 CWP Speed3
 Old 04-19-2012, 01:26 PM   #119
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Subbed for later.
 Old 04-19-2012, 01:36 PM   #120
COOL STORY BRO
Hamilton69's Avatar
Posts: 2,418   (View Stats)
Hamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the world
Groans: 179
Groaned at 179 Times in 30 Posts
BEWARE THE WASTEGATE IS JB WELDED TO THE MANIFOLD
JBR 3.5" WHALE PENIS-su tmic- sure track urethane rmm- corksport catless 3" downpipe- ultimate racing tp-OBX 3" cat back -rally armor urethane flaps-Cobb Accessport FINKLE TUNED-sure shift anchors-autotech hpfp internals-HKS BOV VTA -jbr heavy shift knob- 245-40-r18 Falken 329's-paint matched uber smiley
ZOOM ZOOM BOOM
Hamilton69 is offline   Reply With Quote
The Following User Says Thank You to Hamilton69 For This Useful Post:
bewsted (05-04-2012)
GTX3071 build JacksonMS30 MazdaSpeed 3/6 - Big Turbo Builds 767 05-18-2013 12:49 AM
Cld12pk2go's ATP GTX3071 Build cld12pk2go MazdaSpeed 3/6 - Big Turbo Builds 210 12-31-2012 08:03 PM
Drivers gtx3071 driver311 MazdaSpeed 3/6 - Dyno Sheets/Discussions 3 10-22-2011 03:08 PM
Page generated in 0.59589 seconds with 34 queries
