Like Tree11Likes
 Old 08-16-2012, 01:53 PM   #201
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
What combination of springs do you have in there?
Its a 14psi spring
Galaxy SIII
2009 CWP Speed3
 Old 08-16-2012, 02:53 PM   #202
TRSpeed's Avatar
Posts: 1,537   (View Stats)
TRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the worldTRSpeed is the leader of the world
Make sure necessary ports are capped on the wastegate
This! All the port news to be closed make sure the ones hooked up are on the right place.
Sent from my DROID4 using Tapatalk 2
2008.05 True Red Mazdaspeed3
Lex Tuned
GTX3071r | 38mm Tial WG | Hallman MBC
Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod |
Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM |
Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs
TRSpeed is offline   Reply With Quote
 Old 08-16-2012, 03:19 PM   #203
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Yeah, sounds like you either are missing a cap or simply have your vac lines plumbed incorrectly assuming you have verified that the EWG does move and isn't stuck closed...
 Old 08-16-2012, 03:21 PM   #204
hook up the ewg to an air compressor and see what psi it opens at.
 Old 08-16-2012, 04:59 PM   #205
So Derek looked at as well and its hooked up to spring pressure but the wastegate isnt opening at 14psi which is the same problem I was having before. Thinking of pulling one if the springs out and seeing what happens. All the ports are plugged and tight as well.
Galaxy SIII
2009 CWP Speed3
 Old 08-16-2012, 11:30 PM   #206
Yes, put the softest spring in there and see if it opens. Remember to ease into it!
SleeperHatch (08-16-2012)
 Old 08-17-2012, 07:48 AM   #207
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
I've heard tell of this thing called the Guardian Angel. Rumor is that it keeps things safe when problems just like this crop up.
Just puttin' that out there since Lex is too nice to push his own kit
340hp / 371tq
Lex (08-20-2012), SleeperHatch (08-17-2012)
 Old 08-17-2012, 12:37 PM   #208
dantes5823's Avatar
Posts: 6,576   (View Stats)
How do you have your boost controller set up? Which boost controller are you using actually.
 Old 08-17-2012, 01:30 PM   #209
Oh Ill be gettIng one soon!
Actually just running off spring pressure but im still overboosting
Galaxy SIII
2009 CWP Speed3
 Old 08-17-2012, 01:41 PM   #210
COOL STORY BRO
Hamilton69's Avatar
Posts: 2,418   (View Stats)
Hamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the world
Groans: 179
Groaned at 179 Times in 30 Posts
did you check your vtec solonoid Gayle?
JBR 3.5" WHALE PENIS-su tmic- sure track urethane rmm- corksport catless 3" downpipe- ultimate racing tp-OBX 3" cat back -rally armor urethane flaps-Cobb Accessport FINKLE TUNED-sure shift anchors-autotech hpfp internals-HKS BOV VTA -jbr heavy shift knob- 245-40-r18 Falken 329's-paint matched uber smiley
ZOOM ZOOM BOOM
Hamilton69 is offline   Reply With Quote
 Old 08-17-2012, 01:41 PM   #211
Not yet just getting around to checking the flux capaciter.
Galaxy SIII
2009 CWP Speed3
 Old 08-17-2012, 01:46 PM   #212
COOL STORY BRO
Hamilton69's Avatar
Groans: 179
these things happen you know, cant be too careful
ZOOM ZOOM BOOM
 Old 08-17-2012, 02:03 PM   #213
Just stop chasing your tail and hook it up to an air compressor. Takes all of 10 seconds to see what psi it opens at.
 Old 08-17-2012, 03:47 PM   #214
Will do. Hopefully tomorrow I can get that done before work
Galaxy SIII
2009 CWP Speed3
 Old 08-20-2012, 03:27 PM   #215
Update...
So I hooked up the EWG to an air compressor. @eric@edgeautosport and it didn't actually open till about 25psi which would explain my overboosting although the company did state the EWG came with a 14psi spring. So I then took 1 spring (the one with the most tension) and it now seems to open somewhere around 15psi.
I'm going to take it for a ride and ease into it and see if it opens and what else. Also the boost line's I have been using keep seeming to crack from the heat. What is everyone else using?
2009 CWP Speed3
EdgeAutosport.com (08-20-2012)
 Old 08-20-2012, 03:36 PM   #216
Originally Posted by SleeperHatch View Post
Update...
Yikes be careful with blowing lines! Get a silicone line and use a good metal worm clamp.
atvfreek (08-20-2012), helmetface (11-19-2012)
 Old 08-20-2012, 03:46 PM   #217
Yeah I was a little worried about it but I put worm clamps on there to make sure they don't blow off, just noticed a tiny little crack when taking the EWG off so I'll get something on there very soon.
2009 CWP Speed3
 Old 08-20-2012, 04:37 PM   #218
Took the car out eased into boost and then did a semi WOT pull carefully watching boost and it didnt go any higher than 19psi!!! I think it's under control! @Lex
Galaxy SIII
2009 CWP Speed3
The Following 2 Users Say Thank You to SleeperHatch For This Useful Post:
cld12pk2go (08-20-2012), TiGraySpeed6 (08-20-2012)
 Old 08-20-2012, 04:41 PM   #219
Galaxy SIII
Do a few more pulls punching it and watching boost. If all is well, throw on the solenoid and ease into it again and watch boost.
atvfreek (08-20-2012), SleeperHatch (08-20-2012)
 Old 08-20-2012, 05:12 PM   #220
Ok will do and get it all done tomorrow
Galaxy SIII
2009 CWP Speed3
 Old 08-21-2012, 01:56 AM   #221
So I punched it a few more times after work and it hit 20psi im suspecting because it was about 30 degrees cooler outside. Going to hookup the grimmspeed tomorrow and see what happens
Galaxy SIII
2009 CWP Speed3
atvfreek (08-21-2012), lilred (08-21-2012)
 Old 10-22-2012, 11:27 PM   #222
New tune and parts and I am fast again! Thanks @Lex
2009 CWP Speed3
BPASPEED (10-23-2012)
 Old 10-23-2012, 12:54 AM   #223
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
cars back to fail, stock out
The Following User Says NO Thank You to dooderek For This Un-useful Post:
himurax13 (10-23-2012)
 Old 10-23-2012, 01:01 AM   #224
Your mom
2009 CWP Speed3
 Old 10-23-2012, 02:50 AM   #225
Tabasco69's Avatar
Posts: 554   (View Stats)
Tabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the world
Good to hear you got it all straightened out man.
I can't wait to get my car out of the shop as soon as the haltech install is done.
425whp/395ftlbs - GTX3071R .82a/r- 20psi- 92 octane pump fuel
Tabasco69 is offline   Reply With Quote
GTX3071 build JacksonMS30 MazdaSpeed 3/6 - Big Turbo Builds 767 05-18-2013 12:49 AM
Cld12pk2go's ATP GTX3071 Build cld12pk2go MazdaSpeed 3/6 - Big Turbo Builds 210 12-31-2012 08:03 PM
Drivers gtx3071 driver311 MazdaSpeed 3/6 - Dyno Sheets/Discussions 3 10-22-2011 03:08 PM
Page generated in 0.42435 seconds with 30 queries
