Like Tree7Likes
 Old 06-06-2014, 12:22 AM   #41
levon.mark's Avatar
Posts: 268   (View Stats)
Groaned at 9 Times in 4 Posts
subbed
YEEMARKS
Old Time in S3:
12.4 @ 111
 Old 06-06-2014, 12:36 AM   #42
btstarcher's Avatar
Posts: 4,852   (View Stats)
Damn Kevin I didn't know you made a build thread.....nice work! Nice to see someone around here not full of fail!
SnailTune in progress
 Old 06-06-2014, 12:37 AM   #43
2.3speed06's Avatar
Posts: 811   (View Stats)
2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world
Can't wait to see the finished product
2006 Black Cherry Mica Mazdaspeed 6 GT
Cobb AP 50/50 FREEKTune/Cobb 3port EBCS/C-PE Nano Intake/C-PE TIP/C-PE TMIC/HKS SQ3 BOV/Auto Tech HPFP/M2 DP/Custom CB/Denso ITV 22's/JBR RMM/Sure SSP/Sure Shifter Bushings/Custom EGR Kit/TB&IM TIG/MD Stage2 OCC/Koni Yellow S&S/H&R LS/Stoptech Blanks/EBC Red/Techna-Fit SS Brake Lines/
2.3speed06 is offline   Reply With Quote
 Old 06-12-2014, 01:40 PM   #44
spd6demon's Avatar
Posts: 164   (View Stats)
spd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the worldspd6demon is the leader of the world
UPDATE:
Sorry its been a while, kinda been at a stand still for a few weeks. No pics right now cause I suck...I'll try to post some soon.
Anyway, got the dual OCC setup installed (one catch can VTA, then the other Matts version 1 location. Had to drill and tap the oem PCV plate for the VTA OCC..PITA but well worth it at the end. Thanks @MATT DAMOND; for all the help and advice on my setup!
Also found out I had been running a 6psi EWG spring the whole time...fml. So I went ahead and bought a 14.5psi spring..hello power again! Now just waiting on my new revision from Justin to get the 6th port up and running!
06 MS6 GT // PTE 6266 GEN2 // Kozmic 6th Port Inj. 1200cc // Weisco Pistons (0.020 over) // Manley H+ Rods // JDM Sport EM // Tial 38mm EWG // SP63 Keyed & Polished Crank & Sprockets // 4" WPI // P&P IM // Cobb AP // Custom DP
CP-E Safe Seals // CP-E Rear Diff Mount // Bosch 3.5 BAR // Sure ShortCut // TWM Shift Knob // AutoTech HPFP internals // H&R Springs // DRAG DR-34 +35mm // CS2 Front Lip // CX Racing Air to Water IC // Custom Matt Damond Dual OCC
HTP Small Batt Tray // SP63 EBCS // HKS BOV // Kozmic Oil Feed Line // JBR EGR block off // JBR BSD // JBR Counter-weight // NGK // DW 65c ITFP // JBR PMM // JBR SSB // SU RMM // Corksport TMM Insert // FREEK Tune in progress
305/364 (K04) // 367/387 (2871r)
454/417 (PTE6262 R.I.P)
spd6demon is offline   Reply With Quote
The Following 6 Users Say Thank You to spd6demon For This Useful Post:
2.3speed06 (06-17-2014), 2k4_8 (06-12-2014), Alpha (06-18-2014), Easter Bunny (07-22-2014), MATT DAMOND (06-19-2014), Micha (06-27-2014)
 Old 07-22-2014, 05:47 PM   #45
spd6demon's Avatar
UPDATE:
So here are the results from 93 octane using 6th port injection. For some reason my computer wont let me print scrn my dynojet chart, but attached is my 3rd gear datalog. I imagine if I used 4th gear, the power would be maybe 10 more hp. Anyway, It made 377whp/351tq before knock started to become a factor. I think if people are looking to do 6th port with just pump gas, dont bother. Might as well just do pump with meth for 400+. E85 is where the powers made for 6th port. I will try and post more often so you guys can see the progress.
The Following 8 Users Say Thank You to spd6demon For This Useful Post:
alaskazero (07-22-2014), Alpha (07-22-2014), btstarcher (07-22-2014), Code Monkey (07-22-2014), darkstar5440 (07-22-2014), Easter Bunny (07-22-2014), ItsNox (07-23-2014), jdmage_mx5 (07-22-2014)
 Old 07-22-2014, 07:01 PM   #46
btstarcher's Avatar
Why so much KR? You're not running all that much timing.
 Old 07-22-2014, 11:12 PM   #47
darkstar5440's Avatar
Posts: 477   (View Stats)
Them afr's are all over the place, i'd say possibly knockin the tire off but you haz awd mod
OMWTFYB
 Old 07-23-2014, 06:17 AM   #48
spd6demon's Avatar
There's KR present due to the amount of boost I'm running. I think there's a tradeoff but correct me if I'm wrong; either you can run more boost but less timing, OR less boost, with more timing.
@finalspeed; may be able to give more details on his tune..we both did 6th port injection but the tunes are different. With 93, he was seeing roughly 16-18* timing with 23psi making 330-ish whp I think. However he was using more of his aux injectors. His duty cycle was in the 50-60's while mine was at 92%.
 Old 07-23-2014, 06:21 AM   #49
btstarcher's Avatar
Have you eliminated the possibility that it's just noise? Yes, more boost will yield higher KR, but I had thought that it was because of the higher BAT's associated with higher boost. Your BAT's look fine (as they should with that monster intercooler setup LOL).
spd6demon (07-23-2014)
 Old 07-23-2014, 06:29 AM   #50
Im not a tuner but it seems as if your tune still needs to be cleaned up you shoot up to 26psi down to 22 and back up to 26 and then tapers off and your afrs are bouncing all over. I know when i take a log i hold my boost and my afrs are 11.76 all the way through the log.
Have you done a boost leak test? Spark plug gaps are good?
OMWTFYB
 Old 07-23-2014, 06:48 AM   #51
spd6demon's Avatar
I dont think it is noise, we just started on e85 tuning and there's no KR. With noise KR, wouldnt fuel type not matter? (j/w)
I agree it could use a little cleaning up. Haven't had a chance to do a boost leak, but maybe youre right that I should do one. Does anyone know of other people's power #'s with pump & 6th port?
The Following User Says Thank You to spd6demon For This Useful Post:
btstarcher (07-23-2014)
 Old 07-23-2014, 06:55 AM   #52
Shit man you have a top mount a boost leak test doesnt get any easier than that lol.....
I got two friends running 6th port on 93 and they are both alittle over 400 @ 23psi but they also have pu so can't really compare
OMWTFYB
Last edited by darkstar5440; 07-23-2014 at 06:55 AM. Reason: MSF Database - Automerged Doublepost
 Old 07-23-2014, 07:02 AM   #53
I think there is a guy in maryland running 6th port on a ms6 with a 5862 and his name is shayne....not sure what his screen name is....who is your tuner?
OMWTFYB
 Old 07-23-2014, 07:12 AM   #54
spd6demon's Avatar
You right, its easy as fuck lmao. I didn't think I needed a boost leak test cause Justin (Freektune) hadn't mentioned it..figured everything looked good from a tuners perspective. I had similar boost fluctuations with my old 2871, thought it was normal.
Yea comparing my power to the pu's isnt realistic lol. Can't wait till I get further in this e85 tuning! @finalspeed; is pretty much done with his, Lex is just fine tuning. 510/516ish with 37psi on a GTX3076?!? And with that said, its been 95+ degrees ambient! Cant imagine power during the cooler seasons. O_o
 Old 07-23-2014, 07:15 AM   #55
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
I honestly pictured your final tune being in the upper 400 range or more with your mods.
 Old 07-23-2014, 07:22 AM   #56
Always boost leak test man, whenever you disassemble intercooler piping test it again. When i first went bt i had all my clamps wound down tight as fuck and i was certain in my head it was air tight.....well when i did a leak test i had 4 leaks and one of them being massive
Going over all your hardware makes your tuners life alot easier and eliminates questions
OMWTFYB
Last edited by darkstar5440; 07-23-2014 at 07:22 AM. Reason: MSF Database - Automerged Doublepost
The Following 5 Users Say Thank You to darkstar5440 For This Useful Post:
Easter Bunny (07-23-2014), ItsNox (07-23-2014), jdmage_mx5 (07-23-2014), Jh8909 (07-23-2014), spd6demon (07-23-2014)
 Old 07-23-2014, 07:27 AM   #57
spd6demon's Avatar
It will be but from what I've gathered, pump gas just can't get you past low 400 range. Maybe @Justin@Freektune; @Lex; could explain the issues with pump gas using 6th port
 Old 07-23-2014, 08:15 AM   #58
jdmage_mx5's Avatar
I probably missed it but Benny is on E85 also, right? I'm trying to decide if I should indeed go JMF With PI or JMF with 6th port. Needless to say I've been following your build closely. I wish Benny would keep a build thread going. Both of y'all are the kings of the hill in AR right now. Hopefully I will be able to join y'all sometime in the future.
 Old 07-23-2014, 08:28 AM   #59
spd6demon's Avatar
Yup Benny is on e85. Well if $ isnt an issue, the potential for JFM PI is limitless. 6th port with the 1000cc injectors can get you to the upper 500's from what I've seen. I went ahead and got upgraded 1200cc injectors so I could possibly break the 600whp threshold. Plenty for me haha.
 Old 07-25-2014, 10:15 AM   #60
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
shitty fuel is shitty.
PI is great if you have the octane. The only way to logically (not intellegently) reduce that KR is to target lower AFR's but how low can you go right?
Using meth or e85 will let you use more of the injector before KR is an issue.
Essentially I'm saying if you don't have extra octane/cooling, then KR will hit before you can use the capacity of the PI system rendering it almost useless.
Performance:
Stratified Tune in progress
jdmage_mx5 (07-25-2014)
 Old 07-25-2014, 10:25 AM   #61
btstarcher's Avatar
Dammit Kevin you've got plenty of e85 stations there. Just throw a couple gallons in.
 Old 08-01-2014, 12:17 PM   #62
Only way you can make big numbers on low octane fuel is through a lot of flow and a very large turbo. You are going to make response suffer down low. I would say that unless you have a massive turbo and a ported head/perhaps with cams 6th port is not going to be of benefit on pump fuel alone.
6th port actually loses power unless you need the fueling headroom. DI has its benefits in terms of combustion, atomization, cooling. So use it as far as you can and then swap to 6th port when you've ran out. If you encounter knock before running out of fuel, 6th port is not going to help.
The Following 7 Users Say Thank You to Lex For This Useful Post:
awarren (08-03-2019), btstarcher (08-01-2014), ItsNox (08-01-2014), jdmage_mx5 (08-01-2014), Mauro_Penguin (08-01-2014), spd6demon (08-01-2014), Swinger13 (08-01-2014)
 Old 08-01-2014, 07:19 PM   #63
Justin@Freektune's Avatar
Posts: 954   (View Stats)
With your setup I have no doubt we will end up right around 600. Right now I have your 6th port only at about 50% so this next map is 30 psi. I like to keep DI high 80s to low 90s so we may need to make another aux fuel map. But see how she does with a little more boost and then we can dial in the ignition curve which really hasn't been touched.
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
btstarcher (08-01-2014), spd6demon (08-05-2014)
 Old 08-01-2014, 07:35 PM   #64
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Justin, if fueling starts to become an issue with the 6th port. I upgraded to an Aeromotive 325 and bosch 2200 cc injectors, and was able to cut my last fueling map in half from the previous setup. I also squashed the stock bosch ITFP regulator, and im sitting at 75 psi at idle. Been working flawless for awhile now, and am really curious how much I can squeeze out of the setup before going PI.
Realgib3 likes this.
The Following 5 Users Say Thank You to Etipp98 For This Useful Post:
btstarcher (08-01-2014), impossible (08-22-2017), ItsNox (08-02-2014), Justin@Freektune (08-02-2014), Realgib3 (08-06-2014)
 Old 08-06-2014, 07:25 AM   #65
spd6demon's Avatar
Little update:
This past sunday I was driving around and did a couple logs for the tune. 30psi feels badass btw. The HKS bov no longer makes the high pitch purge sound, instead it just sounds like a loud explosion being released lmao.
I ended up doing a highway pull against my friend in his gsxr600 and pulled on him after 100. Once the run was done, I noticed the right side of my windshield had liquid spray on it. Pulled over and noticed oil had blown out of the dip stick. Apparently there was a shit ton of crank case pressure. Messaged Justin and told him what happened. He recommended doing a compression test, so the next afternoon I went ahead and did one.
Compression results:
cyl 1-190
cyl 2- 190
cyl 3- 185
cyl 4- 190
Oil had gotten on the spark plugs on #1 & #4 :/
After that, I started looking at the plumming of the dual OCC's. Found that the non-vented can was correctly ran, but the vented can was not. I had the check valve that lead to the valve cover facing towards the OCC, not the valve cover like it should have been. I went ahead and removed the check vlv all together so theres no restrictions.
Hopefully that will fix the crank case pressure issue, but we'll see. Maybe I will need the genwon SP63 oil cap breather to help vent more.
btstarcher (08-06-2014)
 Old 08-06-2014, 08:47 AM   #66
btstarcher's Avatar
I'm thinking you want that check valve in there, otherwise it will affect fuel trims. Under vacuum you'll be pilling air into the crankcase, right?
 Old 08-06-2014, 09:27 AM   #67
spd6demon's Avatar
I'm not sure exactly. Justin recommended that I remove the check valve so there were no restrictions. As of right now I only have a check valve coming from the "perm plate" to the vented OCC, and one going to the intake mani from the non-vented OCC. Im going to remove the throttle spring I have securing my dip stick down and see if it pops out under full boost. If so, then I think I'll need the oil cap breather
 Old 08-06-2014, 09:41 AM   #68
btstarcher's Avatar
Oh I see. I think you'll be fine then. I was thinking your vented OCC was installed between the valvecover and TIP.
 Old 08-06-2014, 12:05 PM   #69
Ya his VC vent is going to a vented can. So no need for a check valve there. Let that crank case breathe as much as possible
PTE 6062
633HP/523TQ
btstarcher (08-06-2014), spd6demon (08-06-2014)
 Old 08-06-2014, 04:10 PM   #70
btstarcher's Avatar
Reading fail. Forgot he installed the check valve incorrectly. I was wondering how he could have popped the dipstick with a vented can installed LOL.
 Old 08-08-2014, 07:57 AM   #71
spd6demon's Avatar
So I did a couple logs this week and felt a cut of some sort. Found out it was a fuel cut in my 4th gear WOT log right around 5500rpm. Strange cause the 3rd gear log was perfectly normal, but Im aware the fuel demand in 3rd gear compared to 4th is different.
The dip stick had popped after each log (no oil spewing anymore), so theres still some pressure building in the crank case. I still need to do a leak down test to see if theres any other issues. I spoke to Pablo from Speed Perf6rmanc3 and he was nice enough to offer for me to test out their genwon oil cap breather prototype. Got an email saying he would send it out today cant thank you guys enough! Hope this helps vent some of the pressure building up! Will post some updates when I install the oil cap breather/complete a leak down test.
The Following 2 Users Say Thank You to spd6demon For This Useful Post:
Easter Bunny (08-08-2014), ItsNox (08-10-2014)
 Old 08-08-2014, 09:22 AM   #72
btstarcher's Avatar
Or do like me and run a hose from the valvecover to.....nothing....LOL
The Following 2 Users Say Thank You to btstarcher For This Useful Post:
impossible (08-22-2017), Realgib3 (08-18-2014)
 Old 08-16-2014, 07:12 PM   #73
kbz0129's Avatar
Posts: 986   (View Stats)
Just seeing this thread, this is an awesome build. I've been looking at the 6262 to run on my speed6 build, looking to run direct port meth injection on the jmf intake manifold. Still trying to figure out all the little details but it's nice to know someone is running this on a speed 6.
2010 Ms3 PD Tuned
2006 Ms6 GT-Stock
The Following User Says Thank You to kbz0129 For This Useful Post:
spd6demon (08-16-2014)
 Old 08-16-2014, 09:14 PM   #74
spd6demon's Avatar
Thanks man! The 6262 is a great turbo. It's spooling as fast as my old 2871 did. I'm getting 30psi by 3900rpm. I'm spooling that quick cause I'm running air to water and the piping is only 1 1/2ft long. I'm hoping to get the tuning done by September, but we'll see. I'm waiting on the oil cap breather prototype from SP63 which will hopefully solve my crank case press issue.
2.3speed06 (08-17-2014), kbz0129 (08-17-2014)
 Old 08-17-2014, 03:20 PM   #75
sidekick's Avatar
Posts: 3,093   (View Stats)
I'd think it has more to do with the .63 hotside than the short intercooler piping. I'm sure that helps, but that's amazing in terms of spool. I've always viewed turbos this size as nothing, nothing, nothing, BOOOOOOOST @ 4500RPM+. Lol
 Old 09-30-2014, 11:32 AM   #76
spd6demon's Avatar
UPDATE:
So at the beginning of the month of September, I had noticed the exhaust smoking white intermittently. I checked to see if there was oil in my intercooler pipes, but found small metal shavings instead. FUCK. Turbo seals went out it..Took off all the piping and cleaned it out. Looked at the compressor wheel and saw it had made contact with the housings walls.
I called Preicision to see how much it was to rebuild the turbo. Prices started at $185 and went from there. By the looks of it, it would have needed a new compressor wheel since the edges had a few knicks in them. I went ahead and said fuck it, and bought a
PTE 6266 Gen2 w/ .82 hotside
btstarcher (09-30-2014), Easter Bunny (09-30-2014), fivefingerdeathpunch (10-01-2014), impossible (05-23-2016), ItsNox (09-30-2014), Realgib3 (10-03-2014)
 Old 09-30-2014, 06:14 PM   #77
ItsNox's Avatar
Posts: 3,076   (View Stats)
Atta boy! That's the way you make good out of a bad situation.
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
 Old 05-23-2016, 02:46 AM   #78
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
Got 6266 with .82 ar hotside in 9/30/14, no updates since then.. What's up with the build as of lately?
What You Need to Know to Build a Motor TWOptSL0W MSF KB - Mazdaspeed 3/6 - Engine/Turbo Builds 14 09-26-2012 03:33 PM
HOW TO build an mzr motor!! qtrmile beast MazdaSpeed 6 - Engine, Transmission & Driveline 4 09-12-2012 05:07 AM
kmac's 6262 build kmac MazdaSpeed 3/6 - Big Turbo Builds 509 05-25-2012 06:51 PM
another PT 6262 build andre0121 MazdaSpeed 3/6 - Big Turbo Builds 3 09-17-2011 05:19 PM
Page generated in 0.55700 seconds with 34 queries
