![]() Join Date: Feb 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 95
(Thread Starter) | Not Ranked : 0 score Here's a few pics of the ordeal, didn't get into to much detail with the photos because of the weekend time crunch as this is my dd. I used a stg 2 cpe nano+tip+ic+93 oct. With abilors tuning and perms bt 101 intergated in the tune, it Fired up first couple of cranks ran perfect. idles perfect and low throttle conditions are spot on. wot im experiencing what i believe to be spark blow out around the higher rpms and got pretty lean on me. Waiting to install the new plugs at .026 gap. and go from there. Still waiting on a few other pieces 3.5" wp, wmi, and the 3 bar map sensor, battery relocation and of course a proper tune from who better then the freek! Here's a copy of my tune if anyone could spare their input it would be greatly appreciated!
__________________ BNR stage 3 *cpe sri * sure TIP* sure TIG * Cobb ap * autotech hpfp * PNP IM vtcs delete *custom fmic 2.5" piping * optima red top trunk mounted *egr block off * moroso occ * ets cat-back * bosch 3 bar map sensor * turbosmart bov (recirc) * 3" m2 catless dp* grimmspeed 3 port ebcs* sure ssp* solid shifter bushings * ss brake lines * stoptech slotted rotors w/ oem pads* ngk 1 step colder plugs * mt 90 tranny & diff oil * front & rear strut tower bars * badge-less grill * evo x wheels * 225/40/18 nitto invo's * triple gauge pod autometer gauges* *** Freak tuned *** 21psi best 1/4mile----13.5 @ 104 mph 1500' above sea level |
| The Following 11 Users Say Thank You to Doucems6 For This Useful Post: |
![]() Join Date: Nov 2012 Location: Denver, Colorado
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 204
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score Nice pic layout - for your log, to find out why AFR is where it is, I'd think it would be good if you can log injector data too, but my only real input is that pic of the reflection of the babe in the pipe is way fucking cool. http://www.mazdaspeedforum.org/forum/foru...-26-09_262.jpg
__________________ '09 MGM MS3 - 'MaZcedes' * Cobb A/P * CP/e S2 RMM * Autotech/6oost3d/McMaster-Carr HPFP Internals * JBR PowerPath SRI/TIP * ATP Catless DP * Cobb XLE BPV * Bilstein B8 Sprint Shocks * JBR 32mm Rear Sway Bar * STRATIFIED...proper - ZFZMF! |
| The Following User Says Thank You to turboKart For This Useful Post: | Doucems6 (04-15-2013) |
Thanks I'll take another log after i get the new plugs installed! And that is actually a 21mm socket its called socket art! lol
__________________ BNR stage 3 *cpe sri * sure TIP* sure TIG * Cobb ap * autotech hpfp * PNP IM vtcs delete *custom fmic 2.5" piping * optima red top trunk mounted *egr block off * moroso occ * ets cat-back * bosch 3 bar map sensor * turbosmart bov (recirc) * 3" m2 catless dp* grimmspeed 3 port ebcs* sure ssp* solid shifter bushings * ss brake lines * stoptech slotted rotors w/ oem pads* ngk 1 step colder plugs * mt 90 tranny & diff oil * front & rear strut tower bars * badge-less grill * evo x wheels * 225/40/18 nitto invo's * triple gauge pod autometer gauges* *** Freak tuned *** 21psi best 1/4mile----13.5 @ 104 mph 1500' above sea level | |
| Banned ![]() Join Date: Aug 2011 Location: Dallas, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 253
| Not Ranked : 0 score Those are some good looking welds and cuts...share?! |
| The Following User Says Thank You to mczimer For This Useful Post: | Doucems6 (04-20-2013) |
(Thread Starter) | Not Ranked : 0 score Thanks, my friend and I took our time making sure everything was going to be perfect fit and weld wise ( clearance for shifter weight, reuse of the stock windshield washer tank, fog light housing, horn). Both of us combined also have more than 20 years in oil field fabrication. I'm a pressure vessel welder for the refinery's and hes a oil rig hydraulic fabricator. We had no choice but to do a good job! Were not about doing rework. The whole intercooler set up was designed to be 3 pieces (minimum connections to reduce boost leaks, but still fully removable). If you have any questions i'd be happy to answer and supply more pictures!
![]() Join Date: Nov 2009 Location: Tempe, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,225
Groans: 65
| Not Ranked : 0 score Very nice setup you got. Like the custom ic you made, very nicely made. |
| The Following User Says Thank You to AZSPEED3 For This Useful Post: | Doucems6 (04-20-2013) |
(Thread Starter) | Not Ranked : 0 score Hopefully by the end of the day! Were working on it right now, pics soon after. Oem tank in driver side fender well area. Might have to do some senor surgery, but tank should fit.
| Not Ranked : 0 score Can't wait to see how you will manage to get it to fit. I have a custom FMIC job next weekend, so this would be amazing |
It was a bit of a pain in the ass but we fabbed up three brackets that could be utilized, on the body. 2 of the bolts/nuts were from the tank itself (these were used on the 2 larger brackets made from 1/4 x 2" flatbar). The 3rd small triangular bracket was made as a resting point on a factory bolt. We basically built a jumper harness for the pump, and low fluid level sensor. and just ran them in a new loom zip tied along the other larger loom across the rad. into its new location. We also notched out a small piece just under the intake so that the bottle would sit upright. I know its kind of a vague how to but im hoping the pictures will help it make sense! Keep in mind this is on a speed 6 and highly depends on the routing of the fmic cold piping, we didnt use the tradtional route under the intake we actually notched out some of the plastic rad support to keep the radious as tight as possible. I take no responsibility on anybody else's out come! But i will be happy to help out and take more pics/explaining.
| The Following 6 Users Say Thank You to Doucems6 For This Useful Post: | big angry bird (04-24-2013), Code Monkey (04-22-2013), mczimer (04-22-2013), Menace1 (04-25-2013), TiGraySpeed6 (04-22-2013), turboKart (04-22-2013) |
Bad a**! I had no idea the OEm tank would fit there.... @TiGraySpeed6; | |
| The Following 2 Users Say Thank You to mczimer For This Useful Post: | Doucems6 (04-22-2013), TiGraySpeed6 (04-22-2013) |
(Thread Starter) | Not Ranked : 0 score Let me know if you need anymore pics when you do yo ur fmic!
| Not Ranked : 0 score That's a pretty nifty idea for the washer tank! I've been debating what or how I was gonna mount something, and this should fit the bill rather nicely & the price is right too
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | Doucems6 (04-22-2013) |
![]() Join Date: Feb 2012 Location: Alexandria, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 862
| Not Ranked : 0 score That's awesome. I never even thought of utilizing that big ass empty space over there to relocate the washerfluid tank. Great work.
__________________ 1996 Miata SOLD 2006 Black Cherry Mica MS6 Grand Touring #00584CP-E 3" Straight Pipe Exhaust. CP-E TMIC. StreetUnit TP. Street Unit RMM. HTP 3" TIP. Custom 3.5" MAF SRI. PTP HPFP Internals. Cobb AP. RichTuned. Denso ITV22. Forge V1 BPV. Blox Shift Knob. VEI Boost Gauge. 18x8.75 +33 XXR 530. Nitto Motivo 225/40/18. Megan Racing Springs. SOLD: 2009 Mazda 6i GT. 6-Speed MT. [SIGPIC][/SIGPIC] ![]() |
| The Following User Says Thank You to 6Y MAZDA For This Useful Post: | Doucems6 (04-22-2013) |
Are the bracket mounting points preexisting or did you make the holes there, just to verify what I see! | |
Cut those two run enough wire so they will reach the new location. Be sure to double check they are the right ones before cut. Splice the wires solder and shink wrap them. All the fluid lines will work, just follow them under the winshield and reroute them. Its not as complex as it may seem. Baseline is your just relocating. You need shink wrap, wire 4 . Pos and ground for each sensor. Length may vary. And 2 x 1/4 flat bar to fab you new brackets!
| The Following 2 Users Say Thank You to Doucems6 For This Useful Post: | mczimer (04-25-2013), TiGraySpeed6 (04-25-2013) |
| Not Ranked : 0 score Sweet, thank you. Got all my parts yesterday, so the weekend shall be fun! |
| The Following 2 Users Say Thank You to mczimer For This Useful Post: | Doucems6 (04-25-2013), TiGraySpeed6 (04-25-2013) |
(Thread Starter) | Not Ranked : 0 score Awesome be sure to post some pics when its all complete! I'll be on the look out to see how it went!
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/stage-1-bnr-s3-full-support-142930/ | ||||
| Oh_yea : DIY FMIC for $220 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Refback | 06-20-2013 12:44 PM | |
| Oh_yea : DIY FMIC for $220 - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Refback | 05-13-2013 06:50 PM | |
| Oh_yea : DIY FMIC for $220 - Page 4 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Refback | 05-13-2013 06:48 PM | |
| Oh_yea : DIY FMIC for $232 - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | Post #12 | Pingback | 04-22-2013 05:06 PM | |
| Stage 2... Not hitting full boost | 2010Speed3 | 2010 MS3 - Troubleshoot/Diagnostics | 27 | 06-14-2018 07:47 PM |
| What do I need for full stage 2? | 2012Mazdaspeed3 | 2010 MS3 - Big Turbo Builds | 11 | 03-15-2012 04:23 AM |
| Volvo buys full-page ads to pledge support for distracted driving legislation | Haltech | Automotive News | 0 | 09-30-2009 04:30 PM |
